- Tune for UR Intake?
- turbo inlet for a ralliart?
- Engine oil; pressure problem?
- Fluid line (to turbo) upgades for X turbo
- Check engine light
- Software mods that are not performance related.
- UR HFC rear 02 sensor wire options?
- 09 Ralliart Timing Chain Stretch!!!FML!!
- Fuel pump kit options
- 4b11 running rough on idle ticking noise
- Any CX Racing Owners?
- Different gas?
- Need Serious Answers.....
- running 5w-60
- EvoScan logging fail
- AMS E-Tune Review
- Boost irregular with 2.6 base map
- Badreligi0n's Project Ralliart
- Possible sst help
- Cel: P0171
- Wideband info
- Is this the size of the boost pill?
- grimmspeed ecbs vs boost pill
- Cold Start Chirrping Sound
- Boostpill Base Map users - check your boost levels
- AccessPort and TurboXS Catback Exhaust System 4 sale
- How long is the idle time before shutting off the car
- Evo x Perrin Uicp ??
- wtf asc system service required
- Synthetic Oil Filters (Canada)
- UR Short Ram
- Manifold for the Ralliart
- New catback exhaust booming
- Car wont start need a little help
- UR SINGLE Exhaust
- HFC engine light
- Help!!! Can't go over 20 pounds of boost.
- I was warned my coils would get too hot...
- downpipe or hfc?
- 3'' Mid-Pipe Dimensions?
- Plastic Valve Cover
- Anyone in Kansas City area have a tactrix cable to sell or rent?
- serpentine belt replacement
- Car will not start...
- Why to buy CBRD RAD Turbo Upgrade?
- 11.8 RA pass
- Ticking noise
- Upgraded RA Turbo by FP
- Where to buy CBRD RAD Turbo Upgrade?
- HKS SSQV4 Recirculation
- EvoX IC/ UR piping/ GST basemap
- ETS Intercooler
- What is up with CBRD cannot convert a 08 evo x turbo? Does FP have this same issue?
- Driving steering problems Ralliart hit a gutter
- Trying to get tuned, but my Tranny is messing up Wat should I do is tuner advice a go
- Tranny flush question.
- Cobb exhaust
- Issues....dom 2.0
- Manny Tranny
- Preliminary Dyno Result
- Engine Mount insert?
- Would having a 7 speed SST improve future Ralliarts?
- Bung install for Wideband
- Need opinion on exhausts
- Info: Turbo Swaps
- Info: Modding your RA!
- Turbo Upgrade
- Fuel Cut
- Tuning with grimmspeed?
- Ralliart AFR and Tuning Questions
- pease help i need to know within a few hrs
- Engine Knock?
- Does installing a downpipe need tuning?
- Diff upgrade
- Overboost Issues
- Issues with shift spike and timing, and..
- D1 Spec Filters
- 2011 Ralliart Transmission Problem
- Beware: Diaqueen SSTF-I fluid may or may not be exactly 4 liters per can
- RA/TC-SST Service Manual
- Vic's 2011 RalliArt - E85 - 369hp - Boostin Performance
- Manifold Stuck! RA to EvoX turbo swap
- Ralliart Intakes
- Ralliart Evo X swap. Weird dyno numbers?
- What Hardware is Required for Test Pipe Install
- Cobb Survey!
- Turbo upgrade with SST trans
- 3-Port Tubing Question
- ralliart turbo questions
- ACD Service Required
- Request : Pics of installed TurboXS exhaust
- CP-E downpipe require a tune?
- Captg's Tuned Ralliart
- My top 3 turboback choices - I need your input!
- Transmission Overheating
- Spark Plugs, this doesn't look right???
- Looking to buy a testpipe, Q's!
- RA rear diff ratio and pic request
- Single Tip vs. Dual Tip
- Triangle with ! in it along with check...
- Looking To Buy More Complete Basemap
- I thought i bought an AMS exhaust....
- Tatrix cable edmonton?
- Ralliart - Exhaust Droning
- Engine Knocking
- Ralliart Only Exhaust Systems
- Swiss Knive again: the next level (AMS IC with UPC)
- Oil Pan Gasket Leak
- Help...Ralliart Rear Differential Location?
- Trans Temp Gauge Location?
- Problem, please help diagnose
- dom 2.0 ralliart dyno results inside
- Self tuning help... Confused...
- 'Slow Down' on launch
- Exo i/c licp help!
- Recirculating or Diverter Pipe?
- 09+ Ralliart Upper Intercooler Pipes
- Upgrading RA fuel pump
- K&N drop-in
- Tactrix stolen-League City, TX
- Any good tuners for Evo X turbo swap?
- What kinds of mods would be good for my ralliart?
- Evo engine swap into '11 RA
- on turbo to o2 housing
- WTB: HP - Apply Within
- Where to buy stock RA turbo? Used or new?
- What would you do next?
- Trans Cooler
- Transfercase leak ....
- Ralliart Clutch Upgrade
- Questions Evo x swapped ralliarts chime in
- Quick question about the stock turbo...
- Boost Leak Sound??
- FMIC set up, lower piping?
- AEM UEGO A/F Required With Cobb AP?
- Dealership & Tuned Question
- Hard IC Set, alternative.
- Question About Oiled Air Filter (Works)
- Oil in UICP? Normal? OK?
- 13k and Transmission Service Required?
- Question... Evo X Intercooler....
- AEM R&D Engineering data on the Ralliart Cold Air Intake Box
- AEM's Production Dyno Results for the Ralliart Cold Air Box Intake
- 500hp clutch packs
- SST help
- ACD fixed...now this?
- grimspeed 3port help
- COBB Accessport Owners - Ralliart 09+
- Will UR Downpipe bolt right up to stock setup?
- Driveline info on info screen....
- RA fuelling "Lean spool" switches off above 6500rpm?
- Stock intake vs UR intake?
- GT3076r swap?
- ??? about exhaust
- Quieter Exhaust Advice needed
- Boost gauge question
- Spectre MAF adapters
- Turbo back exhaust?
- White smoke???
- x swap battery question
- Engine Service Soon light
- 2009+ ultimate racing exhaust
- Turbo Noise Gone..
- Engine noise?
- Down Pipe In my Future. Opinions Poll. UR or TSX ?
- ARC UICP Question
- CBRD RAD Turbo
- Big upgrades, some questions.
- Hose Conflict
- Rogue hose
- Figuring out my boost.
- Poll Question need opinions!
- #4 cylinder misfire and exhaust valve burnt?
- K&N Filter cleaning/oiling and now issue.
- SST Trans cooler kit by AMS - Worth it or not?
- Gauges?
- What turbo do you guys want to see?
- UR Exhaust FTW!
- Red devil project
- Misfire when cold?
- Ultimate Racing Turboback Exhaust Tune?
- afr
- RalliArt blown up! why? help me!
- Cel p2253, p0132, p0134
- SST video
- part number for oil cooler bolt seals?
- Rev limit musings
- SSP Pro Gold: SO WORTH IT!!!!!!!
- Help with P184b code
- A/F logging question
- Perrin Intercooler
- AMS intercooler
- 2010 RA Differential fluid change
- RA OEM BPV Question
- what would happen if i lowered my boost to zero
- C.A.I.- Drop in filter..
- Changing Oils
- Stock exhaust piping size?
- Spark plugs whats everyone running whats the best to run for our cars?
- Should I upgrade ic?
- Bpv
- Strange Engine Noise.. need some help diagnosing
- Pig Rich during and just after wot shift
- ECU Logging/Display with Android Phone
- Identifying low Hum.
- EvoX FMIC w/ Stock Ralliart UICP?
- Tranny & differential fluid change
- Dyno results: 3rd or 4th gear?
- A package from CBRD showed up today!
- HELP! 09 RA knocking on cobb ap stage 2 cal map
- Whining sound!?
- FMIC - Ultimate Racing vs. EVO X stock vs. AMS
- TurboXS or UR: DP & RP?
- What mods to get?
- MAP short runner mani
- TurboX DP & HF Cat?
- Baseline dyno today
- ssp clutch pack help ?
- 09 RA engine noise ??
- Battery Bracket Preview
- Question: Evo X CAI
- Idle Problem Associated With Cooling Fans (Not The Usual)
- Launching solved Look what i found!
- EVO X centre diff
- Boost Gauge.. Help!!!
- X swap exhaust manifold question.
- Which Turbo
- X Swap Ralliart by Magnus
- Logging AFRMAP? ROMID 53610010
- Logging with no Laptop - RA logcfg files here
- ssqv3 recirculating
- Strange Air Sound At High RPM
- Stock ECU Tune
- Need help deciding
- Test pipe
- DC Sports Single Exit Catback
- What heat range spark plug should I used on E85
- X swap tuning
- SST Grind on Startup
- Q? What specifically has failed with RA transmissions?
- Grimmspeed EVO X 3port EBC
- ralliart fp green = catastrophe.
- tuning with seprate ecu
- 2010 Ralliart OEM ECU Test Write Error
- Getting Tuned Soon...Got some questions
- post WOT shift hesitation... anyone else?
- EVO X IC swap question
- little help wit exhaust plz
- Tuning with tactrix cable?
- just wanted to share this with you
