PDA
View Full Version : Driving Techniques
Pages : 1 [2]
  1. first launches
  2. First time ever at track and question
  3. Dealing with hydroplanning
  4. Driving the evo?
  5. Need help getting 60' down..
  6. drop throttle oversteer
  7. AWD burnout?
  8. shifting into 5th gear..
  9. "Launching" your car...
  10. shifting on 1/4 runs
  11. Cold tires question (R-compound)
  12. drifting downsides
  13. vid from a while back
  14. Launching the Ralliart...?
  15. And you thought you had skills! Check this out:
  16. Best way to determine shift points?
  17. What gear to launch an evo..
  18. 1st or 2nd gear after a rolling stop?
  19. Not so smooth Shifting
  20. Best way to swing your tail out
  21. detailed instruction on launching awd..
  22. Learning how to drive
  23. Quick Qs about shifting
  24. slipping into gear
  25. 2 QUESTION about heel and toe!!
  26. Launching with FWD
  27. Contour SVT
  28. Headed to Summit Point
  29. Double Clutching
  30. Looking for a Good Racing School
  31. 3rd gear, 40 mph roll..
  32. how i start my car driving in first. is this "riding the clutch"?
  33. APEX early or late braking
  34. Handbreak - what am i risking?
  35. Am i a bad driver??!?
  36. advice on circuting
  37. How to Determine Optimal Shift Point for Acceleration
  38. Shifting technique...
  39. Tech tips on AWD drift.
  40. trail braking
  41. clutch kick
  42. How to be a Psiho Driver!!! ++Tutorial++
  43. tight uturns
  44. what is the best way to lauch an evo with an upgraded clutch
  45. smoother shifting
  46. FWD launch RPM?
  47. Help me
  48. Help me out (define these terms)
  49. How to launch twin disc
  50. Help with manual turbo.
  51. what would happen if clutch dumped?
  52. Manually shifting an Auto
  53. And you thought FWD drifting was hard!!!
  54. Awesome J hook
  55. Automatic launches?
  56. check this and what is itused for??
  57. Has anyone done a 1st to 3rd shift..?
  58. power shifting
  59. launching
  60. 5 spd car, when neutral,can I apply the break without clutch?
  61. Skyline GT-R @ SEMA drifting around the cones
  62. Second Gear Shift
  63. 1/4 Racing Techniques
  64. Regaining control
  65. Driving Tips
  66. [question] double clutch
  67. Up on three wheels?
  68. How to Launch
  69. Pulling the e-brake = hella fun...
  70. Please Do Not Drive Hard In Wet Areas/rain
  71. finally launched
  72. burnout
  73. Should I be able to...
  74. PErfomance driving in NEW England
  75. Good place to buy helmet
  76. Drifting tips
  77. Handling oversteer
  78. Any upcoming high performance driving school in Southern California?
  79. Pulling E-Brake
  80. Why I don't push it in the canyons
  81. Evo bucking @ low speeds on bumpy roads
  82. Damn....It costs THIS much???
  83. Left Foot Braking in a Lancer
  84. racing an oz
  85. Left Foot Braking in an EVO
  86. Ridgecrest Calif Rally school Feb 28
  87. drag racing
  88. Wheel Spin During Cornering
  89. shift problem
  90. Tracking an EVO on a road course...
  91. More about driffitng
  92. what do we call that?
  93. Correct line for cornering?
  94. Safe RPM to launch
  95. brights
  96. acceleration
  97. how to use lancer to 360 turn?
  98. Snow Driving Question
  99. Drifting and donuts in an AWD car
  100. Changing Gears
  101. shifting question
  102. How to brake?
  103. Norris Design Evo7 Launch
  104. clutch- dumped or burned?
  105. how to get the best times?
  106. Do u Drag Gears?
  107. need help
  108. advice for my lil brother
  109. Double Clutching...
  110. practicing standard tranny on an acura rsx
  111. First Launch Atempt
  112. My 0-100 kmph time and question.
  113. Do you down shift while coming 2 a stop?
  114. shift point question (renamed)
  115. Parking the car in 1st
  116. launch vs. rolling start
  117. How to launch a evo
  118. Lift Off Oversteer
  119. how would you get the evo to a good launch?
  120. Driving methods
  121. driving tips
  122. What is double clutching?
  123. best shift points for 1/4 mile in the evo?
  124. Driving Techniques Volume I: Launching
  125. Launching question...
  126. 1/4 Mile Times
  127. What is the proper launch?
  128. How do you shift fast?
  129. Car performance 101
  130. Hill Techniques ad nauseum (MERGE)
  131. Learning to drive standard tranny on an EVO
  132. E-Brake to initiate drift.
  133. How do you guys launch
  134. Left foot breaking experences...
  135. Tire Pressure for the Track?
  136. Teaching Significant Other to Drive
  137. 2 Step
  138. Shifting to neutral without clutching
  139. Shifting and the clutch?
  140. 2nd gear = slower shift for smoothness?
  141. Evo 8 road course prep
  142. break in? 4000k or 5000k shift
  143. Powerslide experience
  144. Faster Acceleration Times
  145. Has anyone ever lost control
  146. Parallel Park!
  147. FWD Doughnuts?
  148. How to do a donuts???
  149. WOO HOO! my first mini-launch today!
  150. So you think you can shift?
  151. Advanced Steering
  152. How do u race an automatic lancer?
  153. How To Launch The Evo
  154. Renting a track for the day
  155. What exactly is heel-toe shifting?
  156. Is there a way to launch from 2nd gear?
  157. Mitsubishi Eclipse Evolution!
  158. what exactly is Double clutching?
  159. lancer MR mods
  160. what exactically is drifting
  161. eliminate your blind spots
  162. How To Brake
  163. Coolest drifting animation
  164. ????
  165. Launching AWD
  166. AT Lancer Help
  167. Good Shift Points? Gear for speed?
  168. Revmatching??
  169. Driving Techniques Dos and Don'ts For Automatics
  170. Tire chain placement for snow
  171. how to launch
  172. using the hand brake?
  173. Canyon Driving
  174. RPM Levels & Racing
  175. auto shift point
  176. Auto-launching
  177. Noob asking for Manual Techniques
  178. n drops
  179. E-Brakes Hand Brakes
  180. upshifting/downshifting
  181. Sweet Ride
  182. I have never driven a manual
  183. using hand brake at light with your auto?
  184. power loss ratio for AWD
  185. Threshold Braking
  186. Good Article
  187. First step to driving better: Go Kart
  188. How to launch.........
  189. Post your 0-60 times here!
  190. Interesting website
  191. heel and toe
  192. Tips and suggestions
  193. Do you downshift when slowing to a stop?
  194. OZ peak power at what rpm?
  195. Any automatic techniques?
  196. Drifting......Rally?
  197. Over and Under Steering...
  198. Double Clutching
  199. drifting
  200. Driving Techniques Dos and Don'ts
  201. Help!! U.S. Lancer ES Drifting Techniques Needed
