PDA
View Full Version : 09+ Lancer Ralliart General
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. Tactrix Cable 2.0?
  2. Exhaust Manifold
  3. Lancer X Ralliart need informations for tune BASE MAP
  4. Ecu Flash
  5. D2 Sport Leaking Shocks - Lancer X Ralliart - No Guarantee/Claim
  6. Selling my Ralliart to someone that wants to rebuild it
  7. Questions as a new owner/builder
  8. Bc racing coilovers
  9. Mitsubishi lancer Ralliart I believe. My timing chain is stretched
  10. RA broke down
  11. Start up Squeel
  12. Spare manifold for 2010 mitsubishi railart
  13. 2016 Lancer CVT or high mileage 2015 Ralliart
  14. Rough idling
  15. Lost my OEM boost pill for Ralliart
  16. Vehicle Battery is Dead, Mechanical Key Won't Work. Why?!
  17. Looking for a tune 2006 ralliart
  18. 2008 Lancer tubro need help to disable DTCs
  19. Possible Selling?
  20. Bearing noise from water pump housing
  21. Rear bumper clips broken
  22. ACD pump failure?
  23. Dove sound
  24. ASC Button behavior
  25. Sell, trade, or scrap?
  26. Several Issues with 2009 Modded Ralliart
  27. 11 Ralliart boost issue
  28. SST Issue 2011 ralliart, gear jumping
  29. Super sport
  30. Gearbox Service
  31. LANCER RALLIART SPORTBACK Rear subframe/rear differential bushing
  32. Engine jerking and error P0420 after new ECU
  33. 2014 Ralliart misfire
  34. 2015 mitsubishi ralliart SST problem
  35. In Need of Mechanic in Orange County, CA
  36. Perfromance mods before tune
  37. Swapped evo x differential to Ralliart rear cross
  38. Ultimate racing full exhaust need gone asap
  39. AWC pump DIY repairs prospect
  40. Evoscan not logging data
  41. Best alternative to RRM?
  42. Current Magnaflow Exhaust set up looking to go OEM
  43. Need help please
  44. Looking for a deep but not obnoxious exhaust
  45. Limp mode issues
  46. Weird noses input.
  47. 09 Ralliart Werid pulsating vibration
  48. Please HELP 2011 rallyart won't start after heavy rain
  49. Please HELP 2011 rallyart won't start
  50. RA needs a new bumper after crash
  51. P184b
  52. 2010 Sportsback Ralliart not idling
  53. 2013 ralliart won't start
  54. 09 Ralliart Compound turbo options
  55. ASC/Transmission error after mapping
  56. New exhaust system for a 2011 ralliart sedan
  57. lancer rear bumper on RA
  58. S sport flash.
  59. Sportback with evo fenders.
  60. 2009 Sportback exhaust help!!
  61. Front bumper switch of a 2016/2017 lancer
  62. Downshifting to first gear problem
  63. 2017 Lancer CVT to ralliart transmission swap
  64. looking for 2014 ralliart definitions for ecu flash
  65. Head Lights and Manifold
  66. Hose not connected to BOV
  67. Steering wheel trim paint colour
  68. Strange Clicking noise
  69. P183D code
  70. 2011 Ralliart Tire noise or Wheel bearing?
  71. Speaker wire location help.
  72. How should I begin modding my 2014 RA?
  73. Engine/Transmission Noise Help
  74. Idling Issue
  75. What am I getting into?
  76. Can’t unlock/lock my doors
  77. I can't find the plug for the fog lights
  78. ECU Flash help pls
  79. ACD Pump only clicks - '09 Ralliart
  80. Looking to get a RA in near future for a DD, want to hear from some veterans
  81. Removing Transmission
  82. Mitusbishi Lancer IOD fuse
  83. 05 Lancer Ralliart Cold Air Intake Issues
  84. Ralliart stuck in P.
  85. 2010 Ralliart fuel pump ?
  86. Ralliart Intake Manifold Connections?
  87. Front License Plate
  88. AMS Boost Pill
  89. Are the for sale forums dead?
  90. Ralliart grinding/purring.
  91. 2009 Ralliart FCC ID
  92. Need advice!
  93. Considering Parting Ways...
  94. fitting
  95. Will a Evo X Differential fit a 2014 Ralliart?
  96. Anyone help me. JDM Ralliart xml
  97. Car won’t start checked everything, just bought from dealer
  98. Looking for advice on buying a 2009 Lancer ralliart
  99. Looking to buy a Ralliart... too good to be true?
  100. Chrome grill trim
  101. Looking for an AUS/EDM GST Base map for 2014
  102. HELPPP! ECU Bricked
  103. Can someone help me plz
  104. How many miles is too much
  105. Product Review - WTFAuto
  106. Ecuflash - evo ROM
  107. I have not stopped thinking about upgrading
  108. 2012 Ralliart won’t start but cranks.
  109. Will i need a flash tune??
  110. ralliart to evo x intercooler
  111. After Market Front Bumpers?
  112. Evo X Turbo swap Tuning
  113. HP on the stock turbo?
  114. Counter balance shaft 4g69 engine
  115. Anyone has a factory cat back laying around?
  116. Has anyone put a type R spoiler on?
  117. Need help
  118. What Should i mod first?
  119. Fuel Pump...
  120. Upgrading Fuel injectors
  121. This noob is about to either learn or break a car
  122. 2009 ralliart tensioner replacement
  123. Ralliart meet up
  124. Ralliart trans questions and track use
  125. Brake Service required notification shuts on then off.
  126. Used 2011 Ralliart (34k miles)
  127. 2010-2011 Ralliart no power to ACD system
  128. To tune or not to tune?
  129. Sst fixes
  130. Should I Buy a 2009 Ralliart
  131. Vin number trouble
  132. Intercooler upgrade
  133. New to Lancers! So,many questions
  134. Intake
  135. 2015 Lancer RA, Rubber Cement Smell
  136. 1770A116 and 1770A271. What is different ?
  137. 2010 Lancer Ralliart SST Slipping?
  138. How to clean the throttle body?
  139. 2011 Lancer Ralliart Sportback. In-tank Fuel Filter questions.
  140. Buying a used 2010 Lancer Ralliart
  141. 09 ralliart Cobb, stuck on 30psi stock turbo help
  142. Turboxs Catback install 2013 Ralliart
  143. Buying used Ralliart - Unsure about the TC-SST clutch wear?
  144. Solenoid g 09 ralliart
  145. Ralliart transmission Compatibility
  146. Rear Bumper Cover
  147. New Ralliart Owner
  148. New Guy - Questions Abbound
  149. 2010 RA inside ventilation problem
  150. Talk Me Out of Buying Another Ralliart
  151. 09+ Recaro Seat Lowering options?
  152. Cobb Tuning/ Gas Octane
  153. Potential 2010 Ralliart? Engine code P0017
  154. Any high mileage Ralliarts?
  155. Short burst of vibration while driving. NEED HELP
  156. Alexrallyar need help
  157. FAST Key Issues
  158. How to remove MAF housing from ralliart
  159. SST Wear Normal vs Sport
  160. Ralliart 2013 : which o2 sensor to get if broken?
  161. Potential New Ralliart Owner
  162. How do you get access to rear strut tower to adjust coilover?!
  163. Hi from a new person
  164. Crucial things to look out for
  165. 2009 Mitsubishi Ralliart bad deal?
  166. Sst p1802 code
  167. Sst transmission issues
  168. Potential buyer of a 2011 Ralliart need advice
  169. I purchased a salvaged ralliart need a lot of questions answered!
  170. No Tarmac/gravel/snow indicator when driving. No flashing. It’s just off.
  171. First Lancer Purchase
  172. Which GST mao do I use
  173. Wide body ralliart!
  174. Hello... and a bit of help
  175. UR Hi Flow cat fitment
  176. Charging system service required
  177. Help...
  178. Resetting Keyless Entry
  179. MOD 2018 East Coast
  180. Shopping for a Ralliart
  181. CJ Lancer Ralliart bouncing idle. Check engine light
  182. Brake/ABS/ASC Service Needed Lights
  183. (2018-July) 2011 Lancer Ralliart Acceleration Hesitation Ongoing Diagnosis
  184. Some stock internals - can my engine handle this?
  185. Nav maps update
  186. Automatic Transmission
  187. Selling Veronica and Moving On...
  188. License Plate removal - screws won't turn - snapping back after a quarter turn
  189. Heat Shield Rattle?
  190. Front side marker lights off when in drive?
  191. Tuning Special @ Boostin Performance - 13% OFF All Mitsubishi Tunes in March
  192. Mud flap
  193. Exhaust manifold?
  194. Moving from RSX Type-S to Ralliart
  195. Fair price for my 09' Ralliart Stock
  196. Need Help Please !!-
  197. Dual port BOV and ECU is confused?
  198. ACD Relocation Kit
  199. Buying rims for 2014 Ralliart
  200. Stereo unit pinout?
  201. Tire Pressure
  202. Exhaust manifold problems
  203. AWC/ACD Pump Relocated to Trunk
  204. 2010 Ralliart Sportback/Hatch
  205. Price Is Too Good?
  206. Sportback rear bumper diffuser
  207. Intake question
  208. 2005 Ralliart diffuser?
  209. SST Oil
  210. What to look for when buying a ralliart!
  211. No clue , need help
  212. Radio not responding, but music still playing
  213. Boost leak? cobb stage 3
  214. Difference between Ralliart years?
  215. E-85
  216. 2014 Ralliart Minor Wreck, Fluid Leak Help ID?
  217. Trying to find Headlamp Assembly
  218. Speedometer over reading
  219. Throttle change clunk
  220. Looking to upgrade in the future
  221. Evo x catback on ralliart
  222. H&R spring rates & coilover question
  223. 2012 Lancer Ralliart
  224. Any good shop in Ontario?!
  225. Boost taper
  226. Ralliart Sportback & Evo X backbox query. UK.
  227. e-tune who is the best??
  228. Fuel type
  229. Upgrades
  230. Alternator spins only one way? Partially seized?
  231. Looking to upgrade to a high flow cat.
  232. Having a wierd problem with my 09 ralliart
  233. August 2017 Featured Car of the Month
  234. Was looking at a stereo upgrade, saw this:
  235. Front Tow Hook Question
  236. Random Bolt in Front Bumper
  237. Evo X battery tray in RA?
  238. Crash bar cover
  239. A pillar gauge pod
  240. 2010 Rallirt Low Revv problems
  241. 2010 Ralliart low revv
  242. Lower Chrome Trim?
  243. '10 Lancer Ralliart....busted transmission
  244. Used 2013 ralliart
  245. Right headlight points high, how to adjust?
  246. Saying good bye...
  247. Engine Under-guard/cover
  248. Desperately seeking help ACD pump
  249. Front plastic engine cover needed?
  250. Future Lancer RA owner
