- USDM IX Headlight Amber Bulb Issue
- Carbon Fiber Ralliart Lip
- Rainbow profi crossover issues... go active?
- Compustar Alarm problem, help needed!
- help, radio problem.
- Anyone familar with the Pioneer AVIC-N4 DVD player
- mitsu gauges?
- Alpine CDE-HD137BT won't powered on
- Will this work? '03 Evo 8 Heater Shaft Replacement
- issue with jdm double din trim piece
- MMCS locked in Evo 7 HELP!!!
- Kenwood Excelon KDC-X996
- Cheap Evo Security Setup Better Than An Alarm
- Evo 9 RS audio questions
- passenger side lights not working!! help please!
- Evolution V speaker sizes
- IX MR Headlight harness NEED TO KNOW
- flip out touch screen
- Starter issues... Need some suggestions.
- Ashtray wideband mount - Stealth mode!
- Fog switch
- MMCS removal questions
- Best Navi Headunit?
- which flip out screens work in an evo 8?
- Best GPS-Based Car Security
- Best 2 DIN Fitment?
- HVAC Relocation
- EVO 7 Sterling one alarm
- electrial question
- I want to upgrade my audio system, can I have some advice please?
- Immobilizer problem: sometimes are won't start WITH programed key
- Car Alarm Specialists Step in!
- Weak Radio Signal after Amp Install
- HVAC craziness!!!!!!
- Need This Paint Code/Colour?
- Alarm and turbo timer?
- 06 MR Ipod hookup
- Voltage drop as engine gets warm?
- Speedometer wiring
- Evo VIII Headlight Problem
- Does this exist?
- Car alarm
- Evo 8 Steering column in Evo 9?
- OEM 06 MR Guages not getting power
- Identify this plug
- need pinouts of cluster to swap
- Evo 9 RS Radio
- delete this
- Double DIN options?
- Headunit; no power after rewire
- Stack wideband and boost gauge both reading incorrectly? (redirect)
- How to wire two fuel pumps ?
- what color black to match dash??
- SSL speaker questions.
- OK... What am I doing wrong?
- Which type of plug for firewall cannon plug?
- i have a question
- anyone have polk speakers??
- audio noob... another headunit thread!
- HVAC Relocation Plate
- Green warning light?
- Stock radio amplifier
- Do you have flip up screen?
- Center roof light not working
- Rear crash beam, results are in..
- Hole plugs?
- Audio build - would appreciate some advice/recommendations.
- rear speaker wires? possible need pic
- LED problem??
- sound cuts out on acceleration
- Evo IX RS Stereo Install
- car start but die after 2 second...
- Installing Interior Tonight
- Power supply for common pwr?
- MR Console in GSR swap
- 11' EVO X MR Information screen HELP!
- Problems seeing the radio in the lower cubby
- rear speakers no work
- Serious Audio Issues
- ACD Lights and Scary Understeer
- Starting problem, that goes "click click". HELP!
- 2006 Ix SSL install?
- My Double Din is in!!!
- 10w6 x 2 with JL 1000/1v2 - Is it overkill?
- 2006 evo gauge cluster
- Replacing OEM HID Ballasts
- 2005 electrical headache
- 2005 evo electrical headaches
- Alternator fuse keeps blowing + melted fuse holder??
- Evo 8 shift boot retainer
- OEM harness plugs?
- static electricity
- FS perfect flawless wing
- *help* gauge cluster off
- Want to buy speakers; Crutchfield says no (please read)
- Looking for seats!!
- Best way to hide aftermarket radio
- Double Din Stereo recomendations??
- What seats do I have?
- What do you think of this speaker setup?
- Electrical Problem
- Parking lights don't work after alarm install
- Boost gauge quit working but it still works?
- Iphone/Ipod issues..Pioneer
- HELP! Electrical Issue, Start & MPH Gauge Issue.
- speaker pods
- Half the gauge cluster doesnt light up?
- Radio Signal Problems
- Which double din head unit fits best???
- Good replacement door speakers
- something happen on the floor pan
- Audio Upgrade
- Double din install advice
- trying to find black emblems
- odd question
- What bumper is best for my 9?
- Help identifying this box and ring I found during my alarm install
- JL W6v2 Sub Cuts out at High Base & Voltage Drop
- Typical starting problem help-_-
- Replacement front speakers??
- Intermittent Ignition Failure
- 06 EVO RS - stereo install
- Alternator Problems Please read and Comment!!!!!
- Cluster goes dim
- Help - Power Windows (except drivers) will not work!
- need SE lip. need help
- Car Cranks but doesn't Start
- Just picked up Infinity Bass Link I...
- best possible brand for generator fins(sonic the hedgehog)
- will a stock bumper fit over my 4" buschur fmic?
- baseball clutch getting old?(stock clutc)
- Sport Meter Kit on Evo 9 MR, What to do with it after Orbital Double Din conversion
- Rear Right Hand Power Window (Any Help Appreciated)
- 2003 Evo GSR - HVAC Issues
- anyway to tell if my car has factory keyless entry?
- VOLTAGE SPIKES and DROPS need help
- Amp advice
- steering wheel controls/blutooth problem
- Swapping in an JDM Evo Cluster into a USDM Evo 8.
- The Definitive Sound-Deadening Thread!!!
- Ac Conderser Fan.
- Switch Stereo Headunit and OEM Gauges
- Evo9 headlights in evo8 problem?
- Evo rs electrical issues?
- Defi boost gauge wont
- Neeed Some HELP!!
- got my jdm evo 9 bumper on from AIT racing! how does it look? (all comments welcome)
- PLZ HELP window wiring
- ACD question Built tranny
- NEED HELP! EVO 8 MR paint code
- SSL Infinty Amp Wiring
- OEM Guages
- Crank angle sensor question. Does the fuel pump prime when...
- Viper 5002 / turbo timer
- EVO 4-6 Climate control
- Window Motor Connector PLZ HELP
- AUX/iPOD hookup with the stock radio
- need info on evo 9 bumper
- Help.. Need part number
- remote won't work
- Calling all JDM VIII/XI Tail lights
- Viper Smart start w/ gps tracking?
- car alarms
- AEM Tru-Boost ER5 (S) but it's not the solenoid! please help.
- SSL Sound issue
- immobilizer
- VIII Wing re clear help.
- Street cage
- Need some advice!!!!
- Orbital install (climate control portion)
- Remote start - do I need a spare key?
- Alpine system
- does anyone have a KDC-X995 fitted
- Valentine 1 connected too the car audio?
- Relocate Fuel Gauge
- QU: Seat Rails for Kirkey Seats ?
- Where to get an EasyCar Alarm Remote?
- For those who have painted their EVO a different color, what parts do I need after?
- Speedometer Doesn't work (replaced vss/plug)
- Fender liner ideas for bigger wheels/tires
- Evo9 MR headlight issue, need assistance
- What do we know about GPS tracking?
- What can cause the evos computer to disconnect.
- HVAC Knob help
- Has anyone successfully done a set of DIY JDM headlights?
- Double din install help
- no power to ac button
- evo just died ?
- Radio Relocation
- where do i insert the spare key for remote start
- clifford g5 proximity sensor
- JDM HVAC control
- Searching for carbon dash panel
- Fuse (Wiper Sprayer) Help
- in dash dvd player??????
- Ignition problem
- Recommened me an aftermarket hu
- Alarm system
- AEM EMS Blowing Fuse
- what LED lights to use in number plate
- My attempt at a custom box
- JDM HID Headlights converting back to USDM HID Headlights
- I chemically de-chromed my mitsu logo(s), looking for new idea of how to mod them.
- seen this video curious what company makes these
- I need some assistance from know-hows
- Need help finding central locking (-)
- Anybody running a sound system with a mini battery?
- Radio relocation
- Evo 8 windows, master door lock, wipers, power mirrors do not work
- front end temp sensor /AC wiring
- replacing aftermarket head unit with stock one and they cut the OEM harness....
- wire connecting to the driver seat in evo 9 MR
- Flip around face receiver?
- Android + Evo
- All audio savy people
- Ebay/Depo LED tail light mini-review
- charge harness question
- Evo 8 CAM Position sensor Wiring
- help with stock radio!!!
- Placement of Sub
- Stock HID conversion?
- panel between right fender and splash cover behind oil cooler
- Electrical Issues
- Does any company make Carpets?
- need suggestions on a start up disabler
- Evo 8 door not unlocking or locking from outside.
- Anyone with Trustz gauges???
- CDT Audio CL-6EX or Polk Audio DB651?
- Help: AC wont turn off when air is on
- Part Number Help
- Jdm evo 8 power windows faulty help !
- Car Audio
- Should I get a dvd player
- HELP w/ Keyless Remote ???
- 2005 evo VIII with SSL (infinity system) iPOD connector?
- Radio problems
- Need help - Headunit on but no sound
- Parking lights not turning on???
- Volume problem
- help me find this ground connector/crimp
- anyone still using the stock speakers?
- help evo 9 mr shift knob part number
- Unresponsive touch screen
- Radio shot? need help
- Weight Reduction questions
- evo RS foglights
- Brake and Battery light on and off
- LED Blinker bulbs blink fast ?
- My tail light problem
- Oem trunk fitment issue
