PDA
View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13
  1. Conversion of pull to push clutch
  2. 2006 ES Brake Light Switch
  3. Request: STM Overflow Tank
  4. Engine Removal.
  5. Help With Greddy Boost Controller
  6. Broken Bleeder Valve. Looking for suggestions.
  7. Which wires from AEM Inline Wideband tie into which OEM 02 Sensor wires?
  8. need help anyone rexspeed va style rear diffuser
  9. Dual fuel pump question (not what you think)
  10. Installing sunglasses holder / interior light into Evo IX. Help please
  11. Mustache Bar Bolts...
  12. brake caliper paint question?
  13. speedo moves faster then the car
  14. Accelerator cable replacement?
  15. Request: How to reinstall Ebrake
  16. 3000gt rear diff ?
  17. Have aftermarket alarm but want stock keyless to work...
  18. Escort Radar Hardwire Install Request
  19. How to Request : DIY Projector Fog Lights on Evo 8 headlights?
  20. Help 03 evo 8 ticking/lifters
  21. Spoiler bolts and nuts
  22. Stock or Aftermarket?
  23. O2 Sensor Question
  24. OmniPower MAP 3 Sensor Install
  25. Does anyone have an Injen Intake w/ Upper and Lower Intercooler Pipes?
  26. 2009 lancer gts amp install help
  27. Peeling Brembos on IX - will warranty cover it?
  28. Switch front seats
  29. Bov
  30. help w/ installing boost gauge
  31. Need help cleaning suede seats
  32. Spark plugs
  33. Boomba High Flow Fuel Rail
  34. Autometer oil pressure gauge removed?
  35. evo 8 tweeter wiring assistance!
  36. Big turbo!
  37. Can anyone help me with Rack & Pinion
  38. evo 8 help
  39. SES Light/ High Idle
  40. gsc cam install question
  41. 60k/water pump diy
  42. Speed Density Question
  43. HOW TO: install AN Fittings between catch can and valve cover
  44. 6266 VBand, Manifold Bolt help?
  45. how can i change my odometer cluster lights
  46. could use some help all over the place
  47. How do you tell if the Timing Belt has been changed?
  48. VIII in dash wire harness
  49. Could use some help?
  50. Any good online sites for performance parts?
  51. I just want to know how other owners take care of their Evo's.
  52. evo 8 nonacd into acd
  53. clutch help please!!
  54. Door hinge Compatible Mirage 99
  55. headliner scuff marks
  56. jmfab o2 dump question
  57. !!!!!!HVAC lights(bulbs) Come on only sometimes HELP!!!!!!
  58. how to: remove stuck dp spring bolts
  59. Request for DIY transfer case removal/ Install
  60. How to connect stock fuel level sensor to AIM MXL Strada dash
  61. How to for changing gauge cluster bulbs?
  62. Crank shaft position sensor?
  63. Turbo timer evo ix
  64. Reverse lights not working
  65. HOW TOO:TRANNY and everything around it install
  66. universal vacuum setup?
  67. Anyone know how to reprogram the keyless entry?
  68. How to: Installing JDM Plate Bracket with JDM hardware
  69. Paint code for touch up paint and best way to touch up.
  70. How to swap halogen headlights for HID headlights? HELP!
  71. timing problem
  72. how do i set up my new mitsubishi lancer evolution 8 for off-road rally racing?
  73. AEM Intake / Synchronic DV Fitment Issues
  74. Confused.
  75. How to "hellaflush" an Evo 8
  76. FP wastegate actuator question
  77. prosport Oil pressure gauge
  78. Camshaft install. Cam timing instructions
  79. prosport boost gauge install - Evo series
  80. rexpeed cf exhaust heat shield
  81. How to replace valve seals
  82. Removing serpentine belt tension with belt on
  83. How do I start a Conversion?? ):
  84. Planning on getting a 2006 evo mr:)
  85. Newbie Q : How to put leds on 2010 lancer headlights
  86. how to wire gauges?
  87. HELP How to take the plastic pieces out of the Recaro Seat headrest
  88. Wanted: Tips and how to remove antenna base.
  89. Need help asap evo noob!
  90. Wanted: How to radiator replacement
  91. How to install OEM exhaust manifold?
  92. How do I remove Stock Guage Cluster
  93. Evo 4 to Evo 8 Engine swap
  94. how to install ralliart cf shift panel
  95. HELP! Bolts are off JDM Rear bumper, but the sides wont come off!
  96. Need help selecting correct Spacers
  97. Rear Emblem Distance
  98. oil pressure and temp instal
  99. Need to remove windshield/roof molding
  100. AEM EUGO - white wire - Evo Scan ??
  101. How To: Installing STM oil cooler with new brackets
  102. Test Pipe Question
  103. OEM Front Bumper lip
  104. wanted: proper coilover/suspension setup
  105. how to put trunk springs back together
  106. how to: dreaded oxidation removal on headlights/taillights
  107. E-Brake or Parking Brake Handle Replacement
  108. IAT sensor wiring???
  109. cowl removal
  110. Spring install - Cut the bump stops?
  111. Blox front/bottom engine mount help!!!
  112. Request: How to powder coat a valve cover
  113. Has any one replaced there radiator?
  114. How to level car for Tcase fluid change/check
  115. How to remove the plastic around the steering column?
  116. Windscreen Washer Motor Fuse
  117. Replacing The Negative Battery Terminal Clamp - 2003 EVO 8
  118. how to trim c west bumper for larger fmic
  119. how to install ix non hid headlights in a stock hid viii
  120. How to install triple pillar pod?
  121. How to change your OEM cluster light to an aftermarket
  122. how to install speed denisty
  123. how do you pass California emmisions with a TBE?
  124. how to replace stock actuator evo 8
  125. Coils and strut
  126. How to Remove Fender?
  127. Evo 8 mr Speedo\Odometer problem
  128. evo 8 to 9 rear bumper question
  129. evo x clutch up in Seattle wa
  130. Headlight evo7\8\9, Do you know ?
  131. Underhood shifter bushings help!!!
  132. Removing the ACD, we know the ECU, PUMP, etc. But what else?
  133. Negative terminal clamp replacement
  134. Help in changing autometer COBALT bulbs
  135. LICP Help Please
  136. SAS removal guide, please
  137. need help installing window visors
  138. 3" downpipe with Flex pipe - Brand Unknown
  139. exedy twin to triple conversion assembly
  140. Evo 9 and Valve spring install
  141. Take a look at my inner rod tie
  142. remove knuckle from control arm
  143. OEM Ev0 8 front license plate mounting
  144. Those with Magnecor 8.5mm spark plug wires
  145. how to set tps?
  146. How do you install a new thermostat?
  147. Help! Steering wheel shaking NOT warped rotors
  148. Underhood bushing
  149. Evo 9 oem hid adjust
  150. shipping larger items?
  151. Tint removal issue
  152. how to install aftermarket hid kit for fogs and high beams
  153. Need help with flywheel removal
  154. Wet sanding headlight lense?
  155. Auto-Off headlight function does not turn on both headlights w/ HID Kit
  156. Need help, half of sunroof stuck in tilt
  157. Chris Fisher
  158. How-To: Rear parking brake assembly
  159. evo 9 gauge problem
  160. Stock Manifold Not Aligning to Stock Hotside :(
  161. Turbo coolant line removal?
  162. Repairing a Front Lip
  163. HKS Turbo Timer Type 1 on Evo8
  164. exedy twin disc question
  165. Another timing belt how to request...
  166. Need help: searching a a How-to wired an LED for the CEL knock warning.
  167. Change gauge cluster bulb help..
  168. Installed AMS underhood bushings 1st and 5th are ????
  169. Help with greedy bov piping instalation
  170. How to re assemble the fog light switch back together
  171. CF hood fading...any help??
  172. Removing sunroof cover?
  173. 4" intake pipe !!!!!
  174. Help with Beatrush Undertray Plz!!!
  175. Cusco Three Point Rear Brace install
  176. How much do you guys think I can sell this for?
  177. Cam install help!!!
  178. Quick Question: Prosport Gauges Connectors
  179. Help : Mini battery install - negative cable
  180. Help. Waterpump leak
  181. Help needed, how to turn off ACC lights
  182. question: how to remove cylinder head?
  183. REQUEST: How To Remove ACD ECU
  184. How to install Ebay special short throw?
  185. Blitz DC turbo timer with boost gauge feature
  186. Evo 10/ H11 Yellow Bulb 100W
  187. radiator hose problem
  188. Vacuum Hose Location, NEED HELP!!!
  189. Anyone knows how to take apart EVO 8 stock wing???
  190. Request: Titek Mod
  191. Anyone near or from the 559 area that knows a good tuner near by?
  192. Door Chime But No Key In Ignition
  193. Evo IX SE FRONT LIP INSTALL
  194. Request: Balance Shaft Install
  195. Re-seal Windshield
  196. How to bleed acd in EVO 8???
  197. EVO X Shift knob does it fit EVO 8's??
  198. Attempt at putting together a Coil on Plug how to
  199. LED parking light??
  200. Timing belt replacement question
  201. Diy cop
  202. How Do I remove the EVO 8 front bumper + tools needed??
  203. Spoiler was painted, can it be removed?
  204. How To: How do you open up the walbro FP to modify it?
  205. 03 evo VIII TT howto
  206. SRS light
  207. how to balance shaft removal ?
  208. Vortex Generator for IX
  209. Tips on Installing New Oil Filter Housing
  210. Where should I mount the o2 bung for an AEM UEGO?
  211. Headunit connector question for Evo IX 06
  212. Please help with caliper assembly!!!!
  213. How to remove the engine?
  214. hks racing suction intake install
  215. check engine for no cat?
  216. Any one know how to install LC-1?
  217. Where to attach for pulling engine?
  218. Trunk torsion bars
  219. How do you clean air vents and ducts
  220. strange noise =[
  221. AMS Small Battery Kit install "need help"
  222. evo 8 ssl sunroof issue
  223. Boost Leak Testing - How and Why
  224. Tie Rods
  225. Battery Relocate Cable Routing
  226. How to: tranny/xcase/rear diff fluid changes
  227. Help! manifold stud replacement
  228. E-VI fuel pump install "The hard way"
  229. How to install EBAY poly lip(with pics)
  230. How to: Installation of Vortex Generator on EVO IX
  231. Remove the Rear windshield?
  232. yokohoma s drive
  233. Evo VIII Ecu Pin Chart
  234. Installing Lip
  235. HOW TO: Timing Belt, Balancer Shaft Belt, and Accessory Belt Replacement
  236. VDO Gauge Install
  237. help with ETS 3.5 fmic on evo8
  238. question about hood...
  239. question about rear wing...
  240. How to reconnect windshield washer pump?
  241. Help!! Defi Link Display Installation
  242. Installing Ingall Dampner??
  243. Intercooler Install
  244. Trunk holes
  245. boost guage, oil pressure, and fuel pressure install?
  246. Caliper Piston Stuck, Tried Everything - Can Anyone Help?
  247. Evo 8 cruise control installation
  248. Rexpeed Carbon fiber lip sides and rear
  249. AEM wideband install
  250. BR Underhood metal bushing install
