PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Just a ?
  2. Robi Visit to Chicago
  3. Castrol SRF
  4. need help please
  5. ksport or flex
  6. agency power 27mm rear sway or 25mm?
  7. quick question about offsets...
  8. 255/40/17s clear Ohlins?
  9. (2) Volk 19x8 inch 2 piece GTV wheel centers
  10. New brake pads....
  11. Need Help Replacing Rotors
  12. Put shims in backwards/rear brakes
  13. Cross drilled Brembo rotors
  14. driverside rear hub assembly w/wheebearing
  15. FOR SALE OEM Bilstein,and Springs EVO9 MR.
  16. helix vs. tein flex
  17. Independant height and preload adjustments
  18. Plz help me out......
  19. possible obscure tire size?
  20. Lower Spring?
  21. Problem with brake. need help!!
  22. Feedback on these wheels
  23. Best handling spring for a MR
  24. 05 mr wheel color?
  25. winter
  26. LOOKING FOR BLITZ Z1.18x9.FOR EVO9.
  27. Daily Driving with Hoosiers?
  28. nt03 fitment
  29. Offsets for volk Gt-u
  30. Swapping springs for winter
  31. I want a little stiffer..
  32. Swift Rear Stabilizer Bar, Actual Experience
  33. 17x9 (275s) to 18x9.5 (285s)
  34. EVO IX BBS Wheels & Advan Tires
  35. Car is higher on right side with coilovers
  36. New Product!!! Whiteline Roll Center Adjusting Kit!
  37. Rays Manufacturing Process
  38. Ingalls camber bolt kits?
  39. Which Evo wheels do you like better 8 or 9?
  40. Lugnut/Rota Wheel question.
  41. MR Wheel Torque Specs ...
  42. Maxxis MA-Z1 Victra???????
  43. Do these adjustments on my camber plates look right? You be the judge.
  44. Tire Question
  45. JIC Coilovers
  46. questions brakes
  47. Pick me a swaybar!
  48. Will these wheels clear brembos
  49. *Pic Request* Post pics of Evo's with WORK CR Kai Wheels
  50. Rear Top-Mounts: Which place spherical bearing the highest?
  51. tein s-techs on a 9 mr?
  52. stupid Q on tire PSI - should refil when cold right?
  53. Installed RaveSpeed Springs - 2" Front, 1" Rear
  54. Cusco camber plates torque specs and alignment question
  55. Ohlins DFV
  56. RBF600 good for street?
  57. MR spring related!
  58. New brakes Dicks need to resurface first before installation?
  59. Can anyone get Bee*R wheels for me?
  60. ao46 or ao46d can i run both
  61. 18x9.5 Enkei Rpf1 Fitment
  62. For those w/ black racing pro n1
  63. Bent rims
  64. Wheel Weights
  65. What are you all paying to have your winters mounted?
  66. can anyone answer my Q?
  67. Wheel Offset Comparison tool
  68. stock ao46d or azenis rt615
  69. Cusco Zero 2r's
  70. What are good all-season tires for the buck?
  71. Where to find the best price for Tanabe GF210 Springs?
  72. Has anyone used PBR BF-600 Brake Fluid?
  73. Rear Sway bar added = rear end super squirrelly on ice
  74. I need tire help
  75. hotchkis sway bar broke
  76. wat kind of springs and struts are good for the evo 8??
  77. BBS RX233DSK Fitment? (searched)
  78. Works or Buschur upgraded rear sway bar
  79. opinions on nex coilovers??
  80. Stanz...
  81. Spring install question... do i need a special tool?
  82. BC coilovers?
  83. Swift springs question
  84. Mercury silver wheels on GG. Ya or Na
  85. Brake Light Under Braking ???
  86. SSR Comp-H in 17x8.5 - why won't these fit?
  87. SSR Comp-H in 17x8.5 - why won't these fit?
  88. CE28 17x8 33offset?
  89. Need Falken Alzenis RT-615 :( (Just One)
  90. little advice for tire choice with driving style
  91. Rear Sway bar install....ramps or remove wheels?
  92. what kind of wheels?
  93. BBS RE deep offset fitment
  94. Gold Calipers
  95. Help! for Ohlins FLAG-L
  96. Any Interchangeable Wheels?
  97. help i need tires 245/45/17 or 255/40
  98. Need some help on wheels....
  99. i know im a little ahead of myself.
  100. A046s wearing improperly... Help!
  101. HELP!!! Tein S tech install
  102. Snow Tire Fitment
  103. Wheels wanted
  104. got new tires, but...
  105. someone please tell me a place to get my car alighned.
  106. 10 piston big brake kit
  107. Tires, ACD, Track Days and Autocross
  108. caliper rebuild
  109. MR Swift Springs Pics????
  110. Where to buy Rota Slipstreams?
  111. Lug key removal-Be carefull! Help!!!
  112. Wedsport SA-70's on my 05 EB EVO
  113. best tire and size?
  114. Rota Tarmac 3 pic request
  115. **Tire Size Question (225/45/17)**
  116. rear lower control arm bushings
  117. autox rubber
  118. powder coating the BREMBO
  119. Which Coilovers?
  120. what rear sway bars do you guys like?
  121. WHICH ONES GN+ Silver OR FN1Orc"s Bronz
  122. New Rubber
  123. Can't decide on which tires for winter
  124. Popping nosie/ New rims and tires
  125. Wheel's size
  126. Volk Te37
  127. Brake help - Noise after rotor/pad/SS line install
  128. Help... need winter tires just for 1 week - what to do?
  129. Boiling fluid no more! UPDATE.
  130. Which wear out first, front tires or rear tires?
  131. SSR Type C RS wheels for Evo?
  132. My Rear Right Tire Blew...
  133. 2006 MR, what is the color of your struts?
  134. GTR Face VS +31mm offset
  135. Help picking wheels size for DD
  136. Hotchkis Install today. Wish me luck
  137. running wider tires and increased suspension wear
  138. 1st Yr Anniv. MakeOver, WW Evo IX
  139. Stock VIII RS wheels on IX MR
  140. Brakes shimmy...........intermittently?
  141. HAWK Perf Ceramic user input wanted
  142. Ohlins 2 adj coilovers, anyone using them? feedback?
  143. Why it so cheap? Buddy Club Race Spec
  144. Help: Brake Bleeding Gone Terribly Wrong!
  145. Help: Brake Bleeding Gone Terribly Wrong!
  146. Help Needed With Wheel Project!!
  147. Brake problem...
  148. Coilover recommendations would be appreciated!
  149. 255/40/17 on 17by 8 +25 and rubbing..please help
  150. Tuning your brakes for track use
  151. 255 wide All season/snow tires??
  152. Anyone offer Staged Suspension Upgrades
  153. Pic Request
  154. best coilover sys, for 1000
  155. I am shopping tires !!! Need advice !
  156. how bad would it be to remove my rear sway bar?
  157. Brake Pads and Tires....
  158. Where to go for a good price...
  159. help on offset?
  160. Good 2 piece rotors
  161. Subaru Rim Fitment
  162. New OZ wheels coming out. *teaser pics*
  163. brakes squealing
  164. An Update on Tire Pressure Monitoring Systems and Aftermarket Wheels
  165. off set question
  166. Offset Help
  167. HELP!!! Car lower by an inch on one side!
  168. 18x9 +22 advans
  169. DS2500 installed ... now have a clicking sound..
  170. Bridgestone LM-25 vs. RE960AS
  171. MR Suspension Is "Soft?"
  172. Mcgard Spline Drive lugs w/ Work Emotion XD9s
  173. What JDM wheels should I get?
  174. tire wear and tear/tire life?
  175. pics of the wheels that fit a skyline but would look great on an evo
  176. grinding noise going over bumps
  177. STOPTECH rotors, POWER SLOT rotors or RACING BRAKE rotors
  178. STOPTECH rotors, POWER SLOT rotors or RACING BRAKE rotors
  179. Suspension sag?
  180. 18" Work Emotion Cr Kai fitment
  181. 18x9.5 Volk CE-28n +15 offset... Will it fit?
  182. Rota P45Rs...
  183. GarageHRS/Ohlins vs. Muellerized Jics
  184. Stock tires for sale in PA
  185. Can this be done with new rotors
  186. stance coilovers
  187. snow tire for rally?
  188. Do I have extended studs?
  189. Strange problem with Brake pedal after DS2500, SS lines, and Motul.
  190. springs and 255/40 tires
  191. aftermarket wheels with stock height?
  192. Black with a polished lip
  193. metric to standard conversion
  194. Least Road Noise Tire
  195. Left front shock getting louder
  196. why is everyone selling their tein springs?
  197. want to borrow one OEM front & rear MR spring
  198. looking for the OHLINS DFV suspension
  199. lower suspension brace(s) pics???
  200. Barum Bravuris
  201. Rear shock absorber leaking. Clunking sound
  202. will these fit for evo 8
  203. Wheel Alignment
  204. Time for new tires for the IX
  205. Open End Stock Style Lug Nuts?
  206. Some questions about EVO VIII
  207. Megan Racing coilover rattle
  208. Tire ratings
  209. Nexen Tires
  210. SSR TYPE CRS & SSR MS1's :D
  211. CCW's on my Wicked White Evolution
  212. SE BBS wheels and tires.....how much???
  213. ARP Wheel Studs (Vendors: Read!)
  214. Clear wheels....???
  215. Who has best deal on Tanabe Sustec Pro 7 w/TEAS ??
  216. Improving 1/4 times with tires?
  217. Moton Club Sport vs. Tein Super Racing
  218. 40 offset ok?
  219. Can I do this?
  220. Official Colored Rims picture thread!
  221. Do OEM center caps fit RPF1's?
  222. Which springs and camber settings?
  223. What wheels shall I by to my slivergrey Evo 6 TME?
  224. anyone sporting RPF1's in sbc on apexsilver
  225. Advan RG 2 17x9.5 Fit???
  226. Feedback from Axxis pad users...
  227. Racing Brake Wheel Studs
  228. Quick eustion
  229. BC Racing coilover
  230. Rota D2 Wheels
  231. HELP with my brake pads!
  232. Anybody make a Caliper relocating kit for 14" rotors?
  233. Bone stock MR brake noise
  234. 17x9 +35 255/40 - need fenders rolled?
  235. Has anyone had experience with.....
  236. Brake problems??!!! Need suggestions.
  237. 18x7.5 rims -Tires and Spacers Questions
  238. Yokohama A038R - New Tire?
  239. Alignment shops say they cant move rear toe on my car
  240. Were can i buy Ralliart wheels
  241. advan rs q?
  242. Help diagnosing coilover noise
  243. Beatrush Front tower strut bar
  244. weird vibrations
  245. What would it take to fit these wheels on an Evo?
  246. Anybody have experience with KW Variant 3???
  247. BC Racing install and review: New Br model
  248. Stock Wheels and Blizzaks...
  249. 18x9.5 (+38) 275/35/18's allowable clearance?
  250. Wheels were recently damaged from tire machine
