- Omegis RA to Evo X swap progress
- Ralliart Synapse DV question
- Evo X Turbo Swap (Air Intake, Battery)
- 2010 RA with Evo X turbo swap 294WHP/315WTQ
- Poll: Oil
- BOV question
- Car shakes when driving
- Evo X FMIC
- Looking For A Stock EvoX Intercooler
- Has Anyone Tried the New UR Long Downpipe?
- Engine Mods Question
- Hi Flow Cat = Cali Smog Question
- Goodbye evom and does anyone want my tactrix cable?
- SST Clutches
- SoCal Tuners/RA Enthusiasts!!!
- Upper Intercooler pipe kit
- Intake
- Do I need a fuel pump w/E85
- ECU Basemaps exchangeable between vehicles?
- Question on O2 Spacers
- Transmission swap for a ralliart?
- RA devin tuned
- Any 11sec Ra's?
- Down shifting question
- Evo X Turbo Swap
- New K&N Filter whistling sound?
- HKS Center Pipe with Stock Muffler
- Car PAID !! Now...
- COBB AP from stage I to II
- Ralliart ssp clutches
- RA dyno 290 AWHP/ 347 AWTQ!!
- Cold Air Intake System
- Clarity needed on the ECU Tuning...
- What intake are you running with your X turbo?
- The "can I borrow a tactrix cable" thread
- meth or 85
- The is it safe to use this mod with this map thread :)
- Magnaflow CB sound clip?
- GST Tune with turboback exhaust?
- EVO X JDM BPV flutters??
- CBRD Turbo - Consumer Experience?
- Cobb AP
- K&M Filter with BOV sound?
- Transmission Service Light
- Need A Tune
- SST temps datalogged in Evoscan
- The Useful threads thread
- Problem with logging data with Evoscan
- Raise your hand if you lost an SST (it broke and needed replacement)
- oil leaks around cooler? easy to fix? HELP!
- Tactrix OpenPort Standalone Logging... 0-5V ADC on OP2.0 Pin 8
- 09 RA 381awhp 321tq
- What is the highest HP RA?
- New Intercooler Arrived Today
- Anyone have the APT UICP?
- UR straight pipe and high flow cat
- ralliart setup
- Ralliart SST cluth kit
- transmission $
- Turbo inlet pipe diameter
- Fpgreen
- About my Injen UICP..
- High flow cat
- ra turbo questions
- What Cobb AP calibrations do you want
- Replacing the stocker plastic BOV?
- sport mode
- AMS Stages for RA
- Tsudo Evo X/RA test pipe
- HKS Legamax Axel Back Exhaust + UR Resonated Midpipe
- anyone have a tactrix cable in NJ?
- Anyone have the dc sport downpipe installed?
- mods and numbers?
- 2010 aus/edm evoscan
- CBRD more testing...
- Timing Chain Replaced Under Warranty
- Transmission acts stuck??
- evo scan locking up computer. HELP!
- Help! Rattling when turbo spools?
- Magnaflow Exhaust on a Sportback
- Getting my ralliart dyno today
- Cobb ap help
- cheapest way to reach 330whp?
- Turbosmart BOV
- evo x wastegate
- 2009 Ralliart + Evo 10 turbo
- Going to flush my tranny and drivetrain fluids...
- td04hl-20?
- What are your FMIC Upgrade Recommendations???
- boost pill
- turbo timer
- Agency Power BOV
- AMS LICP Fitment
- WTB: OEM Intake
- How to check CEL with tatrix and evoscan?
- Possible problem with the ETACS for the ACD.? - Help.!
- Bypass Valve 1507A009
- What are stock IDC%?
- boost controllers
- Cold Weather + Accesport tune
- cnt exhuast
- Turbosmart Dual Port Blow Off Valve
- cobb accessport stage 2?
- Evo X swap questions
- Griffin CarTrip iphone app
- Exhaust help! UR
- ASC off and the ABS?
- Boost
- warranty
- high flow outlet pipe
- anyone upgraded the WGA??
- TC-SST Sport vs. Normal Mode
- evo x intercooler
- Intercooler Question
- Blox Test Pipe Question
- Need help, I installed the AMS intercooler, look @ pic
- SST aftermarket cooler recommendations
- picture of sst transmission filter location
- Ultimate Racing EVO FMIC package for RA...
- Boost Spike
- Check Engline Light On/Off
- Is this bad?
- possible subforum idea
- Evo X BOV Question
- Just bought a Greedy down pipe whats the power gain?
- Is anyone running these Cams??
- evox swap
- Possible SST Failure
- oem x manifold vs megan racing manifold w/outlet
- Light weight Crank Pulley?
- evox turbo swap parts
- Dyno Question
- Quick questions
- 2009 ralliart computer in 2010 ralliart?
- Is this the correct output of power that I should be getting??
- Power Steering / Generator belt
- SST acting up!
- need some advice with my set up
- PLEASE HELP Transmission slipping going into limp-mode alot!!!!
- CBRD Baseline testing-
- what CAN the SST handle?
- help.. upgrading turbo..
- bobcrusader Lancer RA tuned By Creatd Motorsports
- 2009+ Ralliart DC SPORTS Cat-Back Exhaust System
- CBRD and the Ralliart...
- Error Code: P0420
- ralliart questions (n00b)
- UICP worth buying without FMIC?
- cobb ap... not hitting target boost psi?
- having boost problem need help
- NFS Lancer Ralliart
- works stealth muffler
- what's needed to get a 300whp ralliart
- Tranny strengthening
- overboost issue.
- Turbosmart Dualport Kompact 34mm bov
- Perrin bov
- 1000cc injectors rc injectors
- Top end power
- RA snorkel
- lets talk rrm
- Weird Noise after Blow Off
- Blowing Off Twice
- Anyone out there with a turbo timer on a 09+ ralliart or evo x mr w/ fast key?
- Finally tuned
- Issues Datalogging Wideband
- IM Boomba Tuned
- another maf/bov question
- De Cat/Test Pipe
- UR Exhaust defeat drone?
- Ralliart with boost controller
- evo cams in ralliart
- bov vta question
- Confirmed : SST 1st gear throttle limit MR vs RA
- 53610010 XML Needed
- Anyone looking for an Injen UICP?
- exhaust decision
- BOV 27+psi
- Ralliart Tranny in a 2.4 GTS
- BOV Flutter
- missed shift??
- finally got the boost pill in, but how will the increase tbe boost without a controle
- Supercharger
- Help tuning bov for 09 ralliart
- Bryan from gst to come to aus
- 2009 Aussie RA - Tweaking and Tuning
- custom exhaust price??
- wastegate chatter
- hks ssqv3 hose
- Custom Flowmaster Exhaust.
- AMs intercooler/ UICP compatbility
- Timing retardation vs. Intake Air Temp
- BOV location
- Need help with tranny!!!
- Ralliart TPS never exceeds 87.5% - EvoScan mode23
- BBX Lite and supporting mods
- need a QUICK answer TUNE TODAY!!!
- Cobb AP question
- SST Tranny Fluid change
- Ralliart (AUS) ECU Stuff For Dummies
- Best way to reach 250-60whp
- new ra turbos
- Help?!?
- 93 octane tune and using 91 octane is it bad?
- anyone looking for an evo x turbo manifold
- grey smoke
- Boost spikes on Ralliart, related to stock BPV?
- Made 273 thanks to camtuning!
- FEELER stealth catback exhaust
- anyone looking for a stock turbo for RA
- Cobb performance part survey
- Q? Weird Noise after UICP Install
- fast ralliart times
- Octane...
- EvoScan Options
- fp green or bbx lite
- Vibration while stopped
- Need some help with 3xMAP tables.
- True CAI option
- Another issue with ralliart, no boost??
- Transmission Oil Leak
- Turbo XS exhaust
- ams o2 spacer
- stm small battery
- TC-SST Oil Change Time
- AMS cat back dual exhaust
- Evo X turbo swap (base map discussion)
- Blue Fuel Relay
- Terrible Knocking from Rearend
- does this sound normal?
- evo 9 or 8
- Good Idea or Bad? My little Project
- Problem or not?
- Exhaust fitment
- GST boost pill questions
- stock exhaust size
- JB Weld/External thread repair on oxygen sensor
- UICP question
- HKS Oil Cooler KitSST Model
- agency power light weight crank pulley
- evo 3 16g turbo vs. Stock 2009 Ralliart turbo
- Advance Engine Oil for the RA
- Transmission Vibration
- Leaking something. Need help.
- Help, tuner destroyed my transmission
- COBB Ralliart Cat-Back Tip Poll
- new turbo....no boost
- ultimate racing intake with cobb stage 1
- gst+sunroof
- Where I can get GST boost pill?
