PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30
  1. test pipe vs test pipe
  2. Code P0167 ?
  3. ITb's ?
  4. Panel Filter or AEM Intake Kit With FP RED Setup
  5. Atmospheric BOV Qs???
  6. stock exhaust material?
  7. Stroker Kits
  8. DIFF Break In Procedure?
  9. wastgate mod issues anyone?
  10. exhaust rubbing the driveshaft bracket...
  11. Stock Evo X intercooler size??
  12. Agency Power Ti-Tip Dual Catback Exhaust
  13. kelford stage 2 cams/ p0011?
  14. Evo X knock off Injen intake
  15. Buschur Quiet Muffler Cat Back Exhaust
  16. who makes exhaust/tp hangers for the X?
  17. AMS shifter bushings - what's the difference?
  18. Megan Downpipe?
  19. Are All air Filter Cleaning Kits the same?
  20. Zeitronix instead of gauges
  21. turbo timer works with keyless entry?
  22. Tomei ARMS turbo for CZ4A Evo X
  23. Harman Motive Intake installed!
  24. Forged Rods, Pistons, Rings
  25. Forged Rods, Pistons, Rings
  26. High-Flow Cat (Metal Substrate Core)
  27. has anyone gone with ttp's stage 1 package?
  28. Boring out a 4B11 motor????
  29. Oil leak after Boost Leak Test
  30. Ets t3 twin scroll turbo kit or ap t3 twin scroll turbo kit?
  31. relocated BOV
  32. Is the crankcase vent tube connector different from the 08s to the 10s?
  33. anyone heard from Massimo Power
  34. HKS hi-power exhaust
  35. New release ERZ performance EVO 10 one piece Downpipe and Test pipe resonated
  36. exhaust head shield??
  37. Intercooler Wrap?
  38. Ilkr8e-6
  39. Painting Exhaust / Remove Blue Effect
  40. Spark Plug Non Foulers not fixing CEL
  41. No idea what just happened to my car
  42. Need clutch help please
  43. What 35R turbo?
  44. Apexi RS exhaust
  45. FP Red + meth, cams, or dp?
  46. blouch or fp red for evo x
  47. Any other 2010s with a turbo upgrade out there?
  48. Moving from 500 to 550 crank HP!
  49. EVO8 RPM Shoots up for 1 second
  50. Need advice w/ EBCS
  51. O2 Sensor Spacer Help
  52. FP Turbo Install
  53. EVO X FP Red With Supporting Mods
  54. greddy or invidia single exit/overnight shipping?
  55. Does New Fuel Rail need remapping?
  56. UR highflow cat CEL
  57. Magnaflow w/test pipe Vids?
  58. big bang ?
  59. Downpipe Perrin vs. Invidia?
  60. Evo X E85 Conversion How To & Discussion
  61. Is this normal on an aem intake?
  62. AMS DP + HFC Pipe vs. Perrin DP
  63. Tranny whining.
  64. Artisan Race-back Exhaust.*pics*
  65. Ets, perrin, ur, or ams intercooler?
  66. Exhausts, exhausts, exhausts,... (Yes I searched)
  67. Took the clutch restrictor had problems.
  68. Evo X GSR tranny question
  69. Boost Pill Question
  70. Greddy Ti-R Ex?
  71. TurboXS downpipe initial impressions
  72. Steed Speed Exhaust Manifold vs. Tubular Exhaust Manifold
  73. swap
  74. Never noticed before...wonder if it is normal
  75. Fuel System Upgrades
  76. which downpipe to get?
  77. spark plug
  78. Looky Looky what just came in!!!
  79. What is a good coolant?
  80. Fp black????
  81. Edmund's ACD runs dry... $4500 to replace.
  82. Intake?
  83. evo 10 engine rebuild: gap between rod and pin
  84. Boost Problem
  85. EVO X Turbo Facts ???
  86. Help- Car won't start
  87. Artisan Assassin turbo?
  88. Best engine oil grade for EVO X: 15W-50?
  89. help with install tommorow!
  90. ACD C2100 code
  91. Transmission issue-not the grinding
  92. Help, looking for exhaust
  93. thinking of getting a NEW turbo
  94. AMS Downpipe, yea.
  95. Any Ultimate Racing vendors on here?
  96. Short Shifter + Console bushing.......Break my Shift Control Cable
  97. Solutions for eliminating P0420 with AMS O2 spacer on?
  98. Oil cooler, which is better ?
  99. UICP 1 or 2 piece?
  100. True duals exaust?
  101. Crate engine
  102. Start Up Issue
  103. Need Help
  104. Hks ssqv3 recirc tube
  105. Anyone tried the T1R short shifter?
  106. SATATISTICS on lightweight fly wheel, light weight pulley kits
  107. Need your opinions
  108. epm dump w/ megan DP
  109. AFI turbo kit
  110. just about ready...
  111. Flywheel before/after
  112. what determines and engines RPM max?
  113. HKS GT3240 turbo kit for the SST...
  114. Rattleling when letting off gas
  115. Injen UICP piping diameter?
  116. Need some opinions and thoughts about issues......
  117. megan racing o2 housing vs. stock
  118. P0134 Code
  119. Help~ hard to shift after changing the clutch and fixing the transmission leak
  120. Need your opinions...
  121. Another FP RED Evo X....
  122. T1R Short Shifter Pics
  123. Spark plugs
  124. Need Help/Advice
  125. clutch installation price
  126. UICP, LICP Xtremeboost vs Ultimate Racing
  127. Please help, shifter boot is stuck!
  128. clutch and flywheel question
  129. CBRD BB-X turbo update... and products again!
  130. Highest torque Evo X?
  131. Anyone know where the oil relief valve is located?
  132. Best BPV
  133. Nisei UICP got bent, I thought these were suppose to be on super tight? :(
  134. Tomei Products
  135. Question on Intake (AEM, Injen, K&N Typhoon)
  136. I need 30 to 50 WHP more - help pls
  137. What Now? Help/Advice Requested
  138. Bets on how much HP/TQ HBSpeed will get me over the next 3 hrs.?
  139. What's that ticking sound?? Normal or not?
  140. fujitsubo legalis r
  141. Cosworth Intake Manifold
  142. 5speed launch control fp red...
  143. IC pipes + turbo inlet require tune ?
  144. Best Clutch for 400-450HP
  145. Invidia Q300 Cat back
  146. ETS Evo X Single Exhaust System - 3.5"
  147. air cleaner filter vs air purifier filter
  148. Hks legamax or hi-power
  149. 2010 EVO X MR programming to to 08 MR?
  150. Evolution X Stock Pistons
  151. Christmas Early, good wifes ftw
  152. Meth Install *PICS*
  153. amsoil motor oil
  154. which UICP and LICP should i get?
  155. Evo X 75 mm Throttle Body from Boomba Racing
  156. Compression Test Results
  157. Tilton Tripple Disk
  158. T1R 90R Exhaust Video
  159. Transmission fuild drain plug washer
  160. Q re AMS Widemouth Downpipe with AEM intake...
  161. Slow down warning on display on start-up
  162. Crower cams evo x?
  163. Fp Red or Green
  164. Help with installing turbo timer
  165. Need new Fuel Rail
  166. Buschur Racing Exhaust Help?
  167. Meth?
  168. how many maf's have gone bad
  169. Pushing past 8k RPM
  170. Do I need a new driveshaft?
  171. Tubular Manifold Sound Clip/Video Request
  172. Nisei UICP install, any special tools needed?
  173. Blitz Intercoolers
  174. Question about mechanical cel fix for Invidia one piece downpipe
  175. new parts for my x
  176. Proper boost source for Tial WG
  177. Best cams?
  178. Just started car and code p1320 came on.
  179. Clutch Problem?
  180. Intake w/Cat-Back + AMS HF Cat?
  181. Blouch Dominator 2.5R
  182. ETS FMIC, few questions
  183. Who has a Greddy Spectrum Elite SE cat back?
  184. So where is our recommended fluid data?
  185. new intercooler problems
  186. AMS 650HP EVO X Fuel System In The Works!
  187. ASC Off Light Turns on on 5th Gear WOT
  188. P0300 code after Cosworth Cam install
  189. P0300 Code after Cosworth Cam install
  190. 4B11T on a Evo IX??
  191. Boost Leak??
  192. Major Problems
  193. Buschur Racing EVOX double pumper fuel system!
  194. Return Fuel Line Install
  195. TurboXS exhaust. Anybody have it?
  196. Exhaust
  197. 20K miles and I'm already hearing belt squeal
  198. Downpipes..Recirculate or Vent To Atmosphere?
  199. AMS twip tip exhaust and SC test pipe vid
  200. AMS Motor Mount VS. OEM - Confused?&^%
  201. boost tapering
  202. acceleration problems
  203. AMS Widemouth Downpipe Install - is it really this complicated!?
  204. FP Black for Evo X? anyone?
  205. AEM Digital Boost / where to put sensor?
  206. Battery Question
  207. AWD Motorsports Built Evo X.. ETS T3 Turbo kit w/ 35r...
  208. You guys ready for mid 10's?
  209. ? pulley ? did anyone get it ?
  210. HKS piping compatible with ets IC
  211. HELP just changed my clutch and now...
  212. Cost for upgrading turbo and tune
  213. Anyone running 380+hp w/stock fuel sys?
  214. Timing Chain going bad
  215. Just installed TBE, Intake, FMIC, but......
  216. next mod
  217. garrett 3076r maxed out at 27psi?
  218. Lose torque to gain hp?
  219. Estimates of the temperature of stock turbo & downpipe?
  220. ACD Control: Howzit work?
  221. New TurboXS Turbo-back Exhaust
  222. Turbo Inlet Diameter
  223. 3582 twin scroll problems
  224. Exedy Twin HD + AMS clutch master ring + AMS clutch line. I NEED HELP!! PROBLEMS!!!
  225. WOT engine cut out?
  226. boost leak test
  227. Gates311 Review - MODE Racing Double Adjustable Short Shifter
  228. Blitz catalog - Evo X
  229. Intercooler design - explanation of why this picture shows this?
  230. LICP for MR with AEM?
  231. Engine Noise-Grounding Issue
  232. Tilton clutch master review/help
  233. About oil change and engine flush
  234. clutch lifespan?
  235. Radiator upgrade?
  236. Tech Talk - Spring vs. Solid Center Discs
  237. Exedy Clutch= Failed
  238. Fuel Line Recall Concerns
  239. Starting my build, what else do i need? need your advice!
  240. TPMS sensor light..
  241. Valve springs PROs? & CONs?
  242. AP not reading boost? or leak?
  243. The Official: How Many Miles On Your Modded Engine Thread
  244. Complete engine cutoff on the highway
  245. Evo VIII/IX fuel pump sock for an X with E85?
  246. pulley kits?
  247. Meth and NO2
  248. AMS Turbo kit
  249. fujitsubo legalis r anyone?
  250. installing FP Red any additional advice?
