- Help choosing cams
- Stock fuel pump whine
- Exhaust?
- If I do these mods should I add this?
- Weird ACD problem
- Squash Performance Evo X fuel system - tester needed ASAP!
- should i sleeve my block?
- My new FP Red has just arrived!
- Non ball bearing turbo recommendations PLEASE!!!!
- Vibrant 02 anti fouler / spacer
- Buschur exhausts for the x..
- Boost issues(with pictures)
- Engine Swap Evo X
- Extreme Turbo System Exhaust
- Evo X MR Transmission Problem (Help please)
- Need Help with Clutch Purchase!
- SST Mods for my new setup?
- Competition Twin Disc
- Should I post these on the Show & Shine section?
- Stock clutch dying fast. Need replacement advice only mod is Cobb AP Tuner
- Convert SST to Manual
- which holds boost better?
- Center Diff Pins
- Beginning of the end?
- BIG BUILD!6266!I need spark plug help!
- Hole in cv axle boot..
- Mix and match exhaust pieces?
- Engine sputter around 6500-7000rpm...
- Evo X turbo options
- CNT Exhaust and K&N Intake
- Stock BOV
- Varex Mufflers
- identifying fp turbo
- P0134 CEL Light?
- Will straight pipes decrease lag and quicker spool?
- No tune?
- Injen Short Ram w/ UICP thoughts
- E85 question
- Going Green on my SST evo X
- Idle/Driving Issues
- Evo X - Can I use a HKS GTII actuator with the stock turbo?
- Best BOV for a stock turbo?
- Dyno vs Road break in for a built engine
- do i need head studs
- Will my car run with new & upgraded injectors...?
- how long driving with C161E?
- Exhaust Decision: Tomei or Ti-C or...
- Need Some Opinions on Upgrades
- Injen Kit
- Exedy Stage 2 Clutch gone...Help with a new option?
- Limits on stock clutch
- Ark Design 3.5 single exhaust
- Boost problem
- How to disconnect Blaqops quick connects fuel line
- What test pipe downpipe combo is this?
- Zfr 3" intake anyone?
- Switching Fuel Systems - Dual Pump back to single
- ETS V2 vs ETS V2 QUIET
- Clutch master Cylinder
- Question about DP Gaskets
- Evo X Won't start
- HELP evo rear differential convertion
- need tutorial on clutch ajustment
- AMS Short Ram Air Intake
- Leaking transfer case fluid, going to dealership
- HUD says "CHECK" ??????
- Clutch problems
- need help on picking a BOV!!!
- Axle Help
- Clutch problems?
- Agp
- Whine sound around 60mph (t-case?)
- Stock CMC and hydraulics frustrations
- Burnt oil smell
- Cobb Intake
- 500 whp turbo
- Where is this shaking coming from?
- Service engine soon lights on
- AEM Intake + 3 Port BCS
- Supporting an increased Rev Limiter 8500-9000
- SAWC sequence of events
- Clutch suggestions?
- Rods - Carrillo Pro-H vs. Manley Turbo Tuff I-beams
- rough idle
- Mishimoto intercoolers?
- Evo X Block build options??
- Overboost Puzzle
- Fuel Rail Question
- Drive train whine or what?
- New pickup: GTX3071R
- QUESTIONS!from my twin scroll 6266build
- 4G94 Engine injector problems
- Question About Running A Boost Controlled dump pipe
- Mitsu change bottle for ATF SP III? (ACD Fluid)
- Trans fluid temps - manual
- A closer look at H and I Beam Con Rods
- New Evo x GSR BOV question
- Need help, evo x mr please
- Lan evo missfire system
- Good grief fp green/red!!!!!
- Throwout Bearing removal help
- Synchros or Clutch Problems???
- Common dipstick issue
- Bov
- Crank Case Vent Install Locations?
- Just got an X. Need help ID'ing manifold
- Intakes and Knock
- Exhaust popping when warming up engine
- Can Someone Tell Me Where ACD ECU is located ????
- Direct stock replacement LICP other than AMS?
- FMIC and piping
- Clutch stuck to the floor? Plastic CMC fails again!!!
- AMS short ram intake
- ID2000 Injectors (Pump Gas)
- Maintenance on my low mileage X?
- Modding road map , need help!
- Need advices on future build!
- Custom exhaust
- MAP oil feed line routing
- ArkDesign exhaust sound video clip before &after
- Need Help on Power Mods!
- Will ETS intake work with Cobb piping?
- Which Flossy Knob?
- Dual SST
- Flywheel
- Benefits of hardpipes?
- AGP V2 intake tuning
- How to use a new clutch??
- AGP V2 Intake Install
- Stock turbo record
- Shifter Issue
- ACD Servie Required Light
- Injector Decision
- Clutch is gone
- Clutch engagement
- I need some quick advice.
- Anyone with a 2012 and upgraded clutch?
- mod advice
- THANX Akuma Motorsports!!!!
- invidia exhaust tips question
- Clutch Master Cilinder gone! advice
- HELP: Trans/shifter problem!!
- MAP test pipe ?
- AMS 2.2 Short Block Built Moore Automotive Inc.
- 4th/5th Gear Whine/Grinding
- Motor Guard
- ETS Intake with Synapse Synchronic bov?
- ets turbo
- ASC Service - Help
- Walbro 400 - E85 version
- Rear O2 sensor wire question
- Intake
- ETS Performance
- blew the motor, tcase and rear diff
- TWM Shifter Cage
- ETS Intake arriving today
- Short Throw Questions
- Intercooler piping
- Finally decided on exhaust quick question
- Greddy Ti-C - what is this?
- Fuel System for E85
- Cams
- Can any tuner/engine builder sleeve my block
- Car ran lean running at the track
- Sleeved block
- injector and fuel pump question
- convert 4d68 Mitsubishi engine to 4d68T (Turbo) Mitsubishi engine.. URGENT
- Is a Downpipe Worth it?
- Best Cat Back Dual Exhaust System for Evo X under $2,000
- Super Noisy Valvetrain
- TBE suggestions?
- Nooby question about the cosworth cams.
- WARNING: MAP Heat Shield
- Downpipes. One pipe to rule them all?
- Need help with my clutch
- Turboxs and cnt exhaust
- The Goods Just Came
- hard rotational thumping from drivetrain
- turbo kit for safe 400whp?
- New clutch time
- SARD fuel pump/help
- Tanabe Concept G and others
- BC Cams
- Mishimotor Oil cooler
- Valve cover
- FP RED BALL BALL BEARING on Evo X MR SST
- Synapse DV flange problem
- E85 conversion - stock turbo
- Tial bov
- test pipe question.
- Best BOV - evo x
- 2010 Evo X GSR gearbox noise
- Installling OEM Boost Solenoid
- Starter won't turn off!
- Injector O-ring Part Number
- injectors and fuel pump, decisions decisions
- Beatrush Rear Differential Spacer OR Torque Solution Differential Mount Inserts?
- HELP - Engine Noise problem!!!
- Bosch 044 Relocation?
- Last Minute Mods? (Baby on the Way)
- Looking to Steal an Engine from an Evo
- Grimmspeed 3 port & black solenoid
- Huge exhaust leak or.....?
- Intake
- clutch replacement problem
- OE turbo inlet specs
- Correct method of..
- Shifter Rattle
- Turbo has no wind
- Just ordered the RRE Single Stealth exhaust
- time for a new clutch (witch one should i go with)
- Loud Rattling noise, when let off throttle at 4k
- Stock turbo
- Evo X spark plug failures
- Torque with Stock internals?
- Idle issue + Diagnosis
- Greddy Ti-C exhaust details and tuning suggestion
- AWS / AYC / ACD pump failures and rebuilds
- ETS V2 vs less expensive exhausts..?
- Low idle, slight hesitations @ cruise
- Engine problem [urgent]
- Low Fuel Pressure - I'm LOST!!!!!!
- Somebody is coming after me!!!I have a turbo question...
- Injector Resistor
- Tilton Clutch
- 6266 vids?
- Anybody run this?
- DSG/Demi's Time Attack Build!! Now in HD!
- Synapse DV, is this normal?
- Cat-back suggestion: Greddy vs Ultimate Racing .. (Plz Vote)
- ultimate racing intercooler
- To Catch can or not to catch can…???
- AEM CAI question
- Full Race porn with added Zircotec
- HELP! Radiator fan replacements
- Throw out bearing?
- 2011, mr 23,000km Oil pan leak 10mm bolts loose
- have around 1000 or so to spend
- Daily Driven clutch
- The o2 cel fix solutions
- Is this what old spark plugs should look like?
- ACT flywheel advice
- Need some input.. Coolant/radiator problems..
- Precision 6262 Is this is a good deal?
- Please help defeat exhaust drone!
- Stock Cat pipe bolt and nut sizes?
- Having problems with throwout!!!!
- You're Tired of These Threads but... Build Help
- Exhaust Bung Plugs
- Custom Single Exhaust Question
