PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Misfire/ Injectors
  2. anyone know anything about this clutch?
  3. Defi BF Gauge extra fittings & adapters needed?
  4. S-AWC Display bars fluctuate over 55mph
  5. Gtx3576r 4 inch inlet 2 inch outlet
  6. Fighting drone?
  7. what do I need to trap 125-130?
  8. Fellow ETS 4" intercooler and piping owners pls chime in!
  9. Can't wait to install these
  10. Turbos and tubular mani blanket thoughts?
  11. shifter rattling
  12. Opinions on turbo upgrade
  13. High Fuel Pressure
  14. Overboost w/ Cobb
  15. Typical bolt-ons with Factory Cat
  16. Cobb and ETS Fitment
  17. Inner transfer case seals
  18. P0017 code
  19. Open dump downpipe
  20. Can't select 5th gear, just grinds
  21. Vacuum Manifold Installed
  22. Passenger axle seal problem
  23. Exo X MR SST normality
  24. At idle with heat on
  25. Investing in built motor - worth it?
  26. Alteernatives to OEM X Exhaust Manifold
  27. Vacuum Manifold - Mettle Air?
  28. Anybody running Spec 3+ clutch?
  29. Surge tank (Ebay)
  30. Corsa Exhaust System GSR
  31. best turbo upgrade direct bolt on 450 hp goal
  32. Evo 9 mr blow off valve install?
  33. Agency Power Exhaust
  34. Identify This Exhaust!! Pls Help!!
  35. EvoX no tune with AMS test pipe & Vibrant "CEL FIX" spacer
  36. need help to diagnose
  37. Pistons or turbo Failure??
  38. GT3071R on stock Evo
  39. Huge oil leak/turbo shaft play
  40. Need acd help asap
  41. Anyone installed a 02/downpipe (atmosphere dump) to RHD EVO X ?
  42. Evo X MR | Narrowed it down to bad Out CV Joint, repair or replace?
  43. Knock with alcohol injection???
  44. Ams 750xp
  45. Stock location turbos
  46. Blouch Dominator 2.0 Turbo Wheel Sizes
  47. Any reputable shops in ct and tri state area? I need a new clutch installed on my evo
  48. Switching from VTA DV to Recirculated DV
  49. Full bolt ons + mhi 18k
  50. Compressor surge / waste gate flutter??? Need help.
  51. Help! No oversteer!
  52. Stutter / jerking
  53. EFR 7163 TS versus Stock turbo
  54. New CBRD products- Intake with shield
  55. New clutch
  56. cam question
  57. Boost problem brainstorming
  58. Tomei Turbo Back
  59. Anyone launch 450whp-500whp on the stock tranny w/upgraded clutch?
  60. Evo X billet block
  61. Exhaust smells like unburn gas on cold start?
  62. Who is running stock cmc with aftermarket clutch?
  63. NEW!!! VRSF 4" Evo X FMIC
  64. Evo x cranks starts then dies
  65. redline cocktail CA
  66. Gtx3076r tune next week
  67. Stock Turbo + Meth or MHI 18k?
  68. i just want a front axle seal replacement write up... why cant i find one...
  69. High Pitch Sound.....
  70. Clutch slipping already!?!
  71. where does this damn harness go
  72. What does this damn harness connect to!?
  73. BW EFR 7163 Twinscroll kit by CBRD
  74. [Engineering Explained] Mitsubishi Evolution X - How The AWD System Works (S-AWC, ACD
  75. Which clutch for my setup
  76. 2013 evo x clutch problems
  77. Amsoil vs. Redline Cocktail
  78. boost therapy
  79. 6062 Gen 2 or 6262 turbo setup.
  80. Exedy Stage 2 + Exedy Lightweight Flywheel
  81. Clutch/flywheel and CMC Install prices?
  82. Hot to table move to NOT PSI BOOST Falls so much..??
  83. Noises on incline?
  84. wastegate AGP (RED SPRING)
  85. Catch Cans: Radium Dual or Driven Fab PCV Delete
  86. Comp. stg2 clutch noise
  87. Part swap RA to Evo
  88. I need help
  89. cobb vs grimspeed 3port ebcs
  90. 3rd gear (issues) feels notchy on new car!! ideas?
  91. Anyone have experience on "map launch control device" on an Evo x gsr?
  92. Catch can set problem
  93. Evo X start up noise
  94. MAP Turbo Oil Feed Line Kit
  95. duty life of oem spark plugs??
  96. New to the group, Not new to the Evo! please read and leave your advice!
  97. T bolt clamp for LICP
  98. Radium fuel surge tank with OEM FPR and OEM fuel rail
  99. Boost Taper Issue
  100. Whinning noice after fix
  101. Need help finding custom downpipe with wastegate
  102. knock low rpms run at 28lb 91octane gas 2014 gsr
  103. Extreme Lean Issues
  104. ETS or AMS?
  105. DW65c E85 Support Questions
  106. gettin knock after catch can install.
  107. Need your opinions, thinking of changing my clutch set up
  108. EFR 7163 - CBRD RBX Turbo kit on Evo X for 2016 One Lap of America
  109. 1 gear 20lb 2 gear 22 and 3 gear 27lb?wtf any ideas??
  110. Difference between Regular and Widemouth downpipe
  111. Options for 10:1 X pistons
  112. wtf is going on here. clutch issues?
  113. Did I just bend my valves?
  114. Any suggestion for turbo back which is not too loud
  115. Blown motor
  116. FP Red/Black Vs gtx3076r/gtx3582r
  117. Need you guys help to make it shift better
  118. Stock frame turbo help
  119. oil pressure gauge
  120. Anyone heard the Circuit Werks exhaust?
  121. aluminum vs stainless steel bov
  122. Any new turbo options?
  123. "HELP" Best Clutch/Flywheel setup for a daily driver (350-400whp)
  124. Just bought a 2015 GSR, want opinions on this exhaust
  125. Oil leak from turbo?
  126. FS: evo8 viii water pump
  127. Transmission doesn't shift smoothly
  128. Accidentally shifting into first after red lining second
  129. 3" Test pipe to stock 2.5" flange c/b
  130. boost spikes of 30-35 psi will this ruin my motor if wideband readings are ok?
  131. ACD pump rebuild
  132. Engine bogging down under boost + loss of power
  133. EVO X wavetrac rear diff interest thread
  134. Hard clutch Pedal
  135. missfire in high revs and runs rich
  136. Running Lean/Misfire
  137. Ef3 or ef4
  138. Fp green engine build
  139. ACD Winter Question
  140. Driving too hard?
  141. '15 GSR Very Weird Sound When Coming on Boost?
  142. high flow air filter + turbo inlet replacement
  143. ETS Intake Orientation Question
  144. wideband placement
  145. TC-SST Slip count question
  146. 4B11T Girdle Help
  147. P1235 randomly after 6k miles? (6k since ownership)
  148. Deatschwerks 300c Fuel Pump
  149. Map ef 2/2.5
  150. Where does the oil go???
  151. New X Owner, maintenance advice
  152. Review & Install: Quarter Master Twin Disk 8 Leg Street Version
  153. Just had the evo x drive belt recall done at my dealer and then...
  154. Grimmspeed 3 port question
  155. Sst question and help
  156. Best AYC fix? Relocation?
  157. Downpipe
  158. A little turbo help please
  159. Tial Bov with ETS?
  160. ETS Down Pipe and Test Pipe
  161. walbro 450 and fuel line return questions
  162. Clutch and lightweight flywheel advice for 2008 Evo
  163. Whats wrong with my car?
  164. throwout bearing
  165. FP Red - CONFUSED!
  166. Compressor Surge Craziness
  167. ACD codes
  168. P0014 CEL after new oil pump after new block
  169. Help! Evo X rear diff. swap to Evo ix
  170. What compressor housing is this?
  171. In need of kelford 214c Cam reviews
  172. Low power 08 Evo X GSR
  173. Exhaust Leak Question
  174. Stock Housing Turbos for the Road Courses
  175. Shorai for battery replacement?
  176. AMS FMIC fitment
  177. 2015 mid pipe install problem
  178. Grimmspeed ebcs
  179. Evo x Running awful Help!
  180. Fuel filtr
  181. For e85 ID or DW1300cc?
  182. Bolt-on GTX3076R issue - wont boost
  183. Fuel Cut or something else in 5th Gear WOT
  184. Need stock ported manifold
  185. TurboXS Cat-back rattle
  186. Bigger/Better Turbo
  187. Oil filter gasket blowing out
  188. New clutch recommendations?
  189. Removing transfer case help
  190. New Mods, Do I need an EMBC?
  191. Evo x mr sst fluid change
  192. HFC require re-tune?
  193. EVO X MR vs GSR transfer case
  194. Looking to build to unleash my turbos full potential. Looking for suggestions.
  195. Think my clutch is going
  196. Evo X Transmission
  197. fp hta3582 upgrade to hta3586 worth it?
  198. Changed my CMC, now I lose brake pressure
  199. Anything I'm forgetting?
  200. 4B11 Engine Total Weight vs 4G63
  201. Please give your opinion on this exhaust Y Pipe design
  202. Need help! Evo wont start! No spark!
  203. Bill's Englewood Aluminum Driveshaft
  204. strange sound in the rear
  205. Metallic sound please help dealer does not know how.....
  206. Hood Heat Shield
  207. Upgrade injectors and fuel pump question.
  208. 2015 gsr perrin intake
  209. Opinions for Exhausts
  210. Intermittent high knock count when shifting into 1st or 2nd?!
  211. Internet I need your help! BeaterX wont' start :(
  212. Hydrolocked evo x! Help.!
  213. kelford b idle
  214. AMS experience short block
  215. Turbo Issues?
  216. ams downpipe/stock 02 housing gasket reuse
  217. VIN plate / Serial number on evo x engine
  218. Can a tune cause an exhaust leak?
  219. Downpipe Install, LICP Questions
  220. EVO X SST Clutch Plate Replacement/Upgrade
  221. Wont boost past 10 PSI?! PLEASE HELP
  222. Clutch slip?
  223. Gt3071
  224. Engine Build
  225. Would you Sleeve a Motor if you plan to Daily Drive it?
  226. Full Race Kit
  227. for sale ETS V2 quiet & Ets HFC resonated test pipe
  228. EVO X Not Hitting Target Boost
  229. Boost Leak
  230. Evo X, leaning out at WOT/Idle
  231. build question
  232. Front open differential conversion to lsd evo 8
  233. Question for ETS Intake Owners RE: PCV Hose
  234. Help me flesh out this theory.
  235. Weird noise on slow acceleration
  236. help! loud bang when putting car in gear
  237. Boost code/warning?
  238. Read this before using Amsoil in your transmission
  239. Ets open dump downpipe on stock evo/tune
  240. Those of you who have put a rod threw the block look here
  241. Nasty clutch burn smell after new clutch install pls help
  242. Vibrant Ultra Quiet Resonator
  243. akrapovic exhaust
  244. click click click goes the diff
  245. To upgrade cams or not to
  246. If it's not one thing, it's another - strange noise upon decel
  247. Engine turns only a 1/4 turn
  248. Cams Input / Advice
  249. Tranny drain plug won't tighten, advice?
  250. Stock frame turbo options these days?
