PDA
View Full Version : 04-06 Ralliart General
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Hood prop grommet disintegrated
  2. Troubling selling my car
  3. 5k rpm limp mode
  4. Factory air box help
  5. looking for harness wire diagram
  6. crank no start need help ASAP
  7. Colt ralliart 2006 model 3000 rpm and 4000 rpm problem
  8. '04 ralliart not start
  9. Thanks for reaching out.
  10. 04 Ralliart Sportback 2.4 4cyl Random Idle Issues
  11. install winch
  12. Engine mivec lag
  13. Ac pulley is not aligning straight.
  14. 2004 Lancer Ralliart not starting after getting gas, and revving up slowly at idle
  15. Help 4g69 4g18 gearbox clutch
  16. aftermarket radio
  17. Need help finding a half size radiator that isn’t gonna hurt my bank account
  18. trasmission seal
  19. Manual Ra problems
  20. Will a 4g69 swap Into to a 2003 lancer none evo?
  21. 2005 Ralliart Headers
  22. What fits
  23. Where to find turbo?
  24. toque spec
  25. Need some help with code P0125
  26. 4G69 Bench Flash
  27. Gauge cluster light issue
  28. Ralliart 2.4 Muffler
  29. Air dams?
  30. 04 Ra not starting
  31. Memory wire for aftermarket radio
  32. How many miles does your Ralliart have?
  33. 4g69 turbo setup
  34. Radiator fans don't spin
  35. Help! 2004 ralliart keeps blowing fuse
  36. 2004 Lancer Ralliart O.G.
  37. Door Info?
  38. Ralliart 2004
  39. 4g13 to 4g69 swap
  40. 04 ralliart turbo project new owner originally ralliart_on_LSD's
  41. 04 lancer ralliart ra transmission HELP!!
  42. P0335 and P0340
  43. 06 Lancer RA Issues with RPM fluctuations and stalling
  44. Hello again
  45. 05 Ralliart Header info?
  46. Do I need a clutch change?
  47. Need help with breaking system
  48. Max power for stock tranny?
  49. Cruise control never worked, any ideas?
  50. 04 ralliart parts car or junk?
  51. Evo double pumper in ralliart
  52. Drivers side mirror replacement - which part?
  53. 2004 lancer ralliart tuning with tactric need help
  54. I need a tuner!
  55. Where to buy grill online
  56. P0171 Engine Code
  57. 2004 Ralliart Tachometer Swap
  58. AC works great... but will not shut off!
  59. Anyone ever completed an AWD swap?
  60. Trunk bike rack that works with spoiler?
  61. Can anyone help me how to tranny swap AT-Manual my lancer ralliart 2004?
  62. Which threads to check out.
  63. Evo 6 cutting on boost
  64. Evo x steering wheel in 2006 Ralliart
  65. Thinking of buying 06 RA
  66. Cat converter relocation 2.4L Ralli
  67. Modded Ralliarts
  68. Ralliart turbo
  69. Idle problems Stall or Shut the engine off
  70. Horrible gas mileage on 06 ralliart?
  71. Tuning and Emissions Testing, Canada
  72. 04 Ralliart idle and stall problems
  73. Clutch life
  74. 06 Key Issue
  75. Aftermarket Steering Wheel?
  76. 2.4l tranny bolt up to a 2.0l engine?
  77. 06 ralliart
  78. Parking Brake Adjustments?
  79. 2.0 vs 2.4 airbox
  80. Hi everyone
  81. 2006 Ralliart trunk/gas lever wont work
  82. Mass airflow sensor failures
  83. Passenger airbag recall
  84. New to the Ralliart Life
  85. power steering fluid
  86. 2005 Ralliart exhaust options
  87. Where do I get a 2-step tune?
  88. No volts at fuel pump fuse....04 Ra
  89. 2005 ralliart steering wheel wiring carnage
  90. Low heat when cold out
  91. How to replace right parking light bulb?
  92. ECU piggyback on high mileage car
  93. Evo recaros on RA
  94. Lancer 2.0 Badge
  95. 04 Ralliart potential transmission issue
  96. Fender Rust Repair
  97. rattle when driving
  98. Magnaflow
  99. Steering Column wont go down
  100. Transmission fluid
  101. Exhaust system
  102. 4g69 n 4g63
  103. August 2017 Featured Car of the Month
  104. I need help.
  105. bad and good things abouts ralliart 2004-05
  106. Part compatibilty for the Ralliart
  107. help!! 03800400 xml definition
  108. Sst rebuild advice
  109. Clutch problem?
  110. Question Regarding Cold Air Intake Size For My Lancer
  111. 04 Ralliart 2.4L (non-evo) transmission replacement
  112. Short Shift Options
  113. 04 4G69 ralliart intake problem
  114. Instrument lights out, then back again?
  115. Upgrading my 2005 ralliart from stock on the cheap
  116. Wich Serpentine Belt I need in my 2006 Ralliart without A/C
  117. In need of a 5 speed transmission
  118. knuckle part number?
  119. Pricing to Sell?
  120. AC Blows Hot Air and Makes belt Noise When On
  121. Haltech 4G69 Support
  122. Fuel Tank Removal / Fuel Issues
  123. Engine knocking
  124. Evo style flat trunk for ralliart
  125. Loud Exhaust for my 05 Ralliart
  126. New fuel pump, car wont start
  127. Down pipe for stock header?
  128. My Ralliart 2005 Retrofit
  129. Need help with a horn problem
  130. AC quit, engine fan problem?
  131. O4 ralliart shop manual
  132. OBX Header and Downpipe or custom downpipe
  133. RRM Evo 9 Rear Bumper
  134. Oz rally subframe
  135. Duraflex Rally Front Lip
  136. New 2005 RA owner, requesting knowledge
  137. Need bolt to connect knuckle to control arm.
  138. Attention Sportback Owners
  139. Keyless remote questions
  140. Aftermarket Headunit
  141. Running hot 🔥
  142. Time to say goodbye to my 04 Ralliart :(
  143. Exhaust manifold leaks?
  144. Shark fin antenna
  145. 06 Ralliart question
  146. 2004 lancer ralliart exhaust
  147. Will evo radiator fit Ralliart?
  148. Removing Rear Rotors
  149. Oil ligth
  150. Ralliart '06 bumper in a '05?
  151. Fan Issue!
  152. Ricer?
  153. Ralliart Roll Call 2016
  154. WTB Evo 7/8 Spoiler
  155. detaching cables
  156. Tuning Help and questions 04 Ralliart.
  157. Opinion on head light covers?
  158. Introduction/06 RA Journey
  159. 05 ralliart aftermarket front end?
  160. Rear seat courtesy lights and charging station
  161. Ralliart Upgrade
  162. SunRoof "Learn" mode
  163. Desperate need of help - mass flow air sensor
  164. Rear passenger side quarter panel damage
  165. 04 Ralliart power window and locks issue
  166. Aftermarket Seats
  167. Can I convert the body of my 06 ralliart to an evo?
  168. 1/4 mile times
  169. Some few drops in spark plug cavity
  170. It is time.
  171. Shifter Question
  172. Cruise Control not working
  173. I know a lot of you work hard on your Lancers...
  174. Underdash Illumination Kit (OEM Accessory)
  175. 04 Lancer Ralliart bad alternator?
  176. Ready to start build
  177. Aftermarket tail lights
  178. Cluster and tail light problems
  179. 04 lancer ralliart oil pan
  180. 04 Ralliart spoiler
  181. 04 Lancer build help
  182. 2004 Lancer OZ Exhaust
  183. New to EvoM: My introduction.
  184. Electrical Short? Help
  185. Hood wont lock
  186. Dash lighting/will not work
  187. trying to jump start a dead battery
  188. Advice for broken engine screw hole nipple
  189. 2005 Hood same as 2006?
  190. Drivers side door will not lock or unlock elecetrically
  191. Ignition problem need help
  192. Aftermarket battery tray
  193. Randoms not plugged in under dash area, help needed
  194. Need help 2004 Ralliart new alternator and battery malfunctioning
  195. Help for 4g69 swap
  196. 23rd Evo/DSM/GTR Shootout
  197. oil pan on lancer ralliart 2006?
  198. Fuse box picture.
  199. Will a Evo 8 trunk fit our car
  200. Galant Ralliart Tranny swap, (auto to manual)
  201. Dash Lights not working
  202. air conditioning compressor dying?
  203. Third break light problems.
  204. ralliart caliper painting
  205. should i trade?
  206. What is the recommended octane rating for RA 2005
  207. Batt terminals loose
  208. Issue with 06' RA engine light...
  209. Why does everyone underestimate the reliability of a mitsubishi.
  210. 04 RA Build Question
  211. Ralliart help
  212. Buying a new ralliart need some wisdom
  213. Sportback rear bumper protection strip?
  214. 2004 ac problems
  215. Polished reservoirs
  216. Puffing white smoke above 5k RPM
  217. Look to buy a turbo!!!!!!!
  218. Srs type r1 exhaust?
  219. Wheel/Offset Question
  220. Weird Front End Clunk Noise
  221. Steering Problems
  222. First Post: Master Clutch Cyl Replacement
  223. 2004 - 2006 Lancer Ralliart "Track Night In America"
  224. Any good electricians out there?
  225. Ralliart not running, How do I move on?
  226. NOT selling my Ralliart!
  227. Axle seal leak.
  228. Aftermarket bumper
  229. Engine Help
  230. 06 galants at junkyard
  231. Cam gear for 4G69
  232. Evo 8 Spoiler for 2006 Ralliart
  233. 50 car pile up, time for another new car...
  234. HID kit and projector housings for 04' Ralliart
  235. How to get started in the whole 2006 ralliart buisness
  236. Outer tie rod replacement
  237. Sad yet exciting news!
  238. Apexi muffler
  239. Fastworks Tuning
  240. Which brand for evo spoiler?
  241. 04 - 06 Ralliarts, 2015!
  242. Brakes!
  243. Fyi oem $cdn
  244. APEXi SAFC II or NEO Question
  245. oil pan
  246. Kasper's Build Thread (Ginger)
  247. Lancer Cedia Ralliart bumper ?
  248. Just got my ARC shift knob* New Japan :)
  249. Hackish tunes
  250. Oil Temp Gauge
