PDA
View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30
  1. Who has the "Harman Motive" Intake?
  2. Question about part/brand compatability.
  3. Selecting engine upgrade help
  4. "Check Tarmac" on the HUD
  5. Monster Sport parts for Evo X
  6. Intercooler size??
  7. 2 Cone filters, Which do you recomend?
  8. Okada Plasma Direct?
  9. ok so i need help quick
  10. I want more torque!
  11. HTA86 Twinscroll
  12. Which boost gauge?
  13. ARC blow off pipe?
  14. Engine Service Warning
  15. Where to buy the boost pill?
  16. Stock Block, Stock Turbo
  17. Diameter for EVO X Radiator Hose??
  18. UR FMIC for Evo X!
  19. best intake question
  20. installing apexi avcr need help on locating the sensors
  21. Quad Exhaust for the X
  22. Mods with Carb #'s (we should have a sticky thread with this info)
  23. Agency Power Intercooler Pipe Kit question
  24. HKS Super SQV Recirculation Kit
  25. Boost Level
  26. Anyone sell aftermarket OEM spec intake pipe
  27. Where can I get a recirc kit for HKS BOV?
  28. HKS Silent Hi-Power exhaust
  29. Performance Parts Sheet
  30. help me pick: exhaust poll
  31. need help!!! code P0140
  32. Downpipe with Buschur SS Dual Catback Exhaust
  33. Nees Help! Engine oil inside the PCV hose?
  34. !!HELP!! Clutch question???
  35. So my clutch finally went......
  36. Cat vs. hollowed cat vs. testpipe
  37. ETS intake elbow issues?
  38. Need Help... CEL P0171
  39. TMW Short Shifter & Bushings...AWESOME (w/pics)
  40. Ultimate racing downpipe.
  41. Crankwalk/Clutch issues
  42. Anybody recirculate the HKS SSQ BOV?
  43. sick of HKS SSQV setup...
  44. Upgrading Fuel Pump??
  45. upgraded valve spring?
  46. P1238 Help!
  47. Distance to Empty
  48. Experience with Works Stage 2 clutch?
  49. Buschur Racing LOUDER then chambered LS1!!!!
  50. Ultimate Racing Exhaust review
  51. Stock FMIC / upgraded turbo?
  52. Blitz R-Vit i-color on MR?
  53. check engine light
  54. clutch install near Tacoma Wa.??
  55. oil change at the dealership
  56. Anyone try this Exedy Clutch?
  57. Wait on Downpipe?
  58. firmware
  59. Works VS. Cobb Short Shifter
  60. HeadGames/Big Valley team up to make the fastest X..even faster!
  61. HKS Hi-Power Exhaust
  62. UICP and Turbo inlet pipe? is it worth it?
  63. what's needed to power my red?
  64. Bad smell
  65. Short Shifter?
  66. Perrin Exhaust
  67. Blow off valve: Where is it at.
  68. Weird WOT CutOut? Any explaination?
  69. any issues with HKS foam drop in filter?
  70. JUN modified intake manifold kit
  71. JUN big bore throttle body
  72. EVO X Auto Tranny upgrade?
  73. Test pipe or no test pipe?
  74. Turbo manifold
  75. Turbo install w/o tune?
  76. X mod pricing... are you serious??
  77. kelford 214-b vs cosworth mx1
  78. help! drivetrain niose.
  79. Homemade Cone Shield
  80. Works Drop In Air Filter?
  81. intercooler hard pipes??
  82. Help transmission
  83. clutch job
  84. Turbo install pics.
  85. Help With Exhaust
  86. 5th Gear vibration on shifter = rattling
  87. New HKS GT3240 evo Ⅹ
  88. best EVO X exhaust question
  89. aquamist meth injection
  90. Can a 4B11T block be swaped with 4B12s?
  91. Blouch Dominator II vs FP Red - Pros/Cons
  92. EVO X ETS V2 cat-back exhaust installed w/rattling noise
  93. Tranny gone (manual)
  94. hks legamax catback/ur 02/dp combo
  95. Harman Motive Single Exit Exhaust
  96. Buschur Bullet Vs. Quiet Muffler
  97. Recipe for over 410 whp on pump gas
  98. Buschur Quiet vs. ETS dual catback
  99. deepest sounding cat back?
  100. Stock X Injector Size and Fuel Pump
  101. CBRD evo X turbo and bits...
  102. Any LICP fit the stock airbox?
  103. difficult to install cams?
  104. The Upper Intercooler Pipe Reducer
  105. Burshur Racing Catback???
  106. SSTF Fluid, Transfer Oil, Rear Axle Oil
  107. Poll - downpipes
  108. oem intercooler
  109. Boost and vacuum numbers ??? WHat you guys have?
  110. Bye ACT hello Exedy
  111. Blitz panel drop in filter
  112. New Deatsch Werks 800 cc injectors.
  113. Engine knock after exhaust and AccessPORT install
  114. Turbo Boost Hose Help ASAP
  115. Evo ECU
  116. Different Trans fluid
  117. Apexi Power Intake Release Date?
  118. FORGE WGA? pros cons
  119. benefit to muffler with 2 exits?
  120. QTP cutout?
  121. Stock Boost Question
  122. Noob question about Evo exhaust components
  123. Grinding noise
  124. Parts combination?
  125. Any good flowing exhausts that don't drone?
  126. FMIC or downpipe?
  127. accessport and downpipe?
  128. What intake is this?
  129. Will the Ams licp fit Aem intake?
  130. Garage G Force 80mm titanium exhaust (single outlet)
  131. Perrin Stealth CBE...
  132. Just got a new Cosworth dropin filter from RRE
  133. AMS Intake System?
  134. Well any DP&Testpipe work w/ Perrin cbe?
  135. Ever heard of AFE?
  136. ARC or HKS?
  137. exedy stg2 4-puck questions...
  138. EVO X Anyone Making just an o2 housing?
  139. TBE or CBE
  140. Buschur Dual Exhaust w/ Quiet Muffler review
  141. Not the normal missfiring problem
  142. Cobb Turbo Inlet Hose Gap Problem
  143. Fluttering Sound Under Hard Acceleration
  144. Upper intercooler piping
  145. Compression test
  146. ams dual exit exhaust
  147. Evo X Turbo Specs.
  148. HKS Racing Suction Kits
  149. Launch Control Problem?
  150. Perrin Panel Filter
  151. Changing the tranny fluid in the x
  152. Buschur Racing EVO X update.
  153. Hks gt rs bb
  154. Cat or no Cat
  155. cobb turbo inlet pipe
  156. Has anyone blown a motor
  157. arc induction box
  158. Intercooler pipe blew out.No boost
  159. Any COBB Short Ram Users?
  160. Dry Sump Oil System
  161. will a 2g eclipse bov work on evo x?
  162. Clunk in Reverse
  163. Custom 3 inch single exhaust?
  164. nisei intercooler piping
  165. Any new word on the MR's tranny hp capacity?
  166. Is there a quick shifter available?
  167. Check those nuts and bolts boys
  168. Evo X Head. Got porting?
  169. Interesting weight find & other observations today which swapping the clutch...
  170. Official Evolution X Exhaust Thread
  171. good loud but deep exhaust
  172. Bigger intercoolers
  173. New part arrived today from Touge Factory
  174. Down Pipe/O2 housing with Larger Turbo
  175. AGP exhaust
  176. evo x mbc help
  177. Full Race manifold
  178. Turbo upgrade with stock internals?
  179. GReddy Spectrum Elite update?
  180. AEM Intake and LICP Compatability
  181. Anyone go custom exhaust route?
  182. AMS How to build a bullet proof 4b11 Part 2.
  183. Burschur FMIC, IC pipe, shifter bushings installed
  184. HFC or test pipe in stealth mode
  185. Trust - Greddy Exhaust
  186. Tanabe Exhaust for the X...
  187. Artisan Carbon/ti Exhaust?
  188. Nisei intercooler piping compatibility?
  189. Evo X Build
  190. whats involved in changing a clutch
  191. drop in filter vs Cone
  192. Bleeding transfer case?
  193. 6262 or GT35R Opinion...
  194. Differenced between HFC and Testpipe
  195. 5th gear problem
  196. Noob with some parts questions!!
  197. Ultimate Racing twin-pipe exhaust clips!!!
  198. cobb tuning ic piping info ??????
  199. Help!! CONFUSED!!
  200. Question re: uprated wastegate actuator
  201. Cobb ic piping kit w/aftermarket ic
  202. ultimate racing UICP + single exhaust
  203. Consolidate turbo options/sites
  204. HELP: More Codes: P0222, P1234, SAWC Service Required
  205. lighter flywheel yea or nay?
  206. Afi turbo billet fuel rails
  207. dps and testpipes
  208. Add me to the "clutch go bye bye" club (almost 11k miles on the stocker!)
  209. Shifter improvements?
  210. Spark plug replacements
  211. evo x rs turbo failure
  212. New goodies
  213. ETS catback v1 vs V2
  214. Those with the MR's
  215. Oiling system questions..
  216. 3 Cheers for T1R 76s Sparrow!!! HybridR great job!
  217. Buschur Racing EVOX on the DYNOJET 440+whp.
  218. What kinda coolant on the X
  219. Changing ACD fluid... couple questions!
  220. Buscher vs. Ultimate Racing
  221. Lets Talk UIC Piping...AMS vs. Nisei
  222. Wideband Oxygen Sensor on Downpipe or Test Pipe?
  223. A few exhaust questions
  224. exhaust question
  225. Evo 8/9 catback on Evo X
  226. ETS Full exhaust system review
  227. Works modified stock exhaust
  228. Decisions on aftermarket cat-backs
  229. Running with cosworth cam
  230. BR EVOX, 400+ whp on pump gas with Cosworth cams
  231. How much power can the 4B11 handle.....
  232. Which downpipe?
  233. Building a bullet proof 4B11
  234. My T1R 76S Exhaust review (BEWARE)
  235. Buschur's EVO X, making some nice power.
  236. Which BOV you recomend?
  237. HKS Releases Silent Hi Power Exhaust
  238. What are the advantage and disadvantage of a light weight flywheel
  239. Surge Tank
  240. AFI Turbo Project X
  241. What is an INTAKE really worth when you are TUNED?
  242. For those EVO X owners who have the AMS 3-inch test pipe...
  243. How can you tell if your syncros are out?
  244. Transmission drain bolt covered in metal.
  245. HKS Announces Oil Cooler Kit
  246. Evo X TBE Combo
  247. Air Flow Package
  248. Perrin Turboback Sound Clips.
  249. Question on HKS IC Piping
  250. Redline oil
