- HKS SSQ4 BOV recirculation
- Exhaust heat near prop shaft
- evo x diff
- Theory of intercooler piping
- Over boosting :/
- HELP! what am I missing?
- 15k miles and clutch?
- Exhaust volume help
- AMS TMP cams installed (video)
- Transmission failure?
- evo 8 plugs (BPR8ES) use for Evo X?
- AMS TMP cams Idle RPM
- Hey guys! Just bought a 2010 GSR need help!
- Smells gasoline fume from inside....?
- crossflow or cobb oval tip
- Buschur Racing Testpipe with Magnaflow Muffler
- FP Green vs FP Black vs FP RED vs MAF 2.5 (Compare/Differences)
- Whos all running top mount turbo kits?
- anyone running an efr turbo?
- ets t3 kit 6262 or 6266 or 6466
- Replacing Stock bov/bpv Pipe
- Coming up on my 45k service interval
- Tomei Procams
- Compressor surge with new SRI?
- Clutch suggestion
- which downpipe????
- Titek cooling plate
- Belt like noise ???
- Exhaust manifold suggestions
- Greddy Intake question
- Howling on start up under 38ºf
- Shifting making squeaking noises [VIDEO]
- Hows this Clutch, Pressure Plate and Flywheel
- Ark Performance N-II V2 single exit catback review w pics and videos
- buying exhaust
- Help! Engine noise.
- Cel - p0068
- Well its almost Evo time in Northern MN , how about an f7ben build thread
- Water from exhaust?
- who repairs ACD/AYC pumps?
- Which clutch for stock CMC?
- Who makes a after market timing chain???
- Connecting Rod Specs and Info
- Crazy rev hang!
- Pcv
- Any FP Green X's gone to GSC S2's?
- Bad Idle//Pulled my oil dipstick and engine almost died?
- Shep Trans 4.30 Final Drive.
- Another evo x transfer case story
- 09 lancer evo x swap getting code u0121
- Rev-hang during upshift
- What's the purpose of changing ATF in rear diff?
- Is a little oil on the boost pill ok?
- Slight Hesitation
- Turbo selection Help
- Got a CEL, need some input.
- HELP: Transfer case leak
- HELP (tarmac mode problems)
- Cams Recommendation guyz
- Pistons options??
- Ef3 or ef4
- Thinking about picking up a test pipe and downpipe!
- aem intake and cobb exhaust installed yesterday
- Whine noise from tranny, not t-case
- Question on Gear Oils
- Timing Chain Warning Light HELP!!!
- AMS exhaust???
- Bad Idle+car stalls after driving for a while
- What is needed to make my engine "safe" for big HP
- Overboosting T.T
- Competition Clutch Stage 3 Series 2250 or 2600?
- Problem after installing AMS gate selector bushing
- Turbo choice
- Shifter Bushings
- Slight Clunk Left Front
- Ets v2 quiet vs cobb quad
- Cold Weather Whining Siren
- Tomei Downpipe vs UR downpipe
- Question regarding the Notchy trans//Hard shifting
- buschur exhaust comparison
- 08 evox idling rich and dying?
- Upgraded wastegate actuator
- Light smoke in boost.
- Anyone using ATP's downpipe?
- Smelly Clutch
- powertrain warranty gods
- What FP turbo is this?
- 08 GSR Intercooler?
- EVO X max power on stock motor?
- Invidia N1 CBE touching rear diff....HELP
- Intake sound (spooling and bov) question - AMS & ETS
- Evo X is not spooling up?! NO BOOST??
- Seeking 400
- Installed Torque Solutions Rear Diff Bush and...
- Sasquatch spinning my wheels on an Evo X
- Kelford "King Cams" for EVO X!!!
- Launching on stock clutch @ drag strip
- Deep loud exhaust
- Ugly Noise at Cold Start-Up
- Comp Stage 2 HDSS vs CM FX300?
- Evo x mr 08 rough idle
- Stupid sputter. At around 2500-2900 rpm
- Bolt-ons advice
- Upgrade List needs some help
- Cams
- Looking at two clutches.
- 2012 evo x MR with bad cat????
- Changing valve springs with out removing head
- piping question
- Mobil 1 0w40?
- Upgrades
- Q to those w/ SSP CMC
- Cobb sf intake
- Clutch or turbo..
- Shift Linkage Issues
- Saw a blown Motor
- GSC s2's finally installed
- Drop-in Pistons
- Use turbo gasket on divorced DP?
- injen only uicp
- Transfer case removal issue
- MIVEC solenoid separated during head disassembly
- Specific Oil for BBX Turbo?
- Testing a new ACD Controller
- Exhaust too loud!! HELP. What are my options?
- Need some tranny install tips...
- Clutch recommendations?
- GrimmSpeed Install without tune?
- Exhaust Advice
- Need some help with fluid recommendations
- Evo X Transmission help\WORKS Short shifter
- Ef2.5 group buy
- Upgrading EVO X Stock BOV
- Transmission HELP!
- Rear diff pinion gear help
- EVO X connecting rods OEM
- Cracked Exhaust Manifold
- just a few clutch questions, act wore out quick
- GReddy spectrum elite
- K&N Typhoon Intake
- Fully recirculated bov
- Did redline tranny flush and still having problems..
- Please help me pick parts for my DD / track day car
- WORKS underhood bushings - lost one!
- Redline cocktail mixture
- exedy twin hd simple questions and driving impressions
- Megan Racing OE-RS Exhaust?
- stage 1,stage 2 cams
- Intake for a FP Green
- Tsudo CBE installed...my impressions
- Where can I find a oem 4b11T Aluminum Valve cover. Mitsu parts no help
- Vacuum line adapter (larger to smaller)
- Cobb BOV lost its blowing sound
- Turbo XS Exhaust.
- Need help on transmission bushing!!!
- the great air filter question
- T3 vs T4
- Is my '08 GSR tranny toast?
- Evo X final drive feeler
- AMS Turbo Back
- Is it safe to drive without a tune?
- Muffler Delete weird noise
- Deleted
- TiAL QR BOV
- Turbo inlet very dirty an oily.
- mitsubishi made a new turbo for X
- Garret gtx 3071r
- Hyundai Pullies
- Password jdm intake
- How big is power difference...
- how loud will this be?
- ets o2 open dump downpipe with stock cat and ets catback exhaust
- The OFFICIAL Oil Filter Testing and Results Thread (4G63T/4B11T)
- BB FP Red - Oil Leak
- Poll: Who is running HKS GT7460 Turbo?
- What to get after stock clutch goes out?
- AGP cai EVO X GSR
- getting a tune at ivey tuning, cant wait
- Cotter Pin on Shifter Links
- Injen intake for 2013 for X
- what's wrong with my evo video included
- Best tranny fluid to use?
- exedy twin hd driveability
- Reliability?
- Got a taste, now hungry for more
- flapping noise after boost
- Fuel system upgrade question
- New 08' Evo X MR!!! What kind of air intake to get?
- ams or map downpipe..
- 02 sensor please help. Thanks
- Saikou Michi DC3 Dual Catch Can
- RPM problems after track day
- Cobb Tuning BPV question....
- AMS 950R Kit + SSP Stage 4 Tranny upgrade = ???
- sputtering sound when WOT
- Exhaust help needed, the choices are killing me!
- This is what happens when you forget to be careful with the oil return line.
- Awc
- my '12 MR makes noise on bumpy roads
- My mitshubishi Intermittent starting problems
- AEM Wideband Failsafe Gauge
- Idle surging, evap leak
- Help Throwing p0014
- First build...what's next?
- Whats wrong with my Evo X - with video
- Where to buy OEM boost pill
- Stock Evo X Engine Capability
- Clutch + Flywheel pairing questions.
- Blouch BB Turbo for the X
- JDL Manifold
- First X build - Help and opinions wanted (parts list inside)
- Aluminum CMC rumor: 2013?
- Stuck shifter
- Fmic
- Cosworth MX1 vs Kelford 214A
- 2500-3000 RPM Misfire
- Timing Chain Replacement
- Replacement of CMC and CSC
- Turbine Housing Question
- Loud "tac tac" sound from the valve area.
- 550whp on single Fuel Pump?
- New Clutch...not sure what the problem is
- Right time for a new downpipe?
- Anyone have their valves "adjusted"
- New clutch install problem
- Gsrdriver08 2.5L motor build
- Another evo X clutch master cylinder victim.
- Help!Grumbling noise from downpipe?
- Exhaust help, Turboback Exhaust with or without cat?
- dry filter on an ets intake?
- Car stalling out on start up
- ETS Titanium Piping Kit For Evo X
- Intercooler Question
- Comp Stage 2 2100
- What are the odds of Catostrophic failure lol
- i got water in my engine
- Exhaust questions, help appreciated !
- boost controller manual/electronic
- So I stalled my car.......... A lot
- EVO IX MR 6 speed
- New DSLR Video Test; Tomei Expreme Ti Exhaust Video inside
- Quiet Exhaust Installed
- Building Block Piston-Rod Suggestions
- HELP!!!! Evo x build questions/opinions wanted
- Putting together list of parts for 400awhp build
- I shifted to 3rd instead of fifth by accident
- New AMS Head and New TMP Camshafts are in!
- Clutch installed but where does this part go back to?
- Should I get cams? FP black stock block
- Help choosing cams
