PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30
  1. Poor throttle pedal tables leading to premature clutch death?
  2. Aftermarket wastegate actuator owners, in here please
  3. Evo x problem!
  4. Fixing boosting taper.
  5. Is a tune required after intake manifold upgrade?
  6. Intake...MAF...Tune?
  7. SPEC Super twin clutch
  8. Stock Heat Shield and Tuner 02/dp
  9. Complete 4B11T Build
  10. Changed my tranny fluid today....opps?
  11. Carbonetic's new blade clutch
  12. Anyone using this Down pipe/Cat ?
  13. AMS Motor Mount Bushings - Install issues
  14. so let me get this straight...
  15. Oil drain plug gasket - anything more durable?
  16. fluid change?
  17. Getting a new OEM transfer case
  18. Port and Polish Stock Turbo
  19. Gates311 Review - Carbonetic Triple Carbon clutch / AMS Clutch Master Cylinder Ring
  20. Stock OEM Clutch Life - Evo X
  21. Throttle Body Diameter (Coupler Size)
  22. AMS Intake Options?
  23. Evo X Oil Filter Issues / Failures ?
  24. Best Mod's/Parts Out There
  25. Clutch/Brake Pedal Rubber Pads
  26. Pipe from turbo to downpipe?
  27. Nisei UICP Fitment
  28. How to test if uprated WGA is working?
  29. Full TBE -> Stock Muffler
  30. My CP-E Dual Catback Review
  31. Which exhaust doesnt bottle neck?
  32. Megan Racing 3" dual CBE
  33. Exhaust question for the X
  34. Evo Short Throw And Shift Boot
  35. CV axle problem??
  36. HBS Fuel pump housing in the works!
  37. Who here has replaced there own clutch?
  38. Spark Plugs
  39. best drop in
  40. Tomei 2.3L Stroker Kit, ARMS Turbo & Complete Engine
  41. NAME THAT SMELL A week of clutch smell
  42. Best Brand UICP?
  43. ams o2 dp vs perrin dp with hfc part II
  44. Test pipe suggestions
  45. Going to get tuned in a week, preparations?
  46. Groden Lightweight Aluminum Racing Rods now available for Evo X GSR & MR!
  47. Forge RS BOV does fit EVO X ***Pics Inside***
  48. Turbo back exhausts?
  49. Turbo restrictor
  50. Idle Vacuum
  51. Cobb/Perrin Turbo Inlet vs Nisei Turbo inlet
  52. 3" LICP (Cold Side)
  53. Those with a Test Pipe?? Quick Question
  54. Jerking above 5k RPM after UICP Install?
  55. Anyone done this?
  56. Fighting SES light please inform if you know?
  57. Injen Intake Installed... Questions
  58. Which exhaust drones?
  59. ARC UICP and HKS Installed
  60. Transmission/Clutch Noise
  61. Installed the 3" Buschur Bullet catback
  62. Stock Lower Intercooler Pipe Coupler Size
  63. Full race manifold
  64. need help with short shifters
  65. Stock Clutch Collective
  66. Pics: Buschur Carbon Fiber Intake Shield
  67. qtp electric cutout placement question
  68. build date vs engine & trans failures
  69. Knock Retard w/ Accessport
  70. AMS Dual Exit Exhaust Released!
  71. Where Else Can I Buy Works Underhood Bushings And AMS Front Motor Mount
  72. T1R exhaust questions for the people who have it
  73. Rev Hard Piping kit
  74. Which downpipe?
  75. E85/Red: Which shop will take this on?
  76. NEW ARRIVAL: Blitz Intake Surge Tank
  77. Cam Install: Anyone checked / changed buckets?
  78. Reverse is no where to be found...
  79. new clutch : slower 60' :-(
  80. whats better garret 30r? or fp red?
  81. How do you fix the rough changing into second gear
  82. WTF! I broke my 2nd master clutch cylinder in 10 days
  83. Specialty X dual catback
  84. Perrin Stage 2 Power Kit (TBE + ECU tuning stage 2): suggestions please!
  85. HELP question about hks intake w SSQV
  86. Short Ram vs. Cold Air Intake
  87. Help me decide, Perrin or Cosworth drop-in filter
  88. Perrin Turbo Back Exhaust - $1105 a good price?
  89. HKS turbo kit
  90. Still Undecided help me choose!
  91. What exhuast is this?
  92. Large fitting on Greddy oil filter adapter
  93. Fitment Issues with XtremeBoost Downpipe
  94. Mitsubishi unbelievable
  95. HELP!!! Problem after installing new spark plugs
  96. HKS Kansai X-Flow Exhaust
  97. SpeedCircuit CAI
  98. Megan racing single drift exhaust installed!
  99. First Time At The Track 12.61 @ 111.00mph! *un-tuned* Also HELP With Clutch Question!
  100. look at those cheap exhaust
  101. Custom Ultimate Racing Exhaust
  102. downpipe
  103. 2nd Gear jerky Clutch Grab? GSR Manual
  104. weld o2 bung in stock downpipe
  105. so how many people question
  106. How many people run TBE with the factory cat still on?
  107. just got turbo back exhaust
  108. Exhaust....
  109. Need Help, car dies in rain?
  110. Dealer replacing the input shaft
  111. eBay CAI and Hard Pipes
  112. tune or exhaust
  113. rear seal/throwout bearing
  114. Cam comparison
  115. Evo X stock exhaust with 3" test pipe question
  116. ACT ME-1 HDSS Anyone?
  117. aftermarket O2/dump/cat pipe with standard cat back?? suggestions?
  118. Stuck between 3 exhaust...
  119. Crank Pulley
  120. Okay I've got it narrowed down to two exhausts... (I think)
  121. Exhaust hangers
  122. Max out stock turbo
  123. T1R muffler?
  124. Best exhaust for the money?
  125. exhaustdepot catback install and sound clip
  126. 15 dollar HP!
  127. untuned Evo X with test pipe...?
  128. Evo X MR auto tranny switch to manually tranny
  129. Car going back to the dealer
  130. Evo X with Garrett GT3076R Turbo Upgrade
  131. AEM CAI w/stock vac line setup?
  132. New Invidia Q300 for Evo X
  133. Bov question (forge rs)
  134. AMS EVO X Clutch Master Cylinder Reinforcement Ring
  135. would like to know info on exhaust
  136. Rear Bank o2 sensor replacment
  137. Some food for though about the AMS fix for the master clutch cylinder...
  138. New turbo setup
  139. Deatsch Werks 1000 cc injectors
  140. AEM intake gain from 16 to 30whp gain?
  141. Moving to HOT climate! Which air induction method?
  142. Wastegate Actuator vs MBC
  143. Odd exhaust sound
  144. Two choices: HKS Hi Power or Ultimate Racing Dual exhaust?
  145. Motor mounts and Transmission mounts going bad at 16000 miles
  146. ASC off automatically when full throttle pull in first gear if i get full traction
  147. Clutch & Flywheel - Check Light
  148. Evo X Filter Choices...
  149. LICP for EVO X MR
  150. valve cover pic request and info
  151. W5M6A question
  152. ams vs perrin
  153. do i need a tune?
  154. Possible Fuel Starvation Solution
  155. Cp-e single exit exhaust
  156. Garret Bolt ons
  157. I found a way to make MY evo X shift better
  158. Magnaflow Cat-back - More Info?
  159. Accelerated onto expressway then extreme misfiring...
  160. I need...a quiet exhaust
  161. HKS intake install
  162. Bov mess with the MAF sensor?
  163. DIY wastegate is 100% safe?
  164. Cusco front LSD settings
  165. NEED HELP guys.....installed mbc and only 14-15psi
  166. Major Boost loss at 15 lbs
  167. new exedy clutch and funny noises!
  168. HELP! AFR freaking out randomly
  169. Installed ARC FMIC
  170. Anyone experience noise switching back to panel filter?
  171. engine whine after 1st oil change??
  172. 1/8 tap on intake manifold
  173. head studs - has anyone installed a set?
  174. tranny reliability
  175. HKS Drop in filter install question?
  176. what the heck is this
  177. Drop in air filter with the new reflash from factory?
  178. Feels good going back to a stock clutch
  179. head rebuild
  180. Did new clutch fix your Notchiness?
  181. Race gas??
  182. exhaust with a switch from loud to quiet
  183. Wideband issue/troubles
  184. Decent price on shifter bushings
  185. boost increase?
  186. clutch?
  187. Agency Power Exhaust
  188. ~ EVO X : AEM - WORKS - INJEN Intake Shootout: Round 1
  189. Clutch Engagement
  190. 7.2whp gains by adding Royal Purple oil
  191. CP-e Exhaust
  192. FMIC AMS v. ETS v. Perrin (Discussion)
  193. Invidia N1 exhaust on my Evo X
  194. Stock clutch limit?
  195. Best clutch for about 500HP
  196. Braided lines
  197. positive battery terminal question
  198. Which downpipe... MXP or Ichiba ???
  199. drivetrain service required screen????
  200. Cylinder misfire then loudd pop when driving? Helllppp please
  201. Another engine durability question
  202. Ivey, Full-Race BW TS S300 part 2 - woke up the monster
  203. CEL with downpipe and cat-delete
  204. Anyone tried it? MR shift knob on GSR
  205. Drop-in Filter, BOV sound
  206. Megan oe rs sound clip?
  207. Help me decide on CBE *POLL* edited to add more options
  208. Raccoon vs Intercooler... and replacement :D
  209. Help me decide on CBE *POLL*
  210. It was a sad day for me..
  211. take that pos mitsu clutch
  212. What list of mods would you say I should start with?
  213. What is the limit of the stock block?
  214. AMS single tip exhaust owners, how low is the exhaust in the back?
  215. Front Limited Slip Differential
  216. Hesitation after launching
  217. Exedy Stage 2 Cerametallic Clutch
  218. GSR gear ratios?
  219. Forge WGA + HKS EVC EBC
  220. Need help identifying a sound
  221. High Flow cat....
  222. newbie tuner
  223. home made cone filter heat shield
  224. DG Motor's Evo X Cosworth MX1 Cam Idle video
  225. Engine warning light with new TBE
  226. Additional Parts Needed for Clutch Upgrade?
  227. P0420 Code with Speed Circuit Test Pipe??
  228. Boost pill - yes or no?
  229. Eneos 5W-30 Sythetic Motor Oil
  230. Blitz sonic power induction
  231. exhasut leak?
  232. Agency Power downpipe problems
  233. Dumb question. Are there gaskets in the stock exhaust?
  234. 27 PSI okay? With No tune
  235. Need help PLZ w/ hose removal...
  236. Man this blows *pics*
  237. Xtremeboot O/2 dump down pipe
  238. who knows the reason for reverse problems?
  239. AMS Surge Tank kit
  240. post aftermarket install advice
  241. Stock plastic MAF sensor housing > aftermarket metal MAF sensor housing?
  242. Pics Of My FP Red
  243. HKS GT Full Turbine Kit (GT3240)
  244. How much fluid DIAMOND ATF SP III? Equivalent?
  245. couple of goodies
  246. Stiff shifter between 3-4 gears
  247. Pics: Twm short shifter
  248. Blips in throttle. Weird BOV scenario
  249. Injector Dynamics 1000cc injectors
  250. Best Intake/BOV/Exhaust Combination?
