- STI caliper kits
- how many versions of BBS wheels on 8/9's
- could a crappy alignment cause this strange vibration? pics included
- Privat Akzent 18x8.5 +30
- Reversing springs on Tien Flex (front to rear - rear to front)
- Need held from CCW LM20 owners. do they clear front brakes?
- Cusco rear trailing arms with pillow balls
- Enkei RPF1 17x9 +22?
- Neal out till June 18th
- Wheel spacers for Evo8!
- 255/40/17 or 245/45/17 on BBS
- Evo 4 front strut replacement ideas??
- question
- Is RalliSpec a trust worthy vendor?
- Car has gangster lean! help! ideas!?
- Evo IX: Mystery drag when coasting ... brakes or drivetrain?
- Anyone have tips for removing paint from wheels
- Brakes Squeal
- Brakes Are squeeking.. Help Me Understand!
- alignment with lowering springs
- How to adjust HKS Hipermax RS Coilovers
- Grinding sound will driving and turning
- In need of some new suspension (shocks)
- Anyone know if ABS sensor are side specific
- how do you set up your coilover?
- brake master cylinder size?
- Good size for Rota P45R
- anyone w enkei rpf1 17x7.5???
- KW rear spring size
- Wheel studs besides ARP? 55-60mm Length
- Deal of the year?
- Wheel Tire Photo Request
- RS*R Sports Intelligence Coilovers
- Tein vs. Cusco Pillow ball front strut mount. Which one for this car?
- Closeout on Griots Total Wheel and Tire Care Kit $30!!
- Too much camber?
- Exclusive Tire Offer from Tread Depot for Forum Members!!
- wheel fitment questions please help
- Drag DR-31's
- Ferodo DS 2500 Vs. DS 3000 Vs. DS 1.11
- Brembo Slotted and EBC Reds Shaking
- Wheel offset?
- Are these Team Dynamics Pro Race 1.2 wheels
- Ohlins front lower bearing dimension
- fortune auto 500 series coilover adjustment knob - no longer clicking?
- Evo X wheels on Evo 9 - can I use stock Evo 9 lugs?
- Light weight wheel
- Mirage to Evo Brembo's question
- Tire Help
- Adjusting height Function Xs
- Pedal box for evo 8
- New pads and rotors, also caliper question
- Tire Noob (2). Help
- help tire noob here someone help
- Suspension Specalists in North Jersey
- DWs - how quiet?
- Need advise from people who know what their talking about..
- Size of threads on In/Return of Power Steering Rack
- 15mm Spacer, Stock Lug Nuts, Extended Wheel Studs
- brake pads recommandation for stock brembo?
- Hex nut missing from rotor. Should i be concerned?? PICTURE INCLUDED
- Spring Refinishing - Coilovers w/Rusty Springs
- Any aftermarket springs that will not "hurt" cornering with stock struts?
- Clunking sound when turning wheel
- dunlop z1 star spec or HRTZ III?
- Evolution 4 front struts
- picked up tsw nurburgring + nitto 555!
- What tires would you get?
- cracks/cuts in tire? safe or not? (pics)
- One DWS Flat
- Problems getting a New Whiteline Ball Joint spindle back in to steering knuckle.
- Best Handling for evo 9
- Lug nuts
- Looking into coilovers. Suggestions?
- what tire on 17x9+38 desmond regamasters
- Running different tire sizes
- Bilstein HD's
- Removing light scratches from TE37SL
- Creaking from Driver's Front when Turning
- I need dust boots
- What offset will suit my evo4
- Evo 8/9 Front Sway Bar Stiffness % Over Stock
- Steering wheel minor lateral movement
- Ralliart Group N Strut Tops
- wheel spacers
- Metallic click when turning sharply or......
- Alcon brake pades?? ur help
- Enkei OEM 18" rims from a 2009 Mitsubishi Lancer Evolution X
- PSRS on the street?
- Question about wheel fitment
- Ohlin PCV
- Lateral G Test
- Brake cap question
- The Right Wheels for 285/35/18 RS3's?
- Help Me Diagnose My Body Roll
- RotorPros vs Girodisc "Bailout" Rotors
- Rear lower control arms
- Auto X Tire input
- Brakes General question
- Tein Super Street Coilovers
- who knows how to read shock dynos?
- Quick spring install question
- Stop Tech BBK
- Anyone ever seen this kind of markings on a sidewall (RS-3)
- Coilovers Setup
- Brake Pads....Akebono ceramics?
- Evo 9 GSR Stock Bilstein vs Tein Monoflex
- wheel offset
- Coilovers
- gtworx springs and 17x9.5 wheels
- put new wheels on and car pulling hard under accelaration
- my brake squell is driving me insane
- OTS Ohlins R/T DFV valving
- Brake shudder cause from piston seal?
- Stuck on autox tire choice
- will 275 tires on 17x9.5 +38 wheels clear front coilovers
- BBS? or advan
- Measuring car rake
- Wide stance
- IX Brembo Issue
- Hankook Ventus R-S3 here within a week
- F&R big brakes for daily VII
- Goodridge Brake Lines Leaking - Rear Only
- JIC magic coilover
- general alignment question, car pulls
- What size tires should I run on my Advans.
- Anthing good about godspeed coilvers?
- Track/Circuit Wheels for Evo V
- Help with slight noise please.
- ABS light on, air-con off, ACD control off - help!!!
- New brake pad 'problem'
- Make the Evo's rough ride less rough
- Anyone run these godspeed coilvers???
- Rear Fender Liner on 2012's
- RacingBrake Review
- 17x9 +35 Enkei PF01SS Confirmed Fitment
- Tire Pressure Sensors?
- rotas p45
- Rear End link removal?
- brake pad retainer clip where to buy?
- 2004 Evo Front End Clunk!
- Rear Sway Bar Install
- Rota Jmag 17x8.5 +50 Fitment
- Enkei NT03 17x9.5 +38 need spacers?
- DBA series 5000 on backorder, recommended equivalent?
- cut bump stops for tein s tech springs on my MR?
- Best Stock Replacement Tire
- Running two different offsets
- Can't find Bilstein HD's anywhere! Help
- Extreme performance summer tire help
- ABS sensor connector replacment
- 17" Enkei RPF1 offset needed to clear calipers
- Replacing brake pads--rotors too?
- Can anyone identify these wheels?
- anyone used these coilovers
- Suspension downgrade! Ohlin Flags to MR Bilsteins/springs
- Stock lugs
- Knocking coming from front driver side wheel.
- Brake pads to wake the dead (EBC red stuff)
- Coilover drop = new alignment?
- Blackworks coilovers?
- Abs is not working properly
- Brembo seal advice?
- So, Got in a wreck last friday.....
- rubbing
- rubbing plz help
- 265/35/18 fit?
- Looking for Roof Rack
- What's the offset for a evo 8? what's best?
- Drivetrain guru's looking for a educated guess
- Anybody know this suspension.
- An effective way to add caster?
- New wheels and tires
- Evo 8/9 shock and strut
- wheels help 17x9 +42mm wont clear brembo
- Swift Spec R springs question
- Just got my FA 500s
- RE760 or S.Drives?
- xxr 527 Fitment Question
- Strange Request - Evo 8/9 owners, what do the backs of your BBS center caps look like
- Good rotors and brake pads?
- 20mm Spacers w/o Studs?
- rotor issue?
- Uneven Tire Wear, Weird
- Coilover height adjustment
- Evo 4 wheel offset
- Inner side of the front rotors worn off pretty badly
- XXR 521 Owners CHIME IN HERE
- Grinding Noise on new pads and rotors ?!?! need input asap
- dropping the car
- Need help big time reg wheel to fit on my 8
- Help with wheel fitment?
- Another brake Thread.
- good deal on kumho ecsta le sports
- 400+ Daily driven brake set up help..
- coilovers
- EnduraTech Coilovers
- just got swift spec r's for my evo 9 mr
- anyone who has the gt spec trunk cage....
- sway bar asap
- 18x9.5 w/ 265/35 tire.
- tanabe 25.4mm fsb owners, any options for beefier swaybar bushings?
- Help - Grinding while braking/ABS issue
- suggestions for track tire size
- trying to pick coilovers
- Aluminum Spare tire options
- RPF1s and GTWorx springs, will it rub
- Swift springs on 18x8.5 X MR Wheels?
- Best tire choice for my Stock Evo 9
- What to do why doing coilover install
- Bilstein Rebuild Question: Do they need broken down?
- Where to Buy Rays TE37 SL ???
- Another poll
- 127,00 miles Need suspension makeover
- Swift+Bilstein HD installed - Now I have a problem
- wheels
- rotorpros or emil performance brakes
- Brembo LCF600 brake fluid review
- Where to buy XXR's????
- Rice or Not?
- WedsSport TC105n 17x9 +35
- ventus v12 or eagle F1??
- Trunk brace comparison
- Work Meister s1 3p
- Bilstein strut rebuild warning!
- reset steering angle sensor?
- Enkei RPF1.. 18x10.5 +15 possible on evo8?
- Custom RCA for Evo3, ball joint taper question inside
- Wheel Bearings???
- Would kill for this bushing.....
- Need suggestion on Brake purchase~ Thanks.
- What would it take to get a comprehensive offset guide for Evos?
- Rs-r coilvers
- urethane suspension bushings
- Work Emotion CR KAI 18x8.5 +32 Spacers
- Tein Pillow Ball with Variant 3?
- Bilstein re valve thread
- Front stabilizer (sway) bar bushings
- evo 8 front wheel lockup and loud click on turns
- MR bilstein bump stops
- My fitment goal and how to get there... Tips?
- Voltex widebody question
- front sway bar
- HELP Noise! AMS Wilwood Brakes
- Is the bump setting on coilovers like a spring rate adder?
- Where do you guys get torque specs info?
- Tire Size Question
- Time for some new tires/brakes.
- ohlins co adjustment knob extender
- Best fitment for 18" wheels
