- Rev9 Manifold
- Clutch Slip Gone After Oil Change?
- New- GSC S3's for the Evo X
- Need To Find Oil Pressure Guage Reducer/Adapter
- engine removal
- Any Tomei cam users?
- Anyone ever pull the engine leaving the SST in the car?
- Hub nut torque
- New Owner from Tuscaloosa, AL
- Hardware for turbo swap
- gtx3076 build
- Clutch is going out I think help
- 18k On The Way!
- Fuel System Upgrade Questions
- SteamSpeed STX71 Turbo Review
- Misfire won't go away
- Anyone have experience with BAD oil burning smoke? What was it?
- Turbo Selection
- Turbo Rebuild Kit for EF4
- Can the stock BOV handle a Garrett GTX 3582R Dual Ball Bearing Turbo Gen II?
- Mitsubishi SAE90 LSD oil discontinued
- EVOX rear differential mounting brackets
- evo x boost problems
- ACD/AYC Rebuilded pump issue
- tc sst level fluid
- What happen to all the stok housing bigger turbos?
- Help! Which ATP GEN2 GTX3576 Stock Location Turbocharger to buy ?
- manifold, turbo, 02 housing removal
- how to run ewg on evo X !!! help !!!?
- SmokeSolid's EVO X Engine Build + All BoltOns + Upgraded Engine Internals & Turbo
- Pump Warranty Issue
- Xmas gift to myself
- Extreme Turbo Systems Holiday Sale! Hurry!
- Evo X FE goes BOOM!
- Strange Flutter Under Load While in Boost
- Fuel Smell..?
- OEM throw out bearing, to be or not to be?
- New set up ideas
- STM Top-Mount or AMS 900XP Turbo Kit......thoughts?
- Looking for good Jekyl/Hyde exhaust.
- Automatic-dual Transmision oil for Hyundai Tucson 2006 2.0L
- Extreme Turbo Systems Thanksgiving/Black Friday Sale
- Black Friday/Cyber Monday 2017 - Deals Start Now!
- Royal purple gear oil in 5speed 4g69
- Clutch sound normal?
- sst clunk when turning ignition off
- Ralliart EVO swap engine ticking noise
- Mods to get 400-450whp/tq??
- Chasing down multiple issue in regards to power cut
- Evo X vs 9 Intake Mani
- Anyone used an exedy stage 1 HD before?
- Whining noise under 3500 rpm !
- 4B11T Crank
- Front bearing cap/torquing to spec issues
- I put a turbo on my 2015 lancer
- Fuel System Setup
- Injen Evolution intake Installed
- Crank pulley clearance issue..?
- Downpipe cutout or a similar alternative?
- Spectre Air intake
- Knock light e85 issues
- Gear lever issue '11 GSR
- Getting flutter on a 15 ralliart
- Bolt size for Rear main seal?
- p0171 and burnt clutch
- Evo X Rear diff
- Turbo leak
- evo x engine
- Turbo removal
- Evo x GSR Oil filter
- Anyone have AYC/ACD. oil pump seal part number?
- 20g and 71hta discussion
- Bad AYC/ACD pump motor. Source for new? Looks like ABS motor?
- New motor. Car stalls coming to a stop.
- Loud metals noise from under hood
- Ets Precision 6262 or Driven Fab EFR 8374 kit
- Need help removing transfer case
- I need feed back on ETS PTE6262 on stock block
- FP new HTZ Compressor wheels
- Fluttering RPM and air noise?
- Air filter for AMS short ram intake on Evo X
- Injector noise or a bigger problem?
- Solutions for EVOX 3rd gear notchiness&grinding
- Tryna find the right cams for me!!
- Reliability: Turbo vs. E85
- Manifold temps raising rapidly
- Advice on head work "needed"
- Overboosting while car is moving
- Precision 6262 turbo
- Help in installing ETS turbo
- ETS T4 TS Turbo Kit and Phantom Knock (2 month long headache)
- Sst fluid change 2 drains, help help...
- 2015 Lancer -> evo turbo parts?
- GSR shifter just dropped down while driving
- Turbo bolt/stud specs.
- Intermitent long start up
- Engine Warranty
- Need some feedback for possible engine build.
- New Exedy Twin Organic - Wow!
- Planning on Converting to E85 could use some tips
- Part Number or Part
- Rexspeed steering wheel column dual gauge pod
- ISO a few oem parts
- EVO X SST gearbox remove
- does ets cat less downpipe fits in ultiamte racing catback
- Anything else that will add HP?
- 5858 no boost?
- Pump is failing, code C161F, my car is cobb protuned what are my options?
- CBRD Boost Controller Install
- Rear Diff Drain Plug Disappeared?
- Misfire issues
- Evo x a/f ratio issue maybe?
- Clutch Issue - has anybody seen this before?
- Sakura intake and Synapse BOV installed correctly?
- Broken downpipe 😠
- Evo X Drag Build - Inform and Humble Me.
- Solid mounts ?
- Trans Fluid Question
- ETS V2 quiet exhaust
- Oil leak....help!
- IDC Extremely High - Opinions? (Log attached)
- MAF Sensor Blues
- p1877 "pending" fault code
- '08 P0011 code help?
- HELP possible t-case whine
- All gear lock out
- Universal catalytic converter?
- When hot, it goes lean
- Is this block savable?
- 4th gear poping out, Evo 10 manual 5 speed
- Did my clutch just go??
- help identifying engine rattle over rpm 1500
- awc services required and asc services required
- Albans 4.23 From Jacks vs Shep 4.30 final drive
- Evo x sputtering, running lean, fuel issue?
- Code P181b & P181e - problem need help
- JUN Cams
- Switching from COBB bov to HKS question
- Need Some Advice/Input on Mods
- 2013 Evo X ASC System Service Required
- Rough idle with new injectors?
- Blousch Dom 1.0
- First upgrade to do with my evo x?
- Comparable exhaust to ETS Quiet?
- Evo X Rear DIFFERENTIAL
- Best Internals for a 2.4L Build
- Passenger rear diff axel seal leaking
- Cerakote C-187Q heat dissipating coating?
- Wastegate Preload?
- Is any one running the Sheepey built turbo manifold
- Are 3 pulleys (25287-2C000), a belt (K061033), and a 5/8 washer everything I need?
- Any suggestions?
- So I need the aluminum valve cover if I was to buy aftermarket headers??
- Buying a 2010 SE (another SST question thread)
- Strange groan noise occasionally when both accelerating and braking - Videos inside
- 08 Evo X Stumble around 10psi and 4k rpms
- Evo X A/C pressure switch harness question
- No rev limiter? Pls inform
- Looking for New Clutch
- MAPerformance vs other drive train companies
- Rear O2 Sensor Replacement
- Evoscan AYC Codes. Help?
- Hot weather, severe hesitation/stutter on accel
- Comp stage 3 TOB issue?
- Was told this is a OEM clutch...
- Precision 5858 Turbo Issues
- Transfer case and Rear Differential
- Myself 1... Dealership 0
- Valve springs
- Defeated by horseshoe clip on cmc line
- Under Boosting, Cause Unknown
- White Evo X
- NGK Racing spark plugs discontinued?! What are some alternatives?
- Putting a 3.8l mivec in a 2008+ Lancer..
- Normal drivetrain whine or....uh oh
- P0013 issue! Please help
- Doing the clutch did I get everything I need?
- Evo X Broken clamp - what is it?
- Changing Oil Pressure sensor
- AWC system service required, in WARM weather.
- Comp CT3 6765 and High Z FIC 2150
- Comp Twin disk hydraulic tob options?
- Stock muffler part numbers
- Quickest ACD pump to fail on FE
- Clutch pedal stuck
- Taking a chance - Cavalli BB Turbo
- Akropovic Exhaust Tune
- CEL Then Engine Ticking
- Clutch and Flywheel effect on EVO X GSR Tune
- Oil Smells like Gas
- Another Synapse DV question..
- MAP cast manifold hardware alternative
- Transfer Case is Shot
- 2nd clutch upgrade - Can you think of anything else?
- have about $2000 for upgrades
- Test pipe + tune
- MHI 18k: Porting/Coating or no?
- Relocating the serpentine belt
- So i got my GTX3576r installed..
- Lower boost, what could it be?
- Acceleration Issue?
- Double windows in the block
- oil leak from base of dip stick tube
- Recall Gripe
- ABS, AYC, 4WD failure woes
- 7670 Kit on stock Block - Compression and Leak Down - Opinions Wanted
- Magnaflow exhaust 16823
- CMC Failure(I Think)
- seals going, should i get the engine rebuilt?
- Urgent question
- Valve Adjustment
- Rear Diff options
- URGENT QUESTION - Road Tech AntiFreeze Compatible?
- Not Hitting Peak Boost
- boost problem, help and opinions would be appreciated
- Turbo Options for Quick Spool Times and Power
- I Beam vs H Beam Rods
- Going with 18k
- Evo X build
- Only boosting ~12lbs max
- Evo X GSR - P0638 - Boomba TB 75mm
- Oil leak near the 4b11 badge
- Engine Grenade while on Dyno
- ISO stock location Turb FP Red or slightly bigger
- 2014 GSR bolt ons
- I've searched and still searching but could use opinion on new clutch please and thx
- Car still on after it shuts down on it's own.
- What flywheel
- Warning Light (Exclamation Sign)
- Evo X Fuel smell in cabin when weather is hot
- XS Power Open dump Downpipe
- Measurements of MAF sensor O-ring? (P/N: MN137122)
- Another ASC Service Required Thread - (not 30PSI issue)
- Low Boost need help
- What size is the oil feed line banjo bolt
- EFR Twin vs Open
- evo x mr with upgraded MHI 18k with stock clutches
- Engine bay smoke?
- Evo x and evo 8 &9 exhaust manifold differences
- Causes for this busted line?
- Clutch engagement too low? weird.
- need some opinions on a certain turbo/build
- PTE 5862 Turbo Question
- 500 WHP and up Mods
- Good deals on a turbo?
- AYC Relocation
- Engine Noise
- Fluid recommendations
- Possible pulley or pump whine?
