- ralliart manifold question
- Need help
- Start issues?
- Upgrading to bigger TURBO
- need help.
- heads up for injen intake
- RA wastgate
- will this fit our RA
- just found this
- RA turbo upgrade
- Engine rattle questions.
- Can the Dealer Detect an ECU Re-Map?
- Transmission hickups
- A/F ratio with Injen CAI
- Would you swap your TC SST for a Manual
- EvoX parts in Ralliart?
- lookin to get cp-e down pipe
- TC-SST Failure. Imporant!
- A Tactrix reflash cable
- COBB AP in my greedy hands
- Evo X turbo fit on 09 Ralliart?
- Ultimate Racing = Ultimate Customer Service and Products
- Turbo flutter at WOT!
- Boost Gauge
- + - mode
- Oil weights in cold weather
- Questions about RA Turbo
- Genuine Ralliart muffler
- What happens when the SST goes
- Car not shifting in sport mode correctly
- Ralliart w/ X Turbo tuned by AMS
- Extreme WOOTAGE to ensue soon!
- Hks exhaust install
- Ralliart stage 2 262hp/310tq!
- Help!! Ams hfc install
- Intercooler and Upper Pipe for Sale OEM
- Ordered some new toys for RA!
- 280whp need help
- Ams bov question
- Lancershop.com bovs
- Injen UICP kit installed
- Offered Trans Warranty on Ralliart Upgrades?
- Evo X Turbo + Goodies Installed Soon
- UR Axle back install
- Ralliart Turbo and Exhaust Manifold
- The safest amount of torque
- Tim's Lancer Ralliart Tuned @ AWD Motorsports!!! 260whp / 279tq!!!!
- AccessPORT User Survey 2010
- What's the best quality brand of gas?
- ecuflash xml
- VisionArtz 2010 Ralliart Sportback Tuned @ TTP-Engineering!
- Custom tune off GST basmap: 300+HP&TQ
- MAF check engine light
- Ams bov
- so who's making the most power with a RA tc-sst
- Got my Boost Pill Today!
- Cobb Accessport, for Ralliart!
- magnaflow
- gp exhaust
- Evo x - ralliart compatibility
- COBB AccessPORT for 2009 Mitsubishi Lancer Ralliart Now Available!
- Engine knock
- Help with test pipe install
- Works and SSP 400hp Drivtrain Pkg.
- EVO X turbo/ ETS intake/ ETS IC kit/ English Racing Tune
- Turbo Inlet Hose Compatibility
- Stock muffler modifying
- ETS Intercooler VS Stock Ralliart Intercooler
- UICP differences
- For people with custom/basetunes
- Just in!! UR FMIC
- sound clips???
- Magnaflow Exhaust
- Ralliart maf sensor
- general BOV thread
- $567 = 277 whp & 294 wtq
- AMS Hi Flow Cat installed Yesturday
- evo 8 turbo on ralliart??
- injen intake
- Boost Pills...
- Sport Mode
- O2 Sensor spacer technical question..
- Weird stuff in the snow.. Center Dif needs service?? Turning off ASC.. ok.. hmmm
- Help, where is the boost pill located
- delayed shifting into reverse
- Does an upgraded FMIC require a retune?
- Ams bov
- This won't happen for a while but, it'd be nice to start checking...
- Explain to me why
- Twin Clutch SST problem
- Ur fmic
- is there any way to make the ra a twin turbo??
- Evo IX BPV/BOV Question.
- WTB Tactrix cable
- UR cat back optional parts
- SSQV Screw
- burning smell
- Stock Boost Pill Picture Needed
- Rattle Noise
- AWC reflash bunk?
- "New" Borla Catback for 09 Ralliart
- could i sell my tune to someone else?
- Boost Control?
- aem cai
- Turbo Flutter???
- Test pipe or high flowcat
- AGP wastegate actuator?
- Axle backs??
- High-Flow Cat With No O2 Plug... Help!!
- AMS vs. UR vs ?? catback systems
- dc sports
- greddy
- Next upgrade: UR Catback? or Intercooler?
- Rent a Tactrix OpenPort 2.0 Cable
- Active Center Differential
- HKS drop in filter 09 RA
- good article regarding air intakes
- Static fuel pressure?
- Engine Internals
- Would this require a tune?
- using manual mode bad??
- 3 error codes (GST related?)
- Ralliart Intercooler upgrade
- Evo X FMIC and UICP Install Question
- P1037 - Heated oxygen sensor (rear) circuit low voltage
- i think my car is broken!
- Manual Boost Controller
- HKS Super SQV3 BOV
- ATF Fluid?
- EVO 8 Intercooler in my RA??
- UR Alex Back
- -20 C Strange whine from engine
- Is my stock exhaust worth anything?
- NEED SOME INFO PLEASE i just upgrade to UR short intake
- ssp clutch packs
- Intake Questions
- Garrett Turbo Kit
- Help need stock ra turbo!!!!
- Wideband
- fastest ralliart
- www.ralliartperformance.com ecu flash?
- I think my speedo is off
- EVO X Intercooler
- Sprint Boost
- Stock turbo, manifold, and O2 housing....
- Downpipe
- SST fluid change
- Help me decide
- looking for good inexpensive BOV
- 12's on stock turbo and snow tires!
- GReddy Intercooler Upgrade
- noticeable grinding/harsh whirring sound in second gear
- THE Complete Evo X turbo swap parts list!
- Approved oils for ralliart oil change?
- Just curious about the 2010 RA's
- Feel stupid asking this... How do I take out the air filter?
- How small is the stock Ralliart turbo?
- engine sputtering around 6k rpm
- Burning smells from engine bay?
- Analysis of my dyno runs as compared to my drag strip results.
- Dyno results at AMS! (broadband needed)
- Wow! price jump on T1R pipes
- AMS Intake
- Dyno check Next Wednesday!
- Any reputable tuners in NY,CT,PA,NJ area
- New personal best 1/4 mile!
- My next step in mods.
- 09 ralliart, remote start...tach signal
- Is a tune needed with just T1R IC and DROP-in filter?
- TC-SST tweaked?
- question about oil in IC piping
- upgraded fuel system
- Exhaust Questions
- exhaust smells like oil
- Ralliart Intercooler and couplers clamp sizes.
- Evo X IC and stock UICP coupler question!
- Install FP Red turbo on RA
- 346whp uncorrected '09 Ralliart Evo X turbo tuned by TTP!
- Dyno based HP estimates vs drag strip based HP estimates.
- GST Base Map on 93 OCT and some tweaking!
- AMS SRI installed
- HP gains from modifications based on 1/4 mile results.
- My Ralliart Stage 1 Upgrade @RRM/RRE
- Car went WOT as well...
- How to save over $350!!!
- How to make 300/300 on an RA?
- AWC Reflash?
- Forge WG actuator from EVO X confirmed!
- TC-SST Critical Malfunction!!!
- transmission from evo x
- quick ?? about the turbo
- turbo information needed.
- How a Differential Gear works (Get some popcorn)
- gauges and gauge pods...
- Parts compatibility? EVO X MR to Ralliart.
- Tuning in washington state
- Zip ties
- aftermarket intercooler worth any whp?
- 2 Recalls for RA
- Injen Cold Air intake
- Hard 2nd gear knock
- Mishimoto FMIC vs AMS FMIC
- Getting UR Turboback installed on tuesday
- Stock intercooler core sizes
- UR uicp
- HKS Legamax Premium exhaust
- Ralliart Mail-In Flash Now Available
- Plasti-dip/Intercooler
- New TSB for CT Trannie
- Latest product from the garage
- Hks ssqv
- Evo X IC
- CP-E Quick Power Pipe installed
- Purple Smoke @ 6500 Miles
- engine light is on, need some input~
- Tuning for fuel economy
- Check Engine Light
- Anyone install a Blouch?
- Tactrix has cables in stock
- Turbo Kit; whats needed?
- Perrin EBCS
- custom UICP. cheap and easy.
- Cobb AccessPORT for Ralliart
- Car went WOT
- Aftermarket intercoolers..
- Finally dynotuned for all my mods at Lightspeed innovations
- My unofficial 1/4 mile time
- UR UICP & EVO X FMIC - installed
- Anyone Have a Tactrix Cable Near Buffalo NY
- '09 Ralliart, +70whp gains, TTP tuned, full UR TBE, K&N drop in!
- is LOWER INTERCOOLER PIPING really a necessary upgrade in our cars???
- Tuned by english racing
- Anyone Have any trouble with UR Test pipe with the wideband blug?
- ok, i have officially found the most OPTOMISTIC DYNO, period. lol!!
- o2 Plug/ Bung for wideband?
- Stock Dyno Run by RRE
- TC-SST Shift time
- Mishimoto Products
- AMS FMIC+ PIPE or UR FMIC+Pipe ?
- Evo X Test Pipe on a 09 RA?
- Evo 7-9 turbo on a Ralliart?
- Anybody knows about a good tuning place in orlando?
- Intake...even worth it?
- White smoke from exhaust when taking off from a start.
- Ur exhaust question
- 2009 Ralliart Injen Cold Air Intake Tuned by RRE
- AMS Test-Pipe
- Recirculating vs Venting
- Convert Ralliart to EvoX *Ultimate List*
- what part would be more beneficial?
