- 400 hp with stock catalytic converter?
- Tial recirculation BOV
- need advice on engine flush
- where to by fuel pump relay locally
- Turbo Spool Comparison Data
- tomei type R cam
- Aquamist HSF-6 Meth Kit. Meth Experts Inside...
- AMS Fuel Rail Intalled... leaking like no other
- MXP downpipe fitting RHD cars?
- HKS 6 speed H pattern.
- AMS widemouth downpipe fits JDM vehicles?
- Akrapovic Exhaust incoming for the Evo X
- 4B11 Valve Shim Calc Chart
- WHAT CLUTCH should i get?? PLZ HELP
- Updated Blue Fuel Pump Relay
- EVO X WORKS TR-340 Power Package
- the ets hook up thx guys
- VTA BoV /w AMS LICP & AMS Intake
- Clutch upgrade on a budget (Evo IX)
- care to comment on my spark plugs
- AMS 2Lt has anyone built one?
- AWD Motorsports SSP 500HP Clutch, Deep Pan, Oil Cooler Install..
- Oil report done - elevated Iron ?
- To stroke or not to stroke
- Getting a lot of oil around airbox... ?
- differences in downpipes
- Weird grind/hitting around engine bay after clutch job
- Help on choosing intake
- my situation.
- question about dc sport dual canister exhaust
- FP Green: IWG Bracket?
- Just got my Perrin Polished TurboBack Exhaust!
- Evo X Intake Manifold gasket
- A little help
- New Clutch?
- carbonetic single plate clutch
- FP RED = 1100cc injectors?
- Need exhaust opinions....
- Maperformance o2 downpipe w/ coating option review!
- Evo x motec acd controller or other flash options
- IC piping.....
- Green or Red for 400whp on 93?
- ACD reflash like gruppe-s has for evo 9s??
- ETS V2 Quad 2.5" Tip
- Dealer question about Cobb AccessPORT
- Help getting my MBC to work right
- turbo fittings
- Should I have to change my CMC?
- Any Turbo Companies Converting Our Stock Turbos?
- Apm 4b11 Aluminum Rods
- What new under-hood Performance Parts would you like to see from COBB Tuning?
- Clutch Slipping
- Any Proof?/ Benefit From Intake Heat Shield
- Evo X Test Pipe Options
- AGP Turbo "BLACK EDITION" Evo X FMIC package!!!
- FP Red price hike?
- Amount time to install valve springs?
- Stock Evo X with test pipe only?
- Fidanza 4.3 ceramic 6puck
- who has a HKS fmic on their x?
- Which triple disc??
- installing a new blaqops but now there is now power to the original fuel pump wiring
- Evo X hybrid intake manifold
- Squeaking noise from stepping on the clutch
- evo x cams
- Crushing the BOV is easy and works!!
- T1r hfc
- injecters and fuel pump for e85 fp red
- My Clutch Experiences on the X
- YAY! I got my first CEL
- clicking sounds from engine bay...
- injectors or fuel pump first?
- Synapse Synchronic BOV
- Upgrades done! (kinda)
- AMS MC Ring vs SSP MC Kit
- Question on Tomei Cams
- Exhaust Swap Question??
- Ask... And You Shall Receive! Evolution X Stock Replacement External Gate Manifold
- High pitch whistle noise on mid-high boost
- Down pipe question
- Damn clutch master cylinder broke today
- O2 thread size???
- o2 turbo housing
- AEM intake vs Stock box and perrin turbo inlet piping.
- got a service required light need help?
- Just installed: AEM intake + Cobb AP
- E85, surge tank, aluminum?
- cam issue........
- X missing at high RPMs
- ACD Active Center Differential Modes
- Best Fuel system solution for my car E85
- Can you do rod bolts without taking the ...
- DIY - 4B11T Engine upgrade questions
- AMS DP Rattling?
- T1R Catback Exhaust/Testpipe Installed
- Knock, Knock.....
- Grimmspeed 3 port questions...
- Greddy V-Mount Oil Cooler Kit
- Brian Crower Stage 2 or 3
- new clutch in.. not sure if its wrong or what.. help please!
- Ecu awc
- ETS V2 Extreme Vs. Buschur SS...opinions?
- Exedy's Carbon D Clutch
- first mod?? ideas??
- I am totally lost... experienced guys chime in... clutch Q's
- help- CEL, limp mode, high idle
- 'Engine/tranny' ? noise again :(
- HKS bolt on BB turbo.
- Put on my exhaust and now there's a noise
- aFe Dry Flow S air filter DOES NOT FIT
- What would you do with $15K
- Is there a stock based turbo that can hold 25psi to 8K?
- What's your max sustained boost?
- AMS Evo X turbo kits?
- Garage G force cam and mani
- S-AWC display much more "active" since recent service...
- warranty outcome about center diff pins
- need some advice here...help!!!!!!!!!!
- Custom ETS Evo X MR Turbo Kit (GTK500)
- Hearing humming noise when i turn my steering
- Exhaust Choosing time
- backpressure from removing cat converter.
- Ecu reflash...awd computer reflash...acd/ayc?
- Which has less noise - HFC or Muffler test pipe?
- what spark plugs?
- S-AYC vs. Audi's Active Sports Diff
- boost gauge help!
- Just installed turbo and injectors need a little help
- Evo X Blitz Intake Manifold Install!
- Possible Boost leak? opinions plz
- EVO X Transmission failures. Hmm.. I'd appreciate your input.
- NEED HELP: Shes Knocking her ass off - Sparkplug White..
- Go Fast Bits BOV or Tial Q?
- Towed evo- regular towtruck (non-flatbead)
- Technical Review of intended path needed
- evodaves new clutch setup (read if your in the market for a clutch)
- Toss up between two clutches, OPINIONS PLEASE!!
- pushing the x with a precision 62/62
- stock clutch life
- What failed here? hope not another engine fail case?
- ARK PERFORMANCE SINGLE 76mm Prototype. Looks Good. T304 SS Under 98db
- Harmonic balance wobbling
- Custom 3 1/2" aluminum exhaust
- red vs green
- Supporting Fuel Mods For FP Red
- X help needed!
- Need help fast
- Downpipe Recommendations
- Cbrd fmic!!!
- CBRD Manifold Installed 500+WHP On The FP RED
- Longevity of engine life with an FPred
- P0139 after a trip to the dealer - thoughts?
- NOS to spool a turbo?
- The road to 400whp (hopefully)
- single outlet catback exhausts
- ultimate intake
- licp help with turbo kit
- Intake question
- p0403 code egr
- Help me please
- Interesting...
- Anyone have the TurboXS High flow cat?
- CNT Dual n1 evo X exhaust picture and sound clip
- Looking to have custom tune done, will a DP or FMIC make a big diff. with stock turbo
- need advice on flywheel for my evo X
- injen intake need help
- Evo X Tranny
- CBRD- some testing and development
- Longest a X clutch lasted so far..
- Center Diff Pins
- WOT @ 2500, vibration
- Boost Trouble!
- Are you happy with your bolt-on turbo upgrade?
- Fp red?
- Evo X MR upgrades
- Evo X timing marks?
- Brown E85 fuel filter?
- evo x transmission or clutch..............
- Can you use the COBB AP AMS map for Harman Motive
- Whick intake?
- AMS Inline Fuel Kit Question
- Slow break in = piston failure?
- ASC usefull?
- Is it the Ark Design Twin g700 clutch or slave cylinder?
- IC pipe diameters
- Cosworth Cams Untuned Question
- Vac lines from wastegate to compressor side
- Differential/ tranny blowing
- Mobil 1 5w-30 EP vs Mobil 1 0w-40 (Oil Analysis)
- Has anyone pressure testing the OEM valve springs?
- what drop-in filter?
- aem intake
- Greddy catback exhaust only comes with single outlet?
- Greddy IC piping KIt
- Exhaust gasket
- Boost Pill
- Asc help!!!!!!!
- CBRD smaller BBX turbo?
- Spark Plug Types
- Previous Evo 9 owner looking for evo x info
- Rexpeed DP vs AMS widemouth DP
- Tubular Mani & Turbo - Whats your #s
- Boost Leak test AND valve overlap
- Looking for Bearings....any ideas?
- Intake System
- P1320- Ignition Timing Retard Insufficient?
- Exhaust questions advice needed!
- Do my plugs look ok?
- Fluttery boost under Partial Throttle. Take a look
- need some help.
- Evo X with a VAREX tip?
- Trouble starting the X tonight!
- Help~~AGP CAI install question
- Evo X transmission case drain plug
- Need HELP.. just installed cbe and testpipe..
- Stock BOV/BPV leak test
- My Custom Exhaust - 996 - video link
- Help!!! Rust inside intercooler piping!!!
- 3rd gear boost cutout? help!
- CBRD evo X tidbits and parts..
- Turbo, intercooler, injectors
- Engine Oil Consumption
- HKS Hi-power vs Perrin catback
- BB-X or FP Green for Daily Driver
- Boost leak test qs
- HKS EVC-S Help
- amsoil tranny fluid
- CP-E single exit race exhaust
- anyone running the ams uicp?
- Odd ticking from engine..
- Oil Residue inside the Turbo Outlet pipe
- erz downpipe
- Grimmspeed PnP Stock Turbo
- mv-r 44
- new turbo , please help
- drop in filter question
- Building the 4b11T
- Water temperature adapter size?
- Loudest Evo X Exhaust
- x turbo
- help with spark plugs
- Megan racing CBE for 350. am i missing something?
- Convert SST to Manual
- HKS SSQV BOV turbo flutter please help
- SSP clutch master cylinder upgrade
- hand brake and center diff question
- Stock exhaust bend angle...
- FP Red boost up to 8k?
- power gains on hks parts?
- Differential cooler lines leaking? *pics inside*
