- WTB (IL) Stock evo 9 rods/pistons
- oil light but why?
- 272's on the stock valves/head
- What is the Best Gear Oil ?
- New gaskets for new turbo?
- Boost droping fast!!!
- Shift Knob ques
- Do we really need a TT?
- Nisei Intake Pipe Question...
- Hydraulic or cable clutch?
- Upgraded Wastegate actuator.. what does it do?
- oil press gauges... what does yours read?
- Return to stock for dealer to address DTC P1320?
- Where to get BOV tubing lines and Y/T tubing splitter
- Kelford drivetrain question.....
- Battery Dies overnight, HELP!
- Taking a chance with a new shop/clutch :-/
- quick help on the pitch size of a bolt?
- Exedy Twin SD or HD
- R.i.p 4/16/09
- Need advice on clutch, low mods.
- Bigger FMIC = More Lag
- DG Motor's Evo X Goes Under The Knife!
- My goal is 350-375WHP
- Ceramic vs Carbon
- question for those with uber JDM intakes...
- Car won't shift into reverse.
- clutch finally took a dump
- licp that keeps oem bov location?
- size of evo x turbo?
- Test pipe = less engine braking?
- AMS 02/DP vs T1R 02/DP poll:
- down pipe or test pipe
- HELP: Probelm with AMS Underhood Shifter Bushings fitment
- Anyone have aftermarket factory replacement turbo manifold?
- how much hp from o2 housing for evo x?
- Just Downpipe and HF Cat? Thoughts?
- Resonated Testpipr/Mini Muffler
- How does an MR sound with an intake?
- Cold Air Intake or not
- BAD BAD BAD Front CV axles
- Need some opinions please
- Buschur or CP-e
- 1.3 Bar Radiator Cap For A Daily Driver?
- Gear Ratios
- How often do you change your ACD/AYD fluid?
- who makes resonated testpipes?
- Do you know if this is compatible with the MR.
- fuel rail question
- Whistling noise on idle
- Q about fuel rail...
- i/c piping help please
- Evo Addiction
- Spec stage 1 clutch...
- 4" Intake on Larger Turbo
- Agency Power BOV
- How many miles did you wait before a tune?
- Shifter Base Bushings & Transmission Bushings: Metal vs. Urethane
- Boost Leak
- Panel Air Filter
- testpipe queation please help
- Performance expected with Cosworth cams?
- Those with Nisei UICP please help...
- All traders/dealers....
- Questions related to the Boost Pill, Manual Boost Controller and Forge Wastegate
- Sequential Silent R Muffler
- Nisei LICP with stock intake?
- Ultimate Racing Duel Exit Catback?
- ACT Street Disk W/ HD PP Or Exedy Twin
- Injen CAI
- evo ix clutch vs. evo x
- drop in air filter, good choice?
- Got my Cobb AP as first mod...now what?
- Weird engine idle Evo X
- boost problems
- AMS or Buschur????
- JAZ One Pint Mini Breather Catch Can
- Tune for UICP
- Megan Racing Cat-Back Exhaust
- need help wit clutch?
- Valve springs?
- AGP Crank Pulley anyone have it?
- My Evo X FP red set up.
- Problem With Sport and Super-Sport Modes
- Just Curious....
- best bang for buck - power wise???
- Reverse anyone?
- Opinions and Suggestions for This Setup...
- Mr clutch upgrade
- Video of exhausts for the evo
- Paranoid episode inducing ticks.
- drop ins for the 4b11
- Q for UR dual exhaust users
- I only have 3rd and 4th , help needed.
- Check Engine Light - Code?
- Noisy exedy
- clutch peddle gone again....
- How good or bad is the stock exhaust?
- Anyone know T1R exhaust db level?
- SS Braided Clutch line
- Fuel Pump issue
- Aftermarket clutch...???
- Need help ASAP! No boost!
- AMS Downpipe!
- bov question
- HPS intake elbow
- My CP-E 3" Quick Power Pipe with High Flow Cat Came in today
- Shifter shaft thread pitch?
- ETS o2 downpipe vs Ult. Racing o2 Downpipe
- HKS vs. T1R Piping diameters...
- turbo
- Question about Down pipe.
- Can I change the stock BOV to VTA
- who's running Meth? Esp..in DD's
- Transmission clunking
- Hardware needed for exhausts?
- Crush Washer
- quick question, the evo shuts off randomly
- EGT Gauge Defective?
- throttle issues
- Intercooler water spray assembly?
- Lost boost when I went back to stock BOV?
- Buschur Shifter bushings
- G3 Innovate gauge?
- rough idle and stalllllllll
- Intake CAI question INJEN AEM AMS other???? help me out...
- New sound coming from under the hood.
- BOV Fluttering sound
- check engine when cone filter fell off
- Heat wrap turbo? Good? Bad?
- Need help! No reverse!
- Need 2.5 in resonated test pipe
- NEW: Blitz EVO X Surge Tank
- ABS checklite code: c102a
- Ebay intecooler pipes
- Is my clutch going or does my X have other issues?
- BVP/Darton EVO X sleeve block
- Blitz New Nur Spec C-Ti
- Anyone have the Garret GT35r twin scroll turbo on their evo X?
- MR transmission, REV limiter
- GReddy Competition Ti-C Full Turbo Back System is OUT!!
- HKS Filter?
- Exhaust hanger solution
- HKS EVC for EvoX
- What should i do first?
- What exhaust is this??
- Bov?
- Garrett Turbo
- Stock muffler mod {how to} for increased flow?
- Factory Boost Controler
- HKS Valcon cam kit pro
- Borla Exhaust...does anyone have this?
- ic install help
- clutch and flywheel install, Question?
- Lucas Synthetic Oil Stabilizer
- is this normal or do i have a boost leak?
- turbo timer
- Motor blew up :(
- Stock Exhaust Weight of the X
- RRE exhaust
- Reverse failure in transmission in evo x
- X rs gearbox....
- Greddy Spectrum exhaust video / pics - *TF Evo X*
- vacuum pressure at idle???
- Evo X Backfire.. Help.
- Just got my CP-e Catback with Catted Testpipe!!
- CP-e Dual Cat-back
- ARC Super Induction Box
- Cel p0171b
- Long term review Ultimate Racing Exhaust
- PERRIN Oil Catch Can Placement
- any one using the hks suction reload kit
- trans/diff broke
- Manual or Electric boost controller
- Where is TurboXS?
- Spark Plug Non foulers
- Perrin Highflow Cat Downpipe
- Is a crush washer absolutely necessary on the drain plug?
- vishnu catback
- INtercooler Install question.
- ETS Intake
- Powder Coated GReddy SE
- EVO X guys.. what weight oil do you get?
- To test pipe or not to test pipe?
- Edmunds Project Evo X dyno comparison of AMS exhausts
- gas leak?
- Wow. Just wow. If you don't have a UICP.... shame.
- So my O2/dp and test pipe/mini muffler showed up today :(
- check engine light????
- Test Pipe VS Resonated Test Pipe
- Anyone with the WORKS REFLASH?
- blitz
- What to do first...
- Car won't move.
- Common coolant leak?
- Exedy Twin Plate
- Any info on UR FMIC??
- Anyone Upgrade The Turbo or Cams in an X MR Yet?
- New JUN engine parts!!
- ETS Intake Question.
- Boost Controller vs Tuning and some other question
- Clutch WENT OUT
- Boost problem or gauge problem?
- Almost too nice to hide away!!!
- Aftermarkit FMIC weights vs stock
- Best test pipe?
- noise during turbo spool
- Boost Pill hurting performance on 91 octane??
- engine problem!!!!help me
- AMSOIL changed recommended oil??
- Amsoil
- Code P0234 after Jun wastegate actuator install
- Does anyone have cams installed on an MR?
- Agency Power Down and Test pipes
- synchronic bov
- HELP: EBC with Boost Creep!! Apexi AVC-R
- My car is cursed (aka a 2 hours job becomes a 2 day job)
- agp pipes
- Hks bov
- boost pill question
- head studs, head gaskets?!?!
- AMS Cold Air Intake
- HKS Racing Suction Reloaded Kit
- Tomei
- So does anybody know how to warranty a clutch from Exedy
- help!!!!
- So has there been any other problems with long downpipes?
- Help on preloading Jun/Forge wastegate actuator
- LICP; Is it worth it?
- Service engine light
- Time to test those customer service skills....
- gutting stock muffler
- Is this going to damage my MR trans?
- cel code???
- ETS Open Dump Downpipe and Intercooler Piping/3.5" Intercooler
- What are the Signs of a clutch going bad?
- Gsr 5 speed clutch pill removal?
- Evo X Clutch options.....
- 3" midpipe?
- P1238 and C121C after cosworth cam install
- FMIC upgrade, sure it makes power on the stock tune, but what about after a reflash?
- Help Spark Plug re-Gap needed?
- How's T1R product?
- Getting a THUD noise *help*
- BLITZ Nur Spec-R Review
- Blitz upgraded actuator
- vacuum hose size?
- ETS V2 Exhaust Review
- hks legamax with 3" midpipe
