PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Most Cooling Capacity?
  2. Bottom end build
  3. low boost issue
  4. Stock Frame Turbo - upgrade options
  5. change from bov to dv?
  6. Apexi Evolution R Exhaust
  7. Best spark plug
  8. Engine/Drivetrain Questions
  9. DC Sports Single Exit/Dual Can Cat-Back exhaust, thoughts?
  10. Comp stage 2 or spec stage 2 clutch for dd
  11. Will my AEM intake be a restriction?
  12. oil pressure sensor switch
  13. vibrating clutch pedal when depressed
  14. Clutch replacement
  15. Brian Crower Camshafts
  16. Boost issue.
  17. 2010 EVO X MR Touring
  18. MAF honeycomb in 2014 GSR?
  19. Should I replace stock flywheel with Stage 2 clutch?
  20. Best short shifter for Road Course/Street use?
  21. Need to retune after catback change?
  22. AMS or Speed Circuit
  23. Best clutch for a stock cmc
  24. Clutch suggestions for Evo X
  25. I have Two Turbos, which one should I install?
  26. Bbx full bb wheel color
  27. boost gauge line
  28. Full Race Prostock on EF3, worth it?
  29. Transfer Case Leak?
  30. Clutch slipping
  31. Acd c2100 ?
  32. Full bolt ons, time to upgrade Turbo!
  33. BBX full intake requirement
  34. 85.85mm Measured Bore Piston
  35. QTP electric exhaust cutout
  36. Please help me with my compressor surge problem!
  37. Best place to get a new engine?
  38. Do Evo 7-9 share the same clutch disc with the X
  39. ACD/AYC noise (ralliart sportback)
  40. estimated whp?
  41. Six speed shifting issue
  42. upgrading fuel system
  43. FP Black or GTX3076R
  44. Autolite XP5701 Sparkplugs.
  45. Crank shaft bearings, Mitsu warranty was great
  46. EFR: 7670 vs 8374 on a Evo X!
  47. low oil pressure warning after freeway
  48. Shorai Lithium Iron Batteries??
  49. And so the problems start
  50. What kind of tool required for this screw/bolt thing?
  51. Time to worry or no?
  52. acd/ayc pump fail
  53. Weird rubber seal found in oil
  54. Stock Clutch Replacement
  55. FP Red/Black Availability
  56. Block damage? Irreparable?
  57. cant decide on turbo
  58. Best Performance- Cobb short Ram, ETS Intake, Injen Intake
  59. 2014 Evo - Clutch slipping in 2 months?
  60. Just need some suggestions about packaged deals
  61. Best Engine Bearings?
  62. My motor is being covered under warranty
  63. Black Intercoolers ftw?
  64. Upgraded fuel pump - When is it needed?
  65. Whine noise after CMC recall done...
  66. K1 rods = max boost, whp/tq, rpm?
  67. Ef 2.5 owners
  68. thread locker??
  69. MX1 cams
  70. going e85
  71. 93 octane BBX Lite (Ball bearing)
  72. turbo install help
  73. Overriding clutch switch?
  74. Maf housing question
  75. Shifter problem
  76. Compeition Clutch Twin Clutch pedal
  77. "Rabbit-Ear" Clip
  78. Aftermarket DP + HFC w/ OEM CBE, questions
  79. Alternative to GT28 turbo?
  80. Anyone Running Rotella Oil?
  81. Evo X- S2 Cam requirements
  82. Blew a rod? Or worse? Please help
  83. Power Gains Opinion Needed
  84. What's the story on this clutch?
  85. evo 10 turbo bolt up
  86. evo 10 or 9 turbo wich is bigger
  87. New turbos from Cavalli Turbos! Any thoughts/expericence with these?
  88. Urgent help needed!
  89. noticeable delayed in 2010 evo x MR shifts
  90. 500 HP on Stock Clutch
  91. MR sst transmission control unit not responding.
  92. Turbo doesn't work and has no boost
  93. FP ball bearing turbos listed on site at 9,999.00???
  94. Throttle body
  95. 3 port, fuel pump, and tune
  96. spool-up (surge) problem with Kelford 272 Cam
  97. Question about S2 cams
  98. HFC and Tune
  99. Renting a 4b11t Torque plate
  100. Are these mods warranty friendly?
  101. Evo x Turbo Suggestions
  102. Hard to get in gear, easy when off
  103. Torque Solutions Short Shifter
  104. My Exhaust Choice ETS V2 Quiet & ETS HFC
  105. Competition clutch whom has one
  106. engine turbo combo recommendations please
  107. what spring should use for the tial "Q" BOV?
  108. Boost gauge is reading more then 30 inHg! HELP
  109. 4B11T block
  110. Went to buy a turbo today
  111. Mods that aren't talked about often
  112. Cams questions, S1 or S2 . 300kw atw goal
  113. Why oil leak?
  114. DP + HFC combo
  115. Need help!!! Clutch issues
  116. What else to support a MHI 18k?
  117. Turbo as first upgrade
  118. Which test pipe recommend
  119. Maperformance open dump (sound clip)
  120. 2.4l questions
  121. Need help with exhaust
  122. AYC/ACD Service Required light? Check your steering angle sensor!
  123. OEM Clutch Disk
  124. Newbie to the X world wanting to build a 2.0 Forged Engine
  125. Catch can
  126. Inconsistent Clutch Engagement
  127. ISSUES: Installing ETS turbo kit
  128. Interest in a billet wheel upgrade for stock turbo.
  129. Exhaust help.
  130. MHI TF06-18K how much hp can I expect on 91?
  131. What else do I need to shift?
  132. Knocks in high RPM's, spark plug replacement time?
  133. Where can I buy Ohlins? I'm ready
  134. Evo X modding guide
  135. turbo and downpipe
  136. Serious Knock Sum Count! Need help!!
  137. Cobb BPV with AEM Intake?
  138. Tell me the AEM 320 pump was a good buy
  139. when should i replace my diverter valve?
  140. 1000cc injectors & 265lph enough for gtx3076r?
  141. AMS/Cobb Parts
  142. rear differerntial help
  143. rate my spark plugs
  144. Intercooler Coupler Sizes?
  145. AEM Intake connetors
  146. TWM Full Replacement Short Shifter review
  147. Cams or Turbo or E85/93 ?
  148. Upgraded fuel pump needed?
  149. KN intake problems
  150. Grindingish noise at +4.5krpm (video)
  151. [VIDEO] weird SST Problem ? I guess
  152. stock exhaust
  153. Prosport Evo Series Oil Pressure Gauge Help
  154. competition stage 3 or spec stage3+?
  155. Best place for wideband bung
  156. Turbo cleaning question.
  157. Uber Garage Exhaust Manifold Review
  158. Evo x popping out of 3rd on track under load
  159. Bought a 08 evo x mr. Want to change fluids
  160. map dp, ultimate racing hfc and mag cb
  161. Damaged coolant pipe
  162. Turbosmart to stock X bov??
  163. AMS Catback or Tomei Ti-Catback
  164. will evo VIII or IX injectors fit evo X?
  165. Need opinions for next upgrade
  166. (yet another) exhaust thread
  167. Blown T-case? (video)
  168. Identify this part
  169. Need help ETACS and ACD problem
  170. Need help - New turbo, bolts/nuts backing out
  171. Need Opinions on Downpipe
  172. Do i need new injectors?
  173. Any issues with the Tial Q bov w/o a speed density tune?
  174. engine build, need some input
  175. Urgent, need help - oil leak near oil pan
  176. Evo X Garrett GT3071R Turbocharger Turbo Upgrade Kit 475 HP
  177. Need Help Installing Transfer Case?
  178. Weak points of the 4b11
  179. Whining noise under light throttle.
  180. New penzoil
  181. EVO X Clutch blew @ 10K miles, Need advise please!!!
  182. Buschur Mass Air flow pipe?
  183. Anyone have a "Under pressure performance" turbo kit on their X?
  184. Timing Chain
  185. Evo X clutch pedal notchy
  186. Evo x turboxs or CNT high flow cat
  187. Evo x MR sst tranny acting up
  188. Intercooler + piping for mr
  189. Upgraded clutch stage 3 Comp
  190. 2nd oil change - which oil to go with?
  191. Are Head Studs Needed?
  192. Help! Disconnecting SST shift linkage
  193. Does my turbo needs rebuild?
  194. AEM Intake vacuum line?
  195. Bolt-In Surge Tank options?
  196. Flywheel bolts
  197. Acd fail.
  198. Solid and Sprung Clutches
  199. Need advice from the older EVO owners?
  200. GTX3576 Stock Location ordered
  201. Will I have surging issues with the gtx3576r bolt on turbo with 3 inch inlet?
  202. FP Red BB Turbo Evo X For sale
  203. Will this turbo fit
  204. How many miles on your stock turbo?
  205. How to get to 350 +
  206. How to improve GSR clucth/tranny feel?
  207. Transmission/transfer case/acd FLUIDS
  208. ARK Performance N-II v.2 single exit exhaust questions
  209. clutch pedal engagement
  210. AEM Boost Gauge vacuum line
  211. perrin downpipe/test pipe. Help. (stock O2 housing)
  212. Turbo Kit question
  213. Will the Perrin FMIC work with ETS IC Pipes?
  214. Stock location turbo manifold... worth it?
  215. Aem intake
  216. Evo X intercooler
  217. Help me pick 2K of upgrades!
  218. EVO X right front axle??? In need
  219. 08 GSR track performance issue
  220. Ssp group buy with free labor
  221. FP MHI TF06-18K vs. BBX Ball Bearing Full/Lite?
  222. Port/Polish Stock Exhaust Mani VS Upgrading?
  223. JUN vs. Moroso, Baffled Oil Pans
  224. About HKS BOV piping
  225. New Washers for Transfer Case and Rear Diff Fill and Drain Plugs?
  226. What do you think?
  227. 2008 evo X final drive advice
  228. Oil Catch Can - Oil Seperators
  229. 2013 GSR Time for real upgrading
  230. ACD/AYC pump failure - Need some advice!
  231. Is the Speed Circuit Wicked Exhaust Discontinued??
  232. Clutch Question
  233. Stock Injectors
  234. top speed exhaust
  235. CBRD- Ball Bearing turbos, power, etc
  236. Turbo Shaft Play
  237. Getting a cam cap line honed.
  238. Cobb?
  239. Tcase, Trans and axles oh my!
  240. Loosing <1qts between 3.1k mile oil changes
  241. Need help on next step
  242. Gtx3576r or gtx3582r
  243. Clutch Sticking
  244. Whining noise when cold and driving slow
  245. LICP for EVO X MR
  246. Car won't start? Any advice
  247. Aem 320 install help
  248. Competition Clutch Stage 3 Issues
  249. crank pulley bolt size?
  250. A Loudness Comparison Question - Coming from an STI.
