PDA
View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13]
  1. Circle earthing hyper ground
  2. elec. boost contr. settings help
  3. EGT Gauge probe??
  4. HKS Type 1 help???
  5. stock boost levels and where you Tee for pressure source
  6. Mitsu P003 Radio
  7. Remove Rear armrest fabric piece
  8. Clutch install PICS!!!!
  9. Cusco rear strut bar installation question
  10. Do it yourself intake?????
  11. Question about Greddy Type S
  12. where else can you install an oil temp sender?
  13. computer and resurculating blow off valve
  14. Black Housing Headlights ... How To Write Up~
  15. Firewall Pass-thru
  16. Amber HVAC bulbs
  17. removings the panels of the car
  18. Defi Boost Gauge Mounting
  19. Stereo wiring
  20. How the hell...
  21. autometer mech .boost gauge, help!
  22. spark plugs
  23. Wastegate by-pass
  24. Greddy Boost Gauge
  25. Need help with coil overs
  26. Vishnu cam gears
  27. Underside of throttle pedal
  28. Installing coil overs tomorrow
  29. Radio UNINSTALL....
  30. install-MBC
  31. need stuff done look here
  32. Header/Intake UN-engrish instructions.
  33. RMR 6 puck
  34. Help installing Samco radiator hose kit
  35. HKS Carbon-Ti Exhaust and AEM Short Ram Intake - questions
  36. Designing Gauges from Scratch
  37. S-AFC new users guide
  38. Greddy Turbo Timer ground wire?
  39. Definitive Guide: installing euro
  40. Exhaust gaskets question
  41. HKS Type I TT stutter...
  42. Hks Turbo Timer Type 0
  43. Having trouble with glove box
  44. Help! need to disconnect battery but sockets are with friend
  45. Hks Install??? Please help...
  46. SAFC II 94 octane settings
  47. help locating a fuse
  48. Problem after batt. relocation
  49. ? for the guys with the DIN panel gauges installed
  50. Do Not Install Ignition Harness From Emanage On Your Evo
  51. please help throw out bearing ?
  52. How to Install Aftermarket Seats
  53. B&M short shifter
  54. Deck install Question for the EVO
  55. Blitz DTT DCII Help!
  56. Evo Motorsports Tech articles
  57. Rally Strut Install
  58. o2 simulator
  59. Best results polishing stainless?
  60. Greddy harness for Turbo Timer install
  61. Front Sway Bar Install
  62. Upper intercooler pipe ideas?
  63. How To: Valentine 1 hardwire procedure
  64. Air/fuel gauge install
  65. B&B Downpipe question
  66. Cusco Oil Catch Can, HKS Racing Suction, and Custom Ground Kit Pix
  67. Debadging
  68. Tach Lead On A Shift Light
  69. Turboback installation opinion
  70. The needle on my boost gauge fell off!!!
  71. how too greddy tt
  72. Additional boost gauge
  73. how do you wire boost guage for power and ground?
  74. Gauge, vacuum hose....goes through where??
  75. Cusco oil catch can install pics
  76. Exedy Twin Disc??
  77. DEFI BF gages installed
  78. Coil Over install anybody??
  79. Instrument Cluster Needles
  80. Quick exhaust question...
  81. Seat and armrest cleaning.
  82. S-AFC II problem with throttle percentages
  83. Need Help Installing Tachometer
  84. P-Hybrid Power Boost Controller Help
  85. Help!!!! Clutch dead!
  86. HKS SSQ install help
  87. Service manual
  88. Stereo relocation instructions
  89. Boost Guage Install
  90. SS clutch line install... please post
  91. Evo 8 oil change
  92. SWAY BAR INSTALL? Need help
  93. K&N oil filter
  94. Fuel Cutoff?
  95. Buschar air filter
  96. Stealth Airbox Mod
  97. Setting front toe
  98. HKS Super Sequential Blow-off Valve Installed!!!
  99. Help plz
  100. EMERGENCY please help!
  101. E-manage Ignition/Injector install for EVO 8
  102. Custom Intercooler Screen
  103. help with CAI install
  104. installed "jdm" antenna
  105. HKS Type 0 TT
  106. Help Help
  107. AEM Intake and HKS SSQ installs
  108. Good prices on EVO rear bumper
  109. Evo VIII badges
  110. Perrin O2 simulator trouble
  111. how to remove front bumper?
  112. Removing the steering wheel column
  113. Heat Extraction
  114. Need Rim Help Fast!
  115. Article on Evo Box removal please!!!
  116. seemingly stupid question about running wires (dash/headliner)
  117. Does Anyone Have a Turbo XS RFL BOV?
  118. How do I remove the CD player
  119. another exhaust question...
  120. Car hesitating from 3-5k RPM under full boost
  121. Nova 200 Le Alarm
  122. question about exhaust installation
  123. Blow-off Valve and Boost Controller?
  124. installing air/fuel gauge
  125. built DIY grounding kits
  126. Location of high note horn?
  127. Blitz DTT contrast adjustment
  128. GREDDY TYPE S BLOW OFF VALVE, troubleshooting
  129. someone help with clutch install please!
  130. ok how do i change the clutch line
  131. adjusting headlights?
  132. Need help for HKS SAFR installation,Airflow meter type ??
  133. Evo Airbox Removal/Alert
  134. How to protect and detail your EVO inside and out.....
  135. Perrin Oil Catch Can Installation
  136. DEI 700T Alarm Installation Instructions
  137. Evo Driveline Fluid Change w/semi-useful pics (long)
  138. turbo timer with aftermarket alarm problem
  139. clutch install(how to get transfer case off without breaking anything)
  140. Turbo XS Dual Stage Boost Controller
  141. Evo Lighting
  142. boost solenoid
  143. Can someone SoCal help me with hole in firewall?
  144. manual boost controller install help
  145. JDM tailight install???
  146. Boost Gauge installers in So. Cal?
  147. Defi BF boost gauge HELP!
  148. EGT Installation (yes I already searched)
  149. How to connect an A/F gauge on EVO?
  150. What wires to tap for A/F Gauge install
  151. HKS Turbo Timer Type-1 install help
  152. Auto Timer install help
  153. Alarm Bypass???
  154. What to use to tune for HKA AFR?
  155. how do you get the mirror cover off?
  156. Turbo Timer Harness
  157. Help with Autometer Ultra Lite Boost Gauge
  158. rubber blocks holding front springs
  159. GReddy Turbo Timer install guide
  160. How to change gauge color from red to blue???
  161. How to remove front bumper?
  162. valentine one install
  163. Has anyone taken out the clock yet???
  164. Evo8 Alarm install...help
  165. importance of vacuum indicator in BOOST Gauge?
  166. grounding kit
  167. Hood vent removal
  168. How many hours to install?
  169. HELP!~ Greedy Turbo Timer w/ Harness
  170. Instrument Cluster Surround
  171. Links to cam install instructions?
  172. In dash changer/gauge install ?
  173. Apex-I AVC-R Install W/Pics
  174. Greddy Profec e-01 install help please!
  175. Anyone In LA have done the grounding kits?
  176. Downpipe install?
  177. Accurate AFC Install neede. Tried search
  178. Apexi tt wire hook up w/ pics
  179. How to install ralliart pedals
  180. DIY Ground Kit for $20
  181. Evo ECU Removal
  182. oil/ air fuel install pics
  183. Evo 8 e-manage install v-faq
  184. Japanese Instruction Translation
  185. Greddy turbo timer
  186. Air/Fuel Gauge Install
  187. Install: Perrin Short Shifter (pics)
  188. HKS Cams Install
  189. Removing the stock emblem...
  190. Revised JIC EXHaust Install (RMR and Perrin as well..)
  191. Few questions about Blitz TT install
  192. Turbo XS RFL Install
  193. apex-i AVC-R install
  194. Perrin short shifer pics?
  195. Sparco Pedals
  196. How-to: RMR Downpipe and Brace install
  197. A'PEXi auto timer install
  198. Smoked evo tail lights
  199. HU decoy??
  200. Lineage Ground Wire Kit
  201. Manual Boost Controller Install
  202. oil pressure gauge/air Fuel gauge
  203. How to remove the Evo A-Pillar?
  204. Grounding Kit Installation
  205. ground wire kit
  206. WRX WALBRO fuel pump install into EVO - easy
  207. Tranny flush and fluid change
  208. Anybody with an HKS TT Type 1 can help me?
  209. Somebody answer this quickly please
  210. B&M Short Shifter install ++++
  211. How To - Use Toluene to boost your octane
  212. HKS Type 1 Install w/HKS harness...
  213. Blitz SBC-iD EBC install!!!!!
  214. Lightweight battery install on EVO VIII
  215. Will cold air induction kit improve the bogging?
  216. 2 New Steps to Project Vivid EVO Added!!!
  217. How To Relocate The Sports Meter Kit/Replace Factory Stereo
  218. Brake pad installation directions?
  219. How to change stock radio backlight color
  220. oil changes
  221. How to change climate control backlight color
  222. Tons Of EVO Installs and Reviews
  223. Simple front camber increase
  224. Boost Gauge Install
  225. Hardwire V1 to sunroof/lights?Has
  226. Buschur Exhaust Install on EVO VIII
  227. HKS SSQV blow-off valve install documented!
  228. Clutch job on my Evo 5...Same as in 4 & 6
