PDA
View Full Version : Mitsubishi TC-SST Discussion
Pages : 1 2 [3] 4
  1. About to buy Evo X with SST, 2 questions
  2. TC-SST ticking noise while coasting (2nd gear)
  3. S-sport
  4. Concerned Potential Buyer
  5. Can you E-brake turn?
  6. quick question about normal mr behavior
  7. Which clutch type is the SST?
  8. What Is The Actual Cause of the SST Overheating?
  9. Is your TC-SST slow to react to WOT from standing start?
  10. SST trans filter at 6300 miles
  11. Ralliart Lancer shift behaviour questions
  12. SST at the Tracks please inputs.
  13. mr sst warranty
  14. Possible SST problem
  15. problem w/ going from reverse to drive
  16. Shift speed of TC-SST
  17. Is "S-Sport" mode too much for Auto Cross!?
  18. Gear grind on startup. Should I be worried?
  19. 2010 evo se
  20. SST with 19" wheels
  21. A little help with turbo upgrade
  22. 1st Track Day with EVO X MR. Wath is needed
  23. sst problems
  24. Sst shot
  25. Safe to shift from 2nd to 1st at rolling speed?
  26. Will SSP oil help?
  27. Problem after tune.
  28. S-Sport = HAPPINESS
  29. fastest sst 1/4 mile time.
  30. best performance witn only trans oil cooler?
  31. Bye dual clutch, hello 5 spd
  32. SST with simple bolt-ons
  33. from Manual EVO to TC-SST ?
  34. Is Possible to Delete Reverse Beeping?
  35. TC-SST Leaking?
  36. $130 SST Transmission Fluid Change
  37. SST-----TCU----Launching
  38. Torque tables
  39. SSP Clutch Paks
  40. Cooling nozzles on the SST fluid cooler?
  41. 08 MR SST Wont shift out of Park! Please help!!
  42. Does anyone know if the TC-SST can be serviced by anyone?
  43. chattter/knocking
  44. P1808
  45. TC-SST clicking and clunking noises.
  46. TCC-SST filter?
  47. Which driving mode causes least wear on TC-SST?
  48. MSRP of TC-SST
  49. new SST, new clutch pack & seals
  50. Japan EVO X SST blog
  51. SST: Seems to behave exactly how you wouldnt expect
  52. SST @ The Strip
  53. Using A Portable Fan To Cool Down The TC-SST Between Sessions?
  54. Forward jerk after starting engine
  55. Downshift into 3rd not as well matched as others
  56. Manual mode but shifting automatically
  57. How to use launch control
  58. Grind noise after engine start.
  59. Reflash question
  60. HKS DCT Fluid
  61. Q. about SSP 500HP pack
  62. Evo x mr with custom 4 inch turboback
  63. TC-SST change fluid early?
  64. Shifting into reverse, sticky?
  65. new guy with a few SST questions
  66. MR launch control
  67. SSP Deep Pan Fitment Issue.
  68. how much should a dealer charge for a sst swap?
  69. anyone?
  70. noob question...
  71. 2010 MR trasmission flare
  72. Evo x MR reviews - pros, cons, ect.
  73. My TC-SST does NOT overheat on the track!
  74. SST: Transmission Changes from 4th to 3rd gear on decel/low load conditions???
  75. Smoth 3rd gear vs slipping 4th gear dyno sheets.
  76. TC-SST - temp low
  77. Who modded to stay under 350 torque? What are your mods? How are Clutches holding?
  78. TC SST loud bang noise?
  79. Tranny and drivetrain oil substitutes
  80. AWD Motorsports SSP 500HP Clutch, Deep Pan, Oil Cooler Install..
  81. SST Overheated. Now what?
  82. TC-SST Shuddering On Take Off
  83. MR's throttle delay, need answers
  84. hi Evo X MR owners, quick couple of questions
  85. found a SST on ebay.
  86. Disable paddles?
  87. tranny or transfercase?
  88. Almost got rear ended!
  89. Trans Temp Sensor location
  90. RA tranny issues, possible slippage?
  91. Flappy paddle
  92. Why did my baby hit fuel cut?
  93. SSP Oil Pan
  94. South Side Performance Upgraded Clutch Pack
  95. One HUGE reason I love my TC-SST right now
  96. Alternative oil for SST
  97. Oil choose?
  98. ams trans cooler
  99. CEL Codes / Transmission Clunky / SST Service Light On
  100. Too much power now.. sigh.
  101. Who can install the SSP gear on the east coast
  102. Tc-sst shot!!!
  103. SST issue- anyone?
  104. SSP clutch, steels, and seals product review
  105. Help Needed!
  106. SSP Clutch Pack Install
  107. Weird trans. shifting
  108. launch control need input???
  109. TC-SST Manual Downshift Failures...
  110. s-awc service required
  111. What's up with this?
  112. MR must remain daily driver... For now
  113. Highest mileage of TC-SST?
  114. TC-SST fluid level check
  115. About the GETRAG/TC-SST tranny
  116. Looking to build up EvoX MR....
  117. mitsi 1.8 gsr auto
  118. Boost plot + SST
  119. Service Soon Gear on MID, clutches not engaging
  120. So I took the plunge!
  121. TC-SST with LSD
  122. Launching harmful?
  123. Max power
  124. lookin at buyin an mr would u do it again?
  125. Myth?: 10 second EVO X MR
  126. normal,sport and super-sport ?
  127. anythought's on this .?
  128. Anyone blow up the SST?
  129. TC-SST software history
  130. Hard shifting?
  131. Tranny slipping?
  132. Bored out mr?
  133. Updated Mapping of the SST
  134. SST observations and proper manual shift technique?
  135. oil temperature TC-SST
  136. Philamthebest's SSP Rebuild
  137. engine check sst
  138. Plx dm-100 obd & tc-sst
  139. TC-SST improvements from 2008 MR to 2010 MR?
  140. Jumping through gears....
  141. SST Shifting at Rev Limiter
  142. ATR and SST Tables
  143. EcuFlash SST tables...
  144. Which BOV able to keep up with SST shifting?
  145. Warning with ((!)) Do I need to worry?
  146. 1st gear boost limit?
  147. USDM SST temp in EvoScan?
  148. SST Throttle Limit Tables in ECUflash, where are they?
  149. SST acted up strangely today
  150. MR Cammed?
  151. Feels like neutral?
  152. Tapping Noise
  153. This Forum
  154. P1877
  155. Evo X MR problems continue
  156. Basic SST Questions
  157. SST Brake pedal adjustment?
  158. Cold weather + hard downshift
  159. 2nd gear slip in manual mode!!
  160. 0-60 Times Launch/No Launch Tune/No Tune
  161. Question regarding MR SS-T
  162. Why no external transmission cooler for 2010 MRs?
  163. Where all the SST Clutch upgrades at
  164. How brave are you? Neutral drop.
  165. Recommend Transmission Cooler?
  166. SST serviceable soon?
  167. Temporary transmission failure
  168. MR transmission issue.
  169. Proper shifting points for TC-SST?
  170. 2nd gear
  171. Technique For brisk take off from lights w/o LC
  172. MR TCU Flash?
  173. Purchased 2nd Evo and have ton's of ?'s
  174. What's the real deal with boost controllers on the SST?
  175. Rev Limit in auto mode
  176. updates on the upgrades?
  177. How much WHP are MR owners running?
  178. Transmission slip
  179. Trans Temp Gauge Sensor
  180. Got Clunk?
  181. Weird SST behavior during launch
  182. Better launch control with COBB AP?
  183. Fellow SST owners: Is this normal?
  184. SSP Clutch Pack Install Shops..
  185. What happens when the SST reaches its limit? (read inside to find out)
  186. Tranny cooler "group buy"
  187. 305 hp 349 ft/lbs tq
  188. CAMS and SST
  189. AEM Transmission Temp Gauge
  190. Any way to keep the SST shift mode setting to not set it on each start?
  191. SST FLUID COOLER is out!! with test comparisons!
  192. Any actual reviews of the SSP ClutchPacks?
  193. Rough shift from 4th to 5th Gear
  194. SST Coolers- why not use existing tranny coolers?
  195. Compiled List of all SST Oil Coolers
  196. Evo X MR Launch Control? (I know its been asked).
  197. Is it tranny problem?
  198. aftermarket shift knob
  199. TC-SST Fluid Poll
  200. SST oil coolers
  201. TheSin's TC-SST Project an SSP Production
  202. SST Transmission FAILURE THREAD - Post your results !
  203. Service required TC-SST related warning -
  204. Who would switch to a Manual if given the chance?
  205. ams sst cooler kit?
  206. SST & hand brake?
  207. SST engaging sound when throttle on/off...?
  208. Extreme Jerking when doing a rolling stop in normal mode...
  209. Reverse problem (SST)
  210. SST Rev limiter bounce
  211. Another SSP oil cooler installed
  212. launch control ......misshap or blown tranny >>
  213. Clamping Sound & Jerky Movement RA
  214. quick takeoff, but not outright launch with SST?
  215. Anyone have a blown SST for R&D purposes?
  216. is my sst going to dead ?
  217. SST missing a shift?
  218. MR - car won't move in drive
  219. I have an Evo X Mr w/ ~1k miles on it..
  220. Discussion of Slippage/Heat in TC-SST
  221. Blitz SST cooler kit
  222. When to change SST transmission fluid?
  223. Launch Control???
  224. SST with 330 HP and a warranty
  225. Tranny forgetting to shift into 2,4,6
  226. MR problem somethings not right i think..
  227. Boost Controller question for the MR
  228. HELP! My TC-SST is Freaking Out! Symptoms and Remedies...
  229. Difference?
  230. Thinking about getting a tune...
  231. Evo X SST mapping.....
  232. SST not for big modding
  233. hpa motorsports dsg reflash for vw dubs
  234. MR Trans Cooler Fan
  235. My car freaked out after a brisk drive
  236. Spy Pics SST Cooler
  237. Max Torque?
  238. Just bought a mr. have a few question on tuning
  239. shifting in Normal mode
  240. About this forum
  241. Ssp sst upgrade press release
  242. Attn ralliart & mr owners
  243. TC-SST Gearbox
  244. Sst upgrade mr owners must read
  245. SST - Down shifting
  246. Most powerful sst evo x
  247. MR SST: shift delay in manual mode
  248. SST Tranny Work
  249. Mr sst upgrades underway
  250. MR SST and high WHP
