PDA
View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13
  1. HKS Installation
  2. Make your front sway bar adjustable.
  3. Fuel Pressure Regulator Install
  4. How to move the radio down
  5. Help with cam install pointers!!!
  6. safc 2 setup
  7. Anyone installed a trunk net?
  8. Solo S2 Hardwire
  9. blitz power meter install
  10. Painting Headlight housing black
  11. Taking off Exhaust Manifold
  12. Safc 2 install
  13. Trunk solenoid
  14. MBC users PLEASE help
  15. Sports Meter Kit and additional boost gauge?
  16. Interior Lighting
  17. how do you install stiffer bushings?
  18. ARP Head Stud Torque Setting???
  19. How do u install a downpipe?
  20. Installation of Blitz DTT DC
  21. MBC install/concerns
  22. Greddy Profec B Spec II
  23. Front Swaybar Install
  24. installing greddy profec b spec 2
  25. Alpine headunit install, lined up?
  26. How-To: Schroth AutoControl Harness Belt Installation
  27. Post HKS EVC V instructions
  28. installation of Defi BF and controller2
  29. jacking
  30. Make your own oil catch!
  31. Clutch install write-up
  32. Water temperature sensor?
  33. How do you install the APEXI super AVC-R?
  34. afr quesiton
  35. Few notes on clutch line install
  36. Installing a push START button on the EVO
  37. programming ignition key
  38. Perrin Crank Pully Install help
  39. Clutch Install
  40. Fuel Rail Leaking Gas.
  41. How to wire/secure Autometer boost gauge
  42. Official Mitsu Hyperground installation scans
  43. Safest way to put Evo on jackstands?
  44. defi d boost gauge install pics?
  45. Trunk pop solenoid install pictures
  46. Autometer Boost Gauge
  47. 02 simulator
  48. Check Engine Light Need Help?
  49. Exhaust install - O2 sensor bolt hard as hell
  50. How to Fiberglass a Sub Box
  51. Greddy Boost Gauge Install
  52. Smoked Tail Lights
  53. boost gauge removal ?
  54. Proper Boost Adjustment
  55. Any link to cam install instructions?
  56. instalation notes on ss clutch line?
  57. Where to Attach HKS BOV?
  58. How remove bumper and install HID bulbs!
  59. ARP head stud install,no cam removal
  60. has any one done this yet??
  61. 60mm Gauge in 52mm Opening?
  62. Request: radiator removal
  63. Engine Start button install
  64. front brakes
  65. how to install perrin o2 elim
  66. rmr dp and rmr testpipe
  67. Battery Relocation pics
  68. 5zigen exhaust install
  69. DIY on changing the dash color?!?!?
  70. Easy Wing removal
  71. Help.... Only 10psi max boost.
  72. Fuel Injector Installation
  73. ticking after cam install
  74. Passenger A-pillar removal
  75. Not Removing Exhaust Manifold when Installing EGT Probe
  76. EVO 7 Headlight Fog Light?
  77. Whats the Best way for HP break in?
  78. rmr intake install
  79. How to 2wd dyno an EVO
  80. AEM intake install question
  81. Badge removal / installation
  82. Profec E-01 install help.
  83. HKS Downpipe help
  84. Turbo Timer help~!
  85. For those of you who own a Forge Recirc BOV
  86. forge fluttering
  87. Evo all time running fog lights??
  88. HKS A/F Knock Monitor Install Instructions
  89. Installing S-tech springs...question on bump stop cutting?
  90. Need recommedation for good installer
  91. Muffler flap removal
  92. buschur intake install.. HELP!!
  93. Major Problem! turbo timer + anti lock help plz.......
  94. OMORI boost gauge question
  95. Column mounted boost gauge question
  96. Kartboy Shortshifter install how-to
  97. Boost gauge install : TWO ways ?????????
  98. Defi controlunit/boost gauge
  99. Anyone have a writeup on ARP head studs Install?
  100. pillars
  101. Bulb Holders?
  102. Modding the recir. button to stay on until pressed?
  103. egt readings (help)
  104. How do I install my gauges
  105. stock boost gauge connections ?
  106. Cusco Rear Strut Bar into 03 Evolution
  107. Apexi Super Itc Installation
  108. Vivid Racing Fuel Rail install!
  109. Blinker Cancellation...anyone know how it works?
  110. Radio wiring harness information for you gurus
  111. Carbon Fiber Engine Plug Cover Install?
  112. RSR Ti2000 Spring Install
  113. 5 Point Harness
  114. can mech. boost guage tap into vac. line on profec b 2?
  115. For those of you with a-pillar mounted gauges
  116. timing adjustment
  117. Power door lock wires - Alarm install
  118. Spark Plug Wire install procedure
  119. Idle problems
  120. Head and Tail Light mod help!!
  121. Diy Page
  122. Power for Autometer Boost Gauge
  123. Walboro Fuel Pump Install EVO
  124. Timing Belt Tool
  125. Help: How to fully remove back seat?
  126. How To Tune Your Greddy Profec B spec II
  127. ARP Head Stud Install
  128. Is this how I should install my MBC?
  129. help just installed hks evc IV
  130. Just installed HKS Boost controller Type-1
  131. question about blitz turbo timer harness for evo?
  132. Straightning Steering Wheel
  133. help w/ bottle mounting
  134. JIC exhaust install
  135. Lancershop Intake problems?
  136. Red Clock How To !!!
  137. Greddy Eclipse Airinx on Evo?
  138. O2 Sim
  139. Oil Temp Gauge Help!!
  140. how to utilize top part of stock air box
  141. Oil Cooler
  142. Need help with Greddy Type S
  143. boost gauge: can sending units from a different mftr be used?
  144. AEM Short Ram Installation
  145. HKS Hi Power exhaust
  146. Start Boost and Gain setting help?
  147. Need help with Carbontrix A pillar!
  148. Useful Info
  149. does any one know any good sights where i can get clutch install instruc
  150. Add a circuit- very cool.
  151. please help!!!!
  152. Greddy Profec B spec II settings
  153. How do I install my new dual a-pillar?
  154. How can I reset ENGINE SERVICE LIGHT
  155. defi boost gauge, please help
  156. AMS Exhaust
  157. Loud stock BOV?
  158. side markers removal?
  159. short shifter install
  160. Developing custom FMIC
  161. EVO V front fog light bulb change
  162. greddy catch can w/out moving battery?
  163. General maintenance question
  164. Adjustable Cam Gears
  165. Crankshaft TDC (EVO)
  166. fmic install, front bumper help
  167. Serve engine light keeps coming on
  168. Installing UR Test pipe without hacking o2 sensor wires.
  169. DTT install question
  170. Removal of front fender panel
  171. WTD: Evo 1 wiring diagram
  172. Turbo timer/removing panels
  173. EGT installation
  174. Question about Radio relocation
  175. How to empty the radiator?
  176. How to upgrade my HID to 8600k?
  177. How to Replace HKS BOV with Stock
  178. How do u tune a BOV??
  179. Does anyone know why??
  180. Best mounting cup for boost gauge?
  181. How to take off the front lip?
  182. clutch restrictor removal
  183. Help on hadwiring a Valentine 1 RD.
  184. How to swap out altezzas for JDM VII's?
  185. Rear Diff fluid change
  186. Cusco rear trunk bar
  187. EXTRA Samco Hose ?!?!
  188. s-afc with dyno flash
  189. I have no idea how to take off the air box
  190. Anyone drop in 6X9s in rear deck???
  191. How to turn up boost w/ Buschur MBC?
  192. How to install Greddy Profec-B spec???
  193. evolution 8 to 7 conversion
  194. samco IC hoses install
  195. How to splice ecu harness wires?
  196. Headlight Adjustment
  197. vin on rear bumper?
  198. Oil Catch Can Install Instructions
  199. forge recirc valve which spring needed?
  200. Pics of us installing the EXEDY TWIN PLATE CLUTCH
  201. Standart boost controller
  202. clutch install question, differential wont come out.
  203. Question on catch can install
  204. Oil pressure sender
  205. Knocking the S-AFC2
  206. blitz sbc help... pls!!
  207. climate control
  208. Dual Stage Boost Controller
  209. Oil Temperature Sending Unit
  210. need help, just installed safc2 and boost controler
  211. timer trouble shoot plz help
  212. BOV staling out car
  213. Racing Harness
  214. Where did everyone mount there Boost Controller
  215. Custom Gauge / Instrumentation mounts
  216. Turning off constant illumination of cluster
  217. Black wire HOOK on HKS TT type-1
  218. EVC3 help!!!
  219. HKS EVC 5 Question
  220. Gigantic Debadging/Badge Removal Thread
  221. got my jdm spec headlights....
  222. BOV installation (EVO)
  223. Triple Pod Installed!!
  224. plsatic pop-in screws in trunk?
  225. hks evc v
  226. Radio Wire Harness SALE
  227. Need Help On Set Up Greddy E Manage
  228. Triple gauge pillar
  229. Apexi Gauge help
  230. Cusco Rear Strut Bar Installation
  231. parking lights bulb replacement
  232. Fluid change for Evo VIII Japanese Specs
  233. Forge BOV flutterint whoosh
  234. Jacking Points with a Floor Jack
  235. Strange problem with my A/F Gauge
  236. Wiring in lights for gauge
  237. Cat Delete check engine light
  238. Fog light Fuse Help!
  239. Wiring diagram for Lancer and EVO VIII
  240. rear strut bar install HELP
  241. pic of Blitz turbo timer
  242. fACTORY PIECES INTALLED
  243. Removal/Installation of the stock turbo
  244. Turbo timer problems
  245. HKS Circle Earth How To pic...
  246. Front Sway Bar Install
  247. Fog lamps on w/ parking lights?
  248. RMR Catback Question?
  249. Easy way to fill tranny fluid
  250. Is my turbo timer working correctly?
