PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. P0304 Code
  2. Installing new oem pistons and rod confusion !
  3. Installing a “new” OEM turbo + Questions
  4. Oil Pressure Regulator, where to drain?
  5. Low oil pressure after hitting rock
  6. AYC Pump codes?
  7. Built block options
  8. Evo X MR: so many fluids!
  9. Evo X head bolts socket type?
  10. 4B11T#1 vs 4B11T#2
  11. Driven Fab CC-unexpected surprise
  12. AOS return line
  13. SST Trasnsmission Problem
  14. electric motor ACD pump not working - exchange available?
  15. Water pump removal tips?
  16. Boost leak test?
  17. Powder / Ceramic Coating Services @ Boostin Performance
  18. P0234 - Turbocharger Wastegate System Malfunction
  19. Evo Head Service
  20. 08 Evo X autocross DD motor build
  21. 520 whp Blouch Dom 3.0XTR - 2014 Evo X GSR build
  22. Transfer case removal
  23. Maintenance Lancer Evo X MR TC-SST
  24. Boost leak testing
  25. No Start Issue
  26. Short Shift question
  27. New to the Evo X SST platform :(
  28. AYC Pump
  29. .70 ar pt?
  30. Slipping Transmission
  31. As Far As Upgraded Intercoolers Go...
  32. Clutch master?
  33. 500-550 whp dd
  34. ACD/AYC pump relocate kit install
  35. Fuel Return Line Connection Help
  36. Brand new clutch issue/ monoloc collar and throwout bearing.
  37. ETS Dowpipe
  38. Low Fuel Pressure HELP!!
  39. Evo x inter size
  40. Strange SST noise when shifting 1st to 2nd
  41. help with clutch return
  42. Evo X throttle body coolant hose
  43. Shops in SoCal - Clutch Replacement
  44. 15psi Boost issues EVO X. OMNI/ Boost/ Vacuum leak?
  45. EFI quick connect size
  46. 2008 Evo x MR gears grind when manually shifting
  47. Trouble diagnosing drivetrain issue
  48. Evo X timing chain questions
  49. Boost issues
  50. Shops for replacing clutch in south jersey
  51. RPM bounce when going in N
  52. ATS Triple Plate Clutch review
  53. Bye Bye Boost
  54. MAC wastegate control valves
  55. Magnus Launch Control Device
  56. When to upgrade wastegate.
  57. 2008 EVO MR needing help
  58. Cv joint differences
  59. EVO X rattling noise after time chain replacement
  60. Stock fuel return line pressure
  61. Transmission Fluid Question
  62. Rpm jumping at WOT
  63. New clutch
  64. So Cal EVO owners?
  65. Catch Can Question
  66. Ralliart engine swap into Evo
  67. P0171 fuel trims maxed
  68. New Evo X and clutch
  69. Evo x "engine system sevice required"
  70. ACD Pump/Sputters With WOT
  71. Going to be pulling my motor for the first time
  72. Injector Cleaning / Balancing / Flow Testing @ Boostin Performance
  73. First timer upgrading turbo.. looking for recommendations!
  74. Precision 6262 ETS oil drain flange - Is there a better option?
  75. EVO X revs really hard when coming to a full stop, while pressing the break.
  76. EVO X GSR > RS Conversion (Rear diff)
  77. Evo x powertrain elements
  78. SST vacuum hose/breather line at shift linkage
  79. 14 EVO X GSR Rear diff swap to MR???
  80. Engine oil cooler options?
  81. Evo x head cylinder built
  82. Full Race EFR 8374 IWG Problem
  83. Help: ETS Exhaust system.
  84. fuel pressure after shutdown
  85. Engine Idle/Misfire Diagnosis
  86. Best local shop for clutch job...
  87. PCV Valve Possible Issue
  88. Best aftermarket turbo for an EVO X?
  89. Need to rebuild the head on my evo x. NEED HELP!
  90. No Power to Starter after motor build
  91. BOV questions
  92. Evo x turbo not spooling
  93. Heat sheild for full race efr ewg kit
  94. Grinding noise in 1st
  95. MHI 18k conversion upgrade to 3076 hybrid?
  96. Cost of 500 wHP ?
  97. Thoughts on power band, which will half a better 1/4 mile time
  98. 4b12 Engine swap into Evo X
  99. Left over LSD gear oil ok to use?
  100. Injector write up??
  101. OS Giken clutches spotted in a YouTube video
  102. gtx3576r for sale
  103. 4B11 won't start after an engine rebuild, acts like it out of time.
  104. 4B11 to 4b11T
  105. Would ceramic coating the water pipe be beneficial?
  106. Recommended EVO X specialist in Brisbane
  107. Transfer Case replacement on 08 evo mr
  108. Atp Gtx3576R questions
  109. Evo X won’t idle at operating temp..
  110. Return fuel line question
  111. New owner from uk, Problems already! :(
  112. Rear Differential - Internal Leak? HELP
  113. what to replace after blown motor
  114. I think I blew something...
  115. Go from TF06-18K to ETS 5858?
  116. Turbo bay performance turbo question
  117. TPC G-Spec turbo vs Chris Robbins gt35r turbo
  118. Gap in Flywheel
  119. AMS Upper Intercooler Piping Question
  120. Missing down pipe bolt
  121. Need help picking motor
  122. AMS WideMouth DP Vs. MAP O2 ELIMINATOR DOWNPIPE
  123. AGP intake
  124. 2008 evo x mr transmission problems
  125. What's broken?
  126. Turbo Vibration Report
  127. Thermostat housing fitting explodes
  128. Evo X abs,asc and drivetrain problems
  129. Keeping air intake temps low pt.1
  130. ***Help for a self proclaimed Evo noob please***
  131. Need Help. Evo X GSR Map O2 Dump Rattle
  132. EVO X smells like Gas from engine bay, the Heater/AC vents
  133. Car won’t start
  134. Changed my clutch out and the car feels slower.
  135. Throttle body issue?
  136. Wastegate setting gtx3076r
  137. 2008 EVO X GSR Transfer case leak
  138. To AMS cold air intake or not to AMS cold air intake
  139. Cosworth Intake Manifold
  140. Need a tuner for my evo x
  141. No starting issue.
  142. Exhaust fitment issue
  143. 5558 Turbo
  144. Factory turbo mods
  145. HKS Hi-Power
  146. Cracked piston & head waht cusses pic included
  147. Upgrading GTX 3071r g2. Replacment oem parts list
  148. Fluid replacement clarification
  149. Help with building the EVO X to 400WHP
  150. Need help!!!! Question about 6266
  151. GTX3576 GEN2 vs GTX3076 GEN2
  152. Is this engine deal worth it?
  153. Newbie wanting flex fuel
  154. Shop recommendation for engine build.
  155. Flexconverter.com
  156. Check Engine Light on
  157. Need some advice on what turbo to get
  158. What clutch should I go with?
  159. difference in engine internals
  160. Evo X Turbo Upgrade?
  161. When to upgrade throttle body?
  162. Knock sound in rear
  163. Evo X SST 7163 support mods
  164. Whine noise in lower gears
  165. Clutch break in period question
  166. Lean spike/rich under wot
  167. AEM Intake suction tube
  168. e85 + surge tank = FPR ?
  169. rear half shaft knocking sound- help please.
  170. Running terrible need help
  171. Possible rod knock?
  172. How does a turbo turbine wheel come into being?
  173. turbo dropped to 7 psi of 20 help!!
  174. Axle Assembly
  175. Mechatronic problem, turbo does not work
  176. Help with leakdown/compression results
  177. Lucas Racing oil may have saved my block, crank and rods
  178. Evo X has erratic boost not sure if its mivec delete logs attached
  179. Help me analyze this...
  180. 08 Evo X not making anywhere near the power it should
  181. Which interval would you recommend for changing Evo X's coolant?
  182. Anyone recirculated their O2 dump
  183. Clutch Pedal sticks and don't know why please help
  184. Does this look bad?
  185. What the case of burning flyweel and clutch ..pic
  186. Evo x e85 fuel feed line
  187. Brown slime from the Red Line WaterWetter coolant additive
  188. What is the correct size for fuel pressure regulator (FPR) hose in silicone?
  189. Wt is best clutch + flyweel for daily driver and Proformanc
  190. Missing cover
  191. Transmission issue please help cant shift only 3rd & 4th
  192. Bottom end build
  193. Evo x turbo spool?
  194. More power
  195. Vacuum Line Help.
  196. Transmission Error Message
  197. My evo 6 rev limits @ 6000rpm, fan doesnt work with the thermostat. Help please!
  198. Tensioner Pulley Advice
  199. Evo x ets intake and cobb ap
  200. Evo mods
  201. Question about the problem on a EVO X
  202. Looking for more power. Need a turbo suggestion
  203. Detaching release bearing without clutch fork?
  204. Coolant loss in radiator only
  205. dw300c drop in pump w/o inline filter
  206. My big turbo build
  207. Transfer case clutch
  208. Charging System and Squealing noise
  209. I Need Help with Transmission Issue, Pretty Please
  210. I Need Help with Transmission Issue, Pretty Please
  211. Exhaust overheating?
  212. Radium Submersible PTFE Fuel Tubing
  213. 4B11T Front Cam Bearing Bolt Torque
  214. ACD/AYC Pump Fittings
  215. Ticking Noise help!
  216. CV Axle Topic
  217. HKS SSQV4 fittings
  218. Rear Diff and Transfer Case filling procedure
  219. Wgdc for mhi18k
  220. Which engine would you choose for my MR?
  221. Evo x rear diff swap for evo ix
  222. Evo X MR Transmission Issue
  223. Gen 2 Gtx3582r stock location setup
  224. Evo x Xtreme twin plate carbon clutch
  225. Fuel starvation with walbro 450
  226. Some specific questions
  227. Exhaust drone AGAIN!
  228. 18k Turbo Issues
  229. Built Block and Stock Heads
  230. First oil leak!
  231. Learned a few things from a Mitsu master tech on checking the Evo X's fuel system
  232. Unknown service light show
  233. Another BOV Flutter question...
  234. 08 MR wont start or idle without throttle
  235. Boostin Performance Transmission Rebuild - 5 Speed (Evo X)
  236. Left Rear Wheel Shaking
  237. Help with no start.
  238. EVO X rpm jumping while idle or running
  239. Reviews on this Cobra DCT470 rebuilt kit
  240. Evo X Timing Chain Replacement @ Boostin Performance
  241. Estimated HP?
  242. Rear O2 sensor replacement- Need some help
  243. Evo 10 5spd transmission rebuild
  244. 14 Evo making odd sound from downpipe/testpipe area
  245. Single Exit Titanium Exhaust in Tri-State Area
  246. AMS STX500 Kit versus other turbo kits
  247. Stuck in snow, rear tire not spinning
  248. Priority Bolt On Improvements
  249. Car not turning over
  250. Act monoloc compatibility question
