- Clutch smells please help
- Warranty Issues/Fixing SST(Canada)
- Is it safe not to upgrade my SST?
- Idiotic Newbie Question
- sst problem urgent help needed
- A theory on how you can extend the life of your TC SST transmisisions?
- S-Sport In Manual Mode
- Is this normal ? Transmission leaking oil ?
- 09 Ralliart transmission swap
- Auto-shifting delayed during 2nd-3rd gear, car hesitates and no power for a sec. HELP
- Strange noise while decelerating. (even gears)
- 2011 Ralliart SST acting up, need insight
- Ignition / Shift Interlock Cable for SST
- Precautionary Measures
- Right Hand Drive MR Owners: I need some help please
- sst problem
- Mixing SST Fluid?
- cooling duct
- SSP SST Cooler Connection Question
- Does this happen to anyone else after stoping at a light?
- weird noise
- MR owners occasionally tracking/autocrossing your car - TC-SST cooler mandatory?
- '08 Evo X MR SST
- Shift Knobs
- P1874 code, Help!
- P1875 code (Damper speed sensor poor performance)
- A question about my SST operation
- Selecting Neutral with the Paddles?
- 2010 evo x sst will not launch after tune ?
- MR TCU tuning - Places?
- '08 TCU firmware on '13 MR
- Jacks Transmission upgrade, worth it?
- Shift feel and Turbo function between Normal, Sport, S-Sport modes.
- SST Technical Guide & Rebuild Kits HERE
- Sst shifting points for ralliart
- Just turn up your oil pressure?
- S-Sport Flash
- BIG thanks to Jeremy @SSP
- can SST handle EF2 or EF2.5???
- Would you like a new Reverse lockout lever?
- Slushy Gear Shift - Falling Into Gear?
- Evo X MR - SSP problem
- How long Will the SST Clutches Last??
- Weird thing happened launching
- Easy ways to solve overheating?
- former GSR owner, new MR owner
- Need help with TC-SST flush - Denver/Colorado Springs Area
- Anyone in Virginia that can flash sst?
- Questioned for Tuned SST Evo's
- Grinding noise.
- Chatter clutch again after replace clutch basket
- 08 evo x mr no gears engaging
- sst help; lost even gears. p1833 cel
- Need Help Figuring out weird noise from pass. rear
- Show me VIDEOS of High HP TC-SST in action
- Whining at low speed?
- Clutch Pack Replacement At Dealership
- Clutch Slip?
- Question about the sst warning light!
- Rev-hang during upshift
- When do you guys shift your SST?
- concern at start up
- SST overheat + 4wd system service required after 5 minutes of snow drifting?
- Removing/Checking sst filter ?
- SST Ralliart Lurks at low speed
- *****Need help Figuring out whats missing*****
- MR shifting too soon?
- AWD ECU location
- 2012 Transmission in a 2009
- Evo X MR SST PROBLEM **PLEASE HELP**
- List of SST filter including OEM
- Ralliart launch problem
- TC-SST firmware history/updates
- Anyone within a few hours of Memphis that can flash TCU?
- mr tc-sst issue. anyone seen this before?
- SST Final Drive Gears
- The new instructions for oil change.
- SST Maintenance Poll
- Yet another SST question.
- Lightened Flywheel?
- Jack's transmission
- Please help! Another SST owner at a potential loss :(
- Pentosin FFL-4 vs Mitsu Diaqueen SST Oil - Interesting Finding...
- Surgery needed on RA possibly
- SST to 5 Speed Conversion Completed
- SST Upshifting in Manual on its own.
- New SSP Aluminium Flywheel for SST
- reusable filters
- Dealers have completely wrong info on changing and filters??
- Only 2 Drain Plugs on 11' Evo X SST?
- Rattling noise from engine bay
- 2012 mr
- vibrating sounds from exhaust / ETS V2
- P1874 : Clutch 2 system (Pressure abnormality)
- SST - normal, sport and s-sport tuning question
- Delayed shift from 2nd
- Will the dealership flash my '08 TCM to '12?
- TC-SST issue
- TC-SST trasmission, how much power?
- Tranmssion sound at startup while brake engaged
- Pairing new 2012 TCU/SST with 2008 Evo X
- Strange transmission behavior
- My launch control crapped out on me. Cobb AP and basic mods
- NEWB EVO X MR TC-SST ?: GTR transmission compared to TC-SST?
- Anyone with SSP 600 on 2008 model?
- RA´s S-sport and launch. DONE
- Does anyone know if this is the actual TC-SST unit?
- Dodson clutches experience?
- Stage 2 ssp kit opinions
- 2012 evo x MR Questions... new to evoM!!
- Driving TC-SST in Heavy Traffic - Owners feedback wanted
- So where is the TCU located?
- SST Grind on Startup
- SST How It Works, Problems, Upgrades; Tech write up
- Trans service required... message blink
- Not sure if this is an SST Problem
- Usefull SST OEM part numbers
- SSP EVO X MR 600hp 10 Disc Clutch Package
- Manual shifting hard downshifts.
- Can a TC-SST be rebuilt?
- MRP? SSP? XRP? Who is the real manufacturer?
- What to do with my old transmission?
- Many questions from a new TC-SST owner.
- Manual mode - WOT shifting?
- Iveytune/ Dodson SST mods
- Magnetic Drain plugs
- Ralliart TCU swap with MR
- SST fluid change by dealer but no new filter..thoughts?
- want to put together a cooler
- TCU cost
- How are these transmissions doing in the newer cars?
- TC-SST rebuild?
- Transmission Oil Cooler Soft hose replacement
- Highest HP TC-SST
- Dodson Replaceable Stock Filter
- transmission noise
- Sst problem
- tune after catback?
- Quick exhasut question
- Gear shift jerk on SST
- Warning: "Transmission Service Required"
- evo x mr filter Q'S??
- 2nd SST Transmission with a problem - WTH This Sucks
- S-sport shifting issue on high HP
- All About SST Fluid
- SST oil/filter change. Do you flush out old fluid with mineral oil?
- Cold Shifting
- This might surprise some people...
- Sports mode down shift
- first sst fluid change, metal shavings?
- Error when shifting(ed) to neutral
- ralliart sst stalling!?
- need help DIY sst oil cooler part list
- sst problem.(broken)
- SST Limits
- ***TCU Development Donation Feeler***
- A trick I figured out when WOT in 1st
- R blinks occasionally before engaging?
- SST temp gauge
- TC-SST Level check plug.
- SST TCU wanted
- TCU Updates?
- MR won't go into gear at all an has multiple cels
- Odd issue in reverse
- Max torque for a mr
- Dumb question about the MR transmission
- What if my SST fails in 2014, and I own a discontinued 2008 Evo X?
- knocking noise
- SST making weird noises after fluid change
- Fitting a simple Aus-supplied fan to the stock SST cooler
- The evo x SST model modes
- MotoIQ Project Evo X update: SST and Engine oil cooler upgrades...
- HELP! Whats the most an Evo X MR trans can handle?
- Evo MR SST - 11.0@127mph
- Importing TC-SST
- Is this normal?
- sst pics???
- NEWB....MR x Issues....
- Overheat signal when trying to launch control
- slow launch, bogging upshift
- 30+ psi clutches opening
- TC-SST not switching modes
- Clunk/ rough shift every so often?
- Differences Between 2008 and 2010 Trannys (less chances of overheats?)
- Any tc-sst owners bored of their tranny?
- Diaqueen vs SSP vs Willall - Cost
- Breather hose leaking oil?
- TC-SST Problem
- Avoided Slow Down Message On Small Tight Track
- wtq limits for ssp clutch kits?
- Dodson Motorsports clutch discs
- Tuned SST issues
- S-Sport wear and tear
- Info on the future of Getrag, Dry Clutch???
- Tc-sst failure over mods?
- x MR sst question
- Ssp 10pcs clutch pack user remark
- Noob S-Sport question
- SST Longevity
- MR trans fluid
- Evo X 2010 and 2011 - did they get rid of lag?
- Little rough shifts
- SSP Titan Series Stage 3 "Pro track package"
- SSP Titan Series Stage 2 SST Track Package
- Sticky Downshift?
- SST MR/SE 1st gear TPS limiter FOUND!
- Paddle shifts are slow at 16psi. Why?
- Ralliart SST Grind on Startup
- Upgraded clutches on tc sst through mitsubishi
- Summer project: Hks gtii 7460
- SST bad at 1,400 miles - why I hate German engineering
- Having issues with 5th and 6th gear
- Nic's 400+ whp Evo X MR Build
- HELP!!! Front Diff not working
- Need some info for SST, looking to upgrade
- RRE TCSST Cooler (Also In Sticky Above)
- problems shifting from 1st to 2nd in sports mode
- How to get the same throttle response from "Sport" to "Normal" mode?
- Tranny filter - can it be serviced?
- Throttle "blips"during downshifts.....
- 1st gear slow to shift at WOT?
- Possible SST clutch problem? (2008 MR)
- Fan on factory trans cooler
- Is this normal for the sst?
- My transmission story
- Light throttle, clutches opening
- would random slowdown have anything to do with SST?
- noise coming to a stop
- TC SST fluid
- Transmission problem
- Problem with SST, P/R/D nothing happens!
- Chen's Evo X MR build....shooting for 500+whp!
- Do You Change The SST Filter?
- Best tranny cooler for the MR?
- SST pressure data
- Getrag SST Exposed....Must read for X MR owners!!!!
- SSP Clutch Kit
- Worlds Most Powerful X MR.......Part 2!
- What are my options if my SST keeps opening up due to overtorque?
- Idiocy at the dealership(s)
- SST Owner Poll
- Wierd rev occilating phenomenon in second gear with cold tranny
- SST Transmission Only Shifted Between Gears 2-4-6
- Evo X SE?
- How much hp
- Tuners who also tune the TCU
- Issue with SSP Transmission Cooler?
- About to buy back the Evo X MR gotta question...
- SSP - Pro Gold DCT Fluid
