PDA
View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13
  1. HID conversion kit Fog Lights 3000K
  2. can u make cwest canards fit the stock evo bumper?
  3. What's the size for the Greddy shift knob to fit on the Authority short shifter?
  4. Defi-D gauge off
  5. BOOST/AIR FUEL/OIL TEMP quick question
  6. How to clean a O2 sensor
  7. clutch install parts
  8. Rear Bumper Removal
  9. help installing clutch
  10. How to Replace lancer "gauge" with omori 45mm boost gauge
  11. help installing apexi cone filter
  12. Aftermarket "MR" gauges?
  13. I need help removing the top portion of the rear seats
  14. DEFI where do i tap these wires????
  15. Setting up the Apex'i AVC-R
  16. Oil Temp/Pressure Sender Install
  17. adjust throttle cable
  18. How To: Install a Zeitronix Wideband
  19. Carbon Fiber Hood
  20. HELP!!!!!!!! I'm an IDIOT!!!!!!!!
  21. How To: Fog Lights ANYTIME
  22. Megan Racing 02 Housing, How Hard To Install?
  23. Need Help for a friend installing AEM trueboost gauge\controller.....
  24. Turbo Timer Install Help
  25. climate control relocation
  26. Help! Front Right Control arm install..
  27. How To Post a Write up
  28. tein lowering springs....
  29. Please help Im hidious.....
  30. ? For those with the Rexspeed Triple Dash Pod...
  31. '06 RS low beam upgrade headache......
  32. How to Install Power Locks on a RS
  33. Install help for a Greddy Profec-B spec
  34. exhaust manifold.....
  35. intake manifold..problem.
  36. hks grounding kit
  37. license plate holes
  38. How to install a nipple on an Aftermarket LICP. Fixes Low boost flutter of BOV
  39. How To: Make Fog Lights funtional WITH PARKING LIGHTS
  40. Fog Lights
  41. A-Pillar Drilling
  42. How to Dissemble Evo Wing??
  43. need dyi turbonetics mbc install
  44. Glove Box
  45. Help! GL-4 fluid from Mitsubishi
  46. Need Help W/hid Adjustment Motor
  47. Power Enterprise Wiring Help....
  48. How to Install Headlight Protection Film
  49. How-to Perrin 25mm rear swaybar & stout mounts
  50. Blacked out taillights
  51. Clutch Install
  52. any mod to make the 4 corner jackpoint stronger?
  53. Speedometer
  54. HKS filter maitnance
  55. ams vsr intake manifold
  56. cutting out the tri-angle in bumber (8)
  57. Is it possible for an ordinary owner to change TC/tranny fluid?
  58. T-Case removal.
  59. how to hook up greddy TT?/
  60. (Request) How to setup max boost using MBC
  61. Power Enterprise Boost Gauge/controller Installation Diagrams, Color Codes.
  62. EVO IX ECU pin chart
  63. Lock/Unlock Wire color at door
  64. Boost Controller Installed Incorrectly?
  65. turbo timer type 0
  66. Anyone done washer mod on evo headlights?
  67. electrical problem?
  68. Swift Spring Install How-To?
  69. Diy Licp?
  70. help. dash lights out.
  71. apexi super ground system mounting spots
  72. How to remove OEM o2/Downpipe Donut Gasket?
  73. how to install a front engine mount
  74. how to check if crankshaft sensor is bad?
  75. Gauge Options
  76. I need some help
  77. NEW HKS EVC wiring troubleshoot help.
  78. Tc.....
  79. 02 Housing Install w/pics
  80. plug the o2 hole
  81. A-pillar/stock gauge info-help
  82. Torque specs on exhaust bolts
  83. lowering springs???
  84. Help Help, cant get this right
  85. COOLINGMIST METH KIT evo people who have it and i need a experianced installer
  86. HKS Chrono gauges - How to Use??
  87. How To: Install DC3 Catch Can
  88. How To: Install DC3 Catch Can
  89. How To: Install DC3 Catch Can
  90. Help finding a thread - dashboard gauge install
  91. Help: Retarded Oil Pressure Gauge Install
  92. fuel pump install
  93. Cam position sensor housing leak/sealant.
  94. HELP! Car won't start
  95. NEED HELP WITH HID's
  96. Replace/Change/Mod EVO Horn
  97. Car in shambles due to DP...
  98. engine harness removal?
  99. HID bulb replacement
  100. install for connecting rod bolts??????
  101. pulling the drivetrain
  102. Defi Control Unit Install Help!
  103. Installing Beatrush Propeller Shaft Bushings In your Garage
  104. Greddy TT
  105. Where to mount turbo pressure gauge on a EVO VI TME
  106. Rear differential Pic request
  107. is there any way??
  108. Water Temperature Sensor Adapter
  109. JDM EVO MR headlights into US EVO MR
  110. Anyone know how to disassemble stock gauges????
  111. AEM Tru-Boost Tuning Question
  112. How to replace front o2 sensor
  113. Need help With EVO9 9006 bulb replace
  114. Removing B-Pillars And Rear pillars
  115. Simple Question for those who have installed a Gauge
  116. Exhaust Manifold "Stud" Removal
  117. Passenger side window replacement
  118. need help taking out side mirrors
  119. tanabe teas installation?
  120. how do you rewire to keep the foglights on with the lows?
  121. How To: In-Car Valve Spring and Retainer Install
  122. AMS upper intercooler pipe kit
  123. Installing street-legal 4-point harnesses in the Evo (Schroth)
  124. Installing a Beatrush Aluminum Under Panel
  125. Magnecor (or Ralliart) Spark Plug Wires
  126. ok i need some help with an auto meter gauge
  127. how to remove the paint on the hood vent?
  128. How do i get through the dang firewall...
  129. HKS Turbo Timer Type-0 installed but..
  130. How To Remove Wing? Can someone Teach Me?
  131. o2 wire..?
  132. o2 wire..?
  133. Evo VII standard fuelpump size (diameter and length)
  134. Fuse Removal For Radio/Dome Light Help!
  135. how to disable seatbelt beeper sound
  136. How to take off the frozen bolts
  137. Guage Problems
  138. EVO 9 MR HID ballast/ bulb install help..
  139. Window air deflector install tips?
  140. NEW SUBWOOFER BOX IDEA. small size, light weight, and good sound
  141. Safc Ii
  142. head unit
  143. 5th point location with race harness?
  144. Where is a safe place to Jack up your evo9MR
  145. any wiring gurus here?
  146. BC Racing coilover install, BR series
  147. Cheap Mitsu Wheel Studs
  148. evo 9 gauge panel schematics?
  149. Question about painting headlights?
  150. One touch close sunroof mod
  151. How to modify your stock "lancer" gauge to accept useful gauges
  152. How to remove ECU
  153. how can i revert back to stock settings?
  154. Help jdm evo 7 tail install
  155. Clutch fork direction??
  156. Seibon Carbon Fiber trunk on Evo 9 MR
  157. Routing Line for Meth
  158. MBC Tie-In Point
  159. VEI Triple-Gauge Install - boost, AFR, oil pressure
  160. Evo IX Front Bumper Removal
  161. Painting Rims? how to?
  162. Turbo-XS RFL Ti catback install question...
  163. Fuel Pump Install Problem!
  164. Cleaning the throttle body
  165. looking to replace defective turbo coolant line
  166. How to remove sound damping material in a non RS?
  167. Omori guage install???
  168. How to : repainting Brembo brake calipers?
  169. Intercooler piping hitting Fan
  170. How To Install Seibon OEM CF Hood?
  171. Is there a howto for hiding wires in the motor bay
  172. GT35 turbo ...intake..MAF... help/ questions
  173. ...hope this is the right place to post
  174. Helix V2 down pipe install problem
  175. Question on installing aftermarket tail lights....
  176. How To Adjust Camber Front & Rear
  177. Need help removing front axle...
  178. How To- Install SAFC2 into Sun Glass Console
  179. Smog Help in California
  180. 03'/05' Evo exhaust swap?
  181. Greddy Turbo Timer and Remote lock failure
  182. boost
  183. crank angle sensor
  184. How to install a flip-down DVD screen for rear seats?
  185. stock wastegate
  186. Relocating HVAC
  187. forge bov
  188. Major Issue Of Evo? Someone Help Me Out!!
  189. greddy profec spec 2
  190. Gas door question.
  191. Ideas for weight reduction with full interior
  192. oem boost solenoid
  193. Anyone know how to get grease and tar off of underbody?
  194. Door panel removal and speaker installation
  195. need help with shifer light
  196. fUSE ?
  197. need help(auto gear oil)
  198. foglight question.
  199. ATF SP 3-how to change gear iol for auto evo(evo 7 GT-A)
  200. ? APR EVO 8 Carbon Fiber Front Splitter
  201. i need electrical help!!!
  202. Need help with gauge install(wiring)
  203. How To: Protect Your Intercooler
  204. Removing/Installing front lip on Evo IX
  205. exhuast install help?
  206. Mechanical 02 fix...
  207. JDM Headlight Install
  208. Help w door Panel Scratches
  209. How difficult is it to change the accessory belt and radiator hoses?
  210. help with perrin mbc intall
  211. LC-1 owners where do you mount the controller
  212. Autometer Air/Fuel gauge
  213. How to : Install HKS SSQ BOV Recirculation Kit
  214. YARIT: Yet another red interior thread
  215. Replacing headunit of a 2003 Lancer
  216. Brake Rotor Swap
  217. Will the CEL light affect performance?
  218. How to Remove Alternator
  219. 30,000 Major Service
  220. Defi Control Unit Warning Mode Help
  221. how to remove 3rd brake light cover
  222. How to pull the motor
  223. Help installing RALLIART CF center consol
  224. Sun hyper force ignition?
  225. Removing rear o2 sensor on Evo IX
  226. Lost Wheel Lock Nut
  227. Blinder M-20 Laser Jammer Install
  228. fog lights on with run lights
  229. APR GT3 Mirror Install
  230. Need pin chart for Evo IX
  231. stock head stud removal tool?
  232. Best way to remove paint from wheels??
  233. Need help installing APR cf mirrors
  234. How to: HorsePower Freaks 2.5" LICP install*Pics
  235. Radiator fluid chang?
  236. Living in Seattle WA, where do I take my car?
  237. Help:
  238. Performance orientated battery relocation, amplifier and subwoofer install
  239. Help Misfiring
  240. How do you tighten front bumper to get rid of gap between headlights?
  241. HID install
  242. 2003 Eclipse Clutch Install. trying to help friend.
  243. How To: Properly Bed your Brake Pads
  244. O2 Housing and Exhaust Manifold Replacement DIY Request
  245. Crank Pulley Problem
  246. ignition install problems
  247. take out back seats
  248. Perrin boost tube help
  249. RRE oil catch can install and PCV valve delete
  250. Clutch Cable Install
