PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. question on transmission
  2. Rough idle
  3. Parts needed to replace the clutch of a 5MT Evo X
  4. gearbox studshaft greasibg
  5. Oil coming out of Breeder at T case
  6. 4B11T Blown
  7. EVO X MR Loud Supercharger Whine
  8. 08 GSR build advice, input
  9. Tomei ARMS MX8280 Turbo
  10. Whining noise above 75mph+
  11. 1450A015 Replacements
  12. Looking to rebuild my transmission. any suggestions
  13. Stripped transfer case bolt
  14. Axle seals help
  15. Evo X TC-SST lightly leaking transmission fluid
  16. Rattling in car rear
  17. New Engine swap
  18. Did a MotorVac service for my high mileage Evo!
  19. Evo X MAF Replacement Issues HELP
  20. Starting Issue
  21. Another EVO X Misfire
  22. evo x cold start problem
  23. Max 9PSI and P1235
  24. Oil on turbo cold side intake pipe
  25. Evo X Turbo Kit Recommendations
  26. Evo burning oil ;(
  27. JDM motor
  28. Can't separate engine from transmission - help
  29. Help evaluating condition of a used 4B11T I bought
  30. Fixed: Evo X staining floor with coolant-colored fluid under the engine bay
  31. Code U0136 AWC CAN timeout
  32. Maintenance items to do during a motor swap?
  33. Buying a used engine?
  34. sport mode auto shifting
  35. MAP vs JM Fab vs BS Fab tubular exhaust manifold?
  36. transmission warning advice
  37. Rattling on Deceleration/Coasting
  38. Are these stock cams?
  39. Odd Intake Noise
  40. Is this overkill for 450-550whp?
  41. Evo STT gearbox problem?
  42. Brief review: NGK Racing spark plugs R2556G-8
  43. weird noise
  44. 2014 Evo MR.. is this normal sounding?
  45. Low boost pressure
  46. Evo X AWD/AYC Pump Read Low
  47. Evo X - White Smoke Exhaust
  48. System too lean but running rich.
  49. Need help on my daily
  50. Engine Build Recommendations After Damaged Valves
  51. Evo X cover valve baffles
  52. Forged Piston vs Cast Piston
  53. 2012 mr 12inhg/6psi vacuum going into limp mode
  54. Rebuilt motor turbo upgrade
  55. Tomei Cams
  56. MHI 18K upgrade
  57. Turbo type
  58. Evo X not starting :(
  59. is this gong to be a restriction for a 500whp goal
  60. Evo X Diffs 2023
  61. Tpc gt spec turbo
  62. Evo X Fuel Rail Capacity?
  63. 4B11T stock and aftermarket cam data update
  64. Stock EvoX Clutch replacement suggestions in Dallas
  65. Not building boost
  66. Ported intake manifold/65mm TB or Kelford 214c cams
  67. Low compression on cylinder 2
  68. Gsr p0014 help!!!
  69. While Building Boost, Weird Scraping Noise, Listen With Good Set Of Headphones.
  70. Map sleeved block
  71. Evo x wastegate leaking
  72. SST specialist in canada
  73. What did I BREAK?
  74. Rear differential leak
  75. How bad is this turbo crack??
  76. Turbo Upgrade Similar to Stock
  77. Replacing the plastic valve cover with an aluminum one without an oil catch can
  78. Any reviews of the MAP T4 EFR Hot parts kit?
  79. Evo X Low Oil Pressure Weird Problem
  80. Evo X MR SST Issues
  81. Where this thing should to be connected ?
  82. Driveshaft Shop Carbon driveshaft broken
  83. Exhaust MIVEC sprocket broke
  84. Too much exhaust flow?
  85. New Clutch Grinding Noise when getting in motion
  86. Evo x ayc read
  87. 4wd service light
  88. Twin Scroll Turbo Kit Necessary Installs
  89. Evo x ‘08 .. feels like my axles gonna come off when turning at low speed..
  90. Evo x build questions
  91. Red fluid on transfer case
  92. cylinder 4 misfire, tried everything
  93. Stock Exhaust Manifold Question / New Member
  94. Suggestions for sagging firewall insulation (fabric)
  95. Drive train noise/ Oil in the coolant.
  96. Evo X Smoking
  97. Block Heater install location
  98. Clutch Slipping at 7000 km?!
  99. ACD System Re-Design *Idea*
  100. Squeal noise
  101. Ticking noise
  102. Boost lowers after driving for a bit
  103. MAPerformance 3 inch intake MAF Questions
  104. HELP WANTED code p0171, p0463, p0183
  105. Drivability/ Erratic Idle
  106. Input shaft leaked grease on new clutch
  107. 8 AFR on Boost
  108. What would you do - RA build from scratch
  109. Shudder above 60% throttle.
  110. Code P0068 help
  111. Clutch questions
  112. Magnetic encoder protection cover ?
  113. Where does this heatshield go?
  114. Torque setting for front engine mount
  115. Stripped thread in transmission :-(
  116. Are there benefits from replacing the oil fill cap with a breather?
  117. Clutch power
  118. Mystery squealing
  119. New member with evo guts
  120. Porting & Polishing
  121. Walbro 450 upgrade questions
  122. Differences and similarities between Evo X and IX axles
  123. Map cmc
  124. Evo X Clutch Replacement
  125. Is this normal?
  126. Need Help.. Do I need a shortblock or a whole new engine? Blue smoke from Exhaust
  127. Gt3576r reducer
  128. Headstud Sourcing
  129. E85 spark plug heat range
  130. Act hdss clutch smell
  131. Weird Grinding Feeling on Decel
  132. stock frame turbo limit
  133. Block buid suggestions?? for 5,6,700whp
  134. Mil.Spec
  135. Help Error Code P0171!!!
  136. Quiet Exhaust without Retune
  137. Can this block be saved??? Check this out, seriously...
  138. Stock Turbo Compressor map
  139. MHI 18K w/built shortblock?
  140. Knock only when ac is on and at idle.
  141. Up/downgrade to aluminum valve cover
  142. Disable 4wd S-awc
  143. CNC Werx Cylinder Support Systems??
  144. Bent Intake Valve. Aftermarket replacement?
  145. Injector selection an JDM Evo X SST and general advice wanted.
  146. GSC S2 and Valve Lash
  147. Hesitation at wot
  148. The old spun a rod bearing trick
  149. Garrett Gtx 3071R gen 2
  150. Road race cams
  151. What do you need for a reliable 400 hp evo x?
  152. 2015 Evolution Fe transmission problems
  153. Sst stuck in park, seems different than others
  154. Grimspeed EBCS Compatibility
  155. Secondary Air INJ w/ECUflash+EVO X
  156. can anyone tell me what this is?
  157. Evo X rear differential: Fair replacement cost? Can they be rebuilt instead?
  158. C161F Logged with Pictures
  159. NEWBIE HERE: ACD C1613 Code
  160. What the heck came out of my diff?!
  161. Evo X Turbo
  162. Engine knock or no?
  163. Clutch master issue
  164. NEED HELP- Improper Idle After Twin Scroll Kit Install.
  165. AMS FMIC/Intake Overboosting
  166. Please HELP ME!! T/Case oil is spilling everywhere.
  167. AYC pump throwing codes
  168. Driven fab efr 7163 stock frame
  169. The Latest fuel pump Relay?8627A030?
  170. AFR lean at idle
  171. Help me out boys & gals, ACD issues.
  172. Had this little gem come on today.
  173. MAC35 3 port, resistor or no?
  174. MIVEC Cam Gear Disassembly and Cleaning??
  175. Catch Can comparison - Driven Fab vs MAPerformance
  176. Synchronic DV Kit
  177. Install Torque short shifter lost bottom white plastic ball socket cap. Need Help
  178. Evo X AEM box intake
  179. Engine is toast - weird idea
  180. 400whp
  181. Evo X Rebuild Ticking Sound Help - Video Included
  182. Whats the max boost for 91oct?
  183. MAP exhaust manifold OEM heat shield fitment
  184. Dreaded 4wd Service light
  185. Gtx3576r
  186. AMS 3.5” vs DEPO 4.0”
  187. 2008 Evo X MR couple questions?
  188. Turbo help
  189. Transfer Case Death Noise
  190. Random low oil pressure light followed by either p0011 or p0014
  191. Evo X keeps cutting out when warm/hot.
  192. Build direction suggestions??
  193. Powertrain rebuild, only 14psi??
  194. Build EVO X or EVO 9/8
  195. Cost for 800whp?
  196. New to Forum- Looking for help with P0133
  197. Value for money - starting out
  198. Service 4wd on dash today. 72k miles
  199. Bad ride home, won't start. Looking for things to test.
  200. Popping noise from turbo area
  201. Boost not going above 10psi
  202. P184b code
  203. need help with exhaust
  204. EVO X exhaust
  205. Possible Head Gasket Issue
  206. Agency Power BOV from an evo 8 to x
  207. Engine cutout and loud pop noise under heavy acceleration
  208. Fuel pump venturi jet
  209. Does a Comprehensive E85 write up exist??
  210. Service 4wd, service ASC??!!
  211. 2010 MR Build
  212. Odd under car noise
  213. Used FP Red
  214. Stick with stock clutch or upgrade?
  215. New to tuning and need advice. Please help
  216. 4B11T water pump block off plate?
  217. Knocking sound at 3-4k rpm
  218. Evo X GSR 2015 not making compression
  219. Evo X stock turbo upgrades
  220. looking for Someone FP54 Green BB
  221. Evo X MR rebuild discussion
  222. Evo X building head cam selection
  223. Evo x axles surtrack/trakmotive/ autozone
  224. Stage 2 / new clutch
  225. AYC/ACD pump code elimination
  226. Fluids for 2008 Evo X GSR
  227. Evo X build order?
  228. New to the forums and dont know where to ask this question!!!
  229. Evo x doesnt build boost, please help!
  230. 11 X Clutch Slip (Comp Stage 3)
  231. 2015 Evo X Shifter just flops around
  232. Will HKS FMIC piping fit AMS or ETS intercooler?
  233. Turbo/WG/BOV etc. Vacuum Line Routing?
  234. Woowoo!
  235. Boomba Racing front & rear motor mounts for Evo X
  236. Clutch issue?
  237. Turbo Coolant Hose Size
  238. evolution cta9 intercooler upgrade
  239. Evo X MR - 750 Hp goal -- Street-fun/Track toy
  240. Evo X 4th Gear Popping Out of Gear Under Load
  241. Timing chain recommended replacement
  242. TB and Intake Gaskets
  243. Indy area SST service?
  244. Please Help!!!!!!! ROAD TRIP CAR!!!! Rebuild or repair?
  245. !
  246. 08 Evo X full motor build
  247. How Great are Pull Type Clutches?!?!
  248. Turbo Oil pressure regulator
  249. Down pipe to turbo nuts
  250. MAF plug/wiring/harness
