- Maf wire for blaqops ?
- Axl Back
- Video of ETS 200Cell HFC with ETS V2 exhaust
- My Evo X build update! Manifold + Exhaust Pics
- Finally Got rid of the CAT!!!!
- Looking for a new (reliable) after market clutch..
- Evo X: WORKS short shifter vs. TWM short shifter
- Question about Magnaflow CBE
- Underhood Fire Hazard?
- BR Intercooler Help
- Help me decide which turbo kit to buy
- Ebay Midpipe/Centerpipe?
- Tomei Ti Straight Pipe?? Should I add it to the X?
- New TBE new tune???
- What Size Injectors For 600whp E85
- hissing sound and strange smell after mods
- Blaqops ? and complaint
- Just installed ERZ exhaust on the X
- AMS CAI leads to water in LICP
- Weak point on 4b11T?
- sst upgrade installation.
- UICP sound ?
- Anyone a fan of the Apexi RS exhaust?
- Engine building ?
- SSP CMC v2/v3 frustration.
- Intercooler design....
- Need Quiet Exhaust
- sst slip
- Misfire Cylinder 1?
- Help! Filled up on E85, car won't stay running!
- arp ?
- Level of difficulty: DP & Turbo vs. Clutch?
- Whine at 3-4k rpm when rev car in neutral
- Stock Tune, What are the boost levels in high altitude?
- injen uicp??
- Downpipe Removal ?
- Request: TurboXS updated review and exhuast Q's
- Who has a 3-port boost solenoid?
- Forge Vs. Hallman MBC
- Can somebody identify this and tell if if it wrong?
- Toda Racing parts for 4B11T now available!
- Air magicly entering the clutch line?
- cone filter
- Question for FP turbo users
- better than stock
- Tell me why I wouldn't want a green..seriously.
- Machining The Stock Block +0.5 or +1mm
- DW800 Fitment issue
- o2 elim/downpipe options: rexpeed vs MAP (they lowered their price!)
- Turbo size
- Best DP/Testpipe combo for the money?
- better intake? need help!!!
- How lean am I running?
- Need advice on fueling build e85
- Another "Oh no, white smoke"
- Leak Help
- HAHa. Warranty on clutch?
- Air intake vs engine intake temperature
- how many coat their downpipes?
- ACT Prolite Flywheel
- FQ-400 Boost/Power/Torque Curve
- Evo X "ram air" intake
- Exhaust heat shield removal?
- Overheating
- hks 6speed tranny
- Blaqops help
- Apexi Intake
- Low compression and engine tapping
- What light does not having a cat trigger?
- Need some advice, buying a short block...
- Installed fuel rail now car RPMs jump
- Does anyone take the stock turbo and just upgrade the internals?
- 400hp on stock turbo?
- Fuel rail , 1100cc , e85 and more questions inside please help out!
- Your tranny fluid of choice?
- Exedy Dual Ceramic being installed
- T-case noise? Help
- ams or cobb dp ?
- Question: Is this normal? Tial
- Holset on evo x
- Stupid dealer!!!!!
- catback exhaust choices Invidia Q300 or HKS Legamax or GReddy SE?
- Easy way to bypass fuel relay?
- Stage 2 E85?
- BBX... Upgraded Oil Lines?
- AMS Widemouth Downpipe
- coolant
- What clutch wont break CMC?
- Amount of locking force applied in snow mode?
- Tailpipe hitting bumper
- SSP Master Cylinder 2 (Still Issues)
- Wideband Sensor Placement
- Just bought my new evo x, need some help.
- Evo X headgasket
- Clunk/Popping noise on startup
- Ets 4" fmic
- Megan Racing Turbo Header / Manifold
- Shearer Manifold
- Idle/wot issues
- AMS Intercooler Core
- Invidia Turboback Exhaust?
- Info Needed for Beatrush Differential Bushings
- AMS LICP w/ TiAL QR re-circulating kit (wrinkle black)
- T3 Oil Line kit
- Dark smoke from exhaust
- Radiator of Choice
- is it the boost leak?
- cone filter w/ stock setup?
- Eric Morse: Official Evo X Build Thread
- Going Lean at High RPM WOT
- Stock boost problem
- 3-port vacuum hose size help!!!
- 3"-to- 4" exhaust
- "Click" noise when I push the clutch by the engagement point
- o2 eliminator vs just a down pipe
- Which 35R platform Turbo or any Turbo suits my Goals
- Spark Plug question
- need help, turbo xs intake
- cnt version 3 exhaust
- small exhaust question
- Simple question on boost - stock turbo
- FP red
- Urgent help required - Mist explosion!
- Greddy Anyone
- Stock Flywheel Question
- BBX Lite
- my clutch and flywheel at 3700 miles
- Modded Evo longevity...
- Best shop to install evo x downpipe/test pipe.
- bbx vs blouch Dominator
- My custom Apexi exhaust
- Mid-pipe rattle?
- Fuel Pressure Regulator...!
- CP-E Cat-back Exhaust Review
- Bad Timing Chain Tensioner
- PT6235r Too Good to Be true or not?
- Transmission or Clutch or Both
- ETS intake with access port.
- stock replacement/ported stock manifold help, i already broke one..race video inside
- Clutch for high rpm/drag/dd
- New DW1000cc injectors problem and noise........(Again)
- i have a problem shifting...
- AMS intake
- ETS Downpipe install question
- Exedy Twin Disk
- E85 vs 95 octane pump/race gas mix.
- lost all power on interstate backfireing help please
- Synapse BOV review
- hks racing suction kit
- help with cat
- Review: ETS 4" intercooler
- gravity fuel cell
- FP Black????
- Perfered Coolant for X?
- AGP exhaust
- Car running lean. Need help!
- Raw fuel smell when driving
- Anyone with CP-E exhaust?
- any1 using the artisan exhaust system?
- ATP Intercooler
- Will This Clutch Hold Up or Break CMC?
- SST tranny or valve body part no n drawing
- 5857 or 3582 for pump 93?
- turbo life
- AMS Short Ram Intake
- Hesitation, sputtering, idle issues
- SSP MC2 Clutch Master Cylinder
- P0420 Code After Exhaust?
- Help with Buschur boost controller !
- OEM Clutch is Slippin' Help
- Quick question on exhaust noise and after market cat.
- Impact of compression ratio on engine build?
- FP Red differences
- Before my last mods install and last tune...
- Is this a good turbo
- cobb tuning hard pipe kit
- Transmission oil?
- ETS EVO X Makes 806whp!!
- Intake or drop-in? What's your preference and why?
- Castrol Edge
- Evo X MR problem
- ETS Mitsubishi Evolution X T4 Top Mount Manifold
- Its time to go fast ;)
- just got an APT intercooler
- Tial Q Bov issues
- Loud vibration type noise when letting off throttle
- Problem shifting under WOT
- Anyone tried a blow through setup?
- best clutch for the evo x?
- intercooler ?
- Downpipe to Cat flange size
- Car doesn't start...no idea why!
- Any turbo manifolds with..
- Missing relay?
- bbk vs. fp
- deciding on exhaust
- Magnaflow Resonator
- 10K Modding suggestion
- who uses aftermarket wastegate actuators on their stage 2 setup???
- ETS DP (external dump)
- Hfc ?
- 3.5" intake for stock-frame turbo?
- Boost Pill's removal
- 5 speed problem
- Just ported a X head
- Gsc s2
- Intake Manifold + throttle body worth it on stock turbo?
- CBRD FMIC tomorrow!!!
- Road Course racing - what turbo would you do?
- Can you run without REAR o2 sensor, no problems?
- Vibrant Performance / AMS O2 Sensor Spacer - Work for you?
- What is the difference?
- Possible clutch slip?
- Mahle pistons
- Help identifying ded clutch (pics inside)
- Engine break-in with new Clutch (plz read, i've done my share)
- Carbonetic Twin Plate Clutch Review
- COBB 3" Forced Performance Turbo Inlet Hose for EVO X
- Misfire??
- Evo X Blown Motor Out now...
- 8000 rpms
- FP red with external wg or internal actuator ?
- FP Red questions and options
- Final Drive Owners
- ETS V2 owners
- CBRD FMIC install pics...
- Silent catback ?
- Need Opinions....
- ACT XACT Flywheel ProLite
- New APM/Arias Big Bore Evo X pistons
- Intalled T1R Intake :)
- Anyone running a GT3071R?
- I need a down pipe gasket?
- Cusco rear LSD for evo X or other brands looking for setup in and best pricing
- timing chain worn?
- Cosworth's MX2 Cams?
- Can a bad DP install cause a drop in boost?
- Clutch still grinding
- Exhaust diamter
- Titek Exhaust
- Eneos gear oil opinions?
- DeatschWerks new 1300cc EVO X injectors
- Help please *fast* engine noise not found by dealer
- stock intercooler question
- Tial bov
- Anyone using 0W50 oil?
- Test pipe
- full Bushing kits
- Evo x clutch kit
- E85 Fuel System
