- Relying heavily on methanol?
- Water injection tech papers
- Evo 9 meth help
- Race Gas + Nitrous vs. E98 vs. Meth
- flow sensor
- limp mode when meth/water injection - Audi s3 8L
- Upstream injection using standard fuel:
- BMW M4 gets factory water injection!
- Aquamist technical questions for a Motec driven meth Evo IX
- Problem with air pockets
- Meth and TPS
- Questions for Aquamist Long Term Users
- aem methanol failsafe wiring to stock ecu
- Factory EBC as a boost cut failsafe?
- Nitrous 101
- Snow Meth Kit for Evo 9s
- Nitrous intake manifold
- Water/Meth + Nitrous
- evo 1 stalling when coming to a stop
- Switching stock ECU maps with AEM failsafe gauge.
- AEM W/M Hose Kept Popping Out
- Question on using dual nozzles with DevilsOwn kit.
- Ideal AFR on Water/Meth
- Meth tank in engine bay?
- Need advice with DI system please
- water\meth KIT installation help
- Tephra switching maps with HFS-3 , Ecu pin 64 ??
- my new evo9 on meth
- Direct Port Water/Meth Conversion?
- Nozzle place pre-BOV?
- Aem wmi v2
- Labonte wiring manual needed please
- HFS-3 Power wire problem
- Meth/Water
- Tephra+HFS-3 Failsafe help
- HFS5+Tephra Map Switching+MAC valve+MBC
- Alcohol vs meth pros/cons
- Aem wideband failsafe
- News of new products from Aquamist
- hfs-4 fpblack 2.3
- Short stubby meth jets
- Aquamist Gauge
- rapid cylinder wear w/pics again
- Aquamist new DP jets for 2012
- smc pump or controller problems
- Aquamist kit options + SD
- Who's using Tephra map switching with a water/meth kit?
- perrin pw2 vs hfs-3
- Running straight Water
- Wi, afr & egt...
- water injection as a base fuel
- Meth in ny
- nozzle install
- meth spraying when not supposed to.
- Aquamist Tank ????
- Aquamist hfs-5
- Aquamist HFS-4 ...
- How dangerous is meth really to my car?
- 50 hp of NOS question...
- Who´s using AEM meth kit? I have a quiestion!
- reliable easy to tune ethanol injection is best way to go
- should i go from DO7 to DO10 nozzle?
- What if...
- Tank,failsafe
- water/meth on DD
- SMC support?
- SMC progressive kit support?
- AEM Meth Failsafe
- new to W/MI, windsheild washer fluid?
- direct port injection... who installs it?
- E85??
- Dead progressive controller and $300
- Aquamist HFS-3 on 100% Methonal
- Injector location
- race fuel and methanol injection
- water/meth injection
- HFS3 and up users..question on wiring/input
- Something wrong with my aquamist setup?
- hfs6 issues
- How setup my AEm Meth kit??
- FS: 2.5 gallon SMC kit
- meth cutting out
- Is my Aquamist HFS-6 meth kit complete?
- Nitrous on the evos
- Is it ok for me to run the water-meth line inside the car??
- parts needed for aquamist setup
- Meth injection and Drag Racing
- Snow Performance stage 2
- Evo 9 Aquamist HFS-6 Alt Map
- SMC Replacement Line
- Bought an Evo X with meth kit, what am I looking at here?
- Aquamist HFS-6 BNIB - Flow Sensor Leaking from the Inside
- Priming aquamist system
- Aquamist hfs-5 v10 help
- Aquamist dss3 v10 help
- ICS spray on knock with meth
- What are the disadvantages of Overjetting
- Water/Meth jetting size calculation
- Please help quick - I'm at the drag strip
- Lil help - HSFV5 v.9 Troubleshooting
- Quick questions and please double check my math.....
- Looking for user & install manual SMC kit
- Automatic Computer Advancement
- AEM EMS and Aquamist
- The Benefits of Water/Methanol Injection for Gas Engines
- Post up how much meth you spray
- Aquamist jet Question
- where is the stock meth injection?
- Where can i buy the V1 or VP meth injection?
- Good installers/tuners...?
- tuning smc controller
- AFR issue with AEM kit
- Aem Meth Kit Question
- Nitrous?
- wtb a aquamist DDS3 CONTROL BOX
- map switching wiring diagram for JDM EVO7
- Water-Meth: How long can you stock the mix?
- Meth/Water Injection to Increase Octane Rating
- alcohol injection system stage 1 comp meth tank
- wifes xmas gift to me... meth
- Merry Christmas and Happy holidays
- Do I need a 3 port BCS to have proper failsafes??
- HFS-5 V10 install on evo 8
- About spark plugs bad or what?
- How do u choose the right nozzle size?
- Aquamist HFS3-v2 / tephra's new "X" patch development is now available...
- 50/50 Meth tuning timing figures
- Meth switch-on Point
- Running meth on Alcohol Tune?
- newbie
- AEM kit. Question about nozzle selection and mounting.
- PLug Range for WI
- Newbie question methanol without tune...
- Aquamist S1 pump replacement
- quamist hfs1 install problems
- looking for a good tank for my HFS-3 kit
- HELP Aquamist HSF-5 leak question
- HFS-3 love
- Aquamist Hsf-6 install
- Spray meth with nitromethane
- 91oct + 100% meth = what octane rating
- Braided line kit for alcohol/meth kits
- Discolored Plastic Alcohol Lines
- injector nozzles install
- Aquamist HFS-3 on a B5 S4
- Low Flow
- Evo VIII with alkycontrol
- Universal water/meth controller ?
- Propane injection has anyone done it?
- New Water/Methanol Injection Failsafe from AEM
- Meth it not working
- has anyone modded there intake mani for meth injection?
- Pros and Cons of E85 & WMI
- HFS5 failsafe not reverting to actuator boost
- Direct Port W/I Kit??? Aquamist
- Methanol Engine Bay Pump Install
- Meth injection advise.
- EvoX meth tank locations - any good pics?
- howcome everyone here doesnt like meth injection
- Tapping plenum for meth?
- More questions
- Post here if you've had an engine failure or damage due to running an Aquamist kit
- New with meth - few questions
- Meth questions and help please
- HfS-5 Boost-cut Failsafe set-up and wiring
- New Pump and Check Valve for AEM Water/Methanol Injection Kits
- std 560cc injectors with meth
- Additional SMC nozzles ???
- Need help finding this Aquamist Part (pic inside)
- siphoning issue
- What mixture for road racing?
- Tune on 50/50 Water Meth
- Aquamist Failsafe - Map Switching
- HFS-5 double pulse PROBLEM once again!.. VIDEO inside
- HFS-5 help
- Hfs-6
- Long Term Meth Storage
- Two map question
- Howerton Engineering Baffled Tanks - Thumbs Up!
- Current Methanol Prices?
- Universal failsafes?
- Too Much Nozzle?
- SMC Wiring
- Denso spark plug gap with meth
- HELP: AEM failsafe
- SEARCHED... AEM Meth Nozzle Location
- Nozzle size Question
- 100% meth question? Please help :-/
- Tuned for 50/50, knocking on track. Safer mixture?
- Thank you everyone!
- aquamist speciality range
- meth pump surge?
- meth AFR's - whats good?
- twin jets and leaking meth?
- HFS tuning, IDC Gain vs IDC Trim
- white stuff on jet?
- Bubbles in toobs
- HFS-5 messing up with 1000cc inj!?
- Data collection request-please help aquamist...
- Better Big Horsepower DD - Smaller turbo w/meth or Bigger Turbo (w/ or without)
- Aquamist MAC valve the same as AEM??
- aquamist jet question?
- Cosworth M3's FTL... H20 Direct Port FTW!!
- Micropump = Gods gift to meth injection
- Enuff injector?
- can I run 2 failsafes/map switching with AEM meth kit?
- Just bought hfs1 have questions!
- AEM meth kit
- AEM Water/Methanol Injection
- Zeitronix + failsafe + ZAVT-1, looking 4 more info
- HFS-5 acting weird.. any help?
- Couple of questions whether aquamist kit kit failsafe can fail eventhough it has a fa
- Nos wet fogger without fuel - can you run as dry?
- 50/50 with the AEM methanol injection kit or not?
- which water/meth kit should i go for?
- aquamist spray
- where can i find a aquamist manual at?
- few questions on the aquamist hfs-6
- Priming a meth pump
- Water Injection Setups
- Aquamist HSF6 & Perrin Performance PWI-2 Progressive Water/Methanol Injection System
- Aquamist's new HFS-3 for 2010, replacing the HFS-1
- Aquamist DDS3 to Smc Kit Wiring Diagram?
- How long does it take for methanol to go bad siiting in a plactic tank in car?
- hfs6 flow not linear? screenshot inside
- what happened with SMC?
- Where can I buy a nozzle for a 4an line?
- Injection with TPS?
- AEM EMS + AEM Meth + HI/LO Boost from single toggle switch
- Aquamist compression fittings
- Yet Another Direct Port Thread
- Boost leak problem at SMC alcohol nozzle
- What is the real difference between Aquamist and ...
- Meth or Alcohol?
- Water/Meth Injection
- e85 injection instead of alky and a 50/50 mix
- fluid sensor
- meth inj with stock ecu
- 100% meth users enter here (or meth gurus)....need some information
- need quick fix...two things see pics.. meth injection
- Aem meth kit
- Coolingmist good for $199?
- Is timing with 100% meth knock limited?
- question about HFS-1 and meth/fuel ratio
- Budget Water/Meth Injection
- Richard L @ Aquamist, step inside
- VP M1 Color
