- Replaced alarm siren, now alarm won't shut off!
- Help with power window
- Custom dash piece (for iPad)
- Speedo/Odometer stopped working!
- Dropping out of power PLEASE HELP!!!
- Evo turns off randomly
- viper 5904 install going bad
- EVO 8 reverse camera
- Radio random channel surfing
- hid ballast wiring
- Help with pivot meter v
- No power! Help!
- Stereo, clock, power door locks randomly going out
- Who can identify these wires?
- 3 wires going to the positive battery terminal??
- Trunks!
- Serious help.!!
- Defi Gauge Dilemma
- 05 RS headlights flickering
- Radio harness
- Which Flip out head units is good for bottom relocation kit?
- Temp Gauge stopped working
- Double projector Evo headlights?
- need help with evo 8 central locking
- Gauges
- Viper Alarm Problems
- What is this connection?
- Ignition switch problem???
- What is this?
- Best fit Radio for EVO 8
- Coil on Plug vs Standard Ignition VIII
- Evo 8 wont start! HELP!
- How can I get this installed in my evo 8?!
- Evo IX Rear View Camera?
- Help!!! Is there a sensor or wiring for day/night mode evo 8
- Alarm System Ideas?
- Something weird with the alarm
- ignition cylinder issue
- HELP! When my lights are on all the interior lighting goes off!
- Need help. Blitz turbo timer
- LED Map and Dome Lights
- Headlight flickers then goes out
- Harness grounds for sensors by ecu need detailed info
- Galaxy tablet install evo 7
- MMCS from a Evo to Outlander
- EVO 8 Randomly won't start
- Mini Battery
- Keyless Entry ETACS Problem
- Small Battery Low RPM Hesitation/Bucking
- Speedometer, Tach and Odo Not working
- Aftermarket Radio is popping rear right taillight 7.5 Fuse
- Car speakers & head unit recommendations!?
- Backup Light Electrical Connectors
- Evo 9 GSR HID Kit Blowing Bulbs
- Boost gauge that match the guage cluster
- fuel pump relay problem maybe... evo 1?
- Gauge Mounting Location Question
- dimmer switch wtf?
- Higher quality OEM replacements
- replacement speakers for Evo IX
- Tweeters that mount in the stock location?
- wrong battery in evo 8!!!
- Evo 8 no lowbeams
- Convert HID to normal Halogen
- Clock Spring Diagnosis Questions
- HELP, Window issue on evo 8 ssl
- Replacement stereo dash fascia evo 7 with mmcs configuration
- Passenger Side HID Bulb is OUT, HELP PLZ!
- HELP! No battery or engine harness with the windows Dow
- Evo 9 RADIO/HEATER CONTROL PANEL
- Turn signals dont work heeelllppp
- LED Brakelights stay lit with ignition on
- Single din fascia adapter for JDM evo 7 with MMCS
- battery being drained by something while off
- Want a Double Din Setup -- Which Head Unit?
- Alarm System in RS?
- Will basic lancer seat belts fit my evo8?
- Evo VIII sunroof cover replacement?
- engine doesnt crank, low/highbeams does not turn on ; battery tested
- Evo IX Mild Stereo Build
- SuperCapacitor Battery replacement
- Thank you Mitsu for keeping the factory head unit harness the same!
- Stock Stereo
- Trying to get my Evo IX audio back to normal
- Need Help, alternator short & dome light short?
- converting KMH to MPH Speedometer
- 2 JLW6v2 flexin my trunk
- evo 9 bumper mesh
- Instrument cluster and HVAC control bulb part numbers
- Hazard fuse popping
- Sub and amp install questions
- Base lancer rear bumper on Evo?
- Climate Control needs part
- Evo 9 Ralliart Gauge Cluster
- Amp Selection Question
- Srs light is on
- Roof weather stripping clips
- HKS hi power 409 midpipe Resonator Delete !!
- Evo 8 ssl sub replacement
- Working on a NEW solution to Climate Control Relocation
- Evo IX Front lip question
- best double din
- Pioneer AVH-X7500BT Installed
- Any quality brands that still make single-DIN flip out recievers?
- Factory sub hook up
- Oem Headunit - Evo 8 MR
- iPhone 5 Evo IX Custom Mount
- fuel pump no prime wiring related
- stock keyfob issue
- Noise over speakers when headlights are on
- Sub opinion
- power source needed
- nrg quick release
- Properly Set Gains on Front Speakers w/ Amp
- Stupid directional problem. Pics/Video inside
- HVAC controls issues (possible short)
- Evo8 Nose Chop, Evo 9 grill?
- SSL sub harness?
- Looking to invest in a quality system. Upgrading 05 GSR SSL
- Wiper malfunction but the wires are dry
- installing a viper 5904, bypass info?
- weird electrical problem
- Which fuse for add a fuse kit (radar install) radio fuse missing?
- Alternator
- 05 Evolution RS Wiring hell
- Is this a good amp + component speaker combination?
- Compustar remote start error 01
- sub recommendations please *dont merge, it wont get the attention it needs*
- Front speaker Install
- issues with oygen sensor
- Kenwood head unit question
- compustar remote start over cranking
- Best Double Din Nav Fitment Help
- Viper 5704 remote start/alarm questions
- ???Alarm help???
- Oem jack and foam pad
- Alarm PROBLEMS!! any help? "k-9 Mundial SS" system
- keyless entry not staying programmed
- SRS, ACD and ABS lights on
- Are There Other OEM Mitsubishi Steering Wheels That Fit An Evo 8???
- Component speaker crossover wiring
- Earthing kit drain the battery ?
- Evo VIII Audio Issues
- 5 1/4 components worth it?
- Does anyone have the JDP Engineering CF center console?
- Door Lock after 10 MPH - Add this feature yes?
- Ipad mini dash
- Total audio n00b
- IPOD hook up to stock radio
- Reverse lights don't work
- Teh Evo SQ Build.
- Evo 8/9 Headlights Question??
- 03 - Windows aren't working
- Key FOB Module??
- Orbital relocation kit question? Knob stuck. Cable maybe too short???
- Fog light Dash indicator not turning on.
- Differrence in coolant temp sensor, what do the do?demand5" looking up some wiring
- Short in the system.
- Trunk latch does not work
- front under fender plastics/ splash guard
- good sub add on?
- rexpeed type c.
- Will these Evo VIII JDM headlights plug into my IX MR?
- EVO 7 Tail light Replacement Bulb PART #???
- Domelight question
- Rear speaker wires
- sub question
- Evo 9 head light wires. Non ssl 4 wires question?
- Evo 8 oem HID promblem
- Non oem Rockford ?
- Best Place to Wire Defi's
- trunk?
- Prosport gauges
- Evo 8-9 Duraflex front fenders
- Radio question on a 2005 evo
- slim line fan wiring
- Viper alarm system
- Evo 8 vs 9 Rear O2 Sensor connector
- Oxygen Audio Ocar iPhone Radio or something similar?
- New audio project
- prefab sub boxes
- Looking for help with front o2 sensor
- Do I have a chipped key?
- Evo 4 Stock Radio Wiring
- power locks dont work!
- "Click" when starting **Finally fixed**!!!!!!!!!
- Help me decide!
- fuel pump hardwiring
- prosport gauge issue
- keys n locks
- Cannot decide between Alarms.
- Disabling auto unlock
- After market head unit wont save channels :(
- How much are the 9 suede and leather seats???
- Stock Infinity Premium Sub
- ISIS Multiplex vs Tegra VCM?
- Amp power cable from battery
- Radio not turning on
- fog light bulbs
- Ipod cable question - not working
- subwoofer amp install?
- Antenna Cable Routing
- will this hood fit on an 8?
- Bad Alternator bearings?
- Difference w ssl package and other evo packages
- 100amp main fuse is being blown everytime I connect my battery
- electrical gremlins: dome lights and keyless entry
- bulk head cover removal
- Stock radio with external subwoofers??
- does this evo7 wing cover holes?
- Preventing a stolen Evo..
- Help, Whine in front speakers
- Key fob retro fit?
- The best EVO8 carbonfiber front lip out there with the most OEM fit for the money?
- Keyless entry not working
- need to tap into "true ignition source", have diagram, wondering what is best?
- AVIC-Z140BH vs INA-W910 vs DNX9990HD vs KW-NT800HDT: whats better?
- My review of the Pioneer AVH-P8400
- Electrical charging issue (fine for 5 minutes then dead)
- Evo ix oem front lip/wing
- Mods please delete.
- Parasitic drain/acceptable voltage
- Defi's lack of backwards compatability
- How to test older car audio equipment?
- help head unit wiring
- Battery Kill Switch Setup
- HID motor & Hi beam issue
- Sub Box in Rear Seats?
- Audio help
- Keyless entry fob not working!
- Random gauge question
- '05 gsr halogen headlights to oem hid headlights with full function
- Racepack feedback?
- keyless entry battery part number
- Help with my audio setup
- carbon fiber roof cap
- parking lights stay on...
- will this work with my OEM SSL head unit?
- Will a 212mm deep double din "head unit" fit
- Tweeter Blowout
- Interior fuse/electrical issue
- Okada plasma Direct coils help
- Burnt Headlight Bulb Socket
- Best Alarm/Anti Theft System
- gauges/electrical only work when ignition key is on
- Pioneer DEH 80PRS
- gauges wont turn on
- Pioneer z140
- speedometer not working
- Which Evo's come with color matched B pillars?
