PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Full Fluid Change.. Need help..
  2. how muc boost?
  3. Amuse exhaust
  4. Need help with tranny pull...
  5. turbo suggestions...
  6. Port/Polish question
  7. New owner of Gumps PTE 6765 2.3 here
  8. P1235 Code?
  9. Fuel Filter hose
  10. Compact BPV
  11. Couple clutch questions.
  12. Beatrush rear diff bushings installed
  13. Clutch or normal?
  14. Can this get me to at least 350hp?
  15. Weird sound few second after cold start-up
  16. Stock boost pill?
  17. BlaqOps fuel pump kit
  18. P0247 Wastegate Solenoid B
  19. blue and black 3 Ports
  20. will i need to change my bov?
  21. HFC Pic request
  22. Need advice
  23. Evo X smoke at WOT after tune
  24. Installed: AMS FMIC, Cobb Hard Pipe Kit & Fog Light Deletes
  25. Service engine soon light after intake?
  26. Throttle Body goes with Intake Manifold or Exhaust Manifold??
  27. Transfer shaft removal - it's stuck!
  28. Drastic Sudden Oil Pressure Drop
  29. Exhaust help!!
  30. Stock Turbo Failed
  31. What Can I Expect WHP-Wise
  32. Weird CEL
  33. Tarmac - Gravel - Snow
  34. ? FP bb black or AMS 750xp
  35. Question: Intake Manifold vs Exhaust Manifold
  36. To keep Stock Cat Back???
  37. Ultimate Racing Downpipe issue
  38. Clutch Chatter
  39. Downpipe question
  40. leaking on the ayc side of the rear diff
  41. AMS Clutch master cylinder install help
  42. Clutch and Flywheel combo
  43. AGP Cold Air Intake + AGP Hard pipe Kit
  44. The Official "I have not had a timing chain issue" thread
  45. MXP exhaust
  46. ATTN: Custom Fabricators
  47. High clutch engagement point
  48. Getting a protune
  49. stock x turbo
  50. Rev-dependent clicking/rattling noise after some misfiring
  51. Engine Oil Filter Question
  52. aftermarket valve springs with stock retainers?
  53. downpipe and noise
  54. Timing Chain Stretch - How big of a concern is it?
  55. The Big Turbo "still running" Motor club (Evo X only, please)
  56. Blown Piston Ring :(
  57. 400 WHP Goal
  58. Not all intercoolers are created equal!! core comparison pics inside!!
  59. clutch wont disengage and making a loud rattle noise
  60. clutch-pedal height
  61. FP Black(Journal bearing)
  62. eBay Dual exit Catback + test pipe
  63. Radiator fan question
  64. My car feels hesitant... any ideas?
  65. Invidia Q300
  66. injectors correct nozzle (extendet or not?)
  67. Engine/Turbo Problem....Running out of ideas!
  68. My Exhaust Leak
  69. Stock turbo manifold
  70. Evo X Clutch question Please help
  71. Downpipe w/flexpipe vs downpipe w/o flexpipe
  72. 2008 EVO MR Warning/Check Light Keeps Coming on Under Hard Acceleration Please Help
  73. When compressor blades go NOM NOM NOM
  74. Anyone running these injectors?
  75. Running my cobb sf intake on my 11 mr w/o tune?
  76. AEM inline UEGO in ATR with a picture and new updates!! please look
  77. Fuel rail, is it worth it
  78. AYC snow mode + dry autox?
  79. HKS drop-in filter with new turbo inlet or AEM intake box??
  80. Mods suggestion: better X inter cooler out there? And more...
  81. Experiences with depo racing downpipe?
  82. AEM intake, installation and impressions
  83. Do I need an O2 spacer for HKS HFC?
  84. Has your exhaust scared you b4?
  85. Injectors and Fuel Pump
  86. Thoughs on parts?
  87. New timing chain as of April 2012
  88. cams
  89. Clutch Restrictor Pilll!
  90. please delete
  91. Oil pressure
  92. Clutch Questions
  93. Evo X clutch question?
  94. Clutch squeal
  95. Troubleshooting boost solenoid issue
  96. Notice: More FAKE Tomei parts on eBay!
  97. Looking for good price OIL CATCH CAN thats NOT Ebay. Anyone?
  98. CNT version 3
  99. Cracked rods.
  100. How restrictive is the LICP?
  101. About Clutch
  102. Someone confirm this as Clutch Slip please!
  103. boost controller
  104. Engine Winding Noise
  105. Meth Injection Kit Advice?
  106. To much tick?
  107. Installed ETS intake today. One question
  108. Suggestions on new clutch
  109. Opinions & Constructive Critism on this mod list
  110. AMS Downpipe, worth it?
  111. Does a turbocharge engine really need a turbo timer?
  112. ETS FMIC w/hardpipe kit
  113. Any issues with this EBC install? I'm only hitting 16PSI.
  114. Exhaust Hangers
  115. Which injectors and Pump?
  116. Help me identify what FMIC I have!
  117. Fueling Help
  118. Turbo options PTE BB 6262, 5862, 5858
  119. Guidance on modification decision
  120. AMS 2.2 possible problem... smoke vapors from the head
  121. Wastegate Actuator
  122. Alternator belt replacement?
  123. Help with 4-4.5k budget mod list
  124. weird smell when getting on it
  125. Need your professional diagnosis...
  126. Whats missing in this picture?
  127. HELP!! Compressor Surge on EF2 Turbo
  128. AMS and Grimmspeed 3 port
  129. Intercooler Pipe Boost Leak
  130. Some experience offered.....
  131. Blown motor finally pulled
  132. Tuning problems with AMS cold air intake & TurboXS BCS
  133. Advice needed
  134. s-awc problem in warm weather
  135. Front motor mount Bolt missing?
  136. Service Required, 1 Month Past 3y/36k Miles
  137. problems picking a turbo.
  138. Tomei test pipe fitment
  139. Strage Noise Between shifts during WOT
  140. Help on finding a HUIP fo my application
  141. CP-E exhaust / company issues anyone?
  142. Cusco RS diff - Remove AYC
  143. grimmspeed 3 port ebcs
  144. new evo owner.. 3rd gear feels funny
  145. Intercooler pipping OBX Brand any good?
  146. MR vs GSR
  147. Engine builder won't admit to fault
  148. Just my luck
  149. Staged Upgrades / Who should I go with?
  150. 285/30/18 on stock tune
  151. To downpipe or not to downpipe?
  152. Good 08 evo x catback?
  153. Which A/F for Garrett GTX3076R?
  154. slight rattle downshifting between 2 and 1
  155. 08 evo x starts with clutch out in neutral?
  156. Advice for my build
  157. Anyone have/make an AMS CMC review?
  158. Need NYC shop for welding/tapping downpipe
  159. Aftermarket Exhaust Manifold Heat Shield????
  160. ETS intake
  161. Need Help Deciding on Intake for Houston HOT weather. 100degrees 9months of the year
  162. Dual exhaust designs
  163. Prototype Quarter Master Twin disc Evo X
  164. Air Intake, bolt ons
  165. would like to make around 500 hp, would stock block and everything hold up?
  166. Is a downpipe really worth.....
  167. No more BB FP Reds so going BB FP Black!
  168. fuel question
  169. AEM intake mod
  170. Issue with Under Hood Bushing 11' Evo X
  171. Clutch Master FX300
  172. Thinking of Selling AMS DP for MAP External Dump...
  173. Low/Mid range Torque strategy
  174. E85 EF3/FP Red on Stock Block
  175. Question about downpipe bolt...
  176. AWC hydraulic pump issue
  177. The Perils Of Stiffer Exhaust Hanger Mounts
  178. Grimmspeed Ported exhaust manifold
  179. DV whistle?
  180. Evo X MR BOV flutter
  181. New clutch install....
  182. ATTN: EVO 10 Owners, Run a manifold heat shield or your car could catch on FIRE.
  183. new evo
  184. I have a leak! Again
  185. AEM intake to stock, solenoid connections
  186. AMS 2.2L Big Bore Engine
  187. Engine aid?
  188. exhaust shipped!
  189. Turbomart BOV Flutter/Surge
  190. Boomba Racing Fuel Rail VS OEM Fuel Rail
  191. NOOB clutch questions
  192. Quick question regarding ACD fluid reservoir?
  193. Problem with turbo spool...
  194. Higher Output Alternater for the 2010 MR?
  195. How bad is this manifold?
  196. Limit on the Stock Engine???
  197. Blew my motor today :(
  198. Looking to upgrade from FP RED
  199. Which is recommended BOV?
  200. coolant leaking from turbo hotside
  201. Unheard of trans issue. Please help.
  202. ETS or AMS?
  203. Random lean spikes and almost stalled after starting
  204. BOV Vacuum hose
  205. HKS Super Turbo Muffler!
  206. TOB/wavy washer and snap ring
  207. I need 500hp
  208. GSR Transmission fluid...RP anyone?
  209. BOV flutter/compressor surge and a thrown rod
  210. Power loss and weird idle issue .. Please help!!
  211. UR Test Pipe P0420 Fix?
  212. 2k rpm idle - Help!
  213. Is my car running rich?
  214. advice on future build
  215. fuel quick disconnect fittings
  216. Ets 3'' fmic?
  217. dc sport dual canister
  218. 2011 Block
  219. Cusco 1.5 RS Rear Diff Review
  220. Quick exhasut question
  221. loud rattle/bang and car bucking
  222. Got my replacement ETS Down pipe today!
  223. Turbo actuator
  224. BeaterX gets an EF4, thanks MAP!
  225. HKS Hi Power or Legamax Premium?
  226. AMS 750R vs ETS T3 TS GTX3076 spool
  227. WHP v. FHP
  228. Front passenger side axle seal question.
  229. need some exhaust help
  230. Transmission might be done...
  231. HELP!! Transmission/ Lower Engine Vibration?
  232. ef3 or new bb red?
  233. Cobb intake help...
  234. E-85
  235. TWM Short Shifter with 4" Extension in action!
  236. Is it really worth..................
  237. Tomei Expreme Downpipe Big Mouth
  238. BOV flutter any normal?
  239. AMS Widemouth Downpipe vs the "competition"
  240. Stock muffler inlet size?
  241. BOV recirculation spring settings help
  242. Ets V2 Extreme, TP or HFC?
  243. Mobil 1 0w-40
  244. turbo decision... ef3
  245. exhaust
  246. Clutch smell is there agter a week help
  247. Racing Fuel
  248. AWC PUMP FAIL Compilation
  249. AWC Issue
  250. Got Blaqops fuel pump kit? What size....
