PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Hankook RS4 on the street?
  2. Random pulling side to side.
  3. 18x8.5 +35
  4. Constant soft pedal/ brake vibration issues
  5. Help: wheel bearing stuck to hub
  6. Controversial Suspension Option
  7. A Question About Sway Bars
  8. Please help me identify these wheels!
  9. Intermittent steering wheel angle
  10. Difference between 8MR and 9GT suspension
  11. Need Brake Hose
  12. Spring Rates and RSB
  13. Front fender clearance.
  14. "confidence inspiring" handling, from factory to today
  15. steering wheel
  16. ABS Delete evo 8
  17. Bilstein B6 HD - Available from Ross Sport UK
  18. Brake Caliper Leaking in Back
  19. Ohlins CZ4A on CT9A
  20. Please help with tire size
  21. Lower rear control arm and ball joint?
  22. Wheel Questions
  23. Bbs lm f1 gold
  24. Rpf1 Enkei 16x8 5x114.3 offset 38mm 73mm Bore
  25. **PLEASE HELP** lost unique lug key for bolt on wheel spacers
  26. Wrong bolts?
  27. Where to mount rear shock reservoirs?
  28. ABS Codes *Help*
  29. Fully restored 5zigen FN01R-C
  30. Evo 9 Steering Sensor Issue / Help Requested
  31. Brakes, Rotors, Lines, etc @ Boostin Performance
  32. Will I need to roll the front fenders?
  33. Shredding tires
  34. Everything to know about evo 8/9/10 OEM wheels
  35. Help trying to install MN580057 Bushings
  36. SuperPro Front Lower Ball Joint Kit (TRC0001)
  37. Febest or Hardrace ball joints (rear)
  38. Which way to turn tie rod for toe adjustment
  39. Wheels looks weird
  40. Do I have a body kit?
  41. Silvers NeoMax R coilovers
  42. Evo 8&9 Wheel set up that DONT need spacers or roll fenders
  43. Extended studs
  44. Suspension Refresh, question though..
  45. Best way top clean Evo BBS wheels?
  46. Rolling fenders
  47. Wheel Tek lug key
  48. Custom Coilover Camber Plate Options?
  49. Evo 4 stock stock brakes part # for stock Canadian equivalent
  50. to fit....18x10.5 +38 PF01 on a ct9a
  51. Volk CE28 Club Racer II
  52. Brakes no respond after hard braking
  53. Tein Flex Z vs D2
  54. Car lurches left/right over bumps, coilover rebuild?
  55. End Links to Stop Clunking
  56. LCA? Bearing? Clunking..
  57. Hmmmm, I think I’m going to run these.
  58. ES front control arm
  59. 2019 Tire Thread
  60. Stock ride height
  61. Wheel Dimension and Fitment Question!
  62. Which Vendor to Buy Ohlins From? And Lugnut Question
  63. Brembo GT-R BBK?
  64. Brake bleeding problem
  65. Lower control arm bolt wont thread
  66. How much better are quality coilovers for ride comfort really?
  67. Ohlins R&T Old or New Variant??
  68. Racing brake rebuild, Hi temp boots?
  69. Ohlins springs
  70. Quick question about rear camber arms
  71. SS brake lines install and removal of calipers questions
  72. Help Identify Lug Nuts
  73. Front Ball Joint Grease
  74. Evo 8 suspension alternative
  75. Got my Whiteline rear swaybar - need endlinks
  76. Evo 8 Ball Joint/Camber Issue
  77. Tein Flex Z "B" Measurement Setting Value
  78. member who powdercoats & rebuilds Brembos?
  79. Front & Rear Swaybars
  80. Tubular Frame Evo?
  81. Best Hydraulic E brake for ct9a?
  82. 18x10+39 RE30 on a IX with X calipers?
  83. Brake pads that bite better than stock when cold Evo 2?
  84. Heresy?? Subaru parts!
  85. Will 265/35/18 on 18x9.5+15 Enkei RPF1s fit Evo 8/9?
  86. What rotors to buy
  87. Coilovers: Front Higher Or Rear Higher?
  88. EBC Pad users - Advise needed
  89. Bilstein (Yellow) 4060A290 / Eibach (red) 4040a\A113
  90. Please help identify this brake kit
  91. Replacing worn bushings OEM, hard rubber, poly?!?!
  92. Best wheel width for 265/35R18?
  93. brake line banjo bolts and washers
  94. Lowest ride height
  95. Fabricating chassis braces
  96. Steering pulls to the left - Found and FIXED!
  97. What wheels are these? Enkei
  98. Best Wheel for Rally
  99. Does ABS System communicate with ECU
  100. Questions for everyone running 18x9.5 +35 with wide tires
  101. Robispec KW V3 oil leak
  102. Evo IX rear caliper brake pad retainer pins
  103. Sway Bar Lateral Locks
  104. Loud Bang from Front Suspension on Highway Bumps
  105. Spring rate with 16mm rear bar
  106. 2003 Evo VIII rear end floats
  107. Anyone running Bridgestone S007A tires?
  108. Evo 8 Crush Washer Size for Brakes
  109. Rear trailing arm ball joint
  110. Evo 4 Brake Master
  111. Coilover fluid leak
  112. Best brake pads for the street
  113. StopTech Brakes Review
  114. Strong aftermarket rims ?
  115. cant decide what tire to buy :/
  116. MAPerformance Rotors or DBA 4000?
  117. What do I need to make rpf 1 18 x 10.5 +15 work?
  118. Caliper rub on rotors..
  119. 18x10 or 18x10.5??
  120. what should I pick for coil overs?
  121. Coil overs
  122. Evo V pulls to the left
  123. looking to buy a tool for bleeding brakes & flushing brake fluid (not just for evos)
  124. anyone try the STM brake air guide kit?
  125. Evo 7-9 front knuckles on evo 5
  126. New Fortune Auto Coilovers wrong spring rate
  127. Lug nuts question
  128. RC-T4 enkei 17x7.5 +45 on evo4 Brembo brake evo5 fit?
  129. Really BAD braking evo VIII
  130. SSR GTX01 18x9.5 +22 Dark Silver Type C
  131. Using 20mm x 1.5 lug nuts on stock evo 9 BBS wheels
  132. LCA swap out?
  133. Mca purple in Evo 8
  134. Bilstein B6 availablity
  135. Parking brake cable?
  136. Whiteline Front Endlink Issues
  137. CT9A linear lowering spring
  138. Te37
  139. Cheapest place to buy wheels?
  140. Camber = toe in? Out?
  141. Ohlins and General Coilover problem/questions
  142. Ball joints?????
  143. Holy rusted axle nuts!
  144. FA coilover dampening adjustments
  145. Suspension issue
  146. What are the best ways to make your evo 9 handle amazing
  147. AP Calipers CP5555 a good upgrade over stock?
  148. Rear hub bearing questions
  149. ESR SR07 wheels
  150. Brembo rebuild/repaint service (2018 recommendations)
  151. Whiteline Rear Differential - mount rear bushing
  152. Fitment?: OZ Ultraleggera 18x8 on Evo IX
  153. Anyone recommend cheapish coilovers to get ?
  154. Taking out front lower control arm
  155. Question about replacing damaged new tire; replace all 4 or just the one
  156. Opinions welcomed and WHY you think what you do.
  157. Billet aluminum brake spindles
  158. Wheel offsets and dish size
  159. D2 rally asphalt coilovers.
  160. 18x9.5 +22 SSR GTX01 for evo 8
  161. Girodisc (rear) clearance issue
  162. Enkei T6S calliper clearance
  163. Evo IX RS brakes: Rotors and pads P/N?
  164. Brembo GT BBK: Pads?!?
  165. Spring rates
  166. Whiteline kca400m???
  167. Anyone running these Japspeed rear lower control arms?
  168. Stripped bolt on spacer
  169. Tapping/Clicking near front passenger wheel, HELP!
  170. Wheel spacers
  171. Picked up a set of Ohlins Road and Track for the 8. No click on one dampener knob
  172. Flip OEM Camber Bolt Without Alignment?
  173. Interest Thread For Billet Rear Trailing Arms
  174. Evo IV tie rod ends
  175. Clunk Noise?!? Axle, cv joint, struts, wheel bearing, steering wheel??
  176. Bilstein B6 HD Bump Stop Question
  177. Vibration with braking at high speed track
  178. Front Sway Bar Bushing
  179. Volk RE30 Fitment/Offsets
  180. Rear bushings and Ball joints
  181. In praise of magic pads
  182. Coilovers and Spring Rate
  183. Coil over recomendation wanted for a DD Evo7
  184. EVOX vs EVO 8/9 caliper pics
  185. Rota grid drift ADVICE
  186. Anyone run a unidirecitonal tyre the wrong way?
  187. Anyone use the two string method to adjust their wheel alignment?
  188. Tie Rod Jam Nut Part Number PLEASE!
  189. Backspacing Enkei RPF1 18 X 9.5 vs Stock EVO X and EVO X calipers
  190. AD08R or RS-4?
  191. Rear Adjustable Control Arms
  192. Hks hipermax iv gt coilover
  193. Making the best of the OEM Brembo's for track?
  194. Perrin PSRS
  195. Brakes dont 'bite' as well after new rotors, pads, SS lines, fluids
  196. Suspension Refresh Questions
  197. 18x9.5 +22 Enkei rs05r Fitment
  198. Bilstein b6's or b8's + lowering springs. Which?
  199. Best Vendor To Buy Ohlins?
  200. Looking for rear strut dust boots evo 9
  201. SSB Designs Front Roll Center Correction Knuckles - 1.25 inch option
  202. Brake MC noise while bleeding
  203. Clunking from camber plates; bad bearing or shock assembly error?
  204. Volk Racing ZE40 Diamond Dark Gunmetal Wheel 18x9 5x114.3 +25mm
  205. Rebuilding Brembos and the Front Pistons wont go in
  206. What bushings may have gotten old
  207. Noise coming from brakes and/or suspension...need help!!!
  208. Konig Hypergram Question
  209. Aluminum Brake Pistons
  210. removing air from ABS system,how to?
  211. Enkei TS10 Question
  212. Evo X rear brakes on 8/9
  213. Brembo Seals and Dustboots
  214. TEIN Z Coilovers - Are they any good?
  215. Hyper black rota grid
  216. STM Front Crash Beam - Group Buy
  217. Looking at the Rota Grid
  218. 18x10.5 +20 evolution 8
  219. Replacement ball joints
  220. Coilover under 1k for drag racing
  221. SLVRNBLK's - Project MJ build - Part #4 "Suspension"
  222. High performance Grease for Axles !!!
  223. Sound
  224. Removing lug nuts off ground
  225. Help with Coil overs .
  226. Volk TE37V Offset help
  227. Godspeed free shipping!!
  228. 265 question
  229. Front end bounce.
  230. Aftermarket Coilovers
  231. Lightest 18x9 or 18x9.5 Wheels
  232. Brake pedal mush
  233. Enkei RPF1 Inquiry
  234. OEM lug nut shank diameter?
  235. Fortune Auto Coilovers
  236. Stock ix SE suspension front and rear sway bar choice
  237. 17x9 fitment
  238. Wheel Spacer Question
  239. Evo 8 bushings
  240. 100-ish Treadwear
  241. New tires
  242. Black Friday/Cyber Monday 2017 - Deals Start Now!
  243. tire size fitment question
  244. Do just rear sway bars?
  245. Loud squeal driver's side front when braking at low speed with moderate pressure
  246. Temporarily halting brake fluid
  247. Help with rotor problem?
  248. KICS R40 Lock Key Help
  249. Evo 9 front axle play
  250. rally wheels
