PDA
View Full Version : Lancer Engine Management / Tuning Forums
Pages : [1] 2
  1. about xml definition
  2. lancer 4b11 cvt transmission sport mode
  3. Looking for 59500004 xml for a 2014 lancer cvt
  4. Request: XML Definition for ROM ID 54980004 (Mitsubishi Lancer 1.8L M/T)
  5. Seeking XML Definition for Lancer 2.0 ROM 53230006 (CVT to 5MT Swap - Driver Demand/T
  6. Xml definition lancer 2017 4a92 engine
  7. 2-step (launch control) lancer non evo 4b11 and 4b12
  8. adding tephramod v1 to lancer +2008 non evo and outlander
  9. Lancer -2.4L - GTS xml definition
  10. finally mitsubishi +2015 memory model sh72531, 1280k size can read and write ecuflash
  11. finally mitsubishi +2015 memory model sh72531, 1280k size can read and write with ecu
  12. 2009 Lancer CJ N/A Definition File
  13. 2008 lancer need help with DTC off
  14. about xml definition
  15. xml def for ralliart-2009- id 53600017
  16. Turn off dtc code on my lancer
  17. xml def for lancer gt_se 2011 4b11
  18. adding spark cut for all lancer gt,de,es,gts
  19. xml definition lancer 4a92 mivec 2014
  20. xml definition lancer gt 2014 2.0l
  21. LANCER 2009 2.0 4b11 + Turbo file needed
  22. 4b12 4G69 Throttlebody Ecuflash
  23. Lancer GTS 2009 USDM 5MT 5270007 Ecu Definition
  24. 2010 lancer
  25. Ideas for a MT5 "09 Sportsback Build
  26. Help
  27. Project bluebeetle
  28. 2016 Lancer ES vs GT Axle-back exhausts
  29. 2015 Lancer 2.4L SE AWC Limited ECU Reflash
  30. 2005 lancer es ecu help
  31. EcuFlash Definition for 2008 Lancer GTS Manual Transmission
  32. Removing 2016/17 Lancer ES Soft Limiter
  33. Mitsubishi Lancer 2008 gts cold air intake tune
  34. Definition Needed for 2010 Lancer GTS 5MT
  35. Why fuel trims don't work?
  36. ECU Tune
  37. 2008 Lancer Custom Tune
  38. Lancer turbo mt swap 350hp fwd evo x
  39. wanna get a little tune.
  40. 2015 Lancer ES Horsepower Increase
  41. 2008 Lancer Crank but No Start.
  42. 2009 Lancer DE 5MT Full XML file 53220004
  43. I just witnessed someone with a boosted CVT
  44. Lancer de 2008 won’t rev past 4K in park or neutral but will in drive and L
  45. Resonator delete?
  46. Lancer GT 2.4L Mods
  47. Clean firmware 4g15 mpi
  48. XML definitions 4b10
  49. 57380001 definition file
  50. ECUFlash definition needed please 2015 Lancer- base MT
  51. Lancer 2012 CVT wiring diagram
  52. Need definition for 09 lancer de M/t
  53. How to Tune GT 2008
  54. Help me find a tune for my 2011 Lancer DE please
  55. 4B11 boost advice
  56. New to the game 2011 gts
  57. Need definition file for a base 2011 lancer gts non turbo
  58. Help: How to Enable Mode23 Lancer 2015?
  59. 2008 lancer DE definition
  60. 08 Lancer es 5sp
  61. Where to find "PassThru CAN" software
  62. Need xml file for 52500010 rom , please
  63. Full exhaust for 09 Lancer ES
  64. Lancer GTS 2.4 CVT rom and definition
  65. Just pasing by
  66. 2017 Lancer Tune
  67. Can I flash 4B11 ROM over a 4J11 engine
  68. 2015 Mitsubishi lancer ES
  69. Drop-ins / bolt-ons for GTS?
  70. Lancer 2016 or/ and 2017 Rom Definitions
  71. 2014 Lancer GT
  72. Crankshaft scaring... need new engine
  73. Who can give me a 52170039. XML? Thank you!
  74. Engine light for P0420
  75. basic programming recommendations
  76. 2017 daily driver Lancer ES upgrades
  77. Need xml file for 52500012 rom , please !!
  78. 2011 GTS CVT Ignition Timing Tune Assistance
  79. 2009 lancer DE camshaft gear question
  80. lancer 2015 need xml
  81. 4B11 defenition needed
  82. Flashing Evo ROM on NA Lancer
  83. Similaritiy between sub model engines and transmission
  84. Turbo Tuning 2014 ES MT
  85. 2010 lancer Es tune
  86. First time doing spark plugs on this car, got a couple questions
  87. 2010 Lancer ES Tuning Help
  88. 2013 Lancer es cvt transmission swap
  89. Need Help with 52170009 XML
  90. Need Help 2009 JDM 4B11 CVT Xml
  91. 2010 Lancer GTS
  92. Water pumps and coolants maintenance questions
  93. New to this forum! 2008 Lancer GTS ideling problem? HELP!
  94. First performance mod
  95. High RPM after replacing the PCV valve
  96. Muffler size
  97. 2010 4B11 auto CVT xml request
  98. 2016 Lancer GTS tuning
  99. Spark Plug Change - 2nd Opinions?
  100. 54960004.xml Help!
  101. Purchased 2017 ES LE Need MOD help.
  102. Bee R
  103. 2011 ES CVT Upgrades
  104. help which ngk is best for lancer es
  105. Any reviews of the RRM Timing controller?
  106. RPM drop too slowly.. 4B11 Engine 08Lancer ES
  107. Looking for axle back!
  108. Looking for 2015 Lancer es turbo
  109. 4A92 Engine
  110. Egr off
  111. 4B12 header on 4B11
  112. question on rrm piggback
  113. need stock rom & def xml
  114. $120 replacement tailights
  115. need 2011 definition for gt
  116. 2009 Lancer ES Boost/ or engine swap?
  117. Modding help
  118. need rom definition
  119. Modding help
  120. Help with XML
  121. Lancer ES with EVO X Camshafts tuning question
  122. valvule cover gasket
  123. A vw guy in a Mitsubishi world
  124. Question
  125. Definition creators
  126. Help choose headers
  127. Please Help for Lancer Thailand XML
  128. Question about axle back
  129. Issue about Lancer 1.8 FFV 4B10 ( Thailand)
  130. Need Advice with 2008 Lancer ES Mods
  131. 2015 es
  132. Throttle Boosters
  133. XML for 51510023(2008 GTS 4B12)
  134. 2010 Lancer GTS Intake?
  135. Help with deciding what to get
  136. clutch lancer X from evo 3-6 put
  137. Willing to pay someone to help me write my definations
  138. Looking to tune my 2014 Lancer GT
  139. need xml for 56050013 its n/a lancer 2011
  140. 2013 Lancer ES
  141. ECU problems
  142. Question on can it work.
  143. stock firmware cy5a(4b12) need
  144. 4B10 CVT Tuning - is even the smallest gain an impossible task?
  145. Please help for 55925592.xml
  146. lancer 2008 motor mount change
  147. 4b11/4b12 XML and Tuning
  148. 2012 Lancer Sportback SE Muffler
  149. 4b12 54980003.xml needed~~
  150. Just got one heck of a great ECU tune
  151. 2010 gts - practical gains?
  152. 2011 Lancer es performance mods
  153. 2014 es 2.0l most power for N/A
  154. Pzev to Fed Rom
  155. Reflashing an ECU on a GTS
  156. 2013 lancer GT CVT 4b11 definition
  157. 2013 2.4L CVT looking for horsepower gain ideas, im new to tuning.
  158. EvoScan Logs - result in impossible dyno
  159. timing control help
  160. performance tuning..NEED HELP
  161. Looking to tune my 2011 Lancer es cvt
  162. 2014 lancer es
  163. 2013 Lancer Engine Performance Tuning
  164. 2011 Mitsubishi Lancer ES, need advice for performance improvement?
  165. who can create ECU definiton xml lancer 2008+
  166. COBB V3 Stage 1 issues
  167. 30K mileage maintenance, need help plz
  168. gts definition
  169. EOBD-II Modes
  170. Changing 4B11 to 4B12
  171. Lancer GTS Reflash
  172. Lancer gt 2012 question.
  173. Exhaust Choice
  174. Need some help with EcuFlash
  175. ecu flash for base lancer?
  176. 08 lancer es mods
  177. 2009 lancer GTS wiring diagram
  178. Help with a Greddy please
  179. Have any of you put a Chip in your Lancer?
  180. 4g15 ecu pinout diagram
  181. 2012 SE Lancer Upgrades
  182. 4b11 NA
  183. Looking to Tune my 2010 Lancer ES
  184. Mitsubishi MMS Engine monitering
  185. Installing turbo on 2012 GT
  186. 2013 Lancer GT CAI Options
  187. 2011 lancer gts turbo question
  188. Evo Exhaust VS Greddy RS
  189. Dead in the water!!!
  190. Help
  191. 4-2-1 header with stock exhaust
  192. 09 gts cvt w. RRM turbo?
  193. Magnaflow resonator
  194. coilovers or lowered spring
  195. Intake for 2008 Lancer GTS
  196. New GTS Owner- Needs Help
  197. Is a 2009 cvt gts tune worth it?
  198. 4G69 Throttle Body. Does it add HP/TQ to 4B12??
  199. I am looking for some useful mods
  200. Vibration at idle. mainly when a/c ON
  201. 4b11 Lancer GTS MODE23 - Can anyone help?
  202. Settings for Data Logging Lancer GTS using EvoScan
  203. Can't log load or tps in evoscan - Re-opened
  204. My 4B12 Dyno result (reflash ecu and K&n drop in)
  205. Programing 2010 GTS
  206. help: could not get 100% TPS
  207. Service Schedule?
  208. Lancer GTS exhaust/tune up reviews
  209. AWS service required after DYNO run.
  210. Ralliart exhaust upgrade?
  211. Bracket for CAI with CVT?
  212. Ecu maf sensor, need help!
  213. Chips
  214. RRM Piggyback Tuning?
  215. turn overdrive off?
  216. Exhaust options?
  217. 2011 4B11 NA with CVT Dyno Sheet
  218. 08+ Lancer classifieds?
  219. 2011 GTS Manual Transmission Oil Change?
  220. Definition file needed.
  221. Is my Lancer a gts?
  222. programming interface
  223. 4G69 throttle body swap, NEED HELP!
  224. Definition file
  225. Greddy SE
  226. Cel p0420
  227. APEXi Throttle controller
  228. Exhaust on 2010 GTS Hatch
  229. Engine Touble, Oscillating Idle, Stall when stopping, Etc, Please Help
  230. Greddy SP Elite exhaust rattle - help to diagnose
  231. pretty lost with my 2011 gts cvt
  232. help.need lancer gt 2.0cvt jdm 54750003xml file
  233. Greddy ti-c vs sp elite - loudness factor
  234. Ingen CAI 2.0 to work in the 2.4
  235. Need Help Whit ECUflash Lancer 2009 SE CADM 5MT
  236. New intake for 2011 ES
  237. Question about Headers
  238. Wiring ?
  239. NGK plugs and wire set for Lancer GT
  240. GReddy SP Elite Axle Back
  241. RRM is the shizz
  242. Turbo or All Motor? 2010 Lancer GTS
  243. Question re: WORKS ecu flash for 2.4 with SRI
  244. lancer AWD + turbo
  245. Questions about Works Brain Flash P1 on non-pzev 2008 Lancer
  246. 2008 Turbo Lancer DE limp mode problem
  247. Installing a MAP Sensor on a 2009 GTS
  248. questions about tuning
  249. Need help for understanding how to tune NA
  250. ECU flash by WORKS before or after headers?
