PDA
View Full Version : Water / Methanol Injection / Nitrous Oxide
Pages : 1 [2] 3 4 5 6
  1. Labonte Meth Inj Solenoid Testing Video
  2. Using Meth with C16
  3. What Meth Kit Do You Have?
  4. Alky kit help??
  5. Aquamist - Choosing a restrictor size
  6. what to get?
  7. Isopropyl alcohol?
  8. Tapping into MAF
  9. wi part two
  10. E85 and water injection?
  11. Jet location for evo X?
  12. To Vent or Not To Vent?
  13. help with aquamist HFS-1
  14. Meth % meter/gauge
  15. water meth ideas
  16. snow performance kit help
  17. Project X - Water/Meth Install!
  18. Tapping injector Question
  19. Toulene and you!
  20. Find me a meth kit!
  21. USP tanks
  22. Labonte Meth Kit Help
  23. Change meth/water mix sould retune?
  24. MAC valve is now available form Howerton Engineering
  25. Problem with Aem Meth Kit Pumps
  26. Meth and E85
  27. Zeitronix ZAVT, HFS-6; Use both as failsafes?
  28. what mods needed to build the beast
  29. aquamist malfunction
  30. methanol does not spray when its hot outside?
  31. A new generation of water/methanol tank design ... by Howerton Engineering
  32. sneaky snow performance!
  33. Intake temperatures and pre turbo injection
  34. Need help!!!
  35. Basic mods + nitrous?
  36. Does anyone here make their own E85 by chance?
  37. Going to buy a hfs-1..Have questions??
  38. Hose Missing
  39. Sell me your Aquamist HFS-6!
  40. Overlay: old setup on alky vs new setup on pump gas
  41. 400hp switch from M05 to M10 Meth Jet with dyno
  42. Dyno Results! BBK on pump vs alky: Aquamist HFS-1 FTW!
  43. Aquamist DDS3 Parts - For Building Your Own Meth Kit
  44. HFS-6 Wiring Question
  45. Perrin boost tube and meth?
  46. New to Meth, Best Kit to Start With?
  47. Plug & Play Mac Valve
  48. Meth kit maintenance
  49. What nozzle to run for water injection just for cooling to drop my AIT purpose only.
  50. Water Kit on completely stock
  51. Methanol suppliers
  52. AIT ~140 Degrees....What's yours? Im thinking about putting Water Injection
  53. in depth engine specs?
  54. No More Meth for Me :-(
  55. where to get 100% Meth Near Sarasota, Florida
  56. Snow Performance stage 1 o stage 2
  57. windshield washer fluid as meth???
  58. VP vs Sunoco
  59. Meth nozzle and IAT sensor placement help
  60. devils own
  61. Is meth good for course racing?
  62. Aquamist HFS6 Must Read
  63. HFS-6 on stock IX turbo..overkill?
  64. Question for stock turbo'd AEM meth users
  65. Question for stock turbo'd AEM meth users
  66. instead of denaturated alcohol
  67. Need advice on tuning meth
  68. 0-5v flow output from hfs-6
  69. Aquamist HFS-6 installed and running. :)
  70. What EXACTLY is water/meth injection
  71. Where to tap Fuel Injector for IDC for WAI
  72. Running 100% Water ? What to Tune for ?
  73. meth without tune.. question..
  74. hfs-6 won't stop spraying!
  75. 2-Step with Meth
  76. Just bought Labonte Motorsports ISG-S3
  77. going blind from methanol inhalation- is this a risk with vented container lids?
  78. Target a/f when running a $hit ton of meth?
  79. Best Meth Injection???
  80. Meth users i need some fast help...
  81. HELP!! Meth Tank Cap
  82. show me your meth kit setup!!
  83. Power FC & Aquamist
  84. water meth or nitrous???
  85. Labonte Meth kit issues...*****
  86. Labonte Meth kit issues...***
  87. Methanol in San Francisco Bay Area
  88. half gallon leaked strain into UICP pipe over night! Help!
  89. Where to buy Meth in MA/RI?
  90. Aquamist System Install Eye Candy (pics)
  91. Anti lag effects from too much meth?
  92. Looking for a non splash tank
  93. Labonte kit users help please
  94. Alky Jet (sprayer) before Recirc Valve
  95. How bad is water/meth for my evo...
  96. Smc/ Snow performance??
  97. having problem with my labonte setup
  98. Aquamist flow low after 3 months of no use.
  99. Coolingmist EVO Boost + MAF SIMPLE 2D MAP KIT
  100. Aquamist with bigger injector
  101. Direct Port 100% H20, Proof of being the ultimate Injection!
  102. aquamist tanks install question
  103. Aquamist HFS-6's advanced algorthm explained...
  104. What do you put in your Alky or meth tank?
  105. Meth and Water ??
  106. Using failsafe for normal driving
  107. Boost & Timing on a 9 with 91 & 100% Meth
  108. Where To Buy Cap For My Methanol Tank?
  109. Aquamist HFS-5 will be replaced by HFS-6 in2009
  110. Water Meth storage
  111. Meth stopped working? AEM Kit PLEASE HELP!!!
  112. Labonte Water-Meth Injection $20/$20 Rebate
  113. AEM Meth Users....
  114. Tank balls Up
  115. Big meth tank the pump mounts to
  116. pressure guage
  117. Tube length from HSV
  118. aem meth kit
  119. Aquamist - Flow Sensor?
  120. methanol consumption
  121. Meth question
  122. What fuel mods are needed to run meth?
  123. Photo Pre Install
  124. What is the best Pre-Mixed WasherFluid to use for meth injection?
  125. I/C low light for meth level?
  126. Aquamist HFS-5 poblem...
  127. Advice on AEM Meth, Tru Boost, and map switching...
  128. WI seen through "Sight Glass" On Plenum
  129. New source for "Flambeau" tanks
  130. HSF 5 Pump
  131. Meth failsafe ????????????
  132. E85 with 100% meth or 50/50 meth/water?
  133. HSF-5 Being Fitted to my KitCar
  134. Meth Inline filter
  135. Aquamist DDS3v10, tephra and EBC!
  136. What was your odo reading when you did your meth install?
  137. New to WAI
  138. My G35 TT Port Injection Pics
  139. HELLP!! Need a solenoid for my AEM meth kit - recommendations?
  140. Snow Meth Injection Install pics.
  141. Greddy Emanage Ultimate with Aquamist 1S, 2D, 2C
  142. Aquamist DDS3 V.10 Install Pics
  143. nitrous controllers? (dynotune or AEM EMS)
  144. Problem with trunkmount Cooling mist.
  145. Problem with cooling mist.
  146. Coolingmist nozzle parts
  147. estimated gains with meth on std 8?
  148. Flojet to Shurflo Pump- 200psi too much?
  149. DDS3 & AEM pls help
  150. AEM Water/Meth users - *Free Check Valve*
  151. max boost possible running meth plz help
  152. DDS3v10 & Tephra/Jack_of_Trades cable
  153. pics showing meth corrosive
  154. Big thanks to Dudical26 from Aquamist...
  155. Water injection as intercooler replacement?
  156. Meth Solenoid that is PWM safe.
  157. wi wiring tephra wiring harness/loom
  158. winter use
  159. Gasoline Stage 3 and Gasoline MPG MAX™ Boost Coolers!!
  160. Gasoline Stage 3 and Gasoline MPG MAX™ Boost Coolers!!
  161. info about all flow meters
  162. Another EPL Stage 3 S4 with Aquamist HFS-1 installed
  163. IAT Sensor Placement with Meth Injection
  164. Injector size
  165. VP M1 vs M2 Methanol
  166. Labonte-New IFS-30C adds additional level of safety for meth injection
  167. Water Injection Calculator !
  168. Another HFS-5 install....(picts)
  169. More Problems with my HFS-5
  170. Recommend a system for me
  171. aquamist ?
  172. Recirculate BOV with WI
  173. hks evc6 and aquamist hfs5...fail safe-boost cut
  174. Labonte - New Meth Injection Pump, Raising the Bar
  175. HELP! Aquamist HSF-5 4mm tubing leaks!
  176. Injection Mixtures 101
  177. mivec meth
  178. Direct Port Meth Injection
  179. Question about nozzle location in reference to tank
  180. i'm a little confused...
  181. *New to Water/Meth* Advice & Guidence Needed!
  182. Two HSV's with one Aquamist controller
  183. 50/50 or 100% Meth???
  184. air fuel ratio with 50/50 water/methanol
  185. aquamist S1 upgarde
  186. Mounting tank in engine bay running 100% meth??
  187. Map Switching - NLTS
  188. VP M1 or SP Boost Juice?
  189. Aquamist??
  190. my custom failsafe
  191. labonte flow
  192. Quick question
  193. tubing for meth?
  194. Fuel/Meth line where can i get
  195. Supporting mods before I go meth?
  196. AEM Meth + IFS-10 + Map Switching?
  197. Methanol Injection
  198. Making a MAC solenoid Plug & Play
  199. Dual Nozzle Question
  200. Where is there a good place to drill driverside
  201. Failsafe Issue - HFS-1
  202. Smallest nozzle available?
  203. Life span of alky pump?
  204. removing alcohol injection?
  205. Is this rite for me?
  206. Anyone try this?
  207. Direct port meth injection
  208. Vp M1
  209. labonte w/maf help
  210. labonte failsafe help
  211. mac valve/aem boost control valve
  212. need some 100% blue meth in philly area
  213. aem meth kit
  214. My Aquamist 2D to HFS-5 Conversion
  215. What meth kit?
  216. snow perf. 120 octane claims
  217. SMC kit install question
  218. Anybody got HOO knowhow?
  219. Boost leak test with meth kit?
  220. Upgrades to Kits and Components in ALL Snow Performance Systems!
  221. I have a alcohol kit from hyperdrive(extreme motorsports), i need to get the software
  222. Whats a low priced kit thats actually good
  223. Buschur Meth kit
  224. AEM Meth Kit is "Clicking"??
  225. Which Wire?
  226. Safe enough or not meth/h20
  227. i'm new to this
  228. Meth 0-5v flow output signal + LEDs
  229. bbk-10 install need help
  230. bbk-10 install need help
  231. I need help with my HFS-5
  232. best aquamist hfs-1 fail safe
  233. Snow Kit install
  234. Need some info on NOS
  235. does anyone run nitrous?
  236. Aquamist - Setup Questions
  237. Pressure switch..
  238. Aquamist Dyno results and Tephra mapswitching failsafe DYNO TESTED
  239. Meth still spraying on lift??
  240. AIT mounting location and Wiring Q's
  241. What makes ur kit better?
  242. Direct port injection setup with HFS-5
  243. high idle?
  244. Aquamist System with Stock Washer Tank
  245. aquamist labor cost
  246. what devices can be used to switch between maps?
  247. ACD Fluid !!
  248. Water Meth? Summit Racing says you can use windshield washer fluid?
  249. Dyno numbers for gsc s1`s AMS tune (post your gsc s1 dyno # here
  250. Meth Recommendation
