PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Boost Activated Cutout
  2. Catch Can vs Air Oil Separator
  3. Help Removing AMS exhaust manifold
  4. How to get to Turbo coolant line? (Pic inside)
  5. HELP! Advice on bad TOB, removal
  6. Timing chain replacement
  7. Strange noise possible tranny/clutch?
  8. 6466 stock block
  9. EFR Series Turbo Behavior??
  10. Competition Stage 3 Clutch Review
  11. Exedy Twin disk clutch. Opinions\advice\replacement
  12. Help with fuel level
  13. Evo x map o2 eliminator downpipe group buy!
  14. Engine RPM Problems
  15. Future turbo selection tips?
  16. Acceleration Issues
  17. intercooler for 18k turbo
  18. OEM injectors evo X
  19. ATS twin metal clutch?
  20. MAP Clutch Master Cylinder Issues.
  21. New Comp Clutch Stage 3 Issue With First Gear
  22. Shifter Cable Issue. Please Help!!!
  23. Strange Fuel Pressure - Dual Walbro's
  24. Grinding noise when clutch is engaged
  25. camshaft mystery
  26. ID1300 problems
  27. 4B11T Build Parts Review?
  28. Buschur Short Block vs. Others
  29. turbo comparison. old gt3582 vs gtx3582 vs gtx3576
  30. Stock frame turbo cam advice
  31. Weird noise after oil change in the X
  32. 2008+ metal pulley upgrade advice
  33. Flywheel Talk w/ pics
  34. Head gasket question
  35. Exhaust volume and drone solutions?
  36. Spec vs Comp Clutch
  37. First Oil change on its way...?
  38. MAP turbo kit idle issue
  39. Cant reverse without burning clutch?
  40. Pt5858 Issues
  41. New Clutch
  42. Turbo return line issue
  43. AMS CMC kit question
  44. Is this the new Synapse Synchronic DV?
  45. Rust in EVO X FE Rear Diff @ 7K miles.
  46. Cams or 18K Turbo
  47. Copper crush gasket
  48. Upgrade time, but in a bit of a rush!!! HELP!
  49. MAP New VBand 5858 Turbo KIT Review
  50. Need new clutch
  51. Exhaust mivec cam gear issue
  52. 2016 lancer
  53. Help: SMOG check fail due o O2 Sensor not ready
  54. Exhaust issue
  55. Evo sounds like a Subaru under boost?
  56. New gtx3584rs and Gen2 Gtx3582
  57. Final edition 7k miles diffrential rub/grind noise
  58. need advice
  59. Engine Failure - How?
  60. 1st gear transmission whine
  61. What is the problem with my trans?
  62. Difference GTX3076r vs GT3076r?
  63. S-AWC display/system activity
  64. Anyone using the large xona 95/67
  65. Bad turbo or boost leak?
  66. Adding exhaust baffle
  67. Knock knock.
  68. Is it my clutch?
  69. wont start
  70. Bad Vibes, NEED HELP
  71. PTE5858, GTX3582 or EFR7670
  72. Clutch thoughts and recommendations
  73. Before engine build - Questions!
  74. how can i get my engine to handle more tq
  75. Evo X Stage 4 Power Package and OTS Maps
  76. Subject revival on full fluid change.
  77. Intro/seeking build help 08 GSR
  78. turbo question
  79. NEW!!! Evo X Muse 02 dump
  80. Upgrade to evo x turbo ?
  81. Evo X MR leak
  82. Blown piston and damaged block
  83. Symptoms of transfer case going out
  84. Ams Downpipe Stud help
  85. Cracked rear diff
  86. Service Required light, no codes?
  87. Worried about limit of stock clutch after tune
  88. Mhi 18k
  89. Evox dies after injector and pimp install
  90. 6466 or gtx3582r ??
  91. Drop new engine?
  92. Loud ticking after driving for a while
  93. 3rd Gear Synco / New Evo owner
  94. engine would crank but not start
  95. Rear diff ?
  96. Driven fab tubular exhaust manifold for the stock frame turbo.
  97. Regarding New injen evo1800
  98. ASC intermittent error
  99. How To Tell GTX3076R vs GTX3576R
  100. who knows this 20g compressor ?
  101. Ticking & "backfires"
  102. Tomioka 5.00 Final Drive gears
  103. QM 8-leg squishy after hard launch
  104. My 13 gsr build in progress *8374 kelford c's*
  105. Upgrading to a MHI 18k
  106. Swapping out to an MHI 18K, worth it for a DP?
  107. Evo X Engine Bay Squeak? Video Inside
  108. New injen evo x cold air intake system
  109. Installing new CC Stage 3 + ACT Monoloc
  110. 3rd gear clicking
  111. Can't shift into fifth
  112. 3rd gear click
  113. Piper Cams?
  114. Synchronic DV - Is new body design out yet?
  115. o2 housing upgrade necessary?
  116. Emission ready testing not complete HELP!!!
  117. Turbo upgrade with stock block
  118. Off and on smoke from exhaust new turbo
  119. Magnaflow 16823 Exhaust Review
  120. Plz help! Maint required lights!💥💥
  121. Help!! New Engine, no spark!
  122. ETS Extreme exhasut for trade for ETS Queit
  123. Not 4G63 vs 4B11 but 4B and 4G
  124. timing chain "re-install"
  125. RPM fluctuating in 4th gear! PLZ HELP
  126. New Injen Intake?
  127. Planning build cam turbo advice plz
  128. Ams performance intake on MR
  129. Tapping sound around crank pulley?
  130. Turbo Review: TCS Stage 2 OEM Turbo Upgrade 500+ WHP
  131. dryflow filter cleaning
  132. Vibrating under acceleration and above 60 mph
  133. Rebuilt motor oil Debris
  134. 2.0xtr or ams stx500
  135. Stage 2 clutch?
  136. Smoking at idle
  137. Oil Leak, Need Advice
  138. Ultimate Racing Catback.
  139. 2010 gsr possible boost leak? Help
  140. Tomei test pipe
  141. New stock engine
  142. ASC ECU dead?
  143. Evo ecu problems
  144. Help me to identify these cams
  145. I honestly have no idea...
  146. P0400 and P0402
  147. 4B11 vs 4G63
  148. Brian Crower S2 Cams/Cams in General??
  149. AMSOIL Dominator Racing Oil 10w-30 - DD
  150. Dimensions SST cooler
  151. Stock overbore pistons?
  152. HELP.. Clicking after changing gears; burning clutch (badly)
  153. Looking for my first clutch
  154. Beatrush Rear Differential Spacer - Whine?
  155. Anyone one have experience with the Turbosmart Kompact DV?
  156. Great engine builder in AZ ? Helppppppp
  157. Exhaust Questions
  158. Exedy CMC Replacement
  159. 4b11T Cradle Bolts
  160. Evo X with Map EF4 turbo power band
  161. Aftermarket Clutch with Upgraded CMC recall
  162. ARK design superflow dual !!!
  163. ETS high flow cat
  164. ACD help
  165. Ultimate Racing exhaust system for sale
  166. Shortblock core price?
  167. Mystery Engine Squeak (Similar to break squeak?)
  168. Evo X stock engine
  169. Possible Timing Chain Damage?
  170. Help! ABS AIRBAG ASC 4WD Service Required
  171. Really Strange problem. AWD/Outside temp sensor?
  172. Time to upgrade fuel system
  173. What's the point of CNC porting and cam upgrading for the cylinder head?
  174. Exhaust Leak, Limp Mode...?
  175. I think this is a clutch/flywheel issue?
  176. Odd RPM matching noise inside cabin
  177. how to drill top bolt out of turbo on car (pics)
  178. Just purchased 2008 GSR starting to misfire :(
  179. Clearance piston-cylinder
  180. Underhood Shifter bushing part number
  181. Evo X ACD tuning
  182. Help Diagnose
  183. Help identifying part of oil filter bracket
  184. LSD Gear Oil and ATF Fluid?
  185. Custom exhaust (what piping is needed??)
  186. Clutch Advice
  187. EWG EFR turbo kit vacuum hoses
  188. Misfires/Knock - help
  189. Invidia test pipe
  190. This is a killer Street Turbo
  191. Evo X Rear Diff Pinion and Ring Gear
  192. Evo X rebuild help
  193. Confirmed with MAP, Cosworth Evo X intercooler and piping are being discontinued
  194. Evolution X - ACD controllers - ACD-Pro (proposal)
  195. Clutch QUESTION
  196. AMS STX500 or CBRD RBX Twinscroll?
  197. Ralliart rear diff swap
  198. afr log to table
  199. Installed ETS V2 Regular w/ Resonated Test Pipe sound clip
  200. Thoughts on MAP cast manifold
  201. Bolt Identification on Evo X MR
  202. Boost leak test - leaking BPV
  203. Clutch Engagement Very Strange
  204. Can't get this turbo to mount!
  205. 2014 evo x 30-71turbo
  206. Looking for someone to replace my clutch
  207. Recommendations while doing clutch
  208. SST Issues - Jerky while cruising
  209. 4WD Service Required.
  210. Stock turbine housing replacement
  211. anybody experiencing turbo upgrade by turbo r us??
  212. Daasca's 2013 WW Evo gsr build
  213. Radium Fuel Rail -- weird pulsing noise after install?
  214. Clutch Recommendations,
  215. Boost Leak? Spool? Transmission Problem? WTH!!
  216. Turbo upgrade or bottom end build...
  217. Engine Idle in cold tempatures
  218. Engine dies while braking
  219. EvoX HELP MEEEEE PLSSSSS
  220. What's needed for E85 (including winter storage)
  221. Need help with understanding compression test
  222. New down pipe
  223. Ultimate Racing Downpipe Feedback
  224. Clutch Life Expectancy
  225. Cams...Should I pull the trigger?
  226. '15 Clunky Shifting?
  227. need help! High Idle!
  228. Evo X Overboosting and no idea why.
  229. 2011 MR, possible boost leak?
  230. Is a 5 angle valve job worth it?
  231. One stud holding up my turbo upgrade
  232. Understanding fuel pumps and fuel maps
  233. Sakura Race Version Exhaust
  234. Misfire on new car
  235. Another exhaust question thread.
  236. Need help guys!
  237. Evo X powersteering tank leaking
  238. Evo 7 transfer case help
  239. Cracked Exhaust Runner usable?
  240. Would gtx3076r or 3582 bolt-ins support 8000 RPM?
  241. New Evo X GSR 2010 guy
  242. Deatschwerks vs Walbro Fuel Pump
  243. coolant smell
  244. Sometimes engin RPM take too long to drop
  245. 4th gear pop out?
  246. Map fuel filter kit
  247. What hardware for MAP cast manifold?
  248. STX400/STX500/COBB Stage 3
  249. Contemplating FMIC or not.
  250. Misfire/ Injectors
