PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. HKS Hipermax 2 HELP!!!
  2. Tein S. Tech Springs good or bad?
  3. Enkei RPF1 Wheel 17x7.0 +48 fit with 10mm spacers?
  4. 4" wheel studs
  5. Cusco trunk bar
  6. Help hit curb at 10-15mph
  7. Fitment on Tenzo's
  8. powder coating brembos need some help!
  9. Looking for Rota P1's on Evo?
  10. Bedding-in new pads old rotors
  11. Fitment: 18x9.5 +38 in the rear? Stock shocks
  12. megan coilovers
  13. Car not leveled
  14. Where to buy parts for spherical ball joints?
  15. clunking noise after lowering spring install
  16. Noisey breaks please help!!
  17. Sway Bars Tech Q's
  18. evo 8 (gsr) springs with stock shocks..?
  19. stock height alignment
  20. Tire Pressure ??
  21. Can you lower bilsteins
  22. Drag DR-31, MB Wheels Gear: How much do they weight?
  23. Are these the right brake pads?
  24. Wheels question
  25. 18x9.5 +12 te37 question
  26. Where can I get This
  27. SmikeEvo's New Tires - Muhahaha
  28. 18'' rims, what tires size
  29. Going from Volk's to Stock to Rota's
  30. Front anti-sway bar bushings - tough install?
  31. Which all season tires these days?
  32. For those with front end "clunking"
  33. Front Strut
  34. Need Help/Expertise Diagnosing a Problem
  35. 17x9.5 Volk CE28 +28 offset
  36. What suspension bushings to replace?
  37. Front end links
  38. Help with Brembo powder coating...????
  39. fitment 18x9 +30 et
  40. Alignment needed?
  41. Help will this fit with the brembos
  42. new brakepads and rotors after 27000 miles
  43. Broken stock wheels
  44. 5mm spacers, stock studs
  45. Tire Rack
  46. Which Brake Pads Some Questions!?
  47. Question about spacers and camber
  48. What suspension component is this?
  49. Rubbing is frustrating
  50. hotchkis springs install...
  51. Brake pad question!!!
  52. Help on install for cusco e-con dampining controller
  53. What Happened? One Side 1/2" lower than the other.
  54. painting wheels
  55. Need alignment?
  56. wheel size???????
  57. 93 Evo 1 Coilovers
  58. Easy general evo7/8/9 brake question
  59. Anyone runs 17x9 +22 enkei rpf1?
  60. Suspension advice.
  61. Skunk2 Coilovers?
  62. nt555r 245-45-17 weight?
  63. Question for Suspension Guru
  64. Enkei RPF1 Question.
  65. Hawk Track Brake Pads
  66. Suspension question..
  67. WW IX with X rims
  68. Torn between 3 sets of wheels for my Rally Red! Please help me guys!
  69. Need advice on repaired wheels (pics included)
  70. Lowering springs in front, stock springs in the back?
  71. Installed Springs/Struts, Creaking Noise From the Front??
  72. Help with wheel spacer!
  73. Nitto NT05
  74. Bad brakes, ABS, or pads not bedded in correctly?
  75. can someone tell me what they think?
  76. Which Brakelines should I Go With
  77. Gruppe-S SS Brake Lines
  78. MR Bilsteins/Swift Spec-R: Most aggressive 18" wheel width and offset?
  79. Energy Master Bushing Kit
  80. nto3+m 18x9.5 +27=what fender mods???
  81. What wheels for my car?
  82. Rear Coilovers Need rebuilding
  83. Faded paint / clear coat calipers
  84. Tires...255 vs 275!
  85. Trouble Removing Bolt on Rear Shocks?
  86. 255/40/17 S.Drive on IX BBS
  87. Broke a wheel stud
  88. tireeasy.com ?!
  89. Does anyone have pics of rolled fenders?
  90. tire recommendation
  91. Will these rotors last?
  92. Front camber adjusment
  93. Spacer Needed?
  94. Bilstein HD same as Bilsteins from an MR?
  95. Would damaged tie-rods cause 'loose' or numb steering?
  96. Swift Spec-R springs
  97. Brembo 6 piston caliper piston size?
  98. Anyone have Hotchkis springs installed?
  99. Aftermarket Lugs for stock wheels
  100. Found a source for HD Bilsteins
  101. Works brake pads
  102. How do I make 265's fit?
  103. driver side thump vibrations
  104. 18x9.5 +22 - Widest tire?
  105. help what wheels are these:)
  106. Evo 8 wheel paint? touchup paint
  107. Tire thread Transfer case failure..?
  108. 1996 Evo 4 CN-9a Rotors+pads ??
  109. Ever Seen Uneven Rotor Wear like this?
  110. help pulling the tierod
  111. whys my evo drive like $h!t in the snow/wet?
  112. Fitment Question
  113. Stupid noob question, but...
  114. Help with caster/alignment
  115. Worst grinding sound evAR!
  116. Tire review S-Drive and Proxes T1R
  117. Bridgestone RE01R tires--SPECIAL BUY My Thread Was Moved
  118. Wider track or wider tires ?
  119. Painting Brembo's?
  120. Tire Question
  121. Tanabe GF 210 ride height
  122. Squeaky "Girodisc Magic" brake pads
  123. MAX Rim size ??
  124. Spring Install help, this okay?
  125. uneven tire wear
  126. How do you check for good coilover?
  127. Nitto NT05 sizes for the Mistubishi EVO now released [see sizes]
  128. best springs to get?
  129. KW V3 HELP! how to fix this?
  130. Wheel Manufacturer Qualifications
  131. Bad road force on tires?? Need some input
  132. Just ordered my new brake setup!
  133. Replacement brake pads...
  134. Car starts shaking around 40 mph?!?!
  135. Upgrading rotors from Ebc to racing brake slotted? A
  136. rt-615 camber question
  137. 255 on stock 06MR BBS, fender rolling?
  138. Sway Bar Advice
  139. coilover and spring questions
  140. custom wheel spacers
  141. best hillclimb tyres
  142. SWIFT lowered 8, wheel fitment help for a newb
  143. Knocking Noise when turning
  144. E Brake adjustment
  145. KW V3 help!!
  146. Hawk vs Mu
  147. Suspension popping - fixed - not what you would think
  148. Best racing tire
  149. Are your tires safe?
  150. Klunking sound
  151. Stock Evolution Suspension Weights
  152. Evo 8/9 rear trailing arm ball joints
  153. if the rims are 18x9.5 +22 can i run a 245 with stock suspension on a IX
  154. Megan Racing Toe Control Arms?
  155. Snow packing in rims bad for rotors etc?
  156. On tein s-tech what size tire and rim to run???
  157. Brembo bleeding problem
  158. Does anyone here use Swift springs on the stock KYB (GSR) struts?
  159. E-Brake Light Stays On Sometimes?
  160. Where to get Works Center Caps
  161. Stock parts for Bilstein HD's (Tophats, Camber Plates, ...)
  162. all season tires?
  163. Anyone know what rims these are?
  164. ----!!!----What is the best setup for NO RUBBING???----!!!----
  165. Choosing coilover spring rates for your EVO
  166. Popping from front left corner
  167. Coilover Opinion
  168. Recommendation for Stock Strut Replacement
  169. Tire Help??
  170. Ksport and Megan question
  171. NTo3+m 18x9.5 fittment
  172. Some Questions Before Powder Coating Brembos
  173. Shaving tires
  174. Help Identifying springs
  175. front brake kit and wheel fitment question
  176. anyone running tein springs
  177. help! rear break seal
  178. Cheapest place to buy rear magic brake pads?
  179. Ride Height Measurements for GTWORX Springs and Swifts?
  180. New tires come spring time
  181. Camber plates and ride height???
  182. Will 18x9.5+15 with 265/35/18 clear the stock strut?
  183. trouble installing dc sport front strut bar
  184. Legitimate and Serious Wheel Questions. Help me out.
  185. Would it be ok to wear 18 by 9.5 rims for drag racing?
  186. I give up
  187. Reasonable for new Axxis pads to squeal like a stuck pig?
  188. Replacing/Fixing my suspension
  189. Need a photoshop done
  190. Z1 star specs.
  191. Will these wheels fit?
  192. Any body using 25mm spacer with stock wheels?
  193. XXR 502 Wheels Help Pls
  194. WEDS SA-90 17 fitment?
  195. camber question for swift sport springs
  196. SSR Type C RS - Fitment/Pic-request
  197. kosei;s? anyone running them
  198. anyone with JIC JFORCE07 wheels
  199. New rotors+pads == bad vibration?
  200. Whiteline products !!
  201. JIC FLT TAR Coilovers
  202. would you drive on these tires?
  203. knocking noise!! help please
  204. Hotchkis Adjustable Sway Bar... Bracket broke
  205. Looking for lowering spring suggestions
  206. How many have had premature bearing problems
  207. Kyowa KR 628 rims ???
  208. ABS sensor
  209. 18X9.5+15 on a Evo 8
  210. Yokohama S. Drive....help?? RT-615s
  211. Megan Street Coilovers making Noise
  212. E-break light
  213. Handling Advice for Autocrossing
  214. Swift Mach vs Spec-R with stock shocks?
  215. OMG coilovers...what ones? sooo many
  216. Anyone know of a good place to purchase BFG KDW 2's?
  217. 8.5" wheel, +35 offset, 20mm adapter
  218. 35 Offset 8.5" wheel with 20mm Adapter
  219. Whiteline W0588... where does this go?
  220. Wheel fitment
  221. Quick Question on Tires...got a problem
  222. Big Brake Kits!
  223. Buying New Tires Gone Horribly Wrong
  224. Picture Request
  225. Upper hat on suspension bad... what can I do?
  226. Evo 9 SE vs Evo 10 wheels
  227. Hawk Brakes
  228. Tire question
  229. Camber/Caster Plate for stock struts
  230. Seibon TE37 paint Code
  231. Tire Size question
  232. Would you guys run these rotors on your car??
  233. lugs for rota p45
  234. Work VS-XX fitment EVO IX - HELP!
  235. May I introduce the new OZ Alleggerita HLT
  236. What are those Wheels?
  237. Pic Request: Enkei RP03 17x9.5 +38mm
  238. Advan RG2 in anthracite silver???
  239. KYB Rear Struts - Disassembly?
  240. Yokohama Advan RG2 Color Code?
  241. Can someone show me where I can get the OEM brembo rebuilt kits for cheap?
  242. OEM wheel bearing replacement
  243. Is HKS full suspension worth buying?
  244. alignment before or after new wheels?
  245. Agency Power StrideSeven Wheels 18x8.5 29mm
  246. Evo8 shocks vs MR and ride quality?
  247. What do u guys think of these tires at this price?
  248. 4-way suspension
  249. drag racing suspension
  250. !!! What are the widest 18" tires that fits stock EVO VIII??? !!!
