- Question : Magnus smim
- JDM Bumper Install
- Injen UICP install problem/question
- Trunk torsion bar installation problem
- bleed the power steering pump?
- evo head install
- o2 dump install help.
- Perrin DP/HFC doesn't fit. Turn it into HFC?
- looking for a how to on downpipe reomval on the evo x
- headlights?!
- walboro 255 in line pump
- HOW-TO: Android Phone Data Logging and Video Overlay
- rear wiper(help)
- 3"catback questions
- How To: Replace Alternator
- ACD Relocation
- Has anyone ever installed the Schrotch Autocontrol harnesses in their evo?
- Problem with boost gauge install
- do luck carbon fiber trunk install! help asap!
- AMS Shifter Base Bushings
- Transmission reinstall tips need
- P0011 - cam sensor removal, check, and proper install? Need to rotate 180*???
- Help! Installing Tactrix 3-Port BCS
- BR shifter bushings don't fit!
- Q45 90mm TB
- paint stock evo8 taillights?
- Oil pan reseal??
- How to tap a vacume fitting on new turbo???
- How to make a Mini Battery Kit same size as Oddessey.... Fits all Popular Trays.
- Mail in flash, recommend?
- How to: fix AC blower not working on levels 1-3
- Evo 8/9 center dash trim question
- how to install jdm rear?
- Need help with an FP green install.
- How to: Know if it's too late for your transfer case
- Hack 'n MOD '06 MR shifter
- mileage gauge change
- Help with throttle body seal, boost leak
- How To: Crimp ecu pins for evo 8??
- Need HELP PLZ! AC/Heater core removal
- Blitz actuator
- Gauge Questions on Install
- Changing the Intercooler
- P0234 turbocharger overboost
- Taking accent pieces off in the interior
- HELP!!thermostat issues
- Help with MBC please.
- Aftermarket Radio Install in Infinity System
- STRI Gauges
- I need a How to for a tranny rebuild.
- Installing prosport gauges... help
- evo 9 bumper clip where does this go? (pics)
- 06 MR boost gauge question...
- Evolution VIII and New Thule Roof kits
- How to delete a/c and p/s evo 8?
- Intake Manifold Removal and Install
- Water Pump Bolts
- How to change spark plug wires?
- does anyone else have this problem?
- defi control unit BF guages off
- DIY Zeitronix Clock Display Replacement
- how to remove immobilizer?
- Help: short shifter hitting.
- help with seibon cf doors
- Mishimoto Slimline Fan Install
- How to install Q45 throttle body with HKS Kansai Intake Manifold onto Evo 9
- Car will not start unless I give it gas........
- How to: Hardwired power inverter
- how do i install a push type tob on a 6-speed
- Idle issues with Defroster or A/c on.
- SAS Removal - EVO VIII & IX
- OEM Spark plug wires dont fit????
- Rear Wheel bearing replacement..
- HELP!Vibrant MAS adapter plate and perrin intake!
- DIY: Engine Start Button (Evo 9)
- spark plug tuning information
- Question about aem uego and 2nd o2 sensor
- Fitting problems with VIS voltex pieces?
- repairing exhaust manifold studs
- How To Change Rear Axle Boot?
- How to remove the panel under steering column?
- Instal EVC VI
- double pumper
- Cam install, tensioner belt tool thread pitch?
- How To: Port stock exhaust manifold and turbo
- exedy twin to triple conversion assembly
- rear diff rebuild guide
- Double checking??
- Evo pumping fuel out the rear evap system HEPL PLZ
- leak down test-how to?
- does anyone know how to do this...?
- HELP!.. need to take sunroof cover on GSR off!.. PICSinside
- Suspension help!
- Engine install
- help with exterior window trim removal
- Starter Problems! Please Help! -- EVO 9
- Front fender liner
- AMS intercooler
- 1 e-brake line loose
- Precision Injector install
- Hot to install ams half size radiator kit?
- evo 9 engine removal
- uk hvac
- Bee-R Rev Limiter/Launch Controller! RPM stopped working? "Videos"
- re installing an evo 8 turbo
- How to install Magnus smim?
- aem ems
- Defi egt fitting
- evo8 will perrin hiflo cat?
- Clock wire pins
- Just a quick Double Checking, but does the Rear Diff and Transfer case use same fluid
- HELP: HID conversion kit
- how to achieve top dead center
- EVO 8/9 Roof Panel Removal - For carbon or swapping in/out sunroof
- busted turbo oil seals?
- how to install evodave wide front fender mod
- How To: O2 Sensor Mil Eliminator
- clutch removal and install
- hallman cockpit cable
- Request - Rebuild Thread
- How To: Inner Tie Rods
- Request headgasket install how-to
- How to install a headgasket
- getting a jdm bumper
- O2 housing O2 dump JMF
- seibon cf trunk install
- Running E85 with JEGS Fuel Filter
- help!!!
- Turbine Housing Swap
- Invidia 02 Housing
- id2000 install
- I need some advice before i buy
- how do i recirculate my synapse bov with bushur intake?
- Spark Plug install gone bad, help!
- Taillight problem
- How to: Power Steering Removal
- How to remove headliner
- Wing removal ?
- Is there a write up on how to remove an evo 8 head
- How To: Independent Fog Lights
- how do i know which test pipe to buy?
- E-brake not keeping car in place.. How do I fix this?
- how to install hks type 0 turbo timer?
- Whats the best way to bleed the clutch?
- DIY Underpanel
- HID lights moving by itself
- License plate holder with Demonwerkz
- Bov piping
- FIC 2150s Install HELP!!!!
- Oem steering wheel "failure" ;)
- Help!!
- Oil filter housing removal
- How to keep the cuppler into the throttle body without poplin off
- Double-Pumper rewire howto
- how to wire acd pump to run full pressure??
- Remove passenger airbage
- How to: Keep the fkn BOV from poppin off?
- I'm about to use a stick of dynomite to get this head off....
- vibrant o2 sensor simulator
- Need immediate help, drained fluid out of my car and dont know how to get it in
- Help, low idle/stalling!!!!
- DIY grounding kit help
- Manually roll up electric window.
- Need help! AEM guages oil press/air fuel/boost..
- HELP!!! Starter questioN
- 3" exhaust from AWD DSM thermal
- aem seriel gauge
- varis rep lip question..
- How to monitor A/F using Greddy InforMeter Touch
- E85 and injectors?
- second clutch switch
- Bought used HKS Hi Power didn't included brackets.
- clarification on steering wheel/air bag swap
- Air Filter installation help needed
- ARC ti knob in MR
- How to: evo 9 turbo install - video
- installed aftermarket seat, seatbelt chime/warning light ?
- Installed ams licp and front mount, bumper will not go on with crash bar on
- Walbro ??
- (DIY) Intelligent Intercooler Water Spray
- Do stock rotors on Evo 8/9 fit EvoX?
- help !!! wire problem
- need some help any one?
- I just change my tc fluid now leaking
- need some help on placement of oil pressure and oil temp sending units
- transmission fluid
- Help needed, how to turn off ACC lights
- wideband bung placement 8'' from turbo
- How to install hood pins
- how to program remote?
- How to install my forge bov on a injen intake?
- inspection tomorrow need help!
- 3 port solinoid
- Where is the best place to put AIT sensor?
- Help installing sub and amp
- Best way to prep a valve cover for paint?
- Video/Article: How to swap between street and race pads
- Synchronic BOV with injen intake and IC Piping
- Evo 10/ H11 Yellow Bulb 100W
- oil pressure sender and gauge... need help
- is this how to install
- Window motor replacement?
- How To: Remote Start anyone?
- Highbeams not working
- CEL for boost/wga solenoid
- Cat-Back Installation
- hks turbo timer help
- How To: Wheel Stud Removal/Install
- HOW TO: How to remove BONJO bolt from Master Slave Cylinder
- How to: DIY aluminum ball joint and tie rod end heatshields
- Turbo Removal
- Turbo timer problems?
- how to adjust headlight leveling?
- Synapse install?
- How to replace cluster bulbs??
- MT-4 Harness HKS Turbo Timer Instal??
- How to- Evo Red Vinyl Tailight install new!!
- Oil Preasure Gauge Install & Break Down
- How to remove an EVO 8 turbo - Video
- apexi power intake install
- Lost one and only key to my 04 evo rs
- C-West Bumper Install
- How To: Modify USDM rear support to fit JDM bumper
- how to customized your own rear diffuser for EVO VIII
- test pipe and hks carbon ti exhaust help
- Will this work for a Wideband install?
- Transfer case removal questions...
- Front Embelem
- No reverse lights! No leds!
- throughout bearing help
- Using the Evomoto Evo8 cam install for an Evo 9?
- Hella Supertones Install
- valve spring question?
- engine tools for a rebuild
- can the oem hid's be swapped with oem headlights
- valve lashing spec
- turbo timer install
- a/c how it works?
- evo 8 splitter question
- HELP: need to replace evo8 starter
- Need help with rear wiper!
- apr front splitter
- twin fuel pumps ?
- How To: Another DIY Catch Can mod - Dual, with baffles and extended inlet tube
- Aem wideband Help
- How to replace cv boot?
- ScaGuageII Installation
- How to install the digital QTP controller?
- How to: 8 vs 9 turbo
