- Help!!! Can't narrow down a random engine misfire on my evo!
- ZT-2 Installation...Help!
- RED 80mm sound
- Help with Apexi Turbo Timer Install
- HVAC Repair - MEGA Guide
- 4g63 swap
- How to reinitialize a sunroof
- building the motor need help
- Help: Exhaust Manifold Studs.
- need timing help
- 91 Talon AWD TSI parts into EVO IX
- mr/6spd shortened shifter
- Need attachment screws for bride seat !
- Dash lights – help
- How to remove the !@#%$# intake manifold bracket
- Walbro 255 fuel pump install - video
- JIC Titanium Exhaust question
- How to Make Your Own FAA Spec Leakdown Tester
- Vortex Generator HELP
- Buschur intake question...please help
- Buschar intake question...please help
- Problem with SRS light
- Please help.. Calipers..
- car wont start
- AEM tru boost tips?
- ACD transfer case removal -VIDEO
- Finally OEM fog lights, with OEM switch that WORKS!
- help with taking apart pistons?
- Meth pump seals?
- Noise
- Need help How to: innovative LC-1 install
- Trunk Torsion Bars
- How to remove evo 9 climate control cluster?
- Evo 9: How to keep big battery with HKS IC piping kit
- accessory belt change
- How to: Make your own undertray (cheap & easy)
- unexplained noise?
- Serg Trip Computer Install
- tranny drain bolt stripped..
- J-Panel removal.. Anyone know how ?
- Guide to install a HVAC
- How do u raise the beam of your headlight?
- HOW TO NEEDED: Twin disc and hydraulic throw out bearing
- HKS Hi Power
- HELP! installed jdm evo 4 engine but check engine light stays on????>
- Boost Leak Testing - How and Why
- HKS oil cap
- Fixing a Valve Cover????
- How to for removing a fender??
- 03 Evo VIII Engine PS and AC Line Tuck
- Just curious
- Alternator help
- Forge rs service
- How to: tranny/xcase/rear diff fluid changes
- Camshaft help and ?s
- temp control dial
- DIY Radio Relocation Brackets
- Dealer wont do TSBs without finding problem?
- evo 8 head removal how to?
- Install A-pilla gauges or..
- How To: Electrical
- How To: Interior
- How To: Exterior
- How To: Brakes/Wheels/Suspension
- How To: Engine/Turbo/Drivetrain
- i need help with the hks circle earth ground wiring kit
- how to fix the ciggarette lighter in an evo VIII
- E-vi fuel pump install "the hard way"
- How to install EBAY poly lip(with pics)
- How to: Installation of Vortex Generator on EVO IX
- Drain Plugs...
- those plastic clip that hold the evo bumper to fender are weak! any fix?
- Evo 8 Serivce Manual
- Replace Autometer w Prosport boost gauge
- Profec B spec II issues....
- JDM 9 headlight install
- HOW TO: Turn Greddy Full Auto TT red to make lighting
- Help: Key Sensor Switch
- HOW TO: Timing Belt, Balancer Shaft Belt, and Accessory Belt Replacement
- Take apart the rear evo 8 wing? can it be done
- evo 4 and 5 pdf manual here.
- How To: Install Power Transformer for Laptop
- 3" vband clamp fab for o2 and down pipe
- how to take off rivets
- Help Installing Cams on IX MR
- IKEYA Sequen Shifter Installation Help.
- Upper clutch switch question
- Help!! Sparco 4 pt harness
- Article and Video: How to Bed-in Brake Pads and Rotors
- Evo Vii Rs Brake Swap
- Evo 8 cruise control installation
- HELP trans ?
- HOW TO: Install a fuel pressure gauge sensor
- BR Underhood metal bushing install
- Intercooler painted logos
- Synapse Bov install help.
- Replacing rear o2 on a 9
- HOW TO keep floor mats in place
- 9 Headlight with intake duct
- HOW TO integrate leveling motor on non equipped evo?
- Oil filter replacement w/o draining oil?
- Hardware needed for cat-back exhaust?
- Strobe Install
- Help needed AEM UEGO Wiring schematic
- Priming oil system?
- Vortex Gen install how do i
- Stripped thread...how to take out?
- How do i take out studs off turbo hotside?
- How-To: EGR Removal VIII/IX (and charcoal/EVAP canister)
- Black Smoke?
- ETS 3.5'' FMIC install?
- AEM Wideband troubleshoot
- Wastegate installment
- Emblem blackout How to and Where to get Materials
- airbag computer location?
- Magnus v5 Installation on an Evo 9
- How to clean headlights?
- AEM Wideband install ?...
- the right wastegate
- Synapse BOV Won't Fit. Help Needed!!
- Installed PLX wideband on my 9...
- wheel bearing
- 8 to 9 mivec conversion possible?
- how to make oil lines for the GREEN TURBO?
- Things That Will Cause A Trans To Shift Poorly
- How To: Intake Manifold
- help with intake manifold
- How to change the clutch and transfer box fluid?
- how my ACD was defeated! david VS goliath
- BR solid shifter bushing install
- how to instal waste gate with dsbc
- water temp gauge solution
- How to check to see if your aftermarket O2 sensor is bad
- License Plate Lights on JDM IX Rear
- changeing guage cluster color
- wires for the radio?
- How to Compression if you can't Crank?
- How to change spings
- ?tranny problem..i think
- Nisei IC Piping Install Help!!!! Cant connect BOV
- Link for Service Manual PDF (wire harness etc)
- Catback install
- Air/Fuel gauge hook up, help?
- Blue or anycolor gauges and HVAC on an EVO 3 (anycar really)
- Need help asap...headlight problem!!!!
- Greddy profec b-specii install using a external waste gate
- IX fogs help!!!
- Hid install help
- Air Bag removal - after deployment?
- Badge Modding
- Advice on mods
- areomotive fuel filter install
- Prosport changing color
- P E A on Throttlebody
- EVO Real bumper solution???????
- Firewall point for boost gauge install??
- Parcel shelf cover removal ?
- Removing evo VIII car seat
- AMS Remote Oil Pressure Sending Unit Line Install
- Help brakes sticking
- Complete DIY's on starting, charging, engines, trannys, etc.
- how to change: front wheel hub/bearing.
- How to Install greddy Turbo timer
- post a thread on hot to install auto wind on RS!
- How to paint grill ?
- help on how to install voltex rear fender evo 9
- Hks thermostat help?
- Anyone know how to install an ARC oil catch can?
- Need Help!! Keyless remote dont work
- Evo 8/9 Aftermarker Steering Wheel Install
- fmic?
- AEM Uego to Evoscan Wiring...
- How to install the synapse synchronic BOV on 06 MR IX??
- How to wire up an Apexi Turbo timer on 06 MR IX??
- Go Fast Bits BOV Install
- How to trouble shoot your AEM Uego output cable.
- How To: HVAC Double Din Mod
- Where is the Walbro 255 Fuel pump how to
- Exhaust Heat Shield Polish
- Resistor for stock BCS
- Turbo XS Exhaust Question
- Avid Billet Motor Mount Installation
- ECU boost control???
- Question about Slim Radiator Fan wiring
- MBC Removal
- breaking rear hub
- Help** remove evo 9 lip
- Oil Return Tube HTA35R
- egr valve
- beleive it or not , antenna base removal
- Removing Radiator Support
- im looking into buying a new catconverter
- We need an How to do for ACD pump
- Weird sound coming from under the hood....
- Fuel Rail Feed Line Removal / Installation
- looking for info on changing the AC CONDENSER
- car wont start when cools down
- Need a list for JDM healights hid's...
- DIY:How to Install Universal (bosch) o2 sensor
- need some help wit universal o2
- How To: Cam Sensor Heat Shield
- Where are the front JACK points on my EVO VIII
- P0234 Engine overboost code
- looking for 9 front bumper on a 8
- Question About APS CAI
- Homemade Knock Light
- Evo IX SE - Aftermarket Headunit in Upper Din
- How to: Remove Interior Fuse Box?
- my car wont start
- blow off valve
- Power Steering Pump
- Help! AC Condenser Fan motor.
- How To on Water Pump?
- 255 Walbro fuel pump
- retrofit fog lamps
- JDM MR Headlights: Plug and Play Harness
- VIII front bumper removal help
- Need help putting a front CVT boot on.....
- slim fan install?
- Walbro 255
- Request For Buschur Double Pumper Install Pics/How To
- Multi tool: tire press. equalizer / deflator / boost leak test assist, etc.
- Brake bleeding: bubbles after closing valve
- 03 Headlight housings in a 05?
- hey guys wondering how to change my diff and tcase oil
- Request HOW TO: shift control cable
- Is there a installl guide on relocating the battery!?
- HOW TO Fix This so i can drive places
- looking for a how to on turbo removal/install?
- LF a How To : Lowering Springs Install
- installing stock struts how to ? anyone
- Evo 8 front bumper bolts
- apexi avc-r
- Replacing TOB question
- evo 8 255 walbro
- Removing drivers side 3 point belt receiver
- Install a Whiteline KCA395 roll center correction kit on an Evo without a shop press
- How to: Better way to orange interior lights
- Greddy Profec E-01 Install
- HOW TO: Change your wiper blades (Bosch Icons)
- How to: Radiator fluid flush & coolant flush
- Glow shift af gauge
- Need an install for stock guages location
- help me
- Evo VIII Driveline Fluid Change How-To
- aem boost gauge install
- No spark with hks dli2?
- AEM Short Ram Intake question
- Request: Carbon Fiber Trunk
- DIY LICP & Buschur Race FMIC install
