- Clutch Cable Install
- How to connect dash lights to headlights?
- Power steering flush
- Tow hitch
- how do you get to wastegate/adjust?
- Anyone rebuilt their own Transfer Case?
- Evo's oil change with pics
- wheel fitment...
- Help with roof trim....
- Just installed FMIC, what do i cut off of Zero Lift kit?
- RRE MBC install questions
- Cruise (I hope!)
- problem installing a 10.5 hotside
- spring install help !!!
- Removing front and rear crash beams...
- boost leak test
- wing sun damage??
- Spring and Retainer install
- Removing the Head...
- How To Polish and Buff Head Shield
- need advice on removal of.....
- how to install greddy boost guage????
- Apexi Grounding Kit
- ingalls engine torqe damper
- Help! My headlights aren't sealing properly!
- need help on installing my HIDs in my NON HID Evo
- How to discharge/refill ac system?
- Base Ignition timing advance how-to
- Swift Spring Install?
- 10.5 plus o2 housing pics
- Forge Res BOV Type RS
- C-clip and Anti seez, Where can I get this?
- Want to See: Cusco V-Brace Install
- tq Spec
- anyone running a aque mist meth kit
- spoiler removal
- Perrin o2 simulator
- CF under paint on wing
- Help with control unit II install...
- forge mbc easier from under car?
- JDM EVO 9 Bumper Part #
- Evo 8 Hks Cam install
- How To Paint the mesh on the Hood Vent?
- How to lower my car?
- Wanting to change out transfer case...
- Question about bodykits
- need help in tt
- Throttle body air leak...Pics inside with how to fix!!!
- Adjust hand brake?
- help with my avc-r boost controller
- help with forge bov
- Blowout Valve Question!! Help Out Plz!
- need asap!!!
- Conversion Charts for Defi kPa or Celcius gauges
- Proper storage of the gas cap on the clip
- How to: Make your test pipe look like a CAT
- How many hours to require to install the HKS EVC
- Carbon overlay install for Front Mitsubishi Emblem
- $5 o2 cheater/non fouler how-to
- Another DIY Grounding kit Install...
- Shifter cable install?? Please help!
- INtakes..Short ram?cold air? heat shield? drop in?
- Need help with APR canard install, they don't seem to fit
- ghetto evo7 tails for under 30 bucks
- How to get rear view mirror off?
- Cheap and easy trunk lid "handle"
- 10.5 hotside and o2 housing install?
- HELP! can't get the fill plug off!
- How to create a stealthy interior, black.
- Energy Suspension Polyurethane Bushing Master Kit Install
- Porting Question
- HKS RS intake ??s
- is there a how to on removing and installing clutches
- Is There A How To For Water Injection
- Greddy Type RS BOV One Spring Mod
- wheel rash repair
- removing side mirrors?
- Good assembly lube for cam install?
- Walbro Pump Install
- greddy bov rs
- Problems with new injen intake
- trunk/cabin pass-through
- Removing door panels on an RS
- Beatrush Underpanel How To Request
- anyone a diagram for a iat sensor??
- engine harness
- Front emblem removal IX without bumper removal
- In dash DVD install help on a evo IX
- HKS/Blitz Harness work on an IX?
- How To Install the grills on the Evo IX front Bumper?
- SRS warning light question
- t-case drain bolt size
- Hooking up air fuel gauge Question??
- mbc install question
- 06 evo 9 RS question
- glove box removal
- Interior Glow Switch wiring!
- greddy type s help
- Any one has a picture of an MR intercooler
- stupid problem to have
- seibon hood
- cf on wing
- o2 housing
- safe to launch at 5k?
- Fuel Pump Install
- MBC Installation Location
- Jdm Evo 8 rear bumper install
- How-To polish (rims)
- Urgent information needed
- ARC Filter
- Steering Column Cover Removal
- EVO 9 MR speed signal wire help!!
- Problem with transfer case cover
- Rear mud flaps
- Dash Repair
- Want to know how to install HID kit in EVO4-6.5?
- how to wire up headlamp leveler??
- Wire colors for the "low fuel" light?
- Greddy TT Grounding Question
- Is this shifter weird or what?
- HELP with WIRING DIAGRAM
- Ingalls Engine Damper Help
- Simple/cheap front mud flap install
- electrical wiring for guage install??
- How to Request: Programming the Apexi AVCR?
- how do you crack the cam pulley nuts off ?
- Swapping power windows/mirrors/locks and remote locking into an RS
- defi gauges acting up, need some help
- Request: Carbon Fiber how to ???
- How To Modify Front Underbody Panel For Easy Floor Jack Access.
- HKS CAM INSTALL ISSUES :( not good
- heat gun or oven?
- uninstall autometer ultra-lite gauge?
- Need help installing Trailing arm bushing?
- need help with alky instal
- boost gauge vacuum line fpr isnt that bad
- Making your tails JDM look alikes!
- How to make plugs for your spoiler holes
- Oil Temp Sensor Cable
- removing the factory shift knob
- The Ultimate Valentine One Concealed Setup
- DIY - Paint Custom Paint Your Rims! Red Lip (Lots of Pictures)
- Installing control arm bushings
- T-Bolt Clamps (How to and list)
- Changing Entire Exhaust! Any Tips? Advice?
- Yet Another Amber Interior Lights -- Includes Foglight and Headlight Switches!
- AMS Exhaust Gaskets
- How do you install injectors on the evo.
- NOS on a IX?
- Convert BAR to PSI
- Rear passanger auto lock wont work?
- Transfer Case
- Nisei Upper Intercooler Pipe: Help!
- streetconcept V-style help
- DIY Black out your Evo headlights
- How To: Remove Perrin Antenna Gap
- Downpipe Air leak
- Yet another MBC install question (PIC INSIDE)
- Greddy Profec B II Install Pics
- Greddy 52mm Boost Gauge reading in Bar
- Agency Power front motor mount
- Timing Belt How to...
- question about uego install
- How To VID: OEM Grounding Kit installation points
- Questions about Buschur Stage 2 kit w/Deluxe IC
- How do u change the modified fuel cap back to the original fuel cap
- Adjusting E-brake cable
- Greedy type Rs installtion question
- How do you remove the gauge cluster to replace burnt out lights?
- Evo 9 Agency power BOV
- Evo 8 - fitting 3rd stop light after changing spoiler
- Wire problem
- need help
- how to make a dual brake bleeding catch can
- Illum wire in radio/clomate control panel?
- Tips on how to install cusco oil catch can?
- NEED HELP on installing greddy type rs recirculaiton when the BOV is not in position
- URGent
- power window and door locks
- Fixing the caliper paint problem
- Stainless Manifold Stud help
- Painted tailight problem
- Powerflex motormount install w/o press
- Do I have a fuel pump already?
- Installed my MBC, have a question...
- need help..
- Cam install DIY question
- boost problem
- Trunk Bar
- anti fouler
- Oil Temp Gauge
- How to open your tails
- Power Steering Removal Question
- Exhaust and warranty question please help
- How do you adjust JDM headlights?
- HKS type 1 turbo timer install for a IX
- Downpipe to turbo outlet issue
- Authority Turbo Outlet
- Leak tester parts source
- Help Car Wont Start!!!
- intercooler and bov
- HOW TO: Install an EVO 9 CF panel into an EVO 8
- I need your help on Greddy boost gauge
- do you have to remove to subframe to get transfer case out?
- Taillight removal
- IX MR Oil Change
- rs with stock infinity system
- help with timing
- Kartboy Exhaust Hanger Silly Question
- Help!!!
- Bypass Transponder w/ PKU-MIT for E9
- How To: Hook up the boost gauge to the dimmer switch.
- questions about defi oil pressure install
- How To Black out Headlight (Detail)
- Bulb Classification superbrightleds?
- Where to Buy Console Lights
- Will this Triple Gauge Pack fit in the Radio Slot
- DC Sports 2 in 1 Downpipe and Cat. delete install notes
- How much boost can the Type S BOV hold??
- EVO VIII spoiler removal
- HKS BOV poped off
- Valve Spring Tool?
- How to Install Oil Temperature Gauge
- shifter panel
- I have Non HID Foglight headlights and want JDM MR
- question on greddy turbo timer
- Finished my gauge/radio swap...but
- Wallbro?? Fuel Cut??
- help.
- In the middle of radio/gauge swap!!
- Convert GSR/RS to Factory HID w/Fogs
- Defi boost gauge question
- how to install hks TT type-1 HELP!!!
- cig lighter removal
- Wire back to stock ECU
- New FMIC, downpipe, cat delete
- Quick question. about hard pipes
- sports meter kit
- How To replace just the bulb
- Red Interior Lighting on the IX
- Service Manual Boost Gauge Install Question
- What oil filter for a IX
- DIY Muffler Delete
- How do you make custom panels?
- hks evc v instructions
- hks turbo timer type 1 manual
- greddy tt
