- Which valve springs to run.
- Weird noise from Exhaust manifold?!
- Hissing Noise under heavy acceleration?
- How is your TurboSmart bov adjusted?
- Cp-E Exhaust
- Another loud t-case thread
- ASC OFF light coming on like clockwork, even without throttle
- transfer case stuck need help
- Transmission problem (CMC Snapped?)
- Review my motor build.
- Brand new MR, mods?
- Clutch slipping :( recommendations?
- Ams 2.4l
- Weird clutch transmission issue
- Transmission in MR vs. GSR effecting Top Speed?
- Centre diff problem? Clunk clunk...
- stock fuel system and intercooler limits?
- Best BOV or DV for holding boost?
- Borg Warner Airwerks and Evo X
- Got a cel light after cat install
- Cobb quad tip for Ralliart
- How are your built engines holding up?
- Need help with My clutch
- Coverting to E85 and have couple questions
- Castrol srf vs motul rbf 600
- Need help Identifying!
- 10:1 on 93
- Major oil leak
- Scratching / Scraping Noise
- 2011 center diff pin change?
- Best route to go as far as test pipes...1 whole or 2 separate?
- Help picking parts for 450 awhp build
- Deepest/Throatiest Exhaust
- Looking for good valves springs and retainers
- Cobb Shifter
- 5 Speed Disassembly Question
- Comp Stage 3 2600 + AMS CMC Review
- Questions on pricing, thanks!
- Porting vs Bigger turbo
- Evo X GSR Tranny Summary Question
- Synapse diverter valve install. Flutter, choking, etc
- Can't decide on Intake >.< Trying to get some votes!
- Burned clutch, now what?
- Misfire After Performing Compression Test?
- Stock EVO X Turbo
- Invidia q300 louder with test pipe?
- Exhaust
- OEM Coolant black ... ?
- Popping out of 3rd gear
- reading an AWD "service required" code
- I'm stumped! Help!
- overboost
- Oil leak problem. Help!!
- 13' Evo X + Cobb = wOOt!
- Mating 2.5 inch Stock DP to 3 inch Cat-back
- Installed ETS Intercooler :)
- Installing ETS intake & UICP= CEL??
- EVO X - 1 , ACT 6 puck - 0
- QTP test pipe
- transfer-case whine vs ACD weirdness
- short shifter recommendations?
- 2010 Lancer RX Turbo Conversion
- Bent input shaft???
- Has anyone gotten the AMS STX 400?
- Want a more refined catback!
- Question about build?
- Help with a Trouble Code
- Evo x oem piston sizes
- Air Filter Shield
- 4"or 3.5" ETS Intercooler? Help!
- stutter under WOT
- Anyone successfully replaced AWC Pump under warranty past 3yrs?
- New Clutch Soon, Could Use Recommendations For A Stock Car
- Gear shift has lateral movement
- ETS UICP problem
- Ultimate Racing Exhaust?
- Ebay Parts!
- OEM NGK Spark Plug Electrode Ground Broke Off
- Help with Fuel Pressure?
- turbo oil feed line
- ACD/AYC pump failure reports
- Post Turbo manifolds & down pipes
- Weird noise and vibration while driving please help
- weird sound coming from engine bay
- Does anyone know if the RALLIART ACD PUMP is the same with evo x ACD pump
- S-AWC Service Required Light, EvoScan shows no codes
- Cracked exhaust cam sprocket..
- Competition Stage 3 Clutch
- NEED HELP AYC ACD PUMP failing - S-AWC Flashing
- Greddy Ti-C Comp Db Level
- New FP Red for the X??
- Lightweight Driveshaft
- Cyl 2 misfire =New shortblock? Need help!
- Saw this when doing a tranny flush..
- P0303 Misfire only in boost
- The x-teenth Cam Question...
- Stock or stage 1 cams for bbx full on 91
- What to do with the ETS intake..?
- Whats the highest RPM stock motor can handle?
- Finally got my turbo kit on!!!!!(Video)
- Sprung vs solid clutch disc
- Guys, need help, LICP missing a clamp, possibly blown off
- From Spec 3+ to Exedy twin HD
- driveline fluid change
- Changed clutch and flywheel and now have c161e code
- Soon time to replace clutch?
- cobb hard pipe kit with AEM intake
- Fueling for BBX Full on E85?
- crank pulley torque specs?
- Does anybody have some type of monthly checklist?
- Timing chain tensioner
- Quartermaster Clutch for the X
- ets open dump
- whats a fp red???
- Replaced Parts
- When I start my car I hear a clunk in the back
- Help with clutch, video link inside
- Rear diff Cracked LSD
- bad turbo surge/noise while on throttle
- Exhaust valves 4B11 Ralliart-EVO X
- Down pipe or test pipe
- Nuts and Bolts for turbo
- Bumpy/Lagging WOT
- r18eclipse's E85 10.5:1CR 2.4 liter Build
- Standard intercooler spray
- Grinding/Crunchy feeling coming from the clutch pedal?
- Evo X no top end
- Help: Need "lightweight" catback that's not too loud
- Garret DualBoost Turbo
- 2013 evo x clutch
- Kelford cams for evo x
- Walbro 485lph
- Never had such an issue with exhaust....
- clutch pad bnib isnt aligned
- CAM/BUILD suggestion EVO X
- shorter clutch-pedal throw
- Template for COP cover.
- Clutch engagement point randomly changing
- Eventful install week
- S-AWC Issue
- Blue smoke, what to check?
- Got a new timing chain, questions
- need help on getting lower intercooler piping..
- Solution to TOB clip failures?
- EVO engine swap
- UR Mini Muffler Test Pipe with Milspec Cat
- HFC that doesn't throw CEL
- FP Red questions
- 20g Turbo question
- New AMS 2.4L bore
- Clutch Pedal Issue
- resonated test pipe
- Looking for help with turbo upgrade/ other mods
- Clunk when shifting hard into second
- synapse spring...
- ACD Pump Guard
- Potential problem?
- Exhaust bronzing?
- Waste Gate Flutter? Grimmspeed EBCS + UICP install
- Motor oil in my intake...Help!!!
- turbo spooling sound...
- Another Bad AWC PUMP :(
- 100 cell or 300 cell cat?
- Another stuck TOB need help thread
- 2008 evo x mr bad idling then stalls.. Help!!
- 2013 GSR Metal CMC
- Air in fuel line?
- More issues..... P0017 CEL
- Popping sounds from exaust in idle?
- Fuel in oil catch can???
- Port and polish head?
- awd service light.
- Rough Idle 12 Evo X
- rs turbo and diff pins
- EVO X has trouble starting.
- Someone help
- 3rd gear engagement issue
- What mods before a tune
- New shortblock - do it once, do it right, what do i need?
- Which Intercooler out of these two?
- Help with turbo lines
- Bad tranny??? Plz help
- Synapse DV
- AYC Pump: Covered Under Powertrain Warranty?
- CV Joints - Replacement
- Please help with information on MAP 2000CC injectors
- Oils n lube
- Dealer experience with P0012 Code
- DP and TP question
- Having some issues with S-AWC system
- evo x mr ets downpipe and hks catback problem?
- Idle issue
- Random engine service light
- Pte 60-1 in evo x
- Diaqueen for GSR tranny in quarts?
- Which dp to choose?
- Weird idle!Help me!
- clutch
- clutch pedal help !!!!!
- Help with revised timing chain
- P0113 after CMC swap Evo X 08
- P02b8
- At what HP point do you need to upgrade the fueling
- E85 w/ stock clutch?
- to cam or not to cam
- Build finished, starter problems
- SST Problem: At My Wit's End
- External wastegate on stock turbo
- Evo X 2008 SST Issues
- Heat shield for cobb SF intake!!!
- Looking for a Evo Ix. Bov.
- Evo 8 weird rotating metal noise
- AGP hard pipe kit
- Boost Leak/ AFR really high on idle
- 2008 evo x falling in and out of boost???
- Turbo Spool and BOV
- Muse 1piece UICP
- SST Fluid and Timing chain
- Can someone tell me where the starter is?
- Evo X Test Pip
- P0016 code and now P0017 code
- nut facing driver side on downpipe
- It's on! Here's the plan!
- FP GREEN Proven Numbers
- Evo X front left axle shaft
- 420+ awhp
- Dual Exhaust
- Broken UR Downpipe
- Cam choice for a MR with FP Red on 93 octane
- GS 3 port
- Rally Sport Direct
- Issues with my '12 Evo X......HELP PLEASE!!
- Silicone couplers leak from layers?
- cylinder head options
- New evo gsr slow start
- rerouting the stock bov
- Tial QR Spring for a stock turbo?
- Help me make power!!!
- Evo X boost leak test help!
- Do we need to change rear axle oil in EVO X MR??
- UICP and Test Pipe
- BOV Risks
- Is there a way to tell if you're on a stock clutch
- Transfer oil vs transmission oil vs differential oil , SST transmission
- Evo 7 trouble shooting! need help!
- AEM intercooler kit + AEM intake
- Over heated the X
- Buying a magnaflow exhaust. Which 1 should i buy MAP or normal one.
- Differences between DP's?
- @ 63k miles + MAP EF3 for 450whp.
