- Weird idle, other issues, please help
- Modding Exo X, supporting mods?
- need clutch advice
- Need input / reviews on the TTP ACT HD Clutch kit?
- intake, intercooler mods, do you need to re-tune your car?
- How Much WHP Can I expect With These Mods?
- S-AWC problems
- Rebuild @ home?
- High psi on boost gauge
- Leaking BOV :(
- After Market intake harm the engine?
- Does the 4B11T compression test strangely?
- 2010 Tial QR BOV with stock piping solution
- adding aftermarket intake improves gas mileage?
- What exhaust is this?
- No boost :(
- Aftermarket Oil & Water Thermostats?
- blitz quad evo x exhaust
- The New ETS Evo X Billet MAF Adapter
- Turbo back HP?
- Confirmed LICP's for MR?
- For those of you who haven't changed your TC fluid..
- Analyzing a critical engine flaw in the 4b11 by TTP
- CBRD developments
- Help me understand the different kind of bushings for the shifter
- what fluids do you guys recommend for the Tranny, Diff, TC
- Ultimate Racing mufflerless dual exhaust vid
- ARP head stud install question
- Car throwing the PO133 code again!
- Buschur IC Piping, what BOV?
- Boomba Racing catch can install pics?
- p0304 - Misfire in Cylinder #4... HELP :(
- slippage (please help)
- X diverter valve on a IX
- FP Green installation thread - list of parts and tools needed
- Transmission fliud change question...
- Do I NEED a fuel pump with FP Green?
- Exhaust silencer question
- ? about stock IC w/FP green
- Big thanks to Ultimate Racing
- Help with twin disc clutch
- AMS TWIN TIP TBE question.
- Check Engine ( ! ) mystery
- Cobb Intake
- New pickup (clutttch :D)
- Am I crazy? (Bigger turbo!)
- dijon mbc anyone? evo x
- Transmission, TC, and Rear Diff. Need to buy fluid!
- Magnaflow catback or Magnaflow turboback?
- Newb question : What is a twin scroll turbo ?
- High boost engine compartment vibrations?
- *video*Clicking sound from turbo area
- Help with Agency Power BOV install
- SSP Teflon Intake Gasket Set Review & Install
- ATP 35r bolt on turbo?? any users??
- 4B11T rod failure
- WARNING / HOW TO: Fuel Line Return (High Pressure)
- Need cylinder head, who sells ported ones with no core?
- BIG turbo / Spark Plugs ???
- Can't decide which route to go
- FP Red Turbo Questions
- Looking for some exhaust diameter measurements
- Stock Boost Pill OEM?
- Turbo Blanket ?
- Metal shavings stuck to rear diff drain plug
- 17,000 miles and bye bye clutch
- ACD System (question)
- Clutch broke... help?
- turbo back
- mil spec or ams cat?
- Short Block
- Need a clutch education before switching
- any thoughts on injection cleaner?
- 4B11T on engine dyno at Cosworth
- Anybody have experience with SIDE MOTOR MOUNTS or REAR MOTOR MOUNT?
- X MR Upgrades
- intake C.A.R.B. question
- Evo X CV Joint Axle Shaft Issues?
- Evo x mr touring mods????
- Rear Diff Options?? Any info would be great!
- Best clutch for stock evo
- Blaqops double pumper questions
- As far as quiet catbacks go.. how about this
- Tomei install with pics.
- MBC to OEM boost control help needed.
- Aftermarket Midpipe
- Cam install questions?
- Raise launch ctrl with FP Red?
- Let's Try This Again...
- Strange Thing happens
- Killer Blow by
- How much oil in tranny?
- Rexpeed o2 downpipe install & review *56k gtfo!!!!*
- HKS GT Extension Kit
- Shifter play - Video inside
- more hp?
- Can you get an aftermarket WGA for the stock turbo?
- any issues with TurboXS High Flow Cat?
- Why is the Rexspeed O2DP so much cheaper than others?
- FIC 900cc P&P
- Clutch for 8/9/X???
- Intake or Drop In?
- LICP compatibility
- AMS catback and HFC install question.
- Extra bolt for DP
- HKS SSQV on re-circ
- Forge Motorsport Adjustable Actuator
- Anyone run into any problems similar to this?
- Help.
- AMS downpipe (o2 housing) sound
- FQ-400 turbocharger
- Effect of muffler design on performance
- Perrin drop+turbo inlet vs intake
- Gears won't go in
- Evo 8 and Evo X oil cooler?
- Remove the mid pipe, dump exhaust straight from the cat or test pipe?
- 6262 Build, which cams?
- P1320
- Head gaskets & studs
- please help O2 sensor dethreaded
- Exedy Twin Rebuild kit Evo X
- For those running the Nisei LICP
- Fuel Capacity of the X
- ceramic core HFC vs. metallic core HFC questions
- Dom2.0 requirements
- evo x tranny
- FP Red/Green inlet pipe - what are you guys using?
- Dump the muffler
- Works stage 2 clutch?
- Can you hear the turbo and BOV with the AEM intake?
- Which LICP clears stock air box
- First Mil.Spec bolt-on HFC installed
- Will an O2 downpipe make the car louder?
- Anyone using Bosch 950cc injectors?
- Agency Power Dual CBE + HKS Blow Off Valve Clip
- Does stock Ex. manifold?
- Catlesss
- GSC Mitsubishi Lancer Evolution X S2 Cams
- p0223?
- Precision 6765 turbo build
- Filter, CAI, or intake
- Forge bov (rs)
- Injector for E85 and 35R
- Carbon Fiber Driveshafts for the X?
- Review: Coto Sports BOV
- Boost Gauge not reading right after car wash?
- Shifting bushing differences?
- When/at what hp is a twin disc clutch justifiable?
- To port or not to port...that is the question...
- Running Too Rich at Idle - TTP HIAG 2400cc Injectors
- New Tial BOV Q Recirculate 2010 version
- Mixing 91 Octane And E85 On An FP RED
- Twin Disc Clutches
- how to make close to 400rwhp w/ stk turbo?
- To those with test pipe or HFC connected to stock catback
- Custom Performance Engineering Exhaust?
- FP Red Owners...
- Best Upgrade path for fun daily driver?
- cat cell count
- Noisy exhausts - good or bad?
- Tanabe Touring Medalion
- O2 Downpipe style = most power?
- MIL.SPEC Evo X 100 cell bolt is now avaialble...
- ACT Heavy Duty Street Break In
- E85 Effects on Fuel Assembly...6 months later
- BR's EVOX, 514 whp, 93 octane....pictures, information and video inside!!
- 5w50 Mobil 1 Synthetic in an Evolution X?
- check valve???
- Safe boost level on stock tune?
- MR transmission oil and Differential oil change
- Clutch and Flywheel?
- Oil in intake: sign of a problem, or just in need of a catch can?
- Precision Turbo Turbochargers
- Back fire normal ?
- 3.5" or 4.0" FMIC?
- HELP! I threw a CEL
- Just ordered Exhaust!
- Newb needs help picking exhaust!
- Power from basic bolt-ons
- UICP and LICP?
- Exhaust add 60awhp??!!!
- Another TTP Engineering A1000 Aluminum Rods build!
- Identify these X trubo parts
- I need Stock Turbo Spec.s' EVO-X Pls.
- any gains from downpipe vs. o2 downpipes?
- AMS/ETS or Blitz FMIC?
- SSP Clutch MC installed at HB Speed
- AMS Front Mount to Stock Comparison
- Exhaust fitment issue
- BR EVOX T3/GT35r/header thread
- FP red W/ stroker or BB-X W/ forge internal
- FP, Blouch, Garrett, CBRD, Tomei specs?
- Evo X MR -CP PISTONS-CARRILLO RODS-2.2 L BLOCK-SOON
- Installing short shifter broke pivot ball cup... where to get one?
- Is FP making a Black for the X?
- JUN stage 2R camshaft package
- Wait a minute........
- Ceramic Coating
- DW 1000cc Inj.
- AMS completion 4B11 questions
- Turbo question
- Installed cone filter, I think my car feels slower...?
- Evo X short shifter ?
- Installed CBE, now car won't start
- Brian Crower Stage 2 Camshaft
- "Plug and Play" EBCS/AEM Tru Boost Question
- Anyone Offering 2.3L Shortblock For Evo X?
- Kelford Stage 1 cams
- ETS Exhaust Manifold, causing plug to melt in engine compartment (and resolution)
- Hks connecting rod
- Mivec wiring modification???
- Downpipe/02 removal help
- upgrade transmission cooler for MR
- Turbo XS HFC
- twm shifter and works and ams bushings galore! review.
- FP Green vs Dom 2
- So you can't get your Throw-out bearing released?
- Evc boost controller: Boost unable to hold
- 4B11 engine failure documentation thread
- Weird clutch problem..lil help please..
- New intake problem
- Maintence required light on!
- E85 Fuel System HELP!
- Concept G blue
- o2 housing vs o2 housing
- Question:Fuel Filter replacement and efficiency
- Exhaust Choices
- Parts Going On Friday and Saturday!!!
- misfire? not too sure
- min/max oil pressure on X
- Trouble Codes after Boost Leak Test
- ACT HD and master cylinders
- torque specs for intake manifold bolts?
- Any Gains On A Double Pump Setup on 91 Octane?
- vacuum lines
- homemade cat pipe?
- Breather tanks
- questions on 3 port
- transfer case
- ETS V2 Exhaust (No Mufflers)
- P0102
- e85 Fuel Filters
- Evo X AYC Rear Differential Concern - Help
- How much flow does the stock oil pump deliver?
- New Tial 44 MVS Wastegate and Recirc Valve
- New Tial 44 MVS Wastegate and Recivc Valve
- Vibration under boost and ecu pulling timing
- Turbo Manifold?
- exhaust wrap smell?
- Stock EVO X BPV Modification
