PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Center Diff Controller
  2. Turbo ??
  3. CEL P0340 help
  4. ? about ayc/traction control?
  5. Car feels like it lost power after installing custom full 3" exhaust
  6. Do you ever feel resistance / vibration shifting OUT of gears?
  7. 4B11T mark on engine block?
  8. Walbro's new 400LPH pump: X-specific discussion
  9. Loud Ticking/Clunking; Heavy Vibrations in Engine Bay - Please Help
  10. Rear diff making loud noise!!
  11. GrpN Evo X MHI Turbos????
  12. NEED Air Intake Box 5 inch cone
  13. cosworth MX1 RED OR GREEN
  14. Blow off valve?
  15. Looking for a Shop in LA that would do full engine/tranny builds
  16. TC or trans?
  17. Will Perrin Cat Downpipe fit with a Greddy Ti-C Catback?
  18. Clutch slipping?
  19. help!! problem with 4th gear...
  20. T-Case WHY!??
  21. Bogging issue at 2k rpms. (its not the BOV) Gurus please HELP!!!
  22. OEM Piston and Rod Weights
  23. muffler replaced with straigh pipe
  24. intercooler question
  25. Legamax over Hi-Power ??
  26. Seeking some new clutch advice
  27. AMS Clutch Line... anyone done it?
  28. Catch Can Set-up? Please help
  29. Black or Red
  30. Dp
  31. Just in case parts just happened...
  32. Hks v cam
  33. Works Short Shifter/Bushings Package... my review
  34. Cold weather oil recommendations?
  35. Fuel Pressure Regulator
  36. Code p0300
  37. Spark plugs
  38. Love that wbo2 gauge - it just found me a disconnected hose
  39. Is this the boost restrictor pill?
  40. best short shifter
  41. EVO X Turbine ousing failure...who do you blame?
  42. GReddy Spectrum Elite SE + AMS HFC
  43. Oil temperature while lapping and daily driving
  44. Pressure plate replacement
  45. My custom air intake heat shield/stock airbox
  46. best down pipe and mid pipe combo question
  47. Greddy Profec B spec-II vs HKS EVC-S
  48. Cracked transfer case? Not going to be covered?
  49. Notchy/Grinding into 2nd and 3rd
  50. Exhaust Fitment Question
  51. ETS V2 Exhaust experiences with the law in SoCal
  52. Excessive Deposits on Built Motor running E85
  53. Concerned about the plastic valve cover.
  54. i have an exhaust question
  55. Is this legit?
  56. Limp mode, no codes, need suggestions...
  57. ETS vs. AMS
  58. Loud screeching noise under acceleration...Any ideas? (Video inside)
  59. GSC S2 valve clearance after install??
  60. exedy puc 3 clutch
  61. Cobb Hardpipe & AMS CAI?
  62. Stage 3 planing...
  63. primo 3.5 intake
  64. Transfer case leak/overfill/shavings
  65. E85 and Single walbro limit?
  66. Rear differential? clutch slipping *need help plz*
  67. AGP Hardpipe Kit
  68. Tsudo Test Pipe
  69. BOV question
  70. Evo problem
  71. Ams widemouth with ETS
  72. Cosworth 2.2 Stroker
  73. Cams !!??
  74. Forced Proformance only making turbos with ball bearings?
  75. Questions for you CP-E Exhaust Owners...
  76. I think its me... car seems to have lost power
  77. Fuel Pressure Issues - HELP
  78. If your running a FP Green, Red, or Black on a stock airbox..
  79. Stuttering WOT
  80. Oil leaking from exhaust - New Engine
  81. Synapse BOV car went to limp mode
  82. ETS 5 inch intercooler
  83. ETS DP hissing sound
  84. 2010 EVO X questions
  85. Weird Noise.. PLEASE Help!
  86. Boost Solenoid Frequency
  87. e85?
  88. Driveline Whine?
  89. Just installed parts and now I'm bogging BAD!!
  90. smoke from turbo/T-case area
  91. Clutch pedal won't go down
  92. AEM intake with cobb inlet for HKS recriculate kit?
  93. 900x turbo series?
  94. My New Build For 2011 X MR
  95. Tanabe Medallion Touring installed and loving it
  96. ETS 4" FMIC :)... except the damage :(
  97. Bad rear diff?
  98. Tubular manifold on stock turbo
  99. Test Pipe Yes or No?
  100. evo gsr upgrades
  101. best exhaust manifold?
  102. Car not turning over?
  103. Truboost reading
  104. My custom exhaust....kinda
  105. Need some tranny oil help
  106. Whine on cold starts
  107. New MAP short runner manifold cracked
  108. Best boost sensor location
  109. Engine Problem
  110. Fuel System Upgrade Advice
  111. what is better to get as far as intercooler pipes go...need fast input thanks
  112. Hks gt3240
  113. Password JDM intake video clip???
  114. Damaged engine on first track day, advice needed
  115. Oil: 5w30 or 10w30?
  116. air intake help
  117. Fuel Cut at anything over 1/2 throttle
  118. Help me identify this squeaking
  119. help!?
  120. Garrett ball bearing GT3071R VS FP RED
  121. Odd Issue With Acceleration
  122. Forge RS BOV ?
  123. Warranty question..
  124. Thoughts on cams.... 214a vs mx1s
  125. fp black problem
  126. Evo Parts- What do you guys think?
  127. Buschur Racing Hobb switch
  128. Would a Turbo upgrade/rebuild fix shaft play?
  129. Unusual wear on cam bearings.
  130. Where to find this fuel fitting for OEM Feed Line???
  131. Little DV sound question
  132. Best fitment catback for Evo X
  133. Smog friendly cams?
  134. Cons of built bottom end
  135. Touge Factory Ti UICP?
  136. The Manhattan Project (Phantom X Evo's engine build)
  137. Building a turboback
  138. Engine codes?
  139. gtx3071r - dyno?
  140. suggestions on intake?
  141. Little bit of a low idle at times
  142. Throttle body problem?
  143. Could i get away with?
  144. lobing/ fluctuating idle
  145. H-beam or I-beam?
  146. Car makes 11 psi at 100% wgdc
  147. Turbo problem?
  148. Clutch starting to slip, probably need new clutch.
  149. Torque Solutions short shifter. Plz help
  150. erl thread in the 1-9 forum
  151. Engine/tranny noise??
  152. Mods suggestion for evo x MR
  153. Evo X Engine Noise
  154. Problem with A/F Ratio, etc.
  155. Rough Idle, 2010 Evo GSR
  156. Nisei Pipe Kit HELP
  157. BOV question, help?
  158. Just Installed - Magnus CMC - Some thoughts on the process.
  159. greddy RS exhaust?
  160. K&N Typhoon Question ?!?
  161. Ti Exhaust Installed
  162. ETS Intake Question
  163. Akrapovic exhaust?
  164. The best air intake/ exhaust combo
  165. injen CAI??
  166. Another clutch slip thread, but a very particular case.
  167. Best BOV
  168. Help 5spd tranny issue??
  169. Next Step: E85, Turbo, or both? for SST Trans
  170. Best turbo kit option for MR
  171. Cams on a Stock turbo...Good or Bad?
  172. Greddy comp ti-c and ams widemouth
  173. Sneak Peak - AGP's Cast Twin Scroll Turbo Kit
  174. MXP Turbo Manifold
  175. ACD turning OFF? haha. 1 last question
  176. EVO X Td05HA Turbine
  177. air intake recommendations please
  178. TurboXs Hybrid BOV Install and Impressions
  179. FIC 2150cc question
  180. best clutch for me??
  181. It this just my clutch slipping??
  182. car bogs at 4-5k help!
  183. fq-400 exhaust
  184. Missing rubber ring on AMS SRI
  185. rear differential problem.
  186. Topspeed PRO-1 Exhaust Review ( pics and vids )
  187. supporting mods. . .
  188. Bad driveline issue
  189. fidanza clutch
  190. Snapping sound from underneath car.
  191. X clutch fork stop
  192. Weird A/c...
  193. ATP Garrett Dual BBTwin-scroll GT3076R Bolt-on or FP RED?
  194. Clutch Pedal won't come back up! HELP!
  195. Help!need opinions abt turbos/agency power gt35r anygood?
  196. Depo Racing FMIC any good?
  197. HKS Fuel Rail
  198. high rpm lockout on stock clutch 4th gear
  199. Help with OEM boost control solenoid vacuum lines
  200. Modding the car - list here, what am I forgetting for the beginnings of the build
  201. Car Stalls When You Step On The Clutch
  202. S-AYC technical information
  203. clutch slipping on 2008 X
  204. Rattle under valve cover
  205. looking for a grounding kit
  206. Front driveshaft wont come off
  207. Huge turbo lag
  208. OFFICIAL Clutch Master Cylinder Discussion
  209. mid pipe, anyone heard anything on this? Not HKS
  210. Dual tip (Perrin or Greddy) or single Litespec Titanium exhaust???
  211. What does this sound like?
  212. cobb sf intake question..
  213. Tranfr case & rear diff help
  214. Need help asap! Evo noob
  215. Recommended plugs for the x?
  216. c161e code
  217. Bolt On Power
  218. Top speed pro-1 exhaust
  219. LICP Coupler extremely flimsy Video Inside
  220. best response mods??
  221. Problems with SES Light Going On/Off
  222. double pump goodness inside :)
  223. What else do I do?
  224. Intakes that Utilize OEM Snorkel
  225. Octane boost/fuel system cleaner
  226. Evo X Drop in Cams
  227. Transfer Case ACD Bleeding
  228. 2011 GSR gear slow to engage ?
  229. Synchronic dv fittment issues!!?
  230. Are All Intercoolers Created Equal?
  231. Weird idle/Hot start issue?
  232. Catback Heat Shield
  233. Recomendations: DP
  234. 2010 evo x gsr I/C fitment
  235. Evo x intake
  236. S-AWC help
  237. Cobb hard piping kit, aftermarket intercooler?
  238. Coolant on undercarriage...
  239. I cant go wrong with these choices right? i still cant decide
  240. ETS Downpipe or Cobb Downpipe ?
  241. AMS or CBRD?
  242. Wheel spacers..BAD???
  243. Whining sound from Evo X
  244. Muffler portion of Megan Racing SS Exhaust
  245. Exhaust Loudness Question
  246. Replacing my oil cooler on 2010 GSR
  247. So on a scale of 1-10...
  248. Which short shifter to buy?
  249. Car idles funny when AC is on???
  250. Gaskets and exhaust
