PDA
View Full Version : 09+ Ralliart Engine/Turbo/Drivetrain
Pages : 1 2 3 [4] 5 6 7 8 9
  1. Transmission question
  2. Low end motor knock
  3. Intercooler Kits
  4. BOV Question
  5. Feeler - CBRD Ralliart short runner exhaust manifold - group buy
  6. Issue with my 09 Ralliart
  7. What do you think is a good exhaust?
  8. an issue with my 09 ralliart
  9. Instructions to get S-SPort Mode
  10. twin scroll turbo?
  11. o2 at 62k??!
  12. GSR 5-speed swap question
  13. Upgraded my UICP today.....
  14. What Causes the Clutches to Open?
  15. ICP Help
  16. Sluggish/Shaky Acceleration/Shifting
  17. My 09 Ralliart's sad story
  18. downpipe / cutout
  19. Rad Lite Installed
  20. My UR intercooler install... in progress :)
  21. So I ran 1/3 of a can of Seafoam through my engine and this is what happened
  22. Stock ABS BOV Broken Vac Nipple
  23. Cams
  24. Random AWC service light
  25. Car wouldn't start this morning
  26. Exhaust Leaks
  27. Dreaded P2263?
  28. Car Runs Lean from a Stop
  29. turbo gaskets question
  30. sst transmission question
  31. Engine codes
  32. MUT-III Frequently Asked Questions
  33. Would a can of Seafoam be useful for maintenance?
  34. Goodies Delivered Today
  35. New Air Filter, Less Noise?
  36. How to get S-Sport mode & Launch Control on the Ralliart
  37. turbosmart dual port?
  38. Flutter-like sound...
  39. Ralliart Intake Manifold?
  40. 2010 lancer ralliart downpipes and cats
  41. Throttle Body and Intake cleaning
  42. XML File Needed
  43. Check Engine Light - Timing Chain Stretch?
  44. AMS Boost Pill and ECU reflash
  45. Custom Build with a '11 RA turo setup HELP!!
  46. oil pan gasket leak back side of oil pan.
  47. Test Pipe Compatability
  48. Help with tuning? New Owner.
  49. Need logging and evoscan help!!!!! Please!!!!
  50. anyone with the gst tune and bolt ons running 12s?
  51. tuning suggestions?
  52. Delete
  53. EVO X FMIC with stock RA UICP?
  54. Which Dry Drop-In Filter?
  55. Running lean
  56. Borla installed, KN drop in on the way and I need to do the 30000 mile maintenance!
  57. clacking sound when engine breaking
  58. Rear Differential search please
  59. SST shifts?
  60. stock map with pill
  61. Dealer says Exhaust Manifold is cracked....
  62. Turboback Install
  63. Smokey RA
  64. evo ix bpv question....
  65. Short Battery?
  66. Location of ACD hydraulic pump?
  67. Updated AWC software mapping...
  68. 4th gear like hitting wake up strips
  69. P0007
  70. considering 12' ralliart
  71. GFB Respons bov Installed in 2012 Ralliart
  72. WANTED: Reputable tuner in NorCal/Bay Area
  73. AEM Intake Actual Gains?
  74. Question about exhaust
  75. Mishimoto FMIC
  76. RA turbo Life/required service
  77. Cold start problem with Walbro400 & FIC1100
  78. RA´s S-sport and launch. DONE
  79. Questions about SST Problems? Tech/Experienced Answer Here Please!!
  80. Hiclone?
  81. Advice On Future Mods (Mostly FMIC Advice)
  82. Clicking exhaust
  83. Keep HFC or go with muffled test pipe
  84. Size of RA Brake Master Cylinder
  85. Clutch change?
  86. GST no longer tuning RAs?
  87. 2011 ralliart sst definition file?
  88. SST issue
  89. high knocksum on low load/rpm - 09 stock tune
  90. Gas switch?
  91. Blue smoke when gettin on the gas
  92. Should I sell or build my old block?
  93. Mivec Tuning
  94. New Cobb Maps
  95. Blow Off Valve Suggestions?
  96. Recirc. BOV
  97. Suggestions
  98. Soon To Be
  99. Ticking... Normal or Problem
  100. Which High Flow Cat?
  101. What to expect?
  102. turbo upgrad ?'s
  103. Custom downpipe
  104. Decent power with full stock exhast
  105. New Works Catback
  106. Finally I'm ready to get my turbo upgraded
  107. 2-step?
  108. RA cams are smaller than X??
  109. Opinions on fuel additives?
  110. Thermostat replacement
  111. 2012 ra!
  112. blue and black 3 Ports
  113. Car bogged out on me??
  114. best way to drive the tc-sst
  115. pop off valve
  116. BPV Suggestions
  117. disregard this
  118. Ivey Tuned 343 AWH 334 TQ
  119. Idle Control
  120. Oiled or dry ?
  121. What are some good cams?
  122. Sound of TBE
  123. Heres How to Get Launch Control & S-Sport Mode!!!
  124. Aftermarket exhaust manifold with evo X swap?
  125. Evo x Turbo Bolts
  126. Depo Racing Gauges?
  127. Trans Fan
  128. A/F Ratios
  129. Building my motor advice on parts please
  130. Engine fails to turn over after driving in Sport Mode
  131. Help For R&D (Turbo)
  132. Oil Cooler Required?
  133. low boost day?
  134. oil drain plug size/thread
  135. Great Video
  136. Transmission Cooler
  137. Finally tuned at RRE!!!
  138. Anyone running these fuel injectors?
  139. Going to finally break down
  140. Jcusco407 EvoX Swap
  141. Oil Smells Like Gas
  142. Rallliart OEM turbo inlet size
  143. EVO X Blue Fuel Relay
  144. Magnaflow 2" Piece
  145. IC piping evo x
  146. Lighter and/or Underdrive Pulley?
  147. Gear Slip + White Puff Of Smoke
  148. Trans ?
  149. HFC Suggestions
  150. Is Ultimate-Racing the only option for an aftermarket downpipe?
  151. EcuFlash - Stock rom wants 53600016 definition file
  152. Wanting to buy a new Exhuast need help PLZ!!
  153. Ralliart turbo laying around? 02 housing question
  154. Turbo swap question
  155. Engine or Transmission Reinforcement?
  156. Red glowing Catalytic converter
  157. Ralliart x specs n parts
  158. Tactrix or OBDLink (802.11 WiFi and USB)
  159. 11.50 ra pass
  160. Transmission question
  161. Intercooler Q
  162. Evo X BOV question
  163. economy map?
  164. Ultimate Racing Long downpipe
  165. CP-E catback + AMS HFC =
  166. Intake Recommendations
  167. CBRD RAD Lite + Walboro 255 LPH Reviews?
  168. HP and Torque #s
  169. Magnaflow Cat-Back Review
  170. Fp Red Dyno Results
  171. Upgrade
  172. RA with Evo x turbo reliable?
  173. AccessPORT and AccessTUNER Updates for Mitsubishi EVO X and Ralliart
  174. DP with OEM turbo really necessary?
  175. Load Based Boost Targeting
  176. help a noob out with standalone logging
  177. Exhaust review and thoughts
  178. Drone, help please.
  179. Cobb Map for x swap
  180. WG Actuator
  181. 4WD Service Required???
  182. Odd exhaust leak...
  183. Tial Bov spring
  184. Warning Light
  185. Grinding sound from tranny/turbo/?
  186. AYC + AWC without electrics and and AYC pump
  187. Ralliart turbo
  188. OBX 3" Catback
  189. AWD question...
  190. Shift hesitation and an embarrassingly simple questions
  191. 350whp?
  192. CBRD tuned 2011 RA
  193. Ceramic vs Metallic HFC - Which to buy?
  194. aem intake
  195. Traction control problems
  196. 93 oct
  197. AMS Widemouth DP for Ralliart?
  198. DP and HFC recommendations
  199. Adjusting BOV Spring
  200. CBRD RAD lite VS EVO X swap
  201. First logging and Virtual Dyno
  202. That sweet turbo whistle
  203. Petition for dc sports flawed dual exhaust to the bbb
  204. Crazy Knock
  205. Dyno graph
  206. OBX Catback
  207. Ceramic Cat to Mini Muffler
  208. Exhaust Questions
  209. Tablet for Evo Scan?
  210. TiAL QR BOV flange size.
  211. Finally did my evo x swap. Thanks CBRD!
  212. Idle Noise
  213. Check light engine
  214. Ralliart Transmissions Fluids
  215. Evo X oil cooler installation Q's
  216. 4g63 flywheel on 4g69?
  217. Best to replace the SST trans fluid before the evo x swap?
  218. 2011 Candian ecu rom
  219. New Unknown DTC Code P34A0
  220. Variable Cam Timing?
  221. Definition File Needed - USDM 53600013
  222. How to tell if factory tuned?
  223. Can ralliart cat fix on evo x?
  224. What oil changes would YOU do?
  225. Ruminations on SST Driving Habits
  226. Can't launch...
  227. Build plans for my RA/x conversion.
  228. Psi boost
  229. Logging tc-sst
  230. Any Euro-spec Ralliart owners out there with a FACTORY engine oil cooler?
  231. Custom Y-Pipe?
  232. Noise during rain/snow
  233. Upgrading the RA - Pricing Issues
  234. SST fluid change question
  235. ACD fluid drain plug
  236. Boost gauge splice in?
  237. evo x swap question (aftermarket)
  238. 2010 RA - Cel P00117 Code
  239. Turbo/FMIC choices?
  240. Saw This Ad
  241. Hotshot1 2.0 RA build thread
  242. Waistgate and BOV
  243. 09 and up EVO Vs. Rally Art
  244. start up rattle, possible exhaust leak?
  245. E85 on maxed out turbo?
  246. AMS base tune input
  247. Question about FUEL PUMP!?
  248. Whats a good deal?
  249. Getting my first tune
  250. X Turbo Swap Intake Solutions?
