PDA
View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. Aftermarket boost gauge install on MR
  2. carbon fiber trunk
  3. zeitronix???
  4. How to HID complete Headlight swap into RS
  5. Hks Eids Woes
  6. Espelir exhaust question
  7. how to remove headliner?
  8. Greddy boost Gauge wiring help
  9. DIY Mini Battery kit. Looks like the pros.
  10. Boost Gauge question
  11. Putting in Sparco racing shells - A dumb tip
  12. Headlight Adjuster (NOT!) obs.
  13. Manifold installation question
  14. How to Request: HKS Circle Earth
  15. Boost Vacuum lines part number?
  16. Hard Water Spots fix
  17. B&M shortthrow non-adjustable
  18. Perrin exhaust
  19. Timing belt
  20. Getting vacuum line for boost gauge to driver side
  21. Radio Relocate/Stock Gauge Question
  22. blitz induction cover
  23. Attention RS owners
  24. How to change brake pads
  25. Removing driver side air vent...
  26. Hallman Pro Cockpit Controller Add-On Kit
  27. Exhaust Question, not your typical....
  28. Greddy EGT help please
  29. Help with HKS type 1 TT install
  30. Defi "D" EGT Replacement Probe that works found!
  31. Remove AC
  32. Moved my battery to trunk with cutoff switch
  33. Fully Gutted evo with no spoller
  34. Tint Kit?
  35. ALKYCONTROL (AMS) alky wiring diagram please.
  36. How to install HKS circle earth
  37. Tein Type Flex adjust
  38. Rotor Removal Stuck??
  39. Removing the factory govenor
  40. How to Change Your Oil on Your IX
  41. XS Engineering Power Pack V2 install
  42. Attn: Need Help!
  43. Running Nos Lines?
  44. Test pipe install
  45. How to replace low beam HID?
  46. MAF to MAP
  47. RS Power window howto?
  48. How do you remove the cigarette plug from the shifter plate?
  49. How do you remove the cigarette plug from the shifter plate?
  50. someone should make this for evo's
  51. someone should make this for evo's
  52. Injen Intake System w/ Intercooler Hard Pipe and AMS intercooler
  53. Evo IX
  54. Steering Wheel and Shifter Bezel Modification - the Mike Mod
  55. Evo Spoiler
  56. tire pressure
  57. Air intake for Automatic
  58. Help! Tire rotation!
  59. OZ Rally exhaust
  60. average Window tint costs?
  61. Help! Removing the rear seat back
  62. Reverse Light Help
  63. SERVICE ENGINE Light Appears..
  64. Which 3 inch downpipes clear the IX's?
  65. turboxs knocklight help
  66. dynamat install question
  67. Installing an ARC Super Induction Box (intake pics)
  68. Sun and Sound Package +, Infinity Stereo Help Please...
  69. greedy type Rs install questions
  70. Evo 5 Style Fog lights?
  71. stock EVO $4,000 what to buy
  72. Buschur Downpipe Removal?
  73. Cusco Type 2 install?
  74. Question about Buschur Intake Intall
  75. How To: Orange Radio and HVAC lights (cheap and easy, lots of pics)
  76. How to do evo 7 tails?
  77. How to remove stock steering wheel ?
  78. How do i remove the fender lights?
  79. XM satellite
  80. back to stock boost diagram help please
  81. Car alarm issues w/HKS type 1 TT
  82. Anyone Install a U-Haul Hitch?
  83. Service Manual Print-out/PDF/look up request
  84. Disassemble Tail Housing....
  85. How to install your own window tint
  86. Tube coming off turbo on ic kit
  87. What to disconnect before welding on car?
  88. for those boosting over 26psi...
  89. Hoe To convert Non HID Evo to True HID
  90. Changing Infiniti head unit Questions
  91. Greddy Full Auto Timer help
  92. Transmission Protection
  93. Forge MBC installation
  94. Red Clock HOWTO
  95. Coilover setup help
  96. Which R/R is tougher: cams or hotside?
  97. Which R/R is more challenging: cams or hotside?
  98. How to install HIDs on EVO IX ????
  99. Removed Factory Installed Canards
  100. headunit removal
  101. how do install injen uppper IC pipe
  102. How To Reset The GReddy Full Auto Turbo Timer???
  103. How to install rear sway bar?
  104. No more blindspots!*
  105. How 2 Turn Off Seatbelt Warning???
  106. Please help me check the fuses in my MR
  107. Help!!!
  108. OEM MR gauges bulbs
  109. Whats the proper way to install harnesses into an Evo?
  110. In-dash dvd monitor
  111. Need to take the dash apart!
  112. VIS CF Trunk Installation HELP
  113. Wide Band Tap?
  114. Remote Start Question
  115. How do i remove yellow spot from headlights.
  116. HKS Clutch help
  117. Perrin Cel Fix instructions
  118. Remote programming??HappyThankyouDay
  119. Is there a fuse or relay for the radiator cooling fan
  120. Braille Lightweight Battery Installation and Review for EVO IX
  121. Brake Pad / Shim question
  122. Check my hookup on Greddy Boost
  123. HELP on how to install forged bov
  124. drain gas for fuel pump install
  125. Greddy Profec Type S Boost controller install
  126. How to change the key ring light on the ignition?
  127. Fuel Empty Indicator Light
  128. Headgasket Install.
  129. GREDY BOV Installed Lost some boost??
  130. How to install Greddy Turbo Timer??
  131. Wheres the evos fuel pump
  132. Zeitronix display setting??
  133. SLOTTED ROTORS! Which way do they go!?
  134. can this be done.
  135. How do you install the defi boost gauge
  136. Apexi turbo timer in place of clock
  137. $50 DIY K&N intake install
  138. Evo Brake Rotor Removal
  139. How to remove pulley on power sterring pump - Evo 8
  140. Need Help with Manifold Installation
  141. carbon 60mm pod? pics!
  142. EVO 9 ECU Speed sensor
  143. Can you fit a sunglass holder in an evo with sunroof?
  144. HOWTO read hkpa on boost gauge??
  145. any books on rebuilding the 4g63 motor???
  146. Gapping question???
  147. My clock and pwr lock wouldn't work
  148. Apex EL II Gauges Help
  149. HELP How do I install blitz FATT DCIII
  150. For those who have changed mirrrors
  151. How to: Boost controller(which hose)
  152. Vehicle Speed Sensor.
  153. Head removal question..help
  154. seibon CF OEm hood
  155. How to fix a stuck sunroof
  156. How to work Blitz Turbo timmer DC2
  157. APR Headstud Install ?
  158. Help Please....
  159. How do I get under the carpet...
  160. BS Removal
  161. catch cam
  162. helix cat delete instal
  163. MR headlight install ??
  164. Zeitronix with SSI Tech boost sensor HELP
  165. Anyone else run into this????
  166. Shifter Bushing
  167. lowering the stock driver seat
  168. How do you reset the ECU?
  169. Lower instrument panel
  170. o2 Simulator Install - ECU Power Supply Question
  171. Removing fastners HELP!!!!
  172. Boost gauge install
  173. Header Bolts!?
  174. o2 Simulator Install from www.o2simulator.com
  175. PW and PL conversion?
  176. We need Radiator swap
  177. RalliArt Spark Plug Wires
  178. Whats a good place (affordable) for aluminum piping?
  179. What are the quietest exhausts out there????
  180. clutch disassemly problem!!!!
  181. How to Install Ralliart Meter Display?
  182. Front Grill Removal
  183. how to install jdm mr bov?
  184. u.k. trunk badge.. need idea to restick
  185. How to convert
  186. plx (m500) questions
  187. Front Strut Bar
  188. Installing new brake rotors and pads
  189. looking to buy a used Greddy T.I. anyone selling???
  190. Cusco Oil Catch Can ????
  191. need help installing greddy rs on my MR
  192. HKS intercooler install HELP
  193. tanabe springs install question
  194. Need help Installing 7" OverHead DVD Player
  195. Need Help installing 7" Overhead DVD Player
  196. greddy profec type s
  197. picking out an intake for my MR
  198. Evo 8 Car Alarm Central Locking
  199. modifying your stock antenna :)
  200. checking for boost leak
  201. Removing factory Infinity System
  202. Brake line and clutch line question
  203. Evo Cruise Control
  204. Actuated hood
  205. Installing CF A pillar Gauge Pod
  206. Remove my headliner....??
  207. help! loosin timing belt tensioner
  208. any one know how to replace the horn, or atleast know where its located under thehood
  209. Dropping Oil Pan?
  210. Ecu pinouts?
  211. DEI 451T relay
  212. greddy TT w/o harness
  213. How to Drill CF
  214. Need a How To: Check if wastegate is stuck open
  215. Evo 8 which wires to use for immoblizer cut ?
  216. HKS SSQV Install Qs
  217. How to.... EDFC
  218. Pro-1 Hks RS replica
  219. Speed Pulse
  220. how to build 10point roll cage thru dashboard
  221. **Hood pin question**
  222. HKS 272 cams installed *Wierd vibration
  223. how to remove stock shiftboot?
  224. How to: fix your broken downpipe o2 housing bolt
  225. Please Help Me Find Out Why This Hose Is Leaking
  226. x flash info
  227. Need Urgent Help !! ??
  228. cam install?
  229. Headlight motor questions
  230. Cam Timing
  231. How to remove evo front bumper?
  232. engine removal, please help.
  233. how do i find a boost leak
  234. Installing a downpipe
  235. Need help with Greddy TT
  236. Electrical Problem
  237. Which vacuum host to pick for boost
  238. Trunk lid/Deck lid install
  239. help on fuel/air gauge
  240. Removal of the upper dash.
  241. new cam install how-to?
  242. average maintenance cost
  243. Fixing broken front bumper
  244. Need Help MR gauge's install?
  245. Please help. STUCK replacing rotors...
  246. Forge Bov
  247. Wiring Diagram for SSL sub woofer
  248. Help with Mass air pipe and MBC
  249. How to black out the tail lights
  250. Question about The Turbo timer harness
