- Help! 255 in starting out.
- help!!! installing blitz dtt dcII
- How do you install canards?
- Timing Belt Install Guide? Please!!!
- HELP, installing Turbo Timer
- sparco harness bar added installation details
- Question- How long it take s to install the clutch
- Turbo Timer Issue Little help please =)
- Help with spark plug wire change out
- Request: Cams?
- Mitsubishi CAPS - how/where to get?
- More Alarm Wire Q's
- Belt Tensioner for cams?
- Perrin fuel rail install question
- Why Is my Turbo Timer not Working?!?!
- Dome Light Wire
- glowing manifold supposed to happen? mbc install
- DIY exterior/interior fabrication questions
- Blacked out Tail lights..
- Sparco Harness bar Question
- Buschur racing MBC pics please...
- EVO Fuel pump install?
- Need help on carbon hood?
- greddy type s BOV for 05 evo
- Rear bumper removal?
- What did I remove? PICS included HELP!
- Install tools
- o2 housing problems
- splicing / electrical question..
- More on Valentine 1 hardwire....
- Need Help With Install
- HKS Exhaust ti question
- Those with Joe P. MBC...help
- Apexi TT question
- how much it cost.....???
- NEED HELP!!! Front LIC Plate Bracket Install
- HELP! How do I adjust the hood latch? My new CF hood is loose...
- Stero install, HELP!!!
- jdm mr headlights problem
- Buschur O2 install (alternative method) qith pics
- O2 housing
- REQUEST: DEFI-D Air/Fuel Gauge Installation
- Front sway bar , Removing .
- Bulb guide for headlight modders: helpful links
- Defi oil pressure gauge..do I need anything else?
- 02 Sensor Problems
- $2500 to spend what to do next
- Turbo XS Exhaust Question !!?
- alarm/ turbo timer diagram(been away from the forums)
- Boost Guage Question
- Hks Eids Wiring
- Idle Question
- HKS Circle Earth Grounding kit for Evo - need help
- what did your walbro fuel pump come with, exactly?
- exhaust hanging
- CF Rear bumper Guard
- cabin filter size ?
- How to remove / replace your spark plugs
- Lower damper removal
- Carbon Fiber Engine Shroud
- set up boost control
- Part # Question
- Fog lights on with just parking lights?!?
- Greddy Type S VTA BOV problems
- advan tires weight?
- o2 sim install ??
- done modding, need help with the tune
- How To: Change your Brake lines
- Req: Brake Disc, Brake Pads, SS Line Install Howto
- Need pictures of ecu wiring with color wires/diagram
- Help with Greddy Turbo Timers
- Question on Sparco 4-pt Harness Install
- radiator install write up wanted
- How to Greddy Type-S Single Spring Mod
- Helix IC Pipe kit Install
- quick help!!!
- Brake pad tutorial
- intake intall
- How to install a Three Speed Scatter Shield
- How to: install injectors!
- Head unit wiring question
- Clutch disk thickness?
- Sparco 4 point harness install
- Need your clutch changed - contact me
- Apexi TT and HKS harness
- SS clutch line/restrictor pill?
- How do you remove steering wheel column cover?
- Request: How to install the passport zr3 laser jammer
- walbro 255 fuel pump install
- Evo spoiler
- Help my lights went out !
- just installed a K&N drop in filter
- HKS Type 1 install question.
- Another radio relocation kit question
- Installation of 10.5 hotside
- MR stereo wiring
- Knock Link Install Instructions
- greddy ful auto timer instructions
- How to install the spark plug anti-foulers to remove the ses or cel light
- Somewhat of an HKS RS intake installation
- how do you get rid of the rattling in the b-pillar?
- Air/Fuel Gauge Problems
- How to Install Hallman EVo RX PRO
- AutoMeter Triple-pod A-Pillar question(s)
- avic n1 into my 2003 lancer evo
- how do i remove driver side mirror?
- Clutch disable??
- Part number ...from Evo MR
- Draining intercooler spray reservoir?
- How to build an FQ-320?
- BLITZ FAT DCII installation wiring diagram
- restrictor pills???
- Ipod intergration with factory headunit?
- will this short shifter fit my car
- Anyone Replaced an Axle seal yet on their EVO?
- hallman mbc question
- spark plugs
- where is the ecu on evo ????
- hot to se Hallman MBC! please help!!!
- Installation of Blow off Valve
- removing stock header.. question
- MR Vortex Generator - Installed
- how to avoid frustration installing Blitz DTT
- remove stock air box
- painting my engine block's valve cover
- Need help to install Water Tempature Gauge sender
- How to Make Your Factory Console Gauges RED
- need help!!!short shifter kit
- Defi Link unit install question
- Add Foglight to RS?
- Anyone know how to adjust the clutch peddle??
- radio faceplate console thing..
- clutch line bleed - confused
- How to paint the stock enkies?
- Fuel Pressure Sensor Install
- Tein Flex coilover install (ProStreetOnline.com)
- Blitz Fatt Turbo Timer
- Evo Factory Subwoofer
- HKS Timer Type 0 – RPM Connection
- some make write up on sidemarkers
- how to remove storage bin below HVAC??
- MR Headlight installation
- Install how to on Sports Meter Kit
- exhaust question
- apexi TT
- Where does the intercooler sprayer hose plug into?
- Lower Intercooler Pipe install
- Factory Gauge Package
- Need O2 sensor housing!!
- HKS SSQV problem!!!!!........spring not the right one for evo 8?
- Anybody put a remote start on a manual
- ARC heatshield install?
- Disable A/C on with Defrost?
- Avic - N1 color changes
- "How To" Intall HKS SSQV Blow Off Valve!
- different oil pressure sender info...
- Disable '05 EVO 5000 RPM launch limit
- HELP!!!! need info on how to tune HKS SSQV properly
- "How To" Intall Nology Hotwire In 17 Easy Steps!!
- Electronic Boost Controller
- Rear O2 sensor ???
- Spark Plug question...!
- Momo steering wheel Help
- AEM Digital Ignition Module
- Oil Pressure and Temp Gauge Install
- Mitsubishi brake air guide install
- Kartboy Shift Linkage Bushing Install
- How to tell, boost leak
- Clear Bra Paint Protection film Install
- Where are the underhood bushings located.
- AC temperature extremely hard to turn.
- how to take off the side mirrosr?
- cf wing on cf trunk
- Installing aftermaket intake, is it necessary to get an S-AFC for tuning?
- Momo Tuning Pedals
- Purchased a 05' Evo MR, Seeking Advice for Upgrades, tryed and true!
- Black Out Headlight Materials
- Urgent: How to remove hood windshield sprayer?
- How do you set up the Hks Evc V
- ?setting greddy profec bII bc help???
- Reading 16 psi on autometer boost guage
- Installing front sensors for laser jammer sensors???
- How To Install A Blitz SUS Power Intake..?!?!
- Painting Springs Question?
- Remove the back seats... ???
- Using a Fuel Pressure Regulator for Injectors and Pump??
- Seat Help.................please
- Help with Defi link install
- hose sleeving kti help
- question about my BR exhaust
- If you have an Autometer EGT... please read (or any egt with a long probe)
- NOS, BOV, Catback Question?
- Idea for Gauges
- How to Swap Radio with Gauge Panel
- How to make your wing all-CF
- Make A How-To on the FULL Carbon Wing!
- Problem with EGT install
- Apexi Timer
- Bushur FMIC install
- Trany thowr out bearing help
- 02 Housing install
- First MR owner with a stupid question
- How-To: T-Sport Rev-Lite shift light install
- Shifter Base Bushing Install
- IC Sprayer Reconnect?
- which gauge is more reliable?
- HKS Cam Gears adjustment
- How do you remove the A-Pillar?
- Help-Torque Specs For Downpipe Spring Bolts
- HKS TT Type 1 problems
- Keyless Remote Programming
- EGT Gauge Question
- Cold Air Intake Pipe Install & Intercooler Tank Relocation
- A good cat??
- Intake Pics??
- Help installing Autometer boost on Evo 5
- Removing cd player
- Sport Meter Kit relocation?
- Serpentine Belt removal and installation
- EGT Sensor install question
- Trouble with heater controls?
- Rear Bumper Removal
- Question about installing the Buschur Mass Air Pipe..
- Instrument Cluster Problem
- Nifty brake cooling ducts
- AEM UEGO install w/EMS...suggestions..
- Fuel injector Install
- shift light help
- has anyone painted their tail lenses red from the INside?
- OEM Evo Fluids and Redline too!
- Evo headlight blackout
- Need Help ! Stock Recaro Bracket?
- How-to: AEM CDI Install (pics)
- removeing one or two mufflers
- Fuel pump install question? Please respond ASAP!
- Tip: Stop the beeping alert to fasten seatbelt
- Defi Oil pressure and EGT gauge help needed
- Help! I need to know how to remove door panel?
- greddy turbo timer questions?
- DIY Better adjustable stock BOV!! Free mod!
- Very fast click click click sound after Boost Gauge Install
- Self maintenance
- Install a pass-through for the rear seats on Evo VIII?
- Squeaky sound.
- Gear Oil Pump?
- EGT Probe and Water Temp Wiring
- To those with helix down pipe..
- Bolsen's Guage cluster light mod ROCKS!
- Dual Bypass Oil Filter install on an Evo
