- Aquamist HFS-5 system: Official Q&A...
- Meth tank time limit.
- Perrin Water Injection Kit ....
- What kind of TUBING for Snow Performance Injection
- rapid cylinder wear w/pics
- coolingmist varicool test
- I want to get a snow performance kit! Please help.
- New to meth/alky
- What blow off valve and what spark plugs should i use with a meth kit running 28+psi.
- Evo 9 RS Aquamist 2d (pics)
- Can I use a m15 nozzle to spray across the pipe?
- What spark plugs should on my evo 9 with a snow meth kit running at high boost.
- Considering an alky kit...........
- Think your system is really progressive.......read this
- flow testing your injection system
- PWM valve Vs. PWM pump injection system
- Water Incetion vs Race Fuel
- WI set up
- Ace is the place! Alky by the drum...
- Flow sensor or pump not working?
- Hobbs switches
- Aquamist VS Snow Performance
- cost effective setup for california bay area?
- AMS jet size?
- oil analysis
- Tank/Pump Placement Question
- water injected intercoolerless evo
- coolingmist varicool ( does it work )
- SMC Website/ Contact info
- Snow performance kit
- Does anyone make a mw10 nozzle for smc
- Advise on this kit
- Snow Performance Safe Injection Intergrated into SMC kit!
- Snow's Safe Injection Integrated into SMC Alky kit!
- Aquamist HFS-5 system design concept explained...
- prob;em with snow performance stage 2 maf alky kit
- Price for Methanol?
- Nitromethane Q&A..
- water flow Vs. methanol flow thru nozzle
- Evo IX's stock turbo with Meth/Akly Injection
- Alky < Meth? ...getting knock with alky...
- Is anyone running the Perrin Meth kit?
- L-Jet connector sources?
- Aquamist new hi-flow system for 2007
- 5th Injector, Methanol, and AEM EMS
- Perrin WI ??
- Water injection for autocross
- Anone using Snow's Safe Injection with an SMC kit?
- SMC Methanol Users
- Buschur Racing Alcohol Injection Kit
- Long term effects of meth/alky on engine
- Perrin Puts in their h2o cents
- okay to use teflon tape around fittings? how to seal up around nozzle
- Mounting SMC nozzle.....
- Aquamist needs your advice...
- can boost damage alky pump?
- Coolingmist Low-Level Sensor
- Is it really safe having meth mounted inside
- Another alky injection project
- Jet sizing needed for 50 trim
- Aquamist 2d install Question
- WI system with failsafe for $375 or so...
- Introducing the new DDS3 v8...
- alky system, checkvalve, progressive.....good reading material
- question about meth?
- Methonol Injection Should I keep it?
- Alcohol injection without tune....
- Necessary to upgrade OEM IX Spark Plugs with Alky Injection and higher boost?
- Easiest Alch kit?
- Snow Performance questions.... couple easy ones! help me..
- Aquamist forum is alive and online again...
- Is an aftermarket WGA truly necessary when running high boost with Alky Injection?
- Water Injection Research Paper
- Reaction of methyl alcohol with aluminum
- Runing 100% Distilled Water
- Has everyone seen the new coolingmist kit yet?
- BOOST activated system
- would i be able to hit enough boost?
- where to tap for meth jet???????
- Yellow Heet
- Target AFR's for Meth
- Effective Octane
- Home Depot Meth?
- Help!.
- How much to inject?
- Which ALKY kit should i go with??? Need answers quick
- Is a wideband o2 needed to run meth?
- Dual m10's
- In Car Gauge
- Alky Database
- VP fuels meth..M1 or M3??
- Research Paper on Water vs Alky
- Advice or feedback please.
- Install time of Aquamist 1s kit?
- controller problem
- Failsafe for buschur /smc meth injection??
- what bov are u guys running w alky?
- $13 FailSafe Idea
- Water/alky injection with 91 octane and low boost, worth it?
- Keeping methanol suspended in water/meth mixes
- Who here is using coolingmist pda controller?
- The "Big Boys" are on to us.
- Anyone runing FJO WI system?
- some noob questions about alky injection
- 100% meth or water vs 50/50 mix
- Meth injection reccomendation.
- SMC Front Kit
- IC spray tank, alky pump location?
- Battery In Trunk Plus Meth Tank?
- Evo ix & alky?
- Alchy injection questions
- FJO's new water/meth kit
- what's wrong here?
- Do you need injectors to run alky?
- Water Injection Safe EGTs
- alcohol vs meth
- Does METHANOL kill wideband sensors?
- Aquamist new product promotional video...
- Source for Nozzles??
- Purchasing Methanol In Sacramento Area
- SMC kit question about pressure
- Adding Alky
- *** Engine Runup Kit Question ***
- alky q's
- SMC Controller Wiring Help Please
- 20G SMC Alky guys
- Coolingmist Stage II kit
- Failsafes & Closed Loop Control w/ XEDE & Aquamist
- I have come across a good paper on WI/Al injection -
- Which tank did you get alky for?
- torn between these alky kits. help
- With these mods would it be safe to run Water/Alky inj?
- Confused on the water/alky?
- Meth/alky in cincinnati
- alky and cat life
- Integrating the BOV as an additional failsafe
- SMC boost start/stop
- SMC Dip Switch Settings for M10 Nozzle
- before and after timing for W/A inj
- What PSI of boost are you guys running with MEth/Alch?
- a/f was stable at 10.8 now 12...WFT
- alky/meth kit buyers guide.......
- With alchi improve octane?
- Alky injection using Methanol
- 87, 89, or 92/93
- Need Answer Fast
- 12VDC solenoid valve, EPDM, 200psi
- SMC & Aquamist DDS integrated...finally done!
- Alky Injection
- 100% vs. 50/50
- FAQ's for Alcohol Injection
- Safety Measures with SMC version 2
- NHRA tech?
- Question about tuning w/Alky
- where to order smc kit from?
- AEM EMS boost comp and alcohol
- Water Injection????
- toulene or xylene?
- What Alky Injection is everyone using?? Which one should I get?
- how does it all work
- Alcohol Injection or Cams???
- Alky Injection-Yes or No?
- Snow perfomance CHECK IT OUT!!!
- I already have a base flash. Do I need another tune for Alky?
- Snow Performance questions and answers...
- SMC Kit Question
- ARP Head Studs a Requirement?
- Fire Extinguisher
- alchohol injection ona 06 mr9
- anyone using 15gph nozzle
- AIT and Alky Placement question
- TTP-Engineering
- smc kit trouble shoot please!
- Boost on Alky
- SMC pump, kicking on at 18psi?
- How to prevent BLOW if alky fails!
- What sealant is meth resistant?
- Aquamist WI strictly as a SAFETY measure?
- Mounting 2.5 gallong tank?
- long term effects
- Is the smc pump suposed to sound like its pulsing?
- Need help with getting the right kit
- 100% methanol for boost, gasoline for everything else
- Trunk Mount Water/Alcohol Tank
- Aquamist system not spraying.. (Yet)
- maximum flow thru DDS3 sensor
- Is Alky worth it on Stock Turbo?
- Breaking up really bad with meth
- What's the resultant effects of nozzle location?
- where to get low fluid sensor
- problems tuning with meth. help!!!
- Anyone know this!!!!
- Alky install
- Nozzles to buy!
- Methanol Safe Pump
- SMC Kit not working all the time
- Has anyone tried powermist Hot Shot methanol?
- aquamist bracket
- which alky kit ?
- Anyone know were to get spare parts for the Coolingmist (Shurflo) pump?
- water tanks
- 05 Alky
- racing methanol vs. methanol
- My DIY alky kit experience
- Which alky kit
- thanks SMC
- Check Valves with Alky Injection.
- Can I run H2O inj without a tune for 2 months keeping boost at 22 psi?
- what fitting to use off the i/c spray tank?
- Progressive controller settings
- There are failsafes, failsafes and failsafes...
- Spark plug:no water inj vs. water inj
- Water injection and EGT
- just did a "dry" run...
- Shurflo pump pressure switch
- SMC Failsafe?
- Snow's failsafe device - safeinjection
- Seasonal greetings.......
- Accumulators not work w/ progressive setup?
- Distribution of water/r-oh mist and knocking
- Nitrous jet VS Mxx Mcmaster jet for DIY methanol kits
- Changing the setting of my controller after car is tuned
- Tuning with AFR or Lambda?
- Which Shurflo pump to use?
- Stock I/C piping w/ Alky injection
- Spark gap for R-OH/H20 injection
- Progressive injection Vs. on/off injection
- Using washer fluid
- SMC kit questions
- Adding race fuel to an alcohol modded car
- Rare animals - new breed of tuners ...
- H2O/Meth injection results
- Museum pieces
- DIY water-alcohol injection system
- SMC stock pump overloaded?
- Hago injection nozzle info
- My Aquamist 2D/DDS3 installation pics
- My Aquamist 2D Installation
- Switching from denatured alcohol to Methanol after the tunning
- Who's who and what and where...
- Coolingmist progressive controller
- which plugs for 100% methanol?
- Two interesting questions about SMC
- Are you running too rich?
- Where to buy METH or ALKY
- Thank you, EVOM
- Pics of my SMC Alky install, need help/advice...look inside!!
- Alcohol injection getting bad rap
- Denatured alcohol = Methanol ???
