PDA
View Full Version : Evo Electrical / Audio / Security
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16
  1. Wiring up 3 gauges from the center pod
  2. Confused about wiring / Window
  3. ECU for EVO 6 or 7
  4. Faulty fuel filter caused mayhem on my ignition assembly?
  5. Evo 9 tranny ground
  6. Starting issue
  7. LEDs or HIDs
  8. Will Evo 8 starter fit in Evo 7?
  9. Evo 8 Electrical Problems
  10. Battery Relocation for evo 8 wire type questions
  11. Battery wire harness????
  12. Evo 9 oem A Pillar Tweeter questions
  13. EVO 8 no voltage on pin 12 & 25 connector
  14. park brake light + battery check light + RPM gauge stopped working
  15. Evo 8 Ignition Issue
  16. Evo IX 3rd brake light
  17. Evo 9 rear bumper corner lights
  18. Headlight timer
  19. Power folding mirrors on USDM Evo 8
  20. HID headlights in an RS
  21. Anyone have their sub(s) installed in the cabin?
  22. What’s the best car alarm for an evo 8?
  23. What is this?
  24. 03 evo 8 engine wiring?
  25. How to use the trunk release button?
  26. Anyone with electrical knowledge? particularly alternators
  27. Tesla style screen? Has it ever been done?
  28. Evo 6 Gsr Cluster Pin Out Diagram
  29. H/O alternator options
  30. Testing a DIY LiFePo4 mini battery
  31. small battery help
  32. Voltage drops drastically as car is gunned/high revs
  33. Haunted Evo? odometer, WB, oil pressure gauge..
  34. why is there 2 yellow constant wires on my wiring harness?
  35. Popping fuse and car won't start
  36. PC680 Terminals
  37. Dash Light Issues...Any help appreciated
  38. Optima mini for ETS tray
  39. Evo 8 Rear wiper blade install
  40. No electrical power after motor rebuild.
  41. Evo 8 Rear license plate lights?
  42. EVO 8 Stock speaker issue
  43. 2014-2017 FUSE Radio integration
  44. anyone installed running lights?
  45. speed sensor?
  46. Ideal Location for Hands-Free Mic
  47. Please help!
  48. I have been attacked by the Gremlins
  49. OEM Double Din Trim?
  50. Evo 9 Nav unit
  51. Electrical Issue, headlights
  52. Need help headlight bulb is out !!!
  53. Not sure what this relay is for..
  54. Looking to buy HID KIT
  55. Best Security system
  56. Want to install led on my side turn signal mirror
  57. What's a good remote start system?
  58. Evo 9 Dash Cluster Wiring
  59. Fog Lights will not turn on from switch.
  60. 12v wire source?
  61. Reverse lights not working
  62. Headlight Problem! HELP!??
  63. evo 9 cluster wiring diagram
  64. Radiator Fan controller bought the farm
  65. No high beams or fog lights
  66. Dash Cluster Light and tail light not working 😭😭
  67. Key Fob Issue
  68. Starting problem
  69. Weird No Start, Igniton Issue
  70. Help! Unknown sensor
  71. Rear o2 not reseting
  72. WTB Evo 8 headlights
  73. Strange no start issue
  74. Help me identify these wires?!
  75. Car remote fails to start car, how do I fix itÉ
  76. Short in dome light
  77. Sunroof won't budge
  78. Can someone take a photo of their Evo 8 SSL Sub wiring?
  79. HID Leveling motor and Fog Lights not working
  80. 3rd brake light housing
  81. My interior lights work, I swear
  82. OEM Keyless Entry Fob Issue
  83. Headlight Help
  84. Hks twin power
  85. Evo 7 8 9 radiator fan connector plug to the fan speed module
  86. Audio Integrations 'Perfect Fit' Sub Enclosure
  87. Evo Rolling Shell Windows Down (How can I get them up)
  88. Double Din Head Unit Recommendations
  89. The problematic evo returns!
  90. 2005 Evo 8 Key FOB Programming Not working
  91. No brake lights, reverse lights, or windshield wipers, gremlins problem
  92. Looking for Evo 8/9 Gauge cluster wiring diagram
  93. need help asap getting a piece that i have no idea what is it called...
  94. Wiring speakers back into stock harness
  95. Help with wiring gauges / radio
  96. IX Tail light part numbers
  97. Rate my wiring
  98. Evo Vlll GSR Headlight Auto Adjust Issue
  99. Rough idle on cold start and while headlight, fog lights and high beams are on
  100. Everything fine but dome lights
  101. Evo 9 55w HID
  102. OBD2 not working !
  103. Battery relocation ?
  104. Christmas tree dash
  105. Replacement OEM Antenna Cable
  106. Stumped, car won't run. Looking for info
  107. Having trouble programming the remote start bypass (pku mit)
  108. Evo8 double-din brackets
  109. Evo 7 not firing when warm-hot + slow turnover
  110. Voltage drops while driving
  111. Aem boost gauge bad sensor
  112. Spoolinup Used COP Question
  113. Replacement key to reporgram
  114. Anyone have a diagram?(junction)
  115. Interior Dash Loom
  116. rain gremlins (connector)
  117. where does this go?(connectors)
  118. Radio not working
  119. Evo 5 Wireloom vs Evo 8
  120. I need help.. AEM gauges
  121. Black & Purple wire under center console, function?
  122. Spare key for evo 7
  123. Quality of aftermarket ignition coils Evo 8
  124. Door Warning light
  125. Purple fog light?
  126. Anyone know what wire this is?
  127. Windshield sprayers reversed on Evo8 -- how to fix?
  128. car alarm system
  129. Fuse / Hands Free Link
  130. Group 51 (civic) Battery
  131. Light flicker
  132. my wipers and turn signal blinker problems
  133. Another prosport gauge problem..
  134. Car staying on after key switch set to off!(tune/eletrical?)
  135. What kind of ECU is it // MR578511
  136. Temporary low beam headlight drls?
  137. Battery Wiring
  138. Cig lighter assembly
  139. Digital display???
  140. Link to ebay double din kit
  141. Will this Double-Din Headunit fit into a Lancer 205 ES?
  142. Stock ECU Transistors
  143. Put keyless ETACS into RS?
  144. Help with ignition switch/key
  145. Metra dash kit
  146. Replacing Air Intake Temperature sensor
  147. Advice needed: Best anti-theft solution?
  148. Unknown wire hanging?
  149. Evo 7 security and anti theft help?
  150. Help!!!! Wiring issue
  151. Head unit doesn't find channels to play music
  152. Is this a COP or wiring loom issue?
  153. Horn Fuse Keeps Popping
  154. Ralliart Gauge Cluster Bulb
  155. Trouble wiring gauges
  156. My speakers were stolen!!
  157. Circuit Breaker - Battery Relocate
  158. Battery maintainer brand/model recommendations?
  159. No factory radio harness 03 EVO???
  160. she wont start
  161. evo9 ac condenser fan and radiator fan help
  162. Evo 8 electrical problem
  163. Shop recommendations for sound deadening
  164. Clicking / ticking noise when above 2900 rpm
  165. engine/ electrical problems ( evo techs in Houston or surrounding areas )
  166. Evo 6.5
  167. Requesting help from someone with a multimeter
  168. 05 EVO 8 SSL - Amplifier Harness Dead
  169. All Evos compatible with wireless keyfobs?
  170. Aim mxg
  171. USDM GSR Dash Harness - USDM MR/MR SE Dash Harness Q's
  172. Help with Replacement AC Condenser fan.
  173. OBDII splitter
  174. AEM wideband Failsafe gauge (sensor offline issue)
  175. EVO 8 and 9 fuseboxes the same?
  176. Wipers not working, and buzzing noise from the Fuse Box
  177. Unknown 2g or EVO 6 ECU / MD346010
  178. Real problem ! ! !
  179. Ignition Issue, Delayed Start
  180. Delphi vs Denso coils
  181. wire tuck connector identification
  182. Lights stopped flashing when locking doors!!??
  183. Alternator
  184. Wire tuck help
  185. Cost to have shop install MR oem gauges
  186. Help W/ Aftermarket Radio.
  187. Idling issues
  188. Oil Temp Gauge Stopped working after new spark plugs?
  189. Evo 8 alarm problem!!!!!
  190. evo 8mr wont start after removed key chip
  191. Knock sensor ohms reading
  192. Evo 9 mr gauges (volt, temp, boost) bulb
  193. oem ecu analogue out current rating?
  194. JDM headlights
  195. Factory radio differences?
  196. more headlight issues
  197. Acd relocation
  198. Evo 8 mr and evo 9 mr wiring harness
  199. headlight adjustment
  200. Evo 4 Alarm Install - Door Locks
  201. Evo IX Instrument Cluster gauges aren't reading.
  202. Relocate Earth cable
  203. Battery won't hold charge. (Optima yellow top)
  204. anyone modified their alternator to charge at 16v?
  205. Hazards stop working on me!!
  206. help with turn signal and hazard!
  207. d2s bulb replacement
  208. No Brake Lights. Need Help!
  209. Overcharging
  210. A/C compressor keep blowing up fuse
  211. gas gauge failure
  212. evo 6 flasher relay
  213. Hot IAC problem
  214. Keyless Entry Stopped Working?
  215. Ecu no power ....help
  216. Dash lights
  217. gas gauge and lighter plug dont work Helpppp selling car tomorrow
  218. No power and negative gets hot
  219. HELP! No Alt Charge No Dash Lights
  220. Boost guage wired backwards
  221. Re-using oem connectors
  222. Converting 04 RS to factory HID w/fogs
  223. Automatic door lock
  224. Multimeter
  225. Alternator will not charge
  226. Wipers and Squirters Quit, Rear Wiper Fine?
  227. Evo 5 - Headlight/Wiring Issues
  228. Headlight adjustment
  229. Evo 7 Driver side window regulator
  230. 2003 VIII - Spark plugs not sparking/firing
  231. Help Greddy Turbo Timer :(
  232. Driver side rear window wont go down
  233. Evo 4 Aftermarket Key Fob
  234. need help with ground
  235. Evo 8 Headlights needed or help to find part
  236. Calling all Electrical Guru's
  237. Evo won't start unless battery is COMPLETELY charged (12.6 volts)
  238. Instrument gauges pulse during acceleration
  239. boost gauge. Mechanical or digital?
  240. Dash and taillights not working
  241. Double Din Head Units 2015
  242. EVO8 Marelli dashboard
  243. EVO 4 central locking question
  244. EVO IX Open Door Dome Light Issue
  245. Evo IX Remote Start
  246. USDM headlight replacement.
  247. EVO IV Central Power Locking/Key Fob not working help!
  248. evo 8 no connection to dlc
  249. Evo 9 RS.. USDM to JDM headlights
  250. Wanting to Lojack
