PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. q on installing cusco rear LSD
  2. Which clutch would best suit my needs?
  3. Ripped my belt
  4. Service engine light
  5. Magnus CMC engages high?
  6. catbacks
  7. Hollywood / AMS 750R / E85 / dump tube build
  8. Is a new fuel pump needed?
  9. E85 water absorption-fact or fiction
  10. Short review - ACT HD 6Puck Sprung/Streetlite flywheel
  11. ETS intake without a tune?
  12. Oil Squirters Hitting Pistons
  13. Cobb Tuning Quad Tip Exhaust
  14. Need Help! Car not working
  15. Tomei Exhaust
  16. help - serpentine belt
  17. Oversize valves 4b11
  18. Garrett GTX3582r & ETS Mani Heat coated
  19. AQ Motorsports Intake
  20. need help ASAP
  21. Bov
  22. taming an Agency Power exhaust
  23. My teardown
  24. displacement affects on spool
  25. best intake...
  26. To run e85 safely..
  27. maf housing
  28. Downpipe or not on stock turbo?
  29. exhaust question...
  30. Surge tank ideas with double pumper
  31. Shifting Problems?
  32. My engine/turbo build plan, need advice.
  33. Cusco Rear Diff + ????
  34. 375whp evo in need of a new clutch.. HELP!
  35. Forged Performance: 4B11T Motor Build
  36. vibrant cel fix
  37. Erratic Idle - faulty injectors or something else?
  38. Exhaust cam gear - Mivec
  39. Boost Gauge vs Cobb AP
  40. Compresser surge or over boost?
  41. GRRR...Creepy issue with my twin clutch sst now...
  42. take a look at this
  43. new built motor noise help
  44. ETS Testpipe
  45. Thrust bearing fitment?
  46. 26psi stock
  47. Which BOV is best for the evo x?
  48. Garrett Turbo hotside bolt specs
  49. mini battery help
  50. Front Axle Nut Size?
  51. 3rd gear
  52. Transfer case removal?
  53. Maybe I'm retarded? X SE shifting problem
  54. Anyone using an away from engine CAI?
  55. coltspeed muffler
  56. Shep VS TRE Transmissions
  57. Borg Warner s300v turbo controller module
  58. Evo X Launch
  59. Running rich/boost spike cause of exhaust leak?
  60. upgrade help with bolton parts
  61. Tial QR BOV part throttle flutter
  62. Carbon build-up inside downpipe?
  63. Intake manifolds
  64. Any 2.2 / 2.3 Sleeved Big Bore Builds?
  65. Turbo area tapping noise
  66. Help, with CMC questions!
  67. Here we go again, part 3 of trouble.
  68. shep diff
  69. Hi flow/Cat back install
  70. Samco Intercooler Hose kit
  71. possible clutch slip? need help
  72. Exedy twin hd clutch engagement!
  73. evo x turbo hotside
  74. T-case die on me
  75. DTC P1320 Error Code
  76. Exhausts on RHD?
  77. So Downpipes
  78. Turbo noise and shaft play at 58k miles - Normal? (vids inside)
  79. Engine warm up
  80. 2.0, 2.3, 2.4 can't decide? :(
  81. Intake recirc size
  82. One more thread to get suggestions on my setup with cobb
  83. Ultimate racing intercooler thoughts
  84. thumping sounds in rear when turning only
  85. Boost Solenoid Explanation
  86. Question on a test pipe for a CNT catback version 3
  87. Exhaust review + video cp-e
  88. P0301 cylinder 1 misfire after oil change
  89. Yup! Hole in my transmission due to failure of Differential pins
  90. Akuma Intake and CNT Exhaust Video
  91. FMIC Damaged
  92. Ralliart Grp-N I-beam conrods
  93. Ralliart Grp-N CMC kit
  94. upgrading fuel injectors requires tune?
  95. Differential pins made a hole in my transmission
  96. Strange noise
  97. Future build questions
  98. Still overboosting!?!
  99. Fuel pressure gauge in engine bay
  100. DTC Code P183D
  101. MXP test pipe?
  102. Ams LICP Question
  103. Redline Fluids
  104. Weird "break" sound from back drivetrain and service light
  105. ETS does it again!!
  106. Couple issues im having with my mr
  107. Ralliart front axle...interchangeable??
  108. Buschur Crossflow and Perrin HFC Combo?
  109. Which Turbo?
  110. Need help for DV !
  111. fp green installed and tuned-- NOT holding boost?
  112. Hyundai engine part #
  113. Scratchy noise when hitting boost?
  114. Cosworth Cam owners please come inside....
  115. SST Downshift problem...
  116. Is it possible to swap intake and exhaust cams during installation?
  117. FP black lots of smoke clouds out the tailpipes
  118. Blitz Nur Spec Ct-i midpipe question.
  119. '10 MR tranny question
  120. cams
  121. Boost Solenoid?
  122. Downpipe Bolts..?
  123. Ac not working
  124. Good turbo theory site
  125. Question on a custom exhaust
  126. I need more stuff!
  127. Funny smell after acceleration
  128. AEM intake install
  129. Reving in N
  130. Head Gaskets?
  131. Anyone using a light weight flywheel?
  132. Kansai Carbon Air Box - Evo X
  133. ASC and 4 wheel drive issues...
  134. Are these DW 1300's faulty?
  135. Thud or thump from rear during hard shifting
  136. Can stock engine handle 400hp
  137. best fmic
  138. Engine Coolant Temp value
  139. ETS V-band Manifolds For Evo X Turbo Kits
  140. ETS V2 Quiet Edition Exhaust
  141. DW 1300cc Question
  142. help, gruppe m or coltspeed intake
  143. CP-E Downpipe
  144. Mishimoto intercooler
  145. what clutch for 500-600 whp?
  146. Air Intake Bung Question
  147. Urgent help needed
  148. Transmission/Clutch question
  149. Downpipe advise
  150. GSC S2 Mivec Maps
  151. clutch trouble
  152. Funny Smell and Hesitation
  153. clutch/trans issue
  154. what compression ratio for 93oct?
  155. SSP Master Cylinder Problem
  156. FP Green max hp
  157. car slower after test pipe install using cobb maps??
  158. Well my clutch is done.. replacements?
  159. Best settings for oversteer under power (Attn track junkies)
  160. New Carbon Fiber UICP
  161. Cams for FP Red
  162. intercooler core size
  163. Good Exhaust Manifold?
  164. 4b11 power limit with stock stage
  165. Testing the Back Up Switch
  166. Turbo gasket high heat sealant question
  167. Loud exhaust setup
  168. Can my stock turbo be spooling at 3900 RPM?
  169. E85 Containers?
  170. explain effective compression??
  171. Turbo theory
  172. Clutch question
  173. PJDM:Carbon Fiber Intake??
  174. Best Performing Quiet Exhaust
  175. cams
  176. 08 gsr T-case rebuild
  177. Clunking sound going into gear with clutch pushed in
  178. Exhauest question
  179. Dreaded S-AWC warning light help
  180. Stock turbo over speed
  181. Which gear oil do you use?
  182. what is the best safety internal upgrade for fpblack
  183. Can i do downpipe and high flow cat with stock exhaust ?
  184. Invidia TBE
  185. Downpipe/Exhaust Matchup and Fitment
  186. Exedy stage 2 clutch- CHATTER!
  187. Ets o2 eliminator downpipe dump/recirculate?
  188. megan racing exhuast manifold FTL
  189. Grimmspeed 3port
  190. Exedy Clutch Types
  191. TIR exhaust is garbage
  192. New Clutch???
  193. identify this heatshield
  194. exhaust manifold leaks
  195. Downpipe and testpipe???
  196. Diff pins failing symptoms
  197. Magnus Evo IX CMC conversion or SSP CMC?
  198. Need help with 2.0 build
  199. Is "OK" put Tomei Ti exhaust on my car to go to Laguna Seca and have fun?
  200. Megan Racing downpipe
  201. Tomioka Exhaust
  202. Word of Warning: Inner CV Boot Leaks
  203. New Lifters
  204. Exedy Twin Disc or ACT HD 6 Pad?
  205. Clutch advise
  206. Getting ready for a tune..advice?
  207. CNT RS Video. You ask for it now you got it.
  208. Transfer Case Fluid: Diaqueen vs. Amsoil Severe Gear 75W-90?
  209. Oil Catch Can Install
  210. Torn between ams and buscher fmic
  211. Sticking Lifter?
  212. invidia exhaust problem !
  213. HELP! Moaning sound when i start off in 1st gear..
  214. Help with exhaust! MR x
  215. which downpipe?
  216. Cosworth cams on FP-Black?
  217. car dies
  218. Hks racing suction intake
  219. Bad propeller shaft?
  220. valve lash gap?
  221. NEEDED: 10.0:1 pistons for evo x
  222. Slipping
  223. OEM complete head price??? :confused:
  224. Plastic cover under engine
  225. Help on Exedy Stage 1 clutch install...
  226. output shaft won't release
  227. Setting base fuel pressure
  228. OEM TO bearing with Spec clutch?
  229. Cobb 400 kit
  230. ACD reservoir in trunk
  231. fp green or red?
  232. turning the flywheel?
  233. Cm fx400
  234. New part!
  235. Forge Wastegate Actuator spring help?
  236. m7 japan exhaust
  237. Full Race Prostock Tubular Manifold: Qn
  238. FP HTA 3794 or GT4094
  239. dry sump and damper crank pulley
  240. Starter Problem?
  241. Exedy clutch review
  242. Password JDM
  243. tomei exhaust people
  244. Anyone use valvoline vr1 Non synthetic
  245. ACD codes
  246. Little to no boost....stock x :/
  247. Clutch Pedal Not returning...
  248. Wastegate Actuator pretension when using a 3-port
  249. Noise from under the car
  250. Ikea Formula Shifter
