- SpeedCircuit Cat-Back
- Buschur Racing's EVO X, turbo upgrade/clutch upgrade
- Will an IX exhaust fit an X?
- MoaR CowBeLL!!!
- AEM intake help
- Which turbo you would recommend
- P1870, P1235, P0135. Codes
- AFR gauge help
- will i blow my motor?
- S-AWC shut off/trouble
- RRE Evo X Exhaust
- Spark Plugs
- Boost too high??
- Car wont go into 5th! Help!
- induction pipe?
- Cams and clutch install for X
- Works Axle Back Exhaust????
- stock turbo + O2 housing downpipe = good or bad?
- HKS SSQV Recirc Throwing LIMP MODE HELP!
- gsr/mr launching in boost
- Downshifting an MR
- Cosworth High Performance Head Gasket
- Help: P1870, P1235, P0135
- New intake w/out tune?
- Agency Power
- Turboback exhaust throwing a CEL code
- tanabe full cat back exhaust
- Blitz Nur Spec R Exhaust
- Anyone know anything about this exhaust?
- Injen intake ?
- Ebc
- HELP NEEDED!!!Please Read
- Is there a restrictor in the clutch cylinder?
- CornFed-F.P.Red Evo X??
- AMS 35R X 450awhp!!!!
- New Pick Up: Fujitsubo RM01A Exhaust
- Evo X clutches and Tranny rebuilt
- +1 SE and you should do this too!
- AMS Cold air add on??
- My T1R Exhaust Install Pics (lots)
- UICP?LICP Aluminum VS STAINLESS Steel
- A couple of questions on HKS intake and exhaust
- Blitz i color video in my MR
- Amazing mod for EVO X MR!!! $50=22whp!
- Jun Oil Thermostat
- Those with Cobb Turbo Inlet Pipe
- How do you shift this damn thing?
- Question about test pipe noise
- 1200 cc injectors for the X anybody???
- Finally found a picture of the exhaust "look" I am looking for
- ETS NEW O2 Housing !!!
- stroker kit
- can someone develope an exhaust like this?
- Evo X Clutch Pedal/Cylinder **Heavy Duty**
- Rich tune affecting the spark plugs?
- Fuel dilution in oil problem
- NEW Mobil 1 Racing 0W30
- Different oil
- OFFICIAL: Tanabe Concept G Exhaust Arriving Mid December!!!!!!
- When to change Intercooler and some extra
- Cusco ECO. & Sports Throttle Controller
- cosworth, kelford & Jun which cam?
- When/why do I need a fuel pressure regulator?
- Anybody with KTR exhaust?
- Is LIP worth it?
- First Mr Trans To Let Go?
- Oil filter part numbers
- New setup
- Mbc
- Advice on Red set up.
- Blouch Turbo
- AMS single exit catback exhaust opinions
- ASC service light with stealth fx bov
- HKS SSQV Recirc...
- Gates311: FP Red Review
- Testpipe on stock exhaust
- Best High Flow Cat option?
- Type1 racing CBE - any reviews?
- Visited XtremeBoost this weekend
- exhaust manifold
- NEW Xtremeboost Upgrade Clutch Master Cylinder
- Will these pipes be compatible??
- Supporting mods needed w/FP Red
- high boost
- The truth about BOV's
- Artisan Turbo anyone
- Which bolt-on turbo to get? FP red, Artisan, Garrett, etc etc etc
- RE: Clutch master cylinder
- Damn you O2!
- WORKS Clutch offerings - EVO X
- Works Short Shifter Kit
- hks legamax or buschur?
- Clutch GONE...Mitsubishi wont cover it.
- FP Red for EVOX Turbocharger
- HKS Legamax + Center Pipe + SSQV
- best intercooler
- HKS actuator upgrade kit
- MBC in New England?
- BLITZ Super Sound Blow Off Valve VD Announced
- HKS R Type intercooler dyno
- Stock Turbo Boost management solution - WGA & EBC
- Exhaust Manifold Flange for Evo X 4B11T Motor
- HKS intercooler Pipes
- Coltspeed intercooler now available!
- What oil to use on an X
- AGP X Front Mount Intercooler - Now With Cast End Tanks and Larger Core
- ARC intercooler + airbox dyno
- Unlimited Works Titanium Exhaust
- Intercooler Poll
- Does anybody else notice this???????
- HKS Racing Suction Reloaded Kit
- HKS Evo X step-up menu
- Intercooler: ARC, Blitz or HKS?
- ETS 4" IC with piping, ETS Intake and more to come
- AMS EVO X CNC cylinder head work
- Maximum boost with stock turbo and internals?
- CBRD Evo X Vertical FMIC....
- For those running test pipe, how bad is the smell?
- O2/Downpipe thread by Buschur?
- Anyone have the Ultimate Racing mini muffler test pipe???
- quick air filter question.
- I NEED HELP! Is my clutch worn out?
- Question Gruppe M or ARC intake owners
- Stock vs. Aftermarket MAF housing
- Exedy stage 2 takes a crap!! WTF!!!
- So i just got my UR resonated test pipe
- Problems with clutch slip on high whp MR?
- AEM Intake sound clips?
- Problem....
- wondering if there is a problem
- Great Job TTP
- JUN 4B11 Piston Kit
- Exedy Twin Clutch Disengagement
- S-AWC % of torque split
- rear diff failure anyone?
- Aem Cai + Hks Ssqv Bov
- HKS catalytic convertor
- AEM Cold Air Induction System
- FP Red Tuned
- agency power exhaust??
- MXP exhaust anyone?
- JUN High lift camshaft kit
- HKS Actuator Upgrade Kit For Mitsubishi Lancer Evolution X
- Whining Noise??
- Picture/dimensions of stock Injector?
- Evo X Walbro Fuel Pump installation is possible without making a mess!
- Fuel Pump upgrade Help
- Evo X bolt on Garrett GT30R turbos
- Twin Solenoids...
- anyone know where to have turbo kit installed
- EVO X needs advices for more power
- Nisei Engineering's Evo X Line Up!
- APR carbon fibre radiator cover pictures requst and help
- Head Stud help
- Pistons and gasket Questions.
- CBRD Radiator for X- some pics..
- Spark Tech's EVO X C.O.P/CDI Ignition at SEMA
- ?Catback with o2 downpipe combo and high flow cat
- EVO X Intake Manifold
- Advice on Intake choice
- Stock intake "scoop" is USELESS?
- oil catch can
- Greddy TI-c question.
- Another exhaust option
- What do you like best
- Mivec engagement?
- Meth inj vs. Upgraded turbo
- ams mbc
- Looking for quiet 3" inch exhaust
- TWM Short Throw Shifter
- Which Port for EGT?
- EVO X MR Transmission
- Idling problem after a exhaust install.
- Performance vs Reliability
- IC piping kit & Synchronic BOV for X
- Warning Light
- Cosworth MX1 Camshafts for Evo X in Stock and Shipping!
- PSI our block can handle?
- BVP Evo X 10.7 @ 124
- Drivetrain vibration?
- Request: GOOD Video of Buschur Catback
- Go Fast Bits (GFB) Turbo Fuse
- EVO X MR lower i/c pipe release
- Anyone Running the Artisan SA-X 50 Turbo?
- Problems with Turbosmart Eboost2 on EVO X
- Pedal Engagement high after clutch install???
- Wastegate Mod/Boost Creep Help!!
- AFI EVO X Stock Replacement Manifold!!!
- XtremeBoost Evo X turbo kit
- Tester wanted for RPS Billet Carbon Clutch!
- AEM Water/Meth Injection FailSafe.
- did I get this right? where the boost pill goes
- AMS fmic?
- HKS Legamax Exhaust loose power?
- Greddy Ti-C or Buschur Dual Exhaust with quiet muffler
- Ultimate Racing downpipe with o2 housing
- New APEXi EVO X RS Cat Back
- RWD evo?
- Tranny or clutch problem? Help?
- Turbo Help!!! New turbo system from Peakboost
- Pipe compatibility..?
- [HELP] my evo x under power problem.
- HKS type 0 turbo timer installed
- Any news for T1R dual exhaust?
- Looking for Aluminum LICP
- 12"x12"x2" Enough cooling?
- Direct fit High Flow Cats for Evo X
- What is stock turbo dyno record?
- hows my dyno number
- clutch master cylinder
- Why am i the only one with this problem :(
- Buschur Motor Mount Impressions?
- What does a EVO X MR make at the wheels stock
- '08 GSR - Trouble Shifting into Reverse!
- Injectors help!
- Gear problems
- Nisei Pipe Kit/AEM Intake help!
- My engine tick
- Help with boost
- ****clutch is gone**** need serious advice
- AFI GT Series upgrade kit
- What Clutch do you recommed
- HKS EVC EBC works great on the X
- Intercooler
- 114 mph on the stock turbo and a blown clutch!
- Intake, UICP and exhaust...
- Fuel Pressure Regulator Help
- Hallman Boost Control
- Preferred Differential/Transfer Case Oil(s)?
- ICS Evo X with Forge WGA - 376 WHP 384 TQ
- Harman Motive Intake Review
- AMS's EVO X makes 480whp on pump gas and prototype turbo kit
- factory reflash on MR
- Installign stroker kit
- Evo X Initial Cam Testing--Agency Power Kelford Cams
- Manley Forged I Beam Rods Now Available for the EVO X!
- X Turbo kit outside the car
- Forge WGA testing
- CBRD dyno testing with exhaust..
- AMS EVO X Fuel Rail
- Gasket and Head Stud Help
- Swap 5 spd into MR????
- Now Stocking Buschur Racing Evo X Stage 1 - 3
- Harman Motive Evo X Products Shipping!
- Forge WGA
- CBRD racing radiators PICS!!!
- MR Who will answer????
- EVO X TURBOS , What has the titanium ?
- Midpipe/Testpipe??
