- Stock Tune...Lean AFR (Fuel pump relay failure could damage your engine!)
- Down pipe question
- AMS MC ring install help
- Anyone using Brian Crower 272 Cams ?
- Best way to spend $800, look inside
- Full TBE necessary?
- 8000 rpms
- megan racing exhaust, dows anyone have it on ? or have a video??
- Perrin AP Maps?
- Biggest stroker ever...2.5L
- noise in 1st gear
- Hfs-6
- Evolution Dynamics first 4b11 build-up
- 02 sensor stripped upon removal
- Stock Turbo + External Wastegate
- Gear problem
- Tranny problems
- Paint AMS LICP?
- Installed Custom made 3" Aluminum Exhaust
- New install: Invidia Q300
- Greddy Profec B Spec II
- need some help with engine oil
- Air intakes and mileage
- threw a c161e code
- Perrin Drop in Help
- COBB Evo X Exhaust - Limited Edition
- Has anybody install JUN 272R cams on their EVO X????
- Weird 3rd gear
- Will HFC pass emissions?
- **Product Release**AMS Mitsubishi Lancer Evolution X Trailing Arm Bushings
- engine light help
- Stock Boost 1.7 BAr?
- If I remove my HFC... how much louder?
- Blitz Filter fitment question to
- Need HELP
- Any special bleeding prodecure when R&R'ing evo X rear end?????
- Wacky idle
- Evo X GSR Engine Rebuild
- Evo X Megan Racing OE-RS exhaust
- Car's engine shuts down by itself in few seconds
- Help with transfer case oil change
- custom exhaust shop in la?
- Answer: Why FORGE RS BOV (many other BOV's) causes a p1241 Limp Mode!!!
- Cosworth Air Filter
- Threw Codes C1219, U0428, and C2205
- need help with nisei intake pipe install
- Cobb SF intake Leaking Air?
- oil light problems
- boost gauge vs. ECU readings
- rre exhaust?
- CP-E Down pipe
- Installing cams, special tools required?
- Meth injec
- Evo X motor reliability and tuning potential ?
- Redline MTL helped my shift feel, much smoother now
- How Much Smoke is Normal?
- Bluemax 1450cc for evo x
- Exhaust Heat Shield ok to remove?
- Is running 4th to the fuel cut off harmful?
- Diff problems resolved by oil change!
- should i upgrade my waste gate
- Custom cold air intakes for your Evo X (proto pics)
- New Turbo and Tobz Tune
- New k&n intake for x
- Benefits of Intercooler Hard pipes
- Intake Question
- Gear Noise
- One mans theory... Just .02
- perrin downpipe question
- Blitz Nur Spec C-Ti Installed
- Oil issue leak after doing cams ....can anyone help???
- Question on Works console bushings
- ATTN: BUSCHUR *Dipstick Retainer?*
- Head issues
- REVIEW: MXP Resonated Testpipe
- GReddy PE II Ti availability
- How do you check fuel pump Voltage
- Cat back using an AP?
- Anyone using Invidia 100cell Down pipe/Cat ?
- ARC parts availability
- HKS SQV Kit
- Exahaust question????
- Exahaust questions??
- Clutch slippage at around 12k miles - Replacement clutch options
- Does a down pipe make that much of a difference?
- Cosworth fortified Evo X MR built and tuned by Dyno Flash
- Upgrade Turbo?
- nisei intake pipe
- Clutch install requirements. Questions.
- Catch Can Setup
- Boost controller
- removing boost gauge
- Deatschwerks 800cc injectors without upgrade fuel pump on stock turbo???
- Turbo Oil Feed Line WARNING
- P1235 damn it
- Turbo swap
- stock boost problems
- any after markey fuel rails that look "stock"
- Forge WGA and Cobb Stage 2?
- MR with a FP red
- kelford 214-b
- intake poll
- p1240
- Dipstick Popped Out!
- Reasonable exhaust install price?
- Best Upgrades for 2000
- Boost solenoid nipple required?
- Wanted centre differential for Evo X
- Fuel Pump
- Clutch Issues
- I want to build my motor
- Bucshar Raching Intake
- Boost Controller
- My New CBE Drones. Can it be fixed?
- AEM Intake Box and Cobb IC Piping?
- AMS Intake VS AMS Cold Air
- deciding on new parts
- What to upgrade for High RPMs?
- Is the Injen CAI changing the AFR ?
- Attn tranny rebuild specialist
- 3-4 4-neutral resistance
- Artisan exhaust w/ xtremeboost dp with dump
- Mysterious Engine Trouble...knocking and power loss.
- Composite engine valves?
- Already have the Cobb AP, now I need some help
- 02 sensor
- need advice on under drive pully
- Noise while in gear! please help
- Where to buy a stock turbine wheel?
- True Cold Air Intake Sucking Up Water?
- First oil change
- Stock Exhaust Question
- Where to start moding?
- Buschur Racing's EVOX, 11.71@124.01
- Interests in a new 5th gear?
- Serious BOV question... which one works under HIGH boost?
- Transfer Case Leak
- Shifter Bushing
- how loud is...well loud?
- Oil coming out of turbo?
- Can anyone help me!!!!!!!!
- just a question to ask !!!
- Pulleys
- Buschur Racing, 11's at 122+, only 93 octane.
- Which Turbo Kit to get?
- Is this worth the $40?
- **Product Release**AMS Evolution X/Ralliart Stainless Steel Resonated test Pipe
- what spark plugs are everyone using?
- ETS Tubular Exhaust Manifold
- EVO X 5 Speed failures and solutions
- Megan Racing 3" Stealth Cat-Back Exhaust - Evo X (Anyone have it?)
- Evo X Drivetrain problems help?
- Need some power on STOCK exhaust...what are my options?
- Help me decide quick: Which Testpipe, instead of T1R TP?
- ATP 02 Housing/Downpipe Evo X - New?
- cel codes
- kelford stage 2 cams installed, car wont idle
- (Works) trans linkage shifter bushings
- Cbrd?
- Downpipe with external WG on stock turbo
- Universal HKS SSQV
- Those with Nisei LICP and Intake pipe please look!!
- Goodies from Perrin
- AGP Intercooler Installed with Review
- Engine hesitation when cruising on highway
- Is the Evo X PERRIN Downpipe good or not?
- ets exhuast w dp
- buschur lower intercooler piping
- Bent Shift Rail
- Turboback exhaust for 1K
- Drilling out exhaust flange
- Just Installed AMS Intercooler!
- Turbo Fluttering Sound?
- What is this part? (Intercooler Install)
- Turbo Flange to Down pipe. Is there a gasket?
- where can i find fuel filter?
- Do I nedd to upgrade my fuel pump?
- Exhaust Rattle
- manual boost controller
- Ultimate Racing Test Pipe and rear o2 sensor help P0137 code
- **Product Release**AMS Mitsubishi EVO X Clutch Line
- Test pipe install was not smooth
- fuel pump and larger injectors upgrade
- Individuals w/ ETS 4" FMIC?
- weapon-r intake...
- Thoughts on a Transfer Case Fluid Change at 15K?
- Best way to clean ETS intake?
- JVT Racing TBE, cheap!?!?
- exhaust popping/knocking
- Question on some different bolt on parts
- short throw shifter recommendation
- GM Boost Solenoid - EVO X
- Lost Exhaust Bolt, Need Part Number
- Switch my tranny oil to AMSOIL.
- EVO Xs with Single Sided Exhaust Systems (Please Read)
- squeeling/whistling noise
- Cold air intake for MR?
- Burning Smell?
- 0w40
- Power Increase
- Blouch Performance Dominator 2.5
- Colt Speed - Engine Cover?
- Tial BOV battery relocation issue?
- test pipe
- Torque Specs/Service manual???
- Were is the fast BVP at?
- Does anybody sell rebuilt transmissions for the Evo X!
- Did I kill the clutch?
- Ceramic Coated AMS/FP Parts
- i searched and found nothing so i will ask
- High Flow Cat Options?
- Boost solenoid problem
- Hks super reloaded suction kit!!
- need help !!
- How tight are you guys clamping down your t-bolt clamps
- Boost Spike with Forge WGA
- Replacing Fuel Pump & Injectors with FULL BOLT-ON's
- T1R 76s V2 and other goodies ...
- popping/knocking noise
- GT42_Boost Build
- Oil leak! evo x mr, inbetween upper intercooler pipe and turbo
- highflow cats
- Home fabricated O2 housing
- Code 0139 with only catback
- trying to estimate hp gains from these combined
- Front timing cover leaking oil
- AMS Twin Tip Review
- Stock + FP Red = Whp?
- Perrin CBE + AMS High-Flow Cat Pipe = Cobb Stage 2?
- FP RED or Dom 2?
- Anyone else with Race-day (road course) SES or Service Required screen?
- ACT XTG6 or XTSS or maybe Exedy Twin
- UR or other test pipes (straight or bent?)
- ~ What Intake and Exhaust options do you want to see Independantly Dyno'd?
- Clutch Slipping?
- Took the restrictor pill out
- Ultimate Racing Exhaust Install w/ Stock Cat
- Taken clutch restrictor out give clutch longer life?
- Strange sound while driving?
- "off-road use only" CBE
- Ignition coil upgrade: Okada Plasma Direct
- Anyone running cosworth mx1 cams
- new parts installed "an experience"....
- Removing Turbo
- Any Exo X cammed?
- I want to make a positive announcement
- Any Success stories w/ Garrett gt30 ???
- has anyone bought the Invidia downpipe w/HFC yet??
- Eneos 0w-50?
- 2.3L kit with what management system
